Georgia
Recording a blues band
#1012517 - 09/10/12 08:20 AM
Hi, Im recording a blues band for the first time for my BA in music
production. We have to record the whole band together in the control room. Some advise
would be great on mics to use and placements to avoid any major phasing issues. Its a three piece band, elec guitar, bass and drums. Vox are being recorded after. We have a pretty good selection of mics at our disposal too  Would
appreciate some advise  Thanks, Georgia
Mike Senior
SOS Mix Specialist
Loc: Cambridge, UK
Re: Recording a blues band
[Re: Georgia]
#1012532 - 09/10/12 09:24 AM
Quote Georgia:
Im recording a
blues band for the first time for my BA in music production. We have to record the whole
Did I read that correctly? Are you being expected to record a full blues band in
the same room you're monitoring in?
-------------------- Mixing Secrets for the Small Studio
A complete mixing method based around the techniques of the world's most famous producers.
SOS Technical Editor
Loc: Worcestershire
[Re: Mike Senior]
#1012535 - 09/10/12 09:41 AM
-------------------- Technical Editor, Sound On Sound
adrian_k
Loc: Gloucestershire
[Re: Hugh Robjohns]
#1012544 - 09/10/12 10:26 AM
Quote Hugh Robjohns:
Right, something you
might attempt if there was really no other option (even then...), but to be asked to do it
as part of a music production course?
OP - really? Drums in the control room?
Or drums in a live room, guitarist and bassist in the control room with amps in other
rooms or just DI'd?
-------------------- getting better all the time..
Edited by adrian_k (09/10/12 10:27 AM)
Persuazion
Loc: Scotland
[Re: Hugh Robjohns]
#1012545 - 09/10/12 10:30 AM
That can't be what you really mean. And coming here to ask how to do it in the first place
rather defeats the pont of learning. What are you planning to do? What do you think you
should do? Have you learned anything up to this point? It sounds like you're expected to
have.
Genuinely interested here.... Why do you feel you need to ask? Is your
course not giving you what you want? What kind of thing have you been learning about up to
this point?
I also see you mention music 'production'. So many people confuse
this with engineering, it's just ridiculous. And courses and tutors shod be making the
distinctions clear very early on IMO.
-------------------- http://www.loverslanestudios.co.uk
Edited by Persuazion (09/10/12 10:38 AM)
active member
Loc: Sheffield, UK
[Re: Georgia]
#1012556 - 09/10/12 11:18 AM
You tell us how you plan to approach it, and I'll give you some comments.
I'm
sure the 'control room' phrase is a slip of the tongue - hopefully!
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
Exalted Wombat
[Re: Georgia]
#1012565 - 09/10/12 11:54 AM
Quote Georgia:
Hi, Im
recording a blues band for the first time for my BA in music production. We have to record
the whole band together in the control room. Some advise would be great on mics to use and
This all seems a bit odd! It's quite
possible to have recording equipment in the same room as the performance - in fact, in a
home studio I'd much rather have one good-sounding room than a pair of boxy cupboard-sized
spaces - but it rather negates the whole concept of a "control room"!
It's
great that the band will all play together, listening to each other and balancing
musically. But why leave out the vocals? It's very hard not to over-play, crowding out
the vocals, unless there ARE vocals to listen to! And, with the band tracking together,
you're not going to have much scope for "arranging in the mix".
Georgia
[Re: Mike Senior]
#1012715 - 10/10/12 09:01 AM
No sorry i mean live room. Everything at the same time in the live room!
Georgia
[Re: adrian_k]
#1012716 - 10/10/12 09:10 AM
Everything in the live room sorry, control room, live room diff things i know lol.
Heres the plan.. Im going to record the bass and drums in the same room, the bass
is going to be cornered off using sound barriers. Im going to use the recorder man
technique on the drums and the lead is going to be recorded in the corredor. The band said
they all wanted to be in the same room so i figured they can all be in the same room but
to capture a nice clean sound from the lead i will run a wire through the door to the amp
in the corridor.
active member
Loc: Sheffield, UK
[Re: Georgia]
#1012720 - 10/10/12 09:47 AM
Have you considered the emotional impact of separating the guitarist from his amp?
When I track bands live I do so because they have a vibe going when they are all
standing together, cue-ing off each other and hearing a sound they like. Detaching players
from their natural sound will have an impact - not always for the worse, but it will have
an impact.
