Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
Bo Millward
Help! I got a new pc and my firewire interface wont run properly!
      #1033300 - 13/02/13 04:22 PM
Right I've got a Focusrite Saffire Pro 24 DSP which runs perfectly on my old laptop but I've just got a new PC (Zoostorm Desktop PC, AMD A4 3300 2.5GHz, 4GB RAM, 320GB HDD, DVDRW, AMD HD6410D,) and a firewire PCI-E for it (Startech 2 Port Firewire 400 Card PCI-Express) I've been [ ****** ] about for days now and my audio keeps stuttering on a 0.5 sec cycle. I've tried everything I can think of but I can't get it to run smoothly, It's not the Saffire pro it's something to do with the fire wire return from the PC to the interface because diredt montering still comes through crystal clear... Anyone have any Ideas?
Thanks and much love,
Bo
Mixedup
active member
Loc: Cambridge, UK
Re: Help! I got a new pc and my firewire interface wont run properly! new [Re: Bo Millward]
      #1033308 - 13/02/13 05:02 PM
Which OS? If Win 7 do a search for 'roll back firewire". Works for some devices including Focusrite Liquid Mix. Failing that, really do try Focusrite tech support.
Bo Millward
      #1033311 - 13/02/13 05:04 PM
Sorry man I should of said I'm running windows XP, it's not a driver issue. I've pissed about with a number of different drivers for 3 days now and I think it must be something else.
Edited by Bo Millward (13/02/13 05:05 PM)
G-Doubleyou
      #1033332 - 13/02/13 06:48 PM
On PC most audio interfaces specifically want to see a firewire card with a Texas Instruments chip set.
Check your FW card for compatibility.
G-Dub
Studio G-fx 15inch quad-core i7 Macbook Pro Logic913
Ant Gamble
member
      #1033343 - 13/02/13 07:37 PM
Via chip sets should be fine too.....however...
Many Firewire cards also run network drivers, which can cause glitches/stutters. Go into device manager and look in the firewire AND network adaptor devices. If there is a networking element of the firewire card disable it and then see if there's an improvement.
Ant.
Pete Kaine
Scan Computers
Loc: Manchester
      #1033431 - 14/02/13 12:05 PM
Quote Bo Millward:
You bought a new PC and put XP on it? Your a braver man than I.
The fix refered too above is this one : http://www.focusrite.com/answerbase/en/article.php?id=1030
It applies to XP SP2 and & SP3 as well so unless your running an inital release with a vanilla install and completely unpatched, your going to want to try it.
Oh, and of course check that the FW card is indeed has a TI chip on it. All the Startech ones I've seen do, but that doesn't mean they all do. Regarding the VIA comment up top, most of the VIA chips do work with the Focus gear but not all of them from experience.
ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
tim_obrien
      #1033505 - 14/02/13 06:03 PM
Firewire interfaces are VERY picky and, as been pointed out, usually work best with TI-chipset cards.
SIIG and Belkin make known good TI-chip'ed firewire cards.
A good basic rule of thumb is: TI chips only!
Pages: 1
Rate this thread
Jump to
Extra Information
10 registered and 110 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
