Paul881
Loc: Heart of the Shires, England
USB Audio Interface?
#1031752 - 02/02/13 04:14 PM
Hi, it's time for me to invest in a new audio interface. I currently run an M-Audio
Delta66 PCI card with Omni I/O card but its beginning to show its age and so it's time to
look at options.
I need at least four inputs; two mic inputs front mounted
with decent pre's, low latency as I use a lot of synths, 44k1 24 bit simultaneous
recording, a high impedance guitar input would be nice, phantom power and a headphone
socket with level control.
FireWire seems on its way out and my budget of
£400 doesn't run to a PCI solution. On paper, my favourite contender is the Focusrite
Scarlett 18i20.
Comments and opinions all appreciated.
My PC DAW
spec as follows:
Gigabyte GA-EX 58-UD5 MoBo/F7 BIOS/Intel i7 Quad Core 920
CPU/6 Gig RAM/Win XP/Delta 66+omni /SP-5B monitors/Sonar X1 PE/Trilogy/Omnisphere /Stylus
RMX/Absynth4/Kontakt4 /POD XT/Z3ta+/Rapture/ Dimension Pro
Edited by Paul881 (02/02/13 04:24 PM)
therobyouknow
Re: USB Audio Interface?
[Re: Paul881]
#1031760 - 02/02/13 05:19 PM
How about the Tascam US-144mkII ? http://tascam.com/product/us-144mkii/specifications/This
is what I use - it's a USB 2.0 interfaced (and powered) device and works on both PC and
Mac (I used it on my 2010 MacBookPro) and works pretty well. Quote:
I need at least
four inputs;
From the
spec, the Tascam US-144mkII has: "2 XLR microphone inputs with phantom power 2
1/4" balanced line inputs"
Quote:
...two mic inputs front mounted with decent pre's,
As mentioned above, from
the spec, the Tascam US-144mkII has: "2 XLR microphone inputs with phantom power"
Quote:
low
"Zero-latency hardware monitoring"
Quote:
44k1 24 bit simultaneous recording,
From the spec, the Tascam
US-144mkII has: "Up to 96kHz/24-bit audio resolution"
Quote:
a high impedance
From the spec, the Tascam US-144mkII has: "Switchable guitar level input"
Quote:
phantom
power and a headphone socket with level control.
As mentioned above, from the spec, the
Tascam US-144mkII has: "2 XLR microphone inputs with phantom power" ALSO:
"Individual Line and Headphone out level controls (US-144mkII only)"
Quote:
£400 doesn't run
to a PCI solution.
The
Tascam US-144mkII can be bought for under 100 pounds. Leaving you with 300 pounds spare
for something else
Quote:
On paper, my favourite contender is the Focusrite Scarlett 18i20.
Is this mains or USB powered? Couldn't
tell from the spec, the rackmount suggests it might require its own power.
The
Tascam US-144mkII is USB powered which gives you that convenience of not needing an extra
power socket.
Great - so I hope you welcome this suggestion even though it is
way under your budget. I imagine those with high end studios might chide me with
suggesting something so cheap but it does seem to meet your needs
Quote:
My PC DAW spec as
follows:
Gigabyte GA-EX 58-UD5 MoBo/F7 BIOS/Intel i7 Quad Core 920 CPU/6 Gig
Nice spec - I would think the Tascam
US-144mkII would be compatible. Other handy things it has are: MIDI IN/OUT and SPDIF
coaxial in and out.
Paul881
[Re: Paul881]
#1031798 - 02/02/13 09:26 PM
Many thanks, it's certainly an impressive spec, especially for the money. The two
drawbacks it has for me are rear mounted inputs and top mounted controls. This doesn't
suit the situation where my interface needs to go. Otherwise, it would definitely be a
contender.
A lower cost acceptable unit for me than the Focusrite Scarlett
18i20 that I have seen is the Focusrite Scarlett 8i6 @ £239.
Will_m
Loc: Manchester
[Re: Paul881]
#1031805 - 02/02/13 10:13 PM
There's also the Tascam US-600, which is similair only with front facing inputs. I've
heard good things about the Roland UA-55 Quad-Capture which is also well within budget. At
the top end of £400 and a bit more is the Motu Track 16, which had a breakout cable or IO
box that you can position where you want and also the Motu Ultralite MK3, which is USB2
and Firewire. I actually really like the look of the new focusrite though seems
good value and focusrite are usually pretty good for driver/latency and have nice
pre-amps.
-------------------- http://www.williammorrismusic.com
Goddard
[Re: Paul881]
#1031834 - 03/02/13 05:22 AM
I wouldn't necessarily agree that Firewire is on its way out, unless you're using a laptop
with no good onboard FW or expresscard slot. Still plenty of supported FW interfaces
available that would meeet your criteria, including some new hybrid FW/USB ones, and good
PCI/PCIe/Expresscard FW cards (or TB-FW adapters) aren't that expensive.
The
recently updated Presonus and Focusrite FW drivers are offering quite good low latency
peformance, as has been discussed in the Dawbench LLP topic.
So, you need not
necessarily limit your options to USB.