Spill doesn't worry me when I'm tracking a full band. Sure, I want
to minimise it, but I'm not going to make it a priority. Beyond that it depends on the
style of music and how you want it to be represented. For a jazz combo I'd let the mic's
breath, allow more space between source and mic and accept higher spill. For metal I'd be
pushing mic's up everyone's nostrils!
For the drums, I wouldn't necessarily
go 'recorderman' (which I think is overrated anyway if you have a close kick mic). I'd
consider XY above the snare and get close mic's on the rest of the kit, including hat and
ride.
Use baffles where you can, but make sure the band can see each other.
If you start splitting them visually then you may as well consider tracking them
separately - even if they play along while you get the drums down. But don't tell them
this until afterwards - a player who knows their part is a throw-away often plays a
throw-away part, which is no help to the drummer!
If you have the
time/inclination, then tap a DI from the guitars. If all else fails you have the option of
re-amping.
Hope something here helps.
Exalted Wombat
[Re: Georgia]
#1012738 - 10/10/12 10:43 AM
Quote Georgia:
Everything in the
Heres the
plan.. Im going to record the bass and drums in the same room, the bass is going to be
cornered off using sound barriers. Im going to use the recorder man technique on the drums
and the lead is going to be recorded in the corredor. The band said they all wanted to be
in the same room so i figured they can all be in the same room but to capture a nice clean
sound from the lead i will run a wire through the door to the amp in the corridor.
Well...OK. Why the obsession
on separation? They want to play together? Good, LET them play together. And at least
give recording with vocals a try. The musical interaction is much more important than any
small blemishes. Use the time you would have spent constructing this complicated setup to
rehearse the song.
Loc: Worcestershire
[Re: Georgia]
#1012746 - 10/10/12 11:07 AM
Quote Georgia:
Im going to record
the bass and drums in the same room, the bass is going to be cornered off using sound
barriers.
Okay -- but
remember that it will be virtually impossible to prevent the lowest frqeuencies of the
bass from spreading throughout the room anyway because the long wavelengths will ignore
any managably sized baffles!
So in addition to the baffles, you'll need to
minimise spill by close miking the sounds you do want -- drums, guitar amp, vocals etc --
and high-pass filter the drum overheads which have to be placed at a distance.
Quote:
Im going to use the
recorder man technique on the drums...
I suspect you'll find you need to close mic the snare and kick
at the very least to gain sufficient separation and impact if the band are playing 'as
live'. The recorderman technique is okay if you're tracking the drums on their own in a
nice sounding room, but I'd be surprised if you'll get what you need for a blues band
using that technique in session with everyone playing together.
Quote:
...and the lead is
That would certainly help with minimising spill... but the
guitarist might be too happy about it. Be ready with a plan B! I'd keep
the amp in the live room, but use baffles and screens to minimise its bleed to other mics,
and close mic to minimise spill from the kit/bass. Also, record a DI to give the option to
re-amp if necessary, as the Elf suggests.
Of course, there are many ways you
could approach this, and they all involve differnt compromises and priorities. None are
absolutely right or wrong -- they're just different ways that will deliver slightly
different results. You challenge is to find the optimum way to satisfy your requirements
and the band's.
I wouldn't get too bogged down in trying to get ultimate
separation. It's almost impossible to achieve, it's usually unnecessary, and you're going
to mix everything together again anyway... so work with it. If the band play together
there will be spill -- it'll be part of the vibe. Place the musicians, mics and screens to
control the spill so that it works for you.
The only need for total
separation is if you plan to replace parts by overdubbing later. In that case spill from
previous takes will lie embedded in retained tracks under the replacement parts which
probably isn't helpful... But if you don't plan to replace parts, total separation isn't
necessary, it just means that if someone messes up, you'll need to do a retake of the
whole band, rather than fixing it later with an overdub. But most bands are okay with
that, and you'll probably get better performances as they work off each other anyway.
And I'd also record a guide vocal at the very least during the main take...
Exalted Wombat
[Re: Hugh Robjohns]
#1012752 - 10/10/12 11:17 AM
Do remember that your primary job is to enable a good performance. That done, the rest is
easy. Without a good performance, the rest is impossible!
