majorhangups
Brand new to this. Happy to be here but need some help please
#1020111 - 24/11/12 08:40 PM
Hi all, As the title suggests, I am a new fish in the somewhat murky waters of
digital music recording. I have got myself a starter set up which includes a Focusrite
saffire 6 USB interface. I'm using Ableton Live as my DAW. Until funds allow for monitor
speakers, I'm monitoring through good quality headphones. The problem I'm having is
that in order to achieve decent volume levels through my headphones, I have to crank the
gain and headphone volume up to almost max. Not a major issue in itself, but it results in
the 'overload' red light on the interface blinking at me and makes for crackly vocal
recordings. Any ideas? Also, when I get monitors is this likely to be resolved? Sorry
to launch my presence here with what is probably a very naive question, but you guys seem
to know your stuff. I appreciate it very much. Major PS As I said, I am
brand new to this so by all means treat me like a total novice. I have exhausted all my
technical terminology in the above piece of writing
shufflebeat
Loc: Manchester, UK
Re: Brand new to this. Happy to be here but need some help please
[Re: majorhangups]
#1020119 - 24/11/12 09:31 PM
Welcome buddy.
It would be helpful if you can say what the headphones are.
High impedance 'phones might respond as you describe. A low impedance model might give you
more volume for less 'driving'.
It's very important to have an appropriate
level going into the mic input and the gain control should be used for this, not for
compensating for a low monitor level. Distortion at this stage cannot be rectified
later.
A set of active monitors will be expecting the kind of signal your
interface produces. If you're very attached to your existing 'phones you may want to
consider a separate headphone amp.
-------------------- Ohm's Law states, "Your PA isn't as powerful as you think it is".
majorhangups
[Re: shufflebeat]
#1020121 - 24/11/12 09:41 PM
Hello, Thanks for getting back to me so soon. My headphones are Beyerdynamic
DT100.
Also I have a dynamic mic and a condenser mic and get same thing with
both. Just getting really poor sound which is making recording all but impossible. Thanks
again.
Cheers
sam-matter
Loc: Preston
[Re: majorhangups]
#1020126 - 24/11/12 10:03 PM
It looks likely that the Impedance of your headphones are causing the low volume
problem. You say that you have DT100's... a good choice and often cited as a
studio engineers headphone of choice. But did you know there are two
versions? The Beyerdynamic DT 100 Grey - 400 Ohm and the Beyerdynamic DT 100 Grey - 16 Ohm. And the different values of
electrical resistance (ohms) makes a big difference. There is a long article on
the SOS website which explains it all much better than I can... Understanding
Impedance... but to pick out the most relavant bit: "Increasingly, people
tend to use high-quality 'professional'-impedance headphones with portable equipment, and
this is rarely a problem, except that the maximum volume will be reduced compared to a
lower-impedance design" So I'm guessing you have the 400 Ohm version. I would
have thought that the Saffire 6 USB would be able to drive them but since you are unhappy
with the volume then the 16 Ohm version might have been better for your setup.
-------------------- Music Matter - Music Technology Store
Loc: northampton uk
[Re: majorhangups]
#1020128 - 24/11/12 10:09 PM
Welcome Major,
You purchased possibly the least efficient headphones that you
could! Excellent rep' that Beyers have for sound quality they have a lowish sensitivity of
94dBSPL (for I assume 1mW in?) most phones are at around 100dB, This 6dB loss would hardly
matter but that it is compounded by a much higher impedance than most modern "cans" of
400Ohms. 32Ohms is a common impedance these days with 100Ohms being about the upper limit.
You will find very few interfaces that will drive those phones to high levels and precious
few budget mixers. You will also need to be careful what you buy in terms of a headphone
amp (for that is the only way if you want to keep the DT100s) but I am sure good
suggestions are being thought of as I type!
Regarding the mic and recording
levels I suspect you are trying to record too hot. Digital is not tape. You should be
running 24bits and 44.1kHz and the software meters averaging about -18dBFS,peaks no higher
than about -8dBFS.