Paul881
[Re: Goddard]
#1031853 - 03/02/13 11:18 AM
Quote Goddard:
I wouldn't
necessarily agree that Firewire is on its way out, unless you're using a laptop with no
good onboard FW or expresscard slot. Still plenty of supported FW interfaces available
The
So, you need not
I have never been a fan of FW for no better reason than it always
seems to have had issues i.e. hot swapping, plugs easily pulled out, incompatability of
chipsets, microsoft latency etc.
I have read the DAWbench LLP thread and
frankly, it just turns me off. I want to make music and not have to study the in depth
ins and outs of driver code efficiency, chipset performance and IC selection! So I will
be staying with USB as my connection spec of choice; Focusrite have always had a great
reputation for Pre-amps so thats the reason for my listing them as my pre-purchase
favourites.
Of course, there are always those that are now going to post 10+
reasons why USB should never be used!
Paul881
[Re: Will_m]
#1031861 - 03/02/13 11:38 AM
Quote Will_m:
There's also the
Tascam US-600, which is similair only with front facing inputs. I've heard good things
about the Roland UA-55 Quad-Capture which is also well within budget. At the top end of
£400 and a bit more is the Motu Track 16, which had a breakout cable or IO box that you
can position where you want and also the Motu Ultralite MK3, which is USB2 and
Firewire.
pre-amps.
The MOTU 4 Pre
looks pretty good as well. And the Tascam us-800. Decisions decisions......
robin746
Loc: Ireland
[Re: Paul881]
#1031961 - 04/02/13 01:29 AM
Anything by RME. FireFace 400 for me, but they have USB solutions. Absolutely nothing more
solid.
-------------------- "The Drones" now available on BandCamp through Stolen Mirror.
Goddard
[Re: Paul881]
#1031965 - 04/02/13 04:32 AM
Quote Paul881:
Quote Goddard:
I wouldn't
The
So, you need not
Was simply pointing out that Firewire is not necessarily on its way out as your
post had indicated it so seemed. That's a myth ime, despite posts here and elsewhere
declaring Firewire dead/dying.
Have you actually encountered any issues with
Firewire yourself? Your Gigabyte motherboard has onboard T.I. PCI Firewire 400
controllers which are among the best available ime (and which are actually directly
connected to the PCI bus rather than bridged off PCIe as in many current Gigabyte boards
lacking "native" PCI), so I'm curious whether you've tried any Firewire devices with your
motherboard.
Quote Paul881:
I have read the DAWbench LLP thread and frankly, it just turns me off. I want to
make music and not have to study the in depth ins and outs of driver code efficiency,
Your post had indicated you were seeking low latency because you use many
synths, from which I'd understood you were playing/tracking host-based VIs/softsynths. If
that is in fact the case, then I'd suggest you would benefit from reading the info which
Vin has posted on AI low latency performance (LLP) over on the Dawbench site before making
any interface purchase, USB, Firewire or other, because that is specifically what the
DAWbench VI LLP test is all about (along with the DSP LLP test which is of interest if one
uses any host-based fx processing).
Quote Paul881:
So I will be staying with USB as my
connection spec of choice; Focusrite have always had a great reputation for Pre-amps so
thats the reason for my listing them as my pre-purchase favourites.
Your choice entirely, of course. I'd only
been suggesting you needn't limit your available options. I've been generally satisfied
with the preamps in my Focusrite interface (yes, it's Firewire ). FWIW, I
also use some USB interfaces and they work ok (but I don't use them with host-based VIs or
DSP fx on a PC).
Btw, your motherboard also has coax S/PDIF in and out, which
opens further connectivity options.
Also, if you are using streaming samples
(as your sig seems to indicate), you might benefit from moving to Windows 64-bit from XP,
which would enable you to use all of your 6GBs of RAM.
active member
Loc: Sheffield, UK
[Re: Paul881]
#1031968 - 04/02/13 07:15 AM
Quote Paul881:
FireWire seems on
its way out
I'm having a PC built
right now - with Firewire. It will be fine for a few years. Why worry about it if you have
a solution that works?
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
Loc: The wilds of Hampshire
[Re: Goddard]
#1031988 - 04/02/13 11:07 AM
Quote Goddard:
Was simply
pointing out that Firewire is not necessarily on its way out as your post had indicated it
so seemed. That's a myth ime, despite posts here and elsewhere declaring Firewire
dead/dying.
We buy
quite a few decent spec laptops for work and, apart from a very expensive Dell, all the
recent ones have come without Firewire. 6 or 7 years ago just about every laptop had a
built in Firewire port - even my wife's budget Fujitsu has one. So, from my point of view,
Firewire has had its day.
I don't see too many new Firewire audio interfaces
coming out either.
James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Paul881
[Re: Paul881]
#1031992 - 04/02/13 11:20 AM
Goddard, you make some good points in your post and yes I do use FW on my MoBo - to
connect a 1Tb ICE Box HDD. Nothing else I have uses FW. And I have gone over now to Win7
64 bit OS so need to update my sig.
