Elephone
File Issues with Adobe Products
#1031202 - 30/01/13 03:33 PM
Hi, I'm wondering if anyone else has had issues with adobe products on PC
(Windows7/XP).
I saved a .wav file from Adobe Audition -with markers- and
tried to open it with soundforge hoping I could use the markers. The CPU went crazy! I had
to force close both programs and explorer.exe.
On restart the .wav file was
untouchable -I was unable to delete or move the file or even check properties -the CPU
(all four) goes to 100% in each attempt. This is also true in Safe Mode!
Anyway, I did copy the whole folder containing the file onto my USB stick and open the
file in Soundforge on my XP laptop (no markers), so I saved it as a new file (without
metadata) and deleted the old one.
Strangely, when I checked the properties
of the folder (on laptop), it had the 'Read Only' box checked, so I unchecked it, clicked
'Apply', and closed the Properties window. When I rechecked the properties, the 'Read
Only' box was ticked again!
At least I was able to delete the whole folder
containing the file on my Win7 desktop and replace it with the new folder.
I
know it has something to do with Adobe and file associations because a similar thing
happened years ago on my XP laptop. In that case it was image files associated with adobe
photoshop. (I had to unassociate photoshop with all image files.) It's really unlikely to
be virus related (I'm not connected to the web, I've not installed anything for years, or
copied files from other computers until lastnight.
Anyway, I unfortunately
copied the .wav file to my desktop where it remains. There's nothing I can do with it now.
Had it been copied to a folder on my desktop, I'm sure I would have been able to delete
that folder. Weird.
Elephone
Re: File Issues with Adobe Products
[Re: Elephone]
#1031211 - 30/01/13 04:20 PM
EDIT: The 'Read Only' box on my folder was not checked afterall, it was merely highlighted
with a green box (for some strange reason) by not actually ticked.
Anyway,
someone with the same problem:
http://answers.microsoft.com/en-us/windows/forum/windows_7-p...
"The only way to delete those problem files is from DOS. You will first need to
change the access right for your ACLs using the CACLS command. Once you've changed it for
each of the file paths that you wanted to delete, you may delete each files
*individually*. After the deletion, you'll need to restart your computer. then your pc
should run normal with normal cpu usage hereafter."
I don't think I'm
knowledgeable to do this without step-by-step instructions. Is there any user-friendly
software that can manage this for me at bootup? Something like Revouninstall?
I'm not on my PC right now, but someone suggested I open the desktop as a window, kill
explorer.exe, then try to delete the file in the window. I would have thought the window
would vanish after filling explorer.exe(?)
Another solution seems to be to
stop windows 7 from extracting metadata:
http://superuser.com/questions/233223/prevent-windows-explor... of
.wav files.
This solution was inspired by a post regarding a similar problem
to mine:
http://www.pchelpforum.com/xf/threads/cant-delete-stubborn-f...
I have had slight issues with explorer.exe on my PC. Occasionally it takes ages
to index(?) folder contents. The blue graphic on the file location box takes ages to reach
the top and I have to press stop. Once or twice the CPU has gone crazy about that too,
forcing me to restart.
Anyway, I don't need all these complex Windows
permissions. I'm the only one who uses the PC. I want to be able to do anything I want
with all of the files on my system. Is there any way to simplify things? What are all
these login profiles for? User, Admin, etc? I only need one.
tim_obrien
[Re: Elephone]
#1031233 - 30/01/13 07:37 PM
I've run adobe products for 20 years (Photoshop 2.x) and never had the problem.
If it was me I'd be running some diagnostics on the drive (how old is it?) and be
thinking about replacing it...
Pete Kaine
Scan Computers
Loc: Manchester
[Re: tim_obrien]
#1031323 - 31/01/13 10:03 AM
Yeah, i'd also look at the harddrive. If you can work out who makes the drive (should be
able to do this via device manager) you can go to the respective website and download a
tool to check the structure of the drive. If the are any issues it'll flag it up for you.
-------------------- ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
Elephone
[Re: Pete Kaine]
#1031406 - 31/01/13 03:50 PM
*It happens on all drives, which are different brands and are all new.
