Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
Hexo
Loc: Iran
Beyerdynamic 990 vs 880
      #1032980 - 11/02/13 08:27 AM
Dear all
I have tested the Beyerdynamic DT 990pro and I'm totally satisfied with it's sound and frequency response. But environment noise disturbs me. Do you think if a semi-open headphone like DT 880pro can give me the same frequency response with some noise attenuation?
Thanks.
subjective sounds in any mind deserve to exist. +1 to production.
Hugh RobjohnsAdministrator
SOS Technical Editor
Loc: Worcestershire
Re: Beyerdynamic 990 vs 880 new [Re: Hexo]
      #1032992 - 11/02/13 09:42 AM
Semi-open headphones give almost no ambient noise attenuation.
If external noise is a problem, I would suggest the Sennheiser HD-25-1 II (Handbook Here)
hugh
Hexo
Loc: Iran
      #1032995 - 11/02/13 09:52 AM
Oh really? Very good point. Thank you Hugh.
2M
member
Loc: Belgium
      #1032998 - 11/02/13 10:01 AM
I use the BD DT990Pro and DT770Pro. The latter one I use for tracking/recording and in situations where I want the minimum of noise from outside. The 990's I use mainly when mixing or just listening.
As far as sound and response I am totally sold on the 990's, which is why I opted for the 770 as well for tracking. The sound is nearly the same. The difference is most noticable in the lower frequencies. To my ears the bass is a bit tighter and thicker in the 770 (which makes sense seeing the design). Obviously the 990's also sound a bit more open and wider to my ears. But the general sound and response is very very similar to me.
So, if you like the 990's sound, and look for something similar with environmental noise attenuation, my suggestion would be to check out a pair of 770's.
Regards,
Martijn
Hexo
Loc: Iran
      #1033022 - 11/02/13 12:11 PM
Thank you 2M. But I've actually tested the 770pro too and it's not enough for me because I really need that wide bass and even sub in 990pro while designing say a kick or a bass. I'm just eager to know if there's a choice that has 990's lows and 770's isolation.
Smellthevalve
Loc: Surrey, UK
      #1033104 - 11/02/13 10:58 PM
Which impedance of DT770 did You try?
the 80ohm version does not sound the same in bass freqs as the 250 and 600 ones.
-<{DH}>-
Hexo
Loc: Iran
      #1033267 - 13/02/13 11:57 AM
I didn't know they have different impedances. I'll check and update.
2M
member
Loc: Belgium
      #1033280 - 13/02/13 01:41 PM
Good point, the impedance makes a lot of difference. In anycase, for sub and bass response I grab my 770's before I go to the 990's, so your experience with them surprises me a bit! To me bass in 770 is tighter and stronger than the 990's.
Curious to know what you tested.
Regards,
Martijn
Hexo
Loc: Iran
      #1033655 - 15/02/13 08:33 PM
Well, my tested DT770pro is a 250ohms one. DT770pro is a 250ohms and DT770M is a 80ohms as in beyerdynamic's site: http://africa-middle-east.beyerdynamic.com/shop/hah/headphones-and-headset s/studio-and-stage/headphones-for-live-applications/dt-770-m.html & http://africa-middle-east.beyerdynamic.com/shop/hah/headphones-and-headset s/studio-and-stage/headphones-for-live-applications/dt-770-pro.html
What do we find out here?
Smellthevalve
Loc: Surrey, UK
      #1033935 - 18/02/13 01:45 PM
It would appear from the website that the DT770M has a different frequency response to the DT770.
That was certainly my experience with the DT770M 80 ohm version - an increased level in the upper bass freqs changing the tonal balance coupled with not much deep bass compared to the 600 ohm DT770 which I have used a lot in PA sound work.
I can't comment on how the DT880 sound in comparison as I have not heard them, but the DT990 phones are quite good sounding in the bass even though they are open.
Hexo
Loc: Iran
Re: Beyerdynamic 990 vs 880 new [Re: Smellthevalve]
      #1034008 - 18/02/13 10:45 PM
Thanks for your comment, but...
Quote Smellthevalve:
"Though" they're open? I thought we should say "because" they're open. Most audiophiles and the most expensive and headphones specially designed for monitoring are open. It really sounds weird to me that you are on closed headphones side for monitoring. My thought is openback headphones sound better but they lack in isolation. And I'm looking to find an alternative with fixed isolation but the same quality.
Skerrick
Loc: Sydney NSW
      #1034029 - 19/02/13 12:50 AM
when i bought my akgs my mates all said closed back was the best for mixing and recording/producing cos youre hearing the "full sound" with nothing getting away from you through the cups and less interferance from outside noise... im no pro, but i got the AKG K171 MKII's and theyre pretty superb to say the least.
www.soundcloud.com/skerrick
Hexo
Loc: Iran
      #1034086 - 19/02/13 11:28 AM
I think I should proof you wrong:
Hugh Robjohns said:...most closed-backed headphones sounded pretty grim — boxy, dull, and lacking in air and openness. This is not really a problem when overdubbing or playing along with others, because it only has to provide a cue, after all, but making critical mixing decisions is almost impossible if the sound quality is poor ...........
The alternative open-backed headphone design has traditionally provided the best sound quality in headphone monitoring .........
ref: http://www.soundonsound.com/sos/dec03/articles/mixingheadphones.htm and your saying:
Quote:
...cos youre hearing the "full sound" with nothing getting away from you through the cups...
let me say that this is not true! Because the most natural condition is to here the sound from one side of the headphone driver like any other physical oscillator. Closed headphones might reflect the sound and you hear it twice! There might be also phase problems. Of course most modern headphones tend to absorb the driver reflection than reflecting it back to avoid all artifacts above. So the "full sound" you said, believe me,is a myth.
Pages: 1
Rate this thread
Jump to
Extra Information
2 registered and 15 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, SOS News Editor
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
February 2016
On sale now at main newsagents and bookstores (or buy direct from the SOS Web Shop)
Click image for February 2016
DAW Techniques
Home | Search | News | Current Issue | Tablet Mag | Articles | Forum | Blog | Subscribe | Shop | Readers Ads
Advertise | Information | Privacy Policy | Support | Login Help
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
We accept the following payment methods in our web Shop:
Pay by PayPal - fast and secure  VISA  MasterCard  Solo  Electron  Maestro (used to be Switch)
All contents copyright © SOS Publications Group and/or its licensors, 1985-2016. All rights reserved.
The contents of this article are subject to worldwide copyright protection and reproduction in whole or part, whether mechanical or electronic, is expressly forbidden without the prior written consent of the Publishers. Great care has been taken to ensure accuracy in the preparation of this article but neither Sound On Sound Limited nor the publishers can be held responsible for its contents.
The views expressed are those of the contributors and not necessarily those of the publishers.