Getting computer, AI and recording software happily married
can be a bit of a trial but at least you have come to the right place!
active member
Loc: Sheffield, UK
[Re: majorhangups]
#1020129 - 24/11/12 10:09 PM
Hi and welcome!
I have a couple of pairs of high-impedance DT-100 and they need a
very meaty headphone amp to drive them properly. I suspect your DT-100s are the same.
DT-100s are robust and good for low-bleed tracking, but they also sound pretty
dire and I certainly wouldn't want to mix with them.
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
shufflebeat
Loc: Manchester, UK
[Re: majorhangups]
#1020130 - 24/11/12 10:17 PM
There you go.
I find the "dire" sound (I totally agree, by the way) is quite
useful when tracking. Some folks (including me) can get a bit preoccupied with the detail
of a sound rather than their own singing/playing. I have found myself saying "I need the
hd-25s for what I'm doing so if you could use the dt-100s I'd appreciate it". Instant
tuning/timing improvement.
Not for everyone but it's worth considering.
majorhangups
[Re: sam-matter]
#1020131 - 24/11/12 10:21 PM
Thanks again. I was actually reading that article as I didn't know what impedance was. I
do have the 400 ohm 'phones.
I have a set of fairly cheap speakers with a
woofer. I usually jack them into a laptop using the headphone slot (the speakers have the
small jack). I am not sure if they will plug into the interface? There are four sockets of
this size on the back of the saffire, but the speakers run off a single jack.
Thanks for your help. I have a bit of man flu so the confusion levels are exacerbated.
majorhangups
[Re: majorhangups]
#1020132 - 24/11/12 10:24 PM
Thanks all for your responses. I am relieved as I'm happy to change the 'phones if it will
correct the problem.
Thank you.
majorhangups
[Re: ef37a]
#1020134 - 24/11/12 10:28 PM
Quote ef37a:
Welcome Major,
Regarding the mic and recording levels I suspect you are trying to record too hot.
Digital is not tape. You should be running 24bits and 44.1kHz and the software meters
averaging about -18dBFS,peaks no higher than about -8dBFS.
Thanks for your reply, Dave. It all
made sense until I got to the above sentence. I am baffled completely. That said, I do
want to understand this stuff and how it impacts recording. Any chance of breaking it down
a little more for a thickie?
Thanks and regards,
Major
Loc: northampton uk
[Re: majorhangups]
#1020139 - 24/11/12 10:49 PM
Ok M! If you have ever done any tape recording, (ripping LPs for the car?)you will
know of the level meters (often called but never were "VU"meters). The trick was to get
the signal as hot as possible, banging the "0" even into the red part so that you kept
well above tape hiss?
Well digital recording for all practical purposes does
not have any "hiss"!You will be aware of the silent backgound of CD? Well even the
cheapest of Audio Interfaces* is as good as that and most are considerably better. The
upshot of all this is that you do not, and indeed must not record into "the red"...Big
No-No! Keep your signals averaging about halfway up the meters and never closer than 3/4
up on peaks. Of course, this results in rather quiet recordings so you need to crank the
monitoring system a bit but in any case you can boost the signals digitally post recording
(did say it was complicated to start with!)
*Only a week ago tested a Behringer
UCA202, 20QUIDish. Returned -87dBFS noise. That is not far short of CD theoretical max.
Loc: northampton uk
[Re: majorhangups]
#1020142 - 24/11/12 10:57 PM
Re the 16Ohm Beyers. I would not go that route 'twere I, that is too low IMHO, almost
as daft as the 8 Ohm phones of yesteryear.
Either buy different phones more
suited to mixing (Sennheiser do NOT make a bad one!) or a good headphone amp. I suspect
the latter will prove more useful in the long run.
majorhangups
[Re: majorhangups]
#1020146 - 24/11/12 11:27 PM
Thanks very much Dave. So I could go for a set sennheisers for £30 - £40 and
they'd be ok? Interesting looking at that interface you tested. Would be a bit of a
psychological sting if that £20 unit proved to be more up to the task than the £150 one
I have just acquired. Cheers and thanks again.
majorhangups
[Re: majorhangups]
#1020154 - 25/11/12 12:14 AM
I've gone to the other extreme now and plugged in my in ear ipod 'phones. No difference.
