WeBuiltASkyscraper
Making a mix sound big
#1031691 - 02/02/13 01:44 AM
Okay, whilst recording for my band, or for anyone, I always run into the problem of the
instruments not sounding very big. For example, the drums sound like they're very thin and
small and only in the centre in the mix, when they're spread out quite a lot. I've tried
using a stereo enhancer on them but it's not really working, the same applies to each
other instrument. All of the recording are of high quality but I just can't understand why
it's not really working! Could it be the quality of the compressor? I'm just using
cubase 5's standard one, if so, what's a decent one you'd recommend me downloading? Or
could it be another plug in? Please help!
-------------------- http://www.facebook.com/WeBuiltASkyscraper
Four piece alternative band from Birmingham, UK
alexis
Loc: San Antonio, TX USA
SOme of the smart guys on the board may give you advice for a quick fix (maybe you want to
put a link to your work), but in the meantime, maybe this book will be of interest: Mixing Secrets for
the Small Studio . I personally think it's awesome, and if you google around I think
you'll find a bunch of others seem to like it as well, so maybe you will find something
helpful in there too!
-------------------- Alexis -Cubase 6.5.0/SX3.1.1.944, XP SP2, 4GB RAM (1GB not accessible, but used just to balance the computer so it doesn't tip over); Delta 66 in Omni i/O Studio; Motif8; UAD-1
Skerrick
Loc: Sydney NSW
Quote WeBuiltASkyscraper:
Could
it be the quality of the compressor? I'm just using cubase 5's standard one, if so, what's
a decent one you'd recommend me downloading? Or could it be another plug in? Please help!
i use the "focusrite
scarlett compressor" and it does wonders.. you could also look at the D82 Sonic Maximizer
by BBE.. you can shape the low contours of the channel you put it on and you can use the
process dial to bring huge mids out of your bass etc. if youre looking for more
thump in your drums and youre just using a standard compressor, try get your hands on the
D82 or scarlett compressor.. sausage fattener is awesome too, but im not sure about using
it with percussion, ive never tried that tbh, but it can make a smooth/thin bassline into
a deep crunchy ripping kind of sound..
-------------------- www.soundcloud.com/skerrick
active member
Loc: Sheffield, UK
How about posting some examples for us to listen to?
Usually the problems
begin at the tracking stage, so get all those plug-ins out of the way and let's hear what
you're really capturing.
Then we need some details of how you're approaching
the recording - the more details the better!
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
davegorst
Loc: Widnes, Cheshire (UK)
1 possible issue might be that all the instruments are fighting each other for space in
the mix so maybe look at how the instruments are working together decide which ones are
the most important and cut away frequencies of the not so important instruments to give
the other ones some space
Bossman
active member
Loc: UK
+1 for posting a mix for people to listen to, otherwise all anyone here can do is make a
guess. +1 for Mike Senior's Book Mixing Secrets - Its a good read full of good
info
-------------------- www.Lozjackson.com
Stroppa
Hola If your serious about learning +1 Mikes book Mixing Secrets... it's a no
brainer best money you will spend on learning material. +1 adding a link to
your music for more pointed guidance. My 2 cents...Big is open to
interpretation as with most things. But 1) Compression can make sounds fatter
and more pronounced, and help find position in the mix. 2) EQ can help sculpt the
sounds into the mix. 3) Reverbs, Delays, Saturation, Sausage Fattener can all help
beef your sounds. 4) Someone will be along shortly to advise you not to do this but I
find it a great help, Mix Bus signal chain... I like to mix into a Bus Compressor > Tape
Simulator > Limiter. This kind of sets the boundries and then drive the mix into it. 5) Experience we all have to start somewhere. 6) Oh and some decent tunes will
help.  Good Luck Stroppa
Scramble
active member
Re: Making a mix sound big
[Re: Stroppa]
#1031736 - 02/02/13 01:57 PM
Quote Stroppa:
2) EQ can
help sculpt the sounds into the mix.
What is this sorcery of which you speak?
Stroppa
[Re: Scramble]
#1031738 - 02/02/13 02:06 PM
Haha You know that frequency bands thingy.  for doing
stuff to frequencies.
