Honey Badger
Two Cubase 7 Problems
#1030727 - 27/01/13 09:00 PM
Aaaaaggghhh, Cubase 7 is driving me mad! I love its new features, but I have spent so much
time trying to get to the bottom of a couple of "quirks" that I haven't made much music
with it yet.  I have a Q9550, 8GB RAM, and I'm using W7 64bit and the Focusrite
Saffire ASIO driver. The main problem is that I get glitches and dropouts with VST synths
with a buffer size of less than 1024. Is this normal? It means that my input and output
latencies are around the 25ms mark. As I mentioned in another post I thought this was down
to a lack of RAM when I was using the 32 bit bit version but I have now installed the 64
bit version and the problem is exactly the same. The other problem is that from
time to time (I'm afraid I can't be any more specific) Cubase freezes. When it does this I
can play a track by using keyboard shortcuts but if I try to do anything else or click
anywhere with the mouse it doesn't respond and makes a "bing" sound. I would normally
associate this behaviour with having a dialogue box open or the program waiting for a
response from me but this doesn't seem to be the case. The only way round it is by
quitting Cubase through Task Manager. Can anyone shed any light on these issues
please?
-------------------- Le geek, c'est chic
tex
active member
Re: Two Cubase 7 Problems
[Re: Honey Badger]
#1030755 - 28/01/13 04:53 AM
ACore2quad won't cut it with Cubase 7 due to the FSB speed. i7 systems communicate
directly between the ram and CPU removing that bottleneck.
-------------------- Success is round the corner. It's also round the bend.
Pete Kaine
Scan Computers
Loc: Manchester
[Re: Honey Badger]
#1030768 - 28/01/13 09:23 AM
Quote Honey Badger:
Aaaaaggghhh,
Cubase 7 is driving me mad! I love its new features, but I have spent so much time trying
to get to the bottom of a couple of "quirks" that I haven't made much music with it
yet.
Which Saffire is it? Did it also do this on your previous Cubase
revision?
-------------------- ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
Honey Badger
[Re: Pete Kaine]
#1030815 - 28/01/13 12:08 PM
Hi Pete, it's a Saffire Pro 24 DSP. I didn't notice this problem with 6.5 and it is quite
pronounced now, so am confident that it has either started or become worse with version 7.
tex
active member
[Re: Honey Badger]
#1030871 - 28/01/13 03:47 PM
Quote Honey Badger:
Hi Pete, it's
a Saffire Pro 24 DSP. I didn't notice this problem with 6.5 and it is quite pronounced
Each new version of anything chucks out more
data and you have just reached the tipping point of your system. There's a lot going on
with just that new mixer. If you want to hang onto that computer I'd consider sending
Cubase back under the blanket of "not fit for described use" ie: not enough forward
information for the user concerning ancillary equipment needs". Cubase works perfectly on
my i7 computer and it was optimised from v6 for i7 computers and Windows 7.
Pete Kaine
Scan Computers
Loc: Manchester
[Re: Honey Badger]
#1030879 - 28/01/13 04:49 PM
Have you at any point done the FW legacy driver fix? http://www.focusrite.com/answerbase/en/article.php?id=1030I know it's odd that it's only happened after the update but as mentioned above the
could be something extra going down the cable now that is knocking it over the edge. Also what FW card are you using in the system or is it on board? If so what
motherboard?
ScanProAudio Blog
Honey Badger
[Re: Pete Kaine]
#1031101 - 29/01/13 11:04 PM
Thanks Pete and Tex, unfortunately the Focusrite driver fix hasn't made any diffence and a
new PC isn't an option at the moment so I guess I'll have to live with it. I've just fired
up Cubase 6.5 again and the problem is there with the old version too though less
pronounced - I guess I just didn't notice it before for some reason.
I've
currently got a DP35DP - firewire is on the board.
Pete Kaine
Scan Computers
Loc: Manchester
[Re: Honey Badger]
#1031136 - 30/01/13 09:59 AM
That's a TI chip as well from what I can remember, so the shouldn't be an issue  Have you tried running DPC latency checker to look for any spikes? Got a wifi dongle in
there?
ScanProAudio Blog
Honey Badger
[Re: Pete Kaine]
#1031240 - 30/01/13 08:13 PM
OK, so here's a thing. Fired her up just now to run the DPC Latency Checker and there is
absolutely no problem any more! I can even play piano through Kontakt with a buffer size
of 32! Latency ticks along nicely at under 100us and with no peaks by the way. I can only think that the Focusrite driver suggestion did work, but that I forgot to
restart the system yesterday (though I thought I did) - I installed an update of
MixControl at the same time too. So thank you Pete. No need for a new PC after
all, but when I do take the plunge it'll be a Scan
Pete Kaine
Scan Computers
Loc: Manchester
[Re: Honey Badger]
#1031322 - 31/01/13 10:01 AM
Good to hear, could have been either/or of those two things but all that matters is its
working now.
ScanProAudio Blog