Thinking of giving that other interface a go also. Night all and thanks for the help
and advice.
Loc: northampton uk
[Re: majorhangups]
#1020163 - 25/11/12 07:31 AM
Quote majorhangups:
I've gone to
the other extreme now and plugged in my in ear ipod 'phones. No difference. Thinking
of giving that other interface a go also. Night all and thanks for the help and advice.
Hmm, just run a set of Senn' HD448s
from my NI Ka6 interface. Running Samplitude Silver's demo tracks(you can download
same, it is a very good, fairly simple DAW with MP3 encoding)and the level pot at 3
o'clock I get quite enough level, certainly as much as I would want to listen to for
extended periods. That is with the tracks peaking to -2dBFS and I am registered deaf!
The 448s are ~$100 phones and spec' out at 114dBSPL for 1volt in and are 32
Ohms.
active member
Loc: Sheffield, UK
[Re: majorhangups]
#1020181 - 25/11/12 10:47 AM
You sure your DAW's master output fader is set to 0?
Loc: northampton uk
[Re: The Elf]
#1020182 - 25/11/12 10:50 AM
Quote The Elf:
You sure your
Good point!
There might also be something wrong in the
level settings in Windows.
ken long
Loc: The Orient, East London
[Re: ef37a]
#1020206 - 25/11/12 01:16 PM
Quote ef37a:
You purchased
possibly the least efficient headphones that you could! Excellent rep' that Beyers have
for sound quality they have a lowish sensitivity of 94dBSPL (for I assume 1mW in?) most
phones are at around 100dB, This 6dB loss would hardly matter but that it is compounded by
a much higher impedance than most modern "cans" of 400Ohms. 32Ohms is a common impedance
Dave,
He said he was a novice. Why all the tech
guffaw without any explanation of your points (correct as they are)?
-------------------- I'm All Ears.
Loc: northampton uk
[Re: ken long]
#1020221 - 25/11/12 02:18 PM
Hi Ken, Been doing this a while and I prefer to consider people as novices not
uneducated children. I like to pitch the tekky bar a bit high so as not to insult folks
and they can always come back to me and say "WTF are you talking about you BOF!" As indeed
Mr M did (but very politely of course!)regarding recording levels.
Whilst I
have the greatest respect for those individuals less "with it" than ourselves I have very
little for someone who can read and write, hold down a resonsible job, pass a driving test
and generally negotiate the clutter of modern life but who won't apply themselves to
learning at least Ohms Law! 'Tis only the same equation as speed/time/distance and even
moving onto power ratings is way less complex than those "If it take 3 men 6hrs to dig a
hole 2mtrs deep by..." equations that bored us rigid as school ('cept mine were in rods,
poles and perches and the soil in cwts. Got it EASY you kids today!).
If peeps
are serious about learning this stuff they will stick with us and ask. Then, I might be ok
with electronics and audio jargon but 7 years ago I was a complete numpty with
computers...YES! Even numptier than now!
majorhangups
[Re: majorhangups]
#1020227 - 25/11/12 03:01 PM
Hi guys, Thanks again for all the help. I was at a total loss. I have been fiddling
about a bit and have managed to get a little more sound to the 'phones without having the
gain up high at all (around about 2-3 on the dial), and no clipping (my latest techie
word). That said, when I listen back to the recording I have next to no sound at
all, no matter what I do. Is this likely to be related to the headphones still? As I said,
I'm completely new to this and am sure that the sound can be altered with the software - I
just don't know how. My default fountain of all knowledge (youtube) is not coming up with
the goods
Thanks again, in advance. M
Loc: northampton uk
[Re: majorhangups]
#1020229 - 25/11/12 03:13 PM
active member
Loc: Sheffield, UK
[Re: majorhangups]
#1020232 - 25/11/12 03:21 PM
Quote majorhangups:
That said,
when I listen back to the recording I have next to no sound at all, no matter what I do.