Exalted Wombat
[Re: davegorst]
#1031743 - 02/02/13 03:29 PM
Quote davegorst:
1 possible issue
might be that all the instruments are fighting each other for space in the mix so maybe
look at how the instruments are working together decide which ones are the most important
and cut away frequencies of the not so important instruments to give the other ones some
space
Shouldn't happen if
you're recording a real band who are used to playing together. They have ears, and will
have chosen their sounds (and, just as importantly, WHAT they play) so as to fit in with
the overall sound.
It happens all the time when building a song by
multitracking one instrument at a time. Everyone gets obsessed with HIS riff, doesn't
listen to everyone else (including the instruments yet to be recorded :-) and plays FAR
too much.
Better sorted out in the performance and the arrangement than by
remedial mixing.
active member
Loc: Sheffield, UK
[Re: Stroppa]
#1031753 - 02/02/13 04:24 PM
Quote Stroppa:
4) Someone will be
Quote Stroppa:
Bus Compressor
Yes.
Quote Stroppa:
Tape
Simulator
Maybe.
Quote Stroppa:
Limiter
Hmmm.. I wouldn't. A buss limiter is for
mastering, not mixing into IMO.
But all this talk of compressors and mix
techniques is of no consequence if the tracking isn't up to scratch. Everyone is throwing
in their favourite techniques, but if the raw drum kit sounds like kitchen pans and the
bass like a bank then none of this is going to help!
hollowsun
Loc: Cowbridge, South Wales
[Re: The Elf]
#1031762 - 02/02/13 05:25 PM
Quote The Elf:
But all this talk
of compressors and mix techniques is of no consequence if the tracking isn't up to
scratch. Everyone is throwing in their favourite techniques, but if the raw drum kit
sounds like kitchen pans and the bass like a bank then none of this is going to help!
+1
Get it right at source
otherwise you're turd polishing!
-------------------- Website / Music Lab Machines / Blog
WeBuiltASkyscraper
[Re: alexis]
#1031774 - 02/02/13 06:42 PM
active member
Loc: Sheffield, UK
The guitar and bass sound well-recorded.
Forget fatteners and compressors for
the moment! You have more fundamental problems to solve!
You're correct that there is no stereo width anywhere, including the drums. Either you
have a mono recording, or you have something strange in your routing.
Stereo
width would most likely come from your drum overheads and/or room mic's. What
configuration of mic's did you use for these?
Fundamentally:
How were
the drums recorded?
How many mic's?
What was the assignment/configuration of
mic's?
How did you set up your overheads?
How many tracks of drums did you
record and how are they routed?
Are you sending them to a sub-group - if so, is the
sub-group stereo?
How are you rendering your mix - Audio Export?
What happens
if you pan one of your drum mic's, e.g. snare close mic? Does it pan?
Details, details, details!!!
And let's hear no more about 'finding' stuff you have to pay for. You *are* using a paid
for Cubase, aren't you?
WeBuiltASkyscraper
[Re: The Elf]
#1031795 - 02/02/13 09:09 PM
Thanks, I spent quite a bit of time getting those done! Not so much on the drums though, I
was quite time limited! For the drums I used 10 mics. For the Kick drum, rack
tom, floor tom and second floor tom I used the Audix DP7 drum mic package, the mics are:
D6, D2, D2, and D4 respectively. For the snare I used an SM57, I also used a 57 for the
hats. I used SE2's as overheads and 2 SE ribbons as room mics. The drums were set up in a
pretty flat room, it was treated, although it was big enough to accommodate room mics. I
have each mic sent to a different channel in Cubase. In the mix I sent, the
panning wasn't too extreme, probably going no further than 2 O'clock and 10 O'clock. I am
sending them through an FX channel, and yes it is stereo, although the dry signal is also
being sent to the stereo output. I exported it as a .wav file. Yes, if I pan
the snare mic in Cubase, it does pan, I'll experiement with further and mroe extreme
panning, and i'll let you know how that goes. In the mean time, is there anything else you
can do to help? Its very much appreciated! I am using a paid for version of
Cubase, which is why I'm still stuck on Cubase 5 :') I didn't mean that I was going to
download the plug-ins illegally, I meant that I though the focusrite plug in was free, or
that you could use a demo version. Thanks for the advice!
active member
Loc: Sheffield, UK
It's a rare mix that I pull overheads in from full L/R - they are the signal that give the
kit its sense of 'realism'. 10 o'clock and 2 o'clock is way too narrow for overheads IMO -
and it seems you're already hearing that for yourself.
