Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
EDSPECIAL
Loc: West Sussex
samplers
      #1020027 - 24/11/12 09:14 AM
can anyone suggest a reasonably priced sampler or software sampler?
I am working with cubase in cujunction with my Roland Boss BR - 800 multitrack
edspecial
Loc: Norwich UK
Re: samplers new [Re: EDSPECIAL]
      #1020037 - 24/11/12 10:25 AM
Kontakt is practically the industry standard - seems to be 50% off at the moment, offer ends Nov 26th.
http://www.native-instruments.com/#/en/products/producer/kontakt-5/?page=2 529
tim_obrien
      #1020104 - 24/11/12 07:56 PM
Shortcircuit from Vember Audio is FREE and works great.
http://vemberaudio.se/shortcircuit.php
EDSPECIAL
Loc: West Sussex
Re: samplers new [Re: tim_obrien]
      #1020308 - 26/11/12 07:55 AM
Free. I like that. Thanks guys.
edspecial
EDSPECIAL
Loc: West Sussex
      #1020309 - 26/11/12 08:01 AM
ok I've downloaded shortcircuit. How do I open it and use it?
edspecial
Loc: Norwich UK
      #1020318 - 26/11/12 09:16 AM
Install to whatever plugins folder Cubase is looking for (probably something like C:\Program Files\Steinberg\VSTPlugins) and Cubase should see it I guess.
EDSPECIAL
Loc: West Sussex
Re: samplers new [Re: BJG145]
      #1020330 - 26/11/12 10:44 AM
I see I have cakewalk so I have to move it onto my music computer. Thanks.
edspecial
EDSPECIAL
Loc: West Sussex
      #1020349 - 26/11/12 11:37 AM
ok it recognised cakewalk on my music computer now how do I open as use it?
edspecial
The_Big_Piano_Player
active member
Loc: Lincolnshire
      #1020352 - 26/11/12 11:49 AM
Which version of Cakewalk?
www.thediplomatz.com
EDSPECIAL
Loc: West Sussex
Re: samplers new [Re: The_Big_Piano_Player]
      #1020858 - 26/11/12 12:18 PM
SONAR 8.5 LE
edspecial
EDSPECIAL
Loc: West Sussex
      #1020897 - 26/11/12 02:47 PM
SONAR 8.5 LE CAKEWALK, the disk came with my multitrack recorder: Roland Boss BR-800.
Does that help?
So do I need to get cakewalk to import the shortcut download?
edspecial
Loc: Norwich UK
      #1020901 - 26/11/12 03:10 PM
Whatever DAW you're using will have an option for choosing the VST plugins folder. You need to install the sampler into that folder. For Sonar it's usually:
C:\program files\cakewalk\vstplugins
I think Cubase always scans the plugins folder for new entries on startup, though in Sonar this is optional, so you might need to do it manually depending how it's configured.
See here if you get stuck.
http://www.cakewalk.com/Support/kb/reader.aspx/2007012959
EDSPECIAL
Loc: West Sussex
      #1020902 - 26/11/12 03:19 PM
Thank you BJG145 I'll have a go at that
edspecial
EDSPECIAL
Loc: West Sussex
      #1021020 - 27/11/12 10:13 AM
Hi, I've got shortcircuit and cakewalk up on the screen now, are there instrutions for using it? How do you get samples into it and use the midi keyboard to play them?
edspecial
Loc: Norwich UK
      #1021028 - 27/11/12 11:35 AM
Google time...
http://audio.tutsplus.com/tutorials/production/quick-tip-adding-samples-to -shortcircuit/
EDSPECIAL
Loc: West Sussex
      #1021354 - 29/11/12 11:16 AM
Are these the right instructions? The display looks different to the picture in the document. There's no mention of multi or group in the program:
"First of all you need to understand multi, zone, and group." These terms are not in the shortcircuit program?
edspecial
Loc: Norwich UK
      #1021362 - 29/11/12 11:50 AM
Not obvious is it...seem to be lots of Google results for people
(a) recommending it
(b) failing to find any instructions for it
I think the available tutorials (more on YouTube) are geared towards V1 - give that a try. Some users seem to prefer it. Can't expect miracles from freeware I'm afraid.
Loc: Norwich UK
      #1021398 - 29/11/12 04:01 PM
Alternatively, see...
http://www.tx16wx.com/home
...which was just recommended in the "Free software" thread and looks a lot nicer...