I doubt it. I'd place a sizable bet that you have a setting wrong
somewhere. I suspect there's a fader, or volume control turned down somewhere. You need to
work through the chain and find it.
majorhangups
[Re: The Elf]
#1020236 - 25/11/12 03:41 PM
Elf - Re the setting, I strongly suspect this is the case.
Dave - my waves
look nothing like that. They're far smaller, resembling a blip rather than a spike. I'll
look into the download you recommend.
This whole thing is probably something
quite simple that any one of you could rectify in a moment were you to have things infront
of you, before proceeding to beat me about the head with the nearest piece of hardware.
I'm am so very grateful for the feedback and help.
Loc: northampton uk
[Re: majorhangups]
#1020239 - 25/11/12 04:21 PM
Arggh! The (cyber)world is going to H in a handcart. Timewas you just downloaded demo
software. Then you had to download a download "manager". Now, to get a demo of Ableton I
have to download a 364kb "downloader" to then download a 1.24M "installer" to get the
download of Ableton! (all the while of course being very vigilant not to get caught by
some near viral crap that forks one's emails or some such!). #There was an old woman who
swallowed a fly.....#
Anyhoo M, I have it working. I dropped in my "test piece"
a very clean clip of Son on acoustic guitar and it sounded horrible! Loud but horrible,
something called "warp" was set on, not by me, and never will be again! Can't say I like
the look? Bit bleak.
Yes, this is the booger of computer recording. Some
little setting somewhere that can be a reet pain to find but blindingly obvious when you
do!
majorhangups
[Re: majorhangups]
#1020254 - 25/11/12 04:49 PM
Hi Dave,
Yep, completely agree that we're on an exponential curve to H as far
as our advancements go. I'm thinking of digging out a tape to tape and just doing a bit of
high speed dubbing instead. Anyway, I've dowloaded the free version of Samplitude 11
silver. Can't find much on youtube in terms of how to get strarted with it. The
screenshots look completely different (pro version and the like).
Cheers, M
Loc: northampton uk
[Re: majorhangups]
#1020258 - 25/11/12 04:58 PM
Quote majorhangups:
Hi Dave,
Yep, completely agree that we're on an exponential curve to H as far as our
advancements go. I'm thinking of digging out a tape to tape and just doing a bit of high
Cheers, M
NO! Don't give up yet! Loads of
fun I promise you. Check PMs.
shufflebeat
Loc: Manchester, UK
[Re: majorhangups]
#1020278 - 25/11/12 08:41 PM
Persevere, the bits you learn here will be useful whichever programme you eventually
settle on and now you have the attention of the room I'd advise to stick with it
If it's as simple as an unticked box or a low fader setting you'll have it sorted once
and for all. There's nothing to be gained by returning to cheap anal log, you'll just end
up back here with less hair.
Fran Guidry
Loc: Walnut Creek, CA, USA
[Re: ef37a]
#1020282 - 25/11/12 08:58 PM
Quote ef37a:
Arggh! The
(cyber)world is going to H in a handcart. Timewas you just downloaded demo software.
Then you had to download a download "manager". Now, to get a demo of Ableton I have to
download a 364kb "downloader" to then download a 1.24M "installer" to get the download of
Ableton! (all the while of course being very vigilant not to get caught by some near viral
crap that forks one's emails or some such!). #There was an old woman who swallowed a
fly.....#
Anyhoo M, I have it working. I dropped in my "test piece" a very
clean clip of Son on acoustic guitar and it sounded horrible! Loud but horrible, something
called "warp" was set on, not by me, and never will be again! Can't say I like the look?
Bit bleak.
Yes, this is the booger of computer recording. Some little setting
somewhere that can be a reet pain to find but blindingly obvious when you do!