*I've
never had a single problem with any other software or files
*As I mentioned,
I had the same sort of problem with photoshop in Windows XP and I found the reason was
file associations -it cured the problem instantly.
*My current issue seems
more complicated because .wav aren't associated with Adobe, but I think it has to do with
the AA markers/metadata I saved with the .wav file. No other file has this problem so it's
too much of a coincidence.
*Incidentally, AA is the only program that can
access the file, but I am unable to save a modification, saying I do not have permission.
Why would a PC with a single user ever ask for 'permission' to change or access files
anyway?
*Also, I linked to others online who had the same problem
specifically with .wav files who managed to delete it with DOS. So wouldn't that indicate
bug in Windows or a permissions problem? I do have this problem from time to time when
working with AA and other programs (when metadata is saved) where I can't save a file
because it's 'protected'. However, until now, these problems were easy to resolve from
explorer, or by closing/reopening the file, or something simple. I did make a LOT of
markers in that file, and perhaps trying to access it with Soundforge has severely
corrupted it or something.
Thanks anyway. I'll keep searching.
Elephone
[Re: Elephone]
#1031412 - 31/01/13 04:39 PM
Another workaround which seems to support the file association cause:
"I
faced the same problem myself, and while i was lookin around in forums I found no
satisfactory answers. But finally i figured out the problem myself and apparently the
solution is pretty simple. In my care the problem was a corrupted file on the desktop. In
your case, This file may be anywhere in the users folder. Here are the steps i followed to
get rid of it:
1. First identify the file. (in my case it was a flv file)
2.
Uninstall all programs associated with the file.
3. Restart and go to safe mode. Now
you should be able to delete the file.
4. If the file cannot still be deleted or
renamed, go to another standard user account and access the file from there and delete
it.
5. There you go!"
N.B. Identifyin the file can be a headache. In my
case it was right on my desktop but i didn't realis that this was the problem for more
than one week. Do let me know if this works."
My CPU usage has also gone up
since the .wav file has been on my desktop.
Someone else wrote: "I
still do pc repair and 99% of Win7 problems are owner/permission issues. PAIN IN THE BUTT!
Only problem I can find in 7, it is a disaster so far because it corrupts so often"
Surely some of you must have had this problem...?
Elephone
[Re: Elephone]
#1031438 - 31/01/13 06:50 PM
UPDATE: Apparently, Windows 7 thinks the currupt file is 'in use' and so you aren't able
to delete it. Luckily I know which file is causing the problem so I might simply need to
delete it the old fashioned way from command promt: del <drive letter>:\<file
path>\<filename>
If you want to know what files explorer thinks are
'in use' you can use 'Process Explorer' published on Microsoft website
http://technet.microsoft.com/en-gb/sysinternals/bb896653.aspx
Loc: The wilds of Hampshire
[Re: Elephone]
#1031472 - 31/01/13 10:13 PM
I'd point the finger at Sound Forge not handling .wav files with additional fields
properly. Seems like it misinterpreted the file and caused all sorts of problems. To be
honest, if you have Audition then there's no reason to use Sound Forge as Audition can do
just about everything that Sound Forge does - and often does it better. James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Elephone
[Re: James Perrett]
#1031635 - 01/02/13 05:08 PM
Thanks, I couldn't work out how to splice an audio file up into lots of separate files
using AA markers (without turning each one into a 'range' individually, so I just thought
I might be able to open them in SoundForge and do 'marker to regions' > export.
Also, I'm not all that keen on the AA windows. I don't like using more than one
navigation screen (like in 80's computer games) where a larger scope is given at the top.
Also, the cursor seems to go off the screen sometimes and it's difficult to place markers
when the audio position is right at the edges. I did select the option about it staying in
the centre, but the cursor doesn't move the centre until it goes off screen which is
annoying.
Anyway, the fix worked. I deleted the 'corrupt' file from Desktop
with command prompt and the bone idle CPU went down to 0-5%.
[Re: Elephone]
#1031673 - 01/02/13 11:13 PM
I must admit that for the particular task you want to do I use a program called CDWave
which is a small no-nonsense program with the sole purpose of splitting long files into
sections. James.