I have never used my s/pdif interface nor
on my OMNI either. What would that do for me in terms of better performance or is it only
a matter of more options?
From what I read of the DAW Bench test, it seemed to
focus on poor FW driver performance on Windows - maybe I need to persevere and read the
whole thread?
On my system currently, with 384 samples I am getting latency of
under 5mSec's which seems pretty good to me. I'm hoping to get similar with a USB device.
Current favourite for me now is the Focusrite 18i6.
Thanks again for your
comments, they are greatly appreciated.
Goddard
[Re: James Perrett]
#1032048 - 04/02/13 02:30 PM
Quote James Perrett:
Quote Goddard:
Was simply
dead/dying.
We buy
coming out either.
James.
I'd mentioned the lack of FW ports and even expresscard slots on current laptop
PCs earlier, and yes, it's definitely becoming more difficult to find FW-able laptop PCs
(and also, desktops with good onboard FW although add-in FW cards can overcome this).
Hopefully things will improve in this regard as laptop PCs begin to offer TB ports like
Macbooks do now, with inexpensive TB-FW dongle adapters (essentially, a PCIe FW
adapter).
No, not many new FW-only interfaces, although of course the UA Apollo
initially only had FW800 connectivity. But I've noticed a number of hybrid FW/USB
interfaces appearing lately (RME, MOTU, Behringer) and likely such a trend will continue
as it makes sense for manufacturers to offer/support a single model with dual connectivity
options rather than separate FW and USB models, and Archwave offer a hybrid chip solution
with a decent feature spec.
Goddard
[Re: Paul881]
#1032083 - 04/02/13 04:39 PM
Quote Paul881:
Goddard, you make
some good points in your post and yes I do use FW on my MoBo - to connect a 1Tb ICE Box
HDD. Nothing else I have uses FW. And I have gone over now to Win7 64 bit OS so need to
update my sig.
As you are
probably aware, with rear bracket and/or front panel adapters you can also use the other 2
FW ports on your mobo for a total of 3 separate ports
Quote Paul881:
S/PDIF offers a digital 2-channel connection, and should offer low latency/load
performance like an internal PCI card interface using the available Windows WDM-Wave RT
drivers (but without ASIO support although the ASIO4ALL wrapper can be used if needed). A
lot of nice outboard gear has coax S/PDIF I/O, so yes, just more options. Many AIs already
offer coax S/PDIF I/O, as your current M-Audio card does, but another can be handy for
times you need an extra in or out. Just have to be mindful of sync/clock source and sample
rate and use the proper cables.
Quote
Paul881:
From what I read of the DAW Bench test, it seemed to focus on
poor FW driver performance on Windows - maybe I need to persevere and read the whole
thread?
I'd recommend you
take a look at the LLP info on the DAWbench site first:
http://dawbench.com/audio-int-lowlatency.htm http://dawbench.com/audio-int-lowlatency2.htm
and then the
forum thread will hopefully be a bit easier to follow and the comments and discussion make
more sense.
Be aware that the LLP test numbers on DAWbench are for a single
specific high-spec test system only although they do offer a good practical frame of
reference for relative performance comparison between different interfaces, and thus
"ymmv".
Quote Paul881:
On my system currently, with 384 samples I am getting latency of under 5mSec's which
seems pretty good to me. I'm hoping to get similar with a USB device. Current favourite
I don't believe the 18i6 has been DAWbenched yet, and have no idea how it compares
to the tested earlier Saffire 6 USB model. I assume you've already looked at the Feb '12
SOS review of the 18i6 and the buffer/latency info reported therein. Here's another review
of the 18i6 with some latency test info (using an old, lower powered PC) which may also be
of interest:
http://mikeriversaudio.files.wordpress.com/2011/10/focusrite-scarlett-8i6-
and-18i6-review_revised.pdf
In general, USB interfaces tend to require
larger buffers than FW and PCI/PCIe interfaces do, especially as the system loading
increases (e.g. when using more tracks, VIs, DSP fx) due to USB relying more upon the
system cpu (FW and PCI/PCIe interfaces don't generally load the cpu as much as USB does),
and larger buffers mean higher latency. There are exceptions, however, and some
manufacturers continue to improve their drivers, as noted in the DAWbench LLP info, but
many USB interfaces exhibit considerably higher latency (i.e., require larger buffer
settings in practical use) compared to PCI/PCIe and FW ones, as reflected in the DAWbench
LLP charts.
Paul881
[Re: Paul881]
#1032610 - 07/02/13 03:59 PM
Interesting. It's a shame the industry doesn't publish standardised latency DAW Bench type
data so buyers can check this out. Anything more than 6mSec is bad for me. The more I read
the more I think I'll stick with my Delta 66 + omni.
Also a quote from Mike
Rivers "But the main practical advantage of USB over Firewire, CPU resources aside, is
that very soon it will be difficult to find a computer with a Firewire port, while USB 2.0
will probably stay with us for at least a few more years."
Of course if you
have system that works with a FW interface then great. But why choose obsolescence in a
new interface when there are other options?
Edited by Paul881 (07/02/13 04:00 PM)
