Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
calmposer a
member
NI Massive
      #1031231 - 30/01/13 07:29 PM
This synth is fantastic, complex but insanely good.
Listening to tracks on the radio etc you can quite easily single it out and it always sounds MASSIVE.
After experimenting and reading I'm still finding it hard to make it sound really big. I think producers do that even when using just one oscillator.
Any tips about how to make it sound BIG?
desmond
Re: NI Massive new [Re: calmposer a]
      #1031272 - 30/01/13 11:29 PM
Personally, I didn't like it, I thought it was fairly bland sounding and lacking in character.
However, there are many tools to make things sound "big" but it does kinda depend on what your personal impression of "big" is (what you mean by big isn't necesarily what I might mean by big).
But in general, layer oscillators, slightly detune them, add some subtle LFO pitch modulation, use unison to stack up oscillators, and don't also forget how integral effects are, reverbs, delays and compression can all help to give an illusion of bigness. And the rest is all in the arrangement and the mix (actually, *most* of it is here, to be honest... Some things that are small in isolation can sound *massive* in the right context)
mu:zines | music magazine archive
Vintage issues of Sound On Sound, Music Technology, E&MM and more...
Skerrick
Loc: Sydney NSW
      #1031274 - 30/01/13 11:46 PM
i have a hard time getting my head around massive, i just dont wanna dedicate enough time to learning how to use it to its full potential (which i really should) but man theres some incredible youtube tutorials.
just make sure the person in the tutorial knows what theyre talking about.
ive seen a couple where the guy is like "now grab the blue thing and put it on the yellow thing and turn the top right second from the left knob to the right a tiny bit."
so frustrating when youre trying to use your memory to recall how you saw it done haha!
a few of my friends swear by it, its all just about the crazy modulation tbh.
ive donw my fair share fo experimenting with it but i cant seem to get those detuned/out of synch tubular bass wubs.. the tune "cyclical" in my soundcloud is the closest ive come but that was with a fat pad i found in razor and i modulated band 4 and 5 of the eq im using like a madman hahah and it gave me a similar effect, backing up what old mate said about making things sound big in other ways.
also man, yeah i reckon its a bad ting being able to pick a synth out of a tune on the radio, i mean some synths fit in perfectly the way they are and need little or no modulation (guilty as charged) but i prefer to mod them or make my own where i can..
www.soundcloud.com/skerrick
Pete Kaine
Scan Computers
Loc: Manchester
      #1031314 - 31/01/13 09:42 AM
Further to Desmonds advice and depending on what your comparing it too I'd probably say it's just as much about the effects chain as it is the synth.
Obviously at this point I don't know what you are comparing it aginst, but if it's along the lines of big room electro/dnb/dubstep you wouldn't go amiss sticking Guitar rig and Sausage Fattener on it and then slamming it through a group buss with the rest of the bass layers sticking something like cytomics the glue on it.
So breaking it down all that's going on there is distortion, limiters, compression, eq rinse and repeat and of course the are plenty of other effect combinations that will do the job as well, it's just what springs to my mind right now. Be warned you'll lose your dynamics with that lot, but if it's for the dancefloor thats probably what you want anyway.
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
Persian Bit
Loc: Tehran \ IRAN
      #1031336 - 31/01/13 10:37 AM
I found Massive a very powerful synth, but I think it suits only some certain type of music. I still have it in my toolbox, but very rarely I use it. I don't know if it's about its character or what, but the sounds are too 'strong', coloring and sci-fi. Someone would say 'so you gotta create your own presets'. but man! too many knobs and stuff to learn.
Reagrding making the sounds 'big', beside all techniks and tricks that's said in above comments I believe arrangement and production are very important to make something sound big [though as said, 'big' could mean different to different ears. to me, it's being strong in terms of tone and dynamics AND stereo width and depth].
In a very busy and full mix you don't have enough space to put a 'big' synth somewhere. you will end up doing all kinds of low cuts and EQ and compression to keep it up while the master output doesn't clip. It either loses its bigness, or covers up everything.
So I believe it begins in writing and arrangement stage by smart selection of sounds, writing across different octaves and making room for each part 'musically' and generally prepare required space for a big synth to sit in. If listen to those hit songs in radio, you realize how simple and clean their arrangements are. Though obviously there are many layers of produced sounds down there in the mix, but you hear only a few well designed and clean sounds [drums,bass, synth,..]. It lets the mixing engineer put everything in focus, while having that 'big' sound.