Loc: Worcestershire
[Re: Exalted Wombat]
#1012754 - 10/10/12 11:22 AM
^ +100  H
grab
Loc: Cambridge, UK
[Re: Georgia]
#1012816 - 10/10/12 03:17 PM
Re screens for guitar amps to reduce bleed, if you've got limited kit then don't be afraid
to improvise. I've used bench seats and sacks of lentils successfully for this purpose.
tacitus
[Re: Georgia]
#1012830 - 10/10/12 04:10 PM
Damn! I left my sack of lentils in my other jacket ...
(sorry, couldn't
resist)
BoogieBear
member
Loc: Anglesey UK
[Re: Georgia]
#1013051 - 11/10/12 03:20 PM
Reading this might help! :-) http://www.soundonsound.com/sos/oct12/articles/session-notes-1012.htm<
br /> Cheers Anton
-------------------- You see when I was a young kid Elvis was top of the charts - That's 'Presley' not Costello!
mjfe2
Loc: Cambridge, UK
[Re: Hugh Robjohns]
#1013085 - 11/10/12 05:50 PM
Quote:
Im going to use the
I suspect you'll find you need to close mic the snare and kick at
the very least to gain sufficient separation and impact if the band are playing 'as live'.
The recorderman technique is okay if you're tracking the drums on their own in a nice
sounding room, but I'd be surprised if you'll get what you need for a blues band using
In general I'd agree with Hugh here. But
it's worth pointing out that a good drummer (i.e. one who can balance the kit in person)
can yield good results with two mics, even when the rest of the band are in the room: https://www.youtube.com/watch?v=Ii6Ht7ng9vI If
anyone's interested I have some of the original multitracks from this session and the
drums were recorded with two mics, so basically a variant of recorderman!
Loc: Worcestershire
[Re: mjfe2]
#1013110 - 11/10/12 07:24 PM
Quote mjfe2:
it's worth pointing
out that a good drummer (i.e. one who can balance the kit in person) can yield good
Yes... but only if the room sounds nice or
is semi-anechoic and only if the acoustic sound from the other band members is well
balanced in itself, because essentially, you're using the drum mics as simultaneous room
mics. It's all about both the level and the spectral balance of the spill.
chew_rocket
[Re: Georgia]
#1017337 - 06/11/12 12:33 PM
I personally prefer to track live with everything in one room. No need for baffles. Play
with the placements of mics and the bleed can work to your advantage to act as 'glue'.
When it starts to sound instantly awesome, tighten those mic stands!
Magic Matt
[Re: chew_rocket]
#1018286 - 12/11/12 07:18 PM
Quote chew_rocket:
I personally
prefer to track live with everything in one room. No need for baffles. Play with the
placements of mics and the bleed can work to your advantage to act as 'glue'. When it
This method sounds fantastic when done right
in my opinion. Some bands even insist on recording this way. You can't beat the energy of
live performing as a band - I find when things are recorded separately the band can sound
almost sterile - no real interaction between members, everything far too planned.
BigAl
Just The Bass Player
Loc: The King's Height
[Re: Mike Senior]
#1021071 - 27/11/12 02:01 PM
Mike, It's not impossible to get good recordings in this way. I've done it
many times over the last 30 years. Recording isn't always about control rooms and
theoretical perfection.
-------------------- Jack of all trades, master of some.
Tamika Caleigh
[Re: Georgia]
#1039577 - 24/03/13 03:04 AM
Yep Georgia, this is a definately great idea!. How many Mics do you regualry use for a
live recording?
spam signature removed
Edited by zenguitar (24/03/13 12:37 PM)
Mike Senior
SOS Mix Specialist
Loc: Cambridge, UK
[Re: BigAl]
#1039586 - 24/03/13 06:53 AM
Quote BigAl:
Mike, It's not
impossible to get good recordings in this way. I've done it many times over the last 30
years. Recording isn't always about control rooms and theoretical perfection.
Sorry -- I think my comment may have
come across wrong. I've nothing against recording a whole band in a control room at all.
What surprised me was that this should be a requirement for the *first* band recording of
a college course. Surely when you're learning about something as complicated as recording
a band, a proper live-room/control-room setup makes a lot more sense so that you can
actually hear what you're doing? Having to deal with the vagaries of in-room headphone
monitoring only adds to what is already a pretty steep learning curve, I'd say.
