N WILLIAMS
Mackie C4 controller questions
#1031564 - 01/02/13 11:23 AM
Apologises if there has been a Post in the past concerning this subject. I couldn't find
it if there was.
I have managed to pick up a Mackie C4 (not the latest USB
version) midi controller cheap. I am running Cubase 7 and Ableton 8 on the PC. I am
aware the controller is not supported by these DAWs - unfortunately!
I am not
particularly bothered about it not being able to control the DAWs themselves, but is there
a way of creating your own patches/programs to control a VSTi? As you may well know the
majority of VSTi parameters are controlled by Midi CC# rather than Sysex or RPN. There is
not a 'Learn' feature on the controller, but there is on the parameters of a VSTi.
Has anyone found a way of converting Midi CC# data of a VSTi to RPN or Sysex data
on to the Mackie C4 control knobs via the Mackie C4 Commander software so the VSTi can be
controlled in realtime?
Many thanks!
active member
Loc: Sheffield, UK
Re: Mackie C4 controller questions
[Re: N WILLIAMS]
#1031566 - 01/02/13 11:29 AM
Cubase has 'Quick Controls' that can be accessed by any MIDI controller.
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
N WILLIAMS
[Re: The Elf]
#1031579 - 01/02/13 12:40 PM
Hi Elf
Thanks for your reply
I haven't looked into that. Is there a
limitation to what you can assign using that method? i.e. type of parameter or quatity
of parameters?
active member
Loc: Sheffield, UK
[Re: N WILLIAMS]
#1031589 - 01/02/13 01:08 PM
It's not a facility I use much. I think the limit is 8 controllers, but every channel can
have its own assignments. You'll need to check the Cubase manual.
desmond
[Re: The Elf]
#1031606 - 01/02/13 02:24 PM
The Mackie Controllers are"dumb", in that they basically don't have anything to do with
software, they just send out the data they are programmed to do, and rely on the host
software to manage this. If none of your hosts support these, they will be less useful.
You can always use a MIDI monitor program to examine the MIDI data sent by the
controllers and learn stuff manually, but it's a tedious and poor way to use them,
particularly when they were designed from a non-mapping intelligent use to begin with. But
I'd probably start there first...
ConcertinaChap
Loc: Bradford on Avon
[Re: N WILLIAMS]
#1031621 - 01/02/13 03:27 PM
Logic has a function where it can "learn" the output of a controller. Does Cubase have
anything like that? CC
-------------------- Put the fun back into dysfunctional.
Mr Punch's Studio
active member
Loc: Sheffield, UK
[Re: ConcertinaChap]
#1031630 - 01/02/13 04:32 PM
Quote ConcertinaChap:
Logic has a
function where it can "learn" the output of a controller. Does Cubase have anything like
that?
Yes.
ConcertinaChap
[Re: The Elf]
#1031662 - 01/02/13 10:17 PM
Quote The Elf:
Yes.
Well there's your answer, then.
Mr Punch's Studio