Pete Kaine
Scan Computers
Loc: Manchester
      #1021411 - 29/11/12 04:32 PM
Quote BJG145:
I've installed it twice in the past. Both times opened it, poked about, got annoyed and deleted it again.
I can't offer anything more than that really on the cheap. I use Kontakt & Camel Alchemy for sample abuse these days, neither of free, but I get on with them far better than anything else I've used software wise and I've been through all the free/cheap options.
If I could code for toffee I'd build myself a emulation of my old Yamaha 5000. But I can't. So meh.
ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
tim_obrien
      #1021458 - 29/11/12 10:14 PM
Quote EDSPECIAL:
Go to YouTube and search for Shortcircuit. That's how I learned to use it.
It's a simple drag-and-drop.
EDSPECIAL
Loc: West Sussex
      #1023399 - 10/12/12 08:14 AM
No luck, ok forget software ones, how about reasonably priced hardware samplers?
edspecial
Loc: Norwich UK
      #1023405 - 10/12/12 09:24 AM
If you don't get on with the free ones (and I don't blame you, that's why I suggested Kontakt), I should check out demos of budget soft samplers before going the hardware route. Unless you're really pining for the sound and feel of vintage hardware you'll get more bang for your buck, and less hassle.
http://www.112db.com/download
http://www.musicradar.com/gear/tech/computers-software/sampl...
ken long
Loc: The Orient, East London
      #1023432 - 10/12/12 11:40 AM
Quote EDSPECIAL:
Ah.... I was waiting for this... hardware flavour and workflow is the way...
I'm All Ears.
Tomás Mulcahy
active member
Loc: Cork, Ireland.
      #1023436 - 10/12/12 12:02 PM
Quote BJG145:
That looks great. It does something no other soft sampler does- detects the sample's pitch and maps it for you. This was a super feature on the Typhoon OS.
Kontakt is the best soft sampler. Avid Structure is also pretty nifty though not as comprehensive.
I would avoid hardware. As BG415 said, it's a lot of hassle (faffing around with disks, SCSI, tiny screen) for a minor effect on sound quality, an effect that you can easily recreate with plugins. Kontakt has a built in Akai MPC and Emu SP1200 emulation, both of which get you all of the aliasing and transposing artefacts that you'll remember from the past. Sounds quite like a TX16W actually!
madtheory creations
Synths and pianos for Kontakt
hollowsun
Loc: Cowbridge, South Wales
Re: samplers new [Re: Tomás Mulcahy]
      #1023526 - 10/12/12 07:11 PM
Quote Tomás Mulcahy:
Agreed.
With its comprehensive semi-modular architecture, gob loads of filters and modulators, insert FX, send effects, etc., it offers astonishing sample mangling facilities.
But the scripting takes it into a different league.
Furthermore, there is just SO much library out there for it from free to serious pro prices and everything in between - undoubtedly the biggest library support of any sampler at the moment. Even the GBs of library it ships with is very good and more than enough to get you well and truly started.
But Kontakt also reads most of the popular hardware and software sampler formats as well further expanding what's on offer.
It's a shame the OP missed the recent sale - I just picked up K5 for $150 which, IMO, is a bargain...
But then, my background is paying £3,000+ for a lump of hardware that shipped with four floppies ... and that's before buying drives, messing with SCSI voodoo, installing RAM (at an eye watering few £hundred for each stick), etc.. Easy not to have much change out of £5,000!!
Get Kontakt and get it over and done with!
IMO, of course.
Website / Music Lab Machines / Blog
Chevytraveller
member
Loc: London
Re: samplers new [Re: hollowsun]
      #1023535 - 10/12/12 07:48 PM
Quote hollowsun:
Aaaaah.. those were the days
..pass me another terminator
MBP 17", PC 100(Nubus Protools) Motu 896, X-Station, Logic9, Reason6, Korg legacy, ACE, Alchemy, Emax II, E-Synth, Evolver MEK, Waldorf Pulse and Blofeld, AS Telemark, AS Leipzig-S
Tomás Mulcahy
active member
Loc: Cork, Ireland.
Re: samplers new [Re: Chevytraveller]
      #1023539 - 10/12/12 08:19 PM
Quote Chevytraveller:
LOL! I used to be a SCSI witch doctor.
madtheory creations
Pages: 1
Rate this thread
Jump to
Extra Information
0 registered and 18 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