There's a wonderful
piece of recording software that bends over backward to make itself available to you, try
REAPER. http://www.cockos.com/reaper/download.php The demo is _fully_
functional, the download is tiny, there is no license manager or dongle or other license
enforcement tool. The installation is quick and simple, the code it tight, the
functionality is quite complete. I could go on for a while but you get the idea - I think
it's a winner.
As I recall from rigging electric guitars, PA systems, analog
tape recording, and motorcycle repair, it's always some little setting that I didn't know
about that was blindingly obvious once I knew about it - and those systems were as analog
as could be.
Fran
-------------------- E ho`okani pila kakou ma Kaleponi
www.kaleponi.com & www.homebrewedmusic.com
Loc: northampton uk
[Re: Fran Guidry]
#1020290 - 25/11/12 11:01 PM
Hi Fran, I have Reaper, bought and paid for. I have tried it, it IS good but I cannot
get on. I have Cakewalk Sonar Ex1 and hate it! Cubases Ess 4 LE5 and LE6. Ok but I rarely
use them myself (son does, depending upon what he is doing) The truth is we started
with a 10quid copy of MAGIX Studio generation 6 and found that baffling! But since it was
all there was that we could afford so we got to grips. Computer Music then "gave away"
Sampltude SE8 and we have never looked back! I am hoping Son comes home for crimble
when I shall show him the trial of Samplitude Producer and if he like it buy it. I might
even go raving mad and buy Sam proX!
Pete Kaine
Scan Computers
Loc: Manchester
[Re: The Elf]
#1020322 - 26/11/12 10:00 AM
Quote The Elf:
I doubt it.
I'd place a sizable bet that you have a setting wrong somewhere. I suspect there's a
fader, or volume control turned down somewhere. You need to work through the chain and
find it.
Just playing about
with a USB 6 my desk so to give you some starting points on the signal chain:
It looks like windows audio control panel has control over the Saffire so the obvious
places to check would be the speaker icon in the bottom right corner of your desktop which
will open a mixer panel where you need to make sure you've got everything turned up.
Following that head into the sound section in windows control panel. Once
you get into the sound section go to "Playback" click on each output to open the
properties box and click on "levels" and crank them up.
Repeat the process for
the recording section to ensure plenty of incoming signal.
After that your
levels will be controlled either by the Saffires front panel or the application that your
using to record so adjust to suit.
Past that lot I don't think the is much
that should get in the way settings wise.
-------------------- ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
ken long
[Re: majorhangups]
#1021295 - 28/11/12 10:31 PM
Fair enough Dave...
member
Loc: Manchester UK
[Re: majorhangups]
#1021427 - 29/11/12 06:26 PM
Regarding choice of Digital Audio Workstation (for the benefit of other newbs who may
visit the thread). I used to be a big fan of Cubase and couldn't get on with any of the
other DAWs. Then, quite a few years ago, I bought a hardware recorder (an already obsolete
Akai DR16 if you're interested) which served my studio recording needs better (and still
does ). I'm now returning to computer based recording for location work, at least,
and have these thoughts... The best DAW is always the one you're most familiar with,
anything else will be difficult/un-intuitive/awkward (insert your own negative adjective)
and will remain so until you spend time learning how it really works. I'm now using Reaper
for two reasons, firstly I have to learn all over again as Cubase now bears little
resemblance to the version I used all those years ago (and which I probably don't remember
anyway) and their refreshing attitude to distribution (freely available, non crippled demo
versions and a personal licence price I was happy to pay). For a newb, you've got a
learning curve ahead whichever you choose so, for starters, I'd suggest, if your sound
card came with one, trying the stripped down DAW supplied with most sound cards (they all
work if your needs are relatively simple) or trying the Reaper demo which is available for
free, is a full version and doesn't expire. I'd just add, if you do choose to continue
using Reaper, at $60 for a personal license there's no excuse for not paying.
Good luck.
-------------------- Turn it down lads (but only a little bit)