Even If you're near a finished mix which you're not satisfied with yet, thanx to digital audio you still can edit, move and delete stuff here and there to make more space in your mix. Lack of headroom and space means radical and harsh EQ and compression usage which screws a mix. Personally, even in last minutes of closing a mix, I found bits and pieaces that can be cut or be lowered down to let the mix breath.
fay spook
Re: NI Massive new [Re: Persian Bit]
      #1031586 - 01/02/13 12:58 PM
I usually have a problem getting Massive to sit in the mix! You can fill up the frequency range quite easily with the ideas given above but also try moving where the inserts go in the routing page, sending an oscillator or two out bypassing the filters and automate intensity and wavetable position of the oscillators. A little but of overdrive will help. Or sweeping filters/oscillators at slightly different rates. Then you can start stacking instances of it in your DAW.
Also if you can tell us or give an example of where you want to be, is it a full frequency sound ie sound with a large frequency range or one with a lot going on etc???
http://soundcloud.com/for-mash-get-ash
calmposer a
member
Re: NI Massive new [Re: fay spook]
      #1031681 - 02/02/13 12:01 AM
Thanks a lot people, and especially fay spook - you got it bang on I think:
Quote fay spook:
Quote fay spook:
Full frequency type sound - that's what makes it hard!
As an exercise I took a part where the synth is so big and tried to replicate it.
https://dl.dropbox.com/u/36122736/exref.mp3
and my version
https://dl.dropbox.com/u/36122736/ex5.mp3
Interesting huh? What you all think?
Skerrick
Loc: Sydney NSW
      #1031690 - 02/02/13 01:18 AM
Quote fay spook:
i dont usually have any troubles with it at all, i use massive a lot, but i use the presets and tweak those around rather than trying to make a sound from scratch... ive been watching some tutorials lately and having a bit more of a crack with it, but honestly, i disagree about it not sitting well in the mix or sounding too big, all you have to do is use the right fx etc and play with the volume and eq till you have it where you want it.. ive used it in some 'big' stuff but ite pretty damn versatile
i reckon it has some GREAT pads especially.
near the bottom of the list in particular, theres one called "warp x"
if you select it and go to the 'attributes' tab in the top right and turn the drums dial all the way to 0, you have an amazing sound.. theres so many great ones in there..
http://soundcloud.com/skerrick/daydreaming
http://soundcloud.com/skerrick/trap-door-forthcoming-plusquam
http://soundcloud.com/skerrick/sundials
^ pretty much every synth in each of those three, i got from massive in one way or another.. so if you think its for big sounds only then i reckon you should have a geeze at these and see what it can do in terms of the range of sounds that its capable of producing...
oggyb
Loc: Leeds, UK
      #1031802 - 02/02/13 09:41 PM
Pssh I keep trying to reply to threads and then forget to submit after previewing so I'll try to remember what I typed!
I love Massive and use it often, and I find that I get good results when I create a patch with lots of frequencies, then EQ them viciously later on.
That way, the top end sparkle is still there and it sounds big, but the volume of those frequencies is low enough not to mask other things that demand HF space. The meat of the sound can actually be quite narrow in your chosen frequency "slot", but if the top end isn't there it sounds too small.
Composer;
www.ogonline.org
TC higgins
Re: NI Massive new [Re: desmond]
      #1031956 - 04/02/13 12:32 AM
Making your sound big can be done by widening the audio in the stereo field, layering several sounds on top of each other, boosting certain regions in the frequency spectrum, adding all sorts of effects, compression,etc etc.
This has litle to nothing to do with the fact if your using massive or any other vst/hardware synth.
adding extra notes to your harmony/melody will also result in a "bigger" sound, especially adding severall perfect 5th's.
Producing music with home studio equipment
urbangorilla
      #1032955 - 10/02/13 10:55 PM
I've found that the on-board effects inserts and eq (on the upper-ish right) are what usually take things to the next level for me in Massive. For adding space, the dimension expander, reverb effects are pretty handy for getting things to really start to sound amazing. With the dimension expander, you might want to watch out for phase issues if you're working with real bassy frequencies.
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 20 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, SOS News Editor
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
May 2016
On sale now at main newsagents and bookstores (or buy direct from the SOS Web Shop)
Click image for May 2016
DAW Techniques
Home | Search | News | Current Issue | Tablet Mag | Articles | Forum | Blog | Subscribe | Shop | Readers Ads
Advertise | Information | Privacy Policy | Support | Login Help
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
We accept the following payment methods in our web Shop:
Pay by PayPal - fast and secure  VISA  MasterCard  Solo  Electron  Maestro (used to be Switch)
All contents copyright © SOS Publications Group and/or its licensors, 1985-2016. All rights reserved.
The contents of this article are subject to worldwide copyright protection and reproduction in whole or part, whether mechanical or electronic, is expressly forbidden without the prior written consent of the Publishers. Great care has been taken to ensure accuracy in the preparation of this article but neither Sound On Sound Limited nor the publishers can be held responsible for its contents.
The views expressed are those of the contributors and not necessarily those of the publishers.
