Elephone
File Permissions in Windows
#1031407 - 31/01/13 04:15 PM
Hello. As I'm the only human to ever use my PC, I have absolutely no need for permissions
restrictions on my files. I'm specifically talking about my own working files not
application data.
So, is there any reason why shouldn't remove all such
restrictions and gain full control using the following Microsoft fix on the
drives/partitions containing only my music projects and audio files?...
http://answers.microsoft.com/en-us/windows/forum/windows_7-s...
Pete Kaine
Scan Computers
Loc: Manchester
Re: File Permissions in Windows
[Re: Elephone]
#1031415 - 31/01/13 04:46 PM
No reason not to do it and shouldn't be any harm having a go. As the sole admin account
you should have permissions for them all already.
-------------------- ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
Elephone
[Re: Elephone]
#1031636 - 01/02/13 05:20 PM
Many of my files did not have 'full control' given to all users. I still don't understand
why there are so many users like:
USER-JimALPC (me)
Administrator
Trusted Users
CREATOR
...and one or
two others.
Now I've given permissions to 'USER-JimalPC', 'Administrator',
and 'Trusted Users' to all disks and folders, when I opened a file in Soundforge, the
computer asked if I want to allow Soundforge to 'make changes' to my computer.
I clicked the link to the The User Account Control where an permission options slider
appeared:
'Notify me only when programs try to make changes to my
computer'
...the lowest one turns this off but is not 'recommended'.
Do other people give permission every time a program opens?
The best
thing would be if Microsoft's install program (optionally) asked new users to tick boxes
next to what they needed from the PC, how many users will there be, etc.
This could also be revised if the computer is given away or more users are added.
Not that difficult.
WaveOnWave
[Re: Elephone]
#1032097 - 04/02/13 05:31 PM
everything you do under your own account name will give sufficient rights to files you
work on.
could you be more specific on which problems you encounter.
Edited by WaveOnWave (04/02/13 05:32 PM)
Scramble
active member
[Re: WaveOnWave]
#1032114 - 04/02/13 08:21 PM
I had problems with permissions in W7 initially, for some reason I couldn't access a lot
of the files in ther Users section. So I installed some registry hack that someone had
written called 'Take Ownership' which gave me control (even this was a faff, as it would
sometimes take ages to change all the permissions in some of these folders, but it
eventually solved all the problems).
Magic Matt
[Re: Elephone]
#1032396 - 06/02/13 02:06 PM
Quote Elephone:
...when I opened
a file in Soundforge, the computer asked if I want to allow Soundforge to 'make changes'
to my computer.
This is
because it is set to run as Administrator. That's an ugly work-around for when software
isn't written to be fully compliant with Windows. Some programes, particularly those with
ropey copy-protection systems, need write-permission in their own program folder, which is
only possible when run as administrator.
The added level of security is there
to protect your PC. Turning it off as you are doing is just compromising the security of
your system. I wouldn't have done that personally.
Elephone
[Re: Magic Matt]
#1033636 - 15/02/13 05:00 PM
Quote Magic Matt:
The added level
of security is there to protect your PC. Turning it off as you are doing is just
compromising the security of your system. I wouldn't have done that personally.
It's not connected to the internet and
no one else uses my (password protected) PC at all.