(I'm going to assume
you've already got all of the phase relationships sorted out, or we're on a
non-starter...)
Mute everything but the overheads. Pan them fully L/R and
bring them up in the mix. Roll off everything below 100Hz for the moment.
Now
listen to the overheads and try to hear where each drum appears in the stereo image. Lift
each close mic a tiny amount and match its pan position to where it appears in the
overheads. You'll spend a lot of time here muting/un-muting close mic's until you have it
fully set, but take your time with it.
For kick and snare you may find that
you can 'force' them into the centre, even if they are not quite centred in the overheads.
This is worth doing, if possible.
Use just as much close mic as you need to
get the definition for each element of the kit. Close cymbal and hat mic's may need savage
low-cuts; you probably only need the high 'click' of stick on cymbal for them to do their
thing - you may not need them at all. Check and double-check your phase relationships as
you do this - you never know.
Lastly, pan the room mic's fully L/R and lift
them into the mix where they begin to give the drums their sense of space. I'm not a great
fan of a 'roomy' drum sound, so I'm quite sparing with them. I often prefer a synthetic
room reverb. I would also roll off some (actually I roll off a *lot* of) bottom from the
room mic's. If the kit sounds too wide with the rooms L/R, bring them in and see how that
sounds. You may even prefer one or other of the room mic's on it's own in mono.
You'll need to fine-tune the low-cuts in all the mic's to where it is helping to define
the drum it is set on, and not adding clutter you don't need. Depending on the style of
music my overheads can be cut up to 500Hz. Don't forget to gate the tom mic's (or edit the
audio part, preferably), so they aren't adding even more clutter when there is no tom
present - unless, of course, you like what they add by leaving them open - it happens.
Don't do any more with the EQ, other than I've suggested for now.
And...
...then drop us a new version of your mix!
Exalted Wombat
For the
Try
getting a mix from just four of them - the overheads, bass and snare. Then add in just a
little of the others, if needed. It might not be.
WeBuiltASkyscraper
[Re: The Elf]
#1031866 - 03/02/13 12:17 PM
Just to clear things up, all phasing problems have been addressed and solved! I've tried to do all of the above, but I'm still left with the snare and kick drum
sounding very mono, I'm not too sure why. I do like them to be in the centre of the mix,
but they still sound very thin etc. Would this be where I'd look to plug ins begin to
thicken out the sound? Below is a link to the updated mix, still with no plug
ins or effects used... https://soundcloud.com/webuiltaskyscrapersos/the-sound-of-machines-no-fx-n
ew Like you, I'm not a huge fan of a roomy sounding drum kit, I like it to
be quite tight and clean! anyway, let me know what you think  Thanks!
active member
Loc: Sheffield, UK
Well that sounds a lot better, so you're on your way. The rest is down to the art of
mixing, and the options are endless - with the best will in the world it's not something
we can do step by step over a forum.
(I offer a 1-2-1 tuition service. You can
PM me for details if you're interested.)
Exalted Wombat
[Re: The Elf]
#1031875 - 03/02/13 02:20 PM
The drums may be sounding a bit isolated from the rest of the mix because the guitar is
pushing ahead of the groove - a musical ensemble problem rather than an audio one. I've
got other comments, but they may change when I listen on my music computer rather than
this laptop.
Exalted Wombat
[Re: Exalted Wombat]
#1031893 - 03/02/13 04:58 PM
...but it's not as bad when you can hear the bass as well. Forget that.
I'd
still like to hear a mix with just the overheads, snare and bass mics. And with less
reverb on the guitar, maybe a little more on the overall mix. Get everything into the
same room.
WeBuiltASkyscraper
#1032410 - 06/02/13 03:10 PM
