Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
tim233
Loc: London, Essex
Yamaha MoX6 & Logic Pro
      #1034681 - 22/02/13 02:00 PM
Hi anyone know the settings I need to change to get the MoX6 and Logic/Mac talking to each other?
The synth comes with Cubase but it also says you should be able use Logic and other software just using the USB/Host connection (no audio or Midi leads required) I have tried various settings in the USB and MIDI utilities on the mox6. Maybe to do with the Saffire Pro interface I am using, as the Mox6 also has its own audio interface. many thanks in advance
desmond
Re: Yamaha MoX6 & Logic Pro new [Re: tim233]
      #1034683 - 22/02/13 02:21 PM
If it's plugged in via USB then it will create it's own MIDI port, which you use in Logic just like any other external MIDI instrument.
Do you know how to use/setup external MIDI instruments in Logic?
tim233
Loc: London, Essex
Re: Yamaha MoX6 & Logic Pro new [Re: desmond]
      #1034686 - 22/02/13 02:33 PM
Hi Desmond yes I have been using a MIDI controller keyboard in Logic with the same USB connection with no problem. But with this new USB/Host port on the synth, it is supposed to transmit MIDI and Audio data together, and is not registering either in Logic/Mac. In fact, when I first connected the synth, the Mac thought it was a 'computer keyboard' I was trying to connect.
desmond
      #1034690 - 22/02/13 02:53 PM
Quote tim233:
That means, your computer should see both a virtual MIDI device, and a virtual audio device. Open your AMS Utility - is your keyboard listed under both the MIDI and Audio tabs? If not, install it's software it came with, the keyboard may need drivers to announce itself to the computer.
tim233
Loc: London, Essex
      #1034716 - 22/02/13 05:09 PM
I have already downloaded and installed the latest Yamaha USB driver for the MOX6. I can see this driver in the System Preferences under 'Other' but there are no Device Names against the drop-down menu, even with the MOX6 connected and powered up. Not sure what you mean by AMS?
MarkOne
Loc: Bristol, England, Earth, Perus...
      #1034725 - 22/02/13 06:13 PM
AMS=Audio MIDI Setup... in your applications/utilities folder
The other thing to watch is that the MOX will probably be installed as not only a MIDI port but also an Audio Interface (This is how my Roland works), so you can get the audio from the MOX down the USB cable but either that then becomes your interface, or you have to create an aggregate device in Audio Midi Setup to aggregate the MOX with your existing sound card/interface
New album 'Fantasy Bridge' available now!
Making of Fantasy Bridge Diary
tim233
Loc: London, Essex
Re: Yamaha MoX6 & Logic Pro new [Re: MarkOne]
      #1034738 - 22/02/13 07:56 PM
Thanks MarkOne & Desmond. Ok the Saffire is there in the AMS but nothing that says Yamaha etc. Does that mean the driver is not installed? As I said, the driver shows up in the System Preferences under 'Other' but with no Device Name against it and greyed out Send buttons ?
desmond
      #1034756 - 22/02/13 08:33 PM
If there is no audio interface listd in the AMS for the Yamaha, then there is no way to feed audio in via USB. Try a reinstall, or connect the Yammy's analog outputs to your regular audio interface and bring the audio in that way.
Ditto with MIDI.
tim233
Loc: London, Essex
      #1034781 - 22/02/13 11:28 PM
Thanks. Ok I downloaded & reinstalled the correct USB driver! (Yamaha/Steinberg)
Now MOX shows up in AMS ok.
Getting a MIDI signal into Logic ok, but no Audio signal from the MOX, so nearly there.
desmond
      #1034802 - 23/02/13 06:58 AM
Quote tim233:
So, so in Logic's audio driver preferences, which devices do you have set as the input audio device, and the output audio device? If you want to use the MOX as the input audio device, to feed it's audio into Logic, you'll need to choose it as the input audio device (I'm keeping things simple for now until we can verify everything is working ok).
tim233
Loc: London, Essex
      #1034818 - 23/02/13 10:47 AM
Thanks Desmond. I have set Logic audio input to MOX, but still no audio to Track (track input set to 1/2) Also note: Is there not a way of getting digital audio out from the MOX but keep using the Saffire? (which is Firewire not USB) as its more preferable for ins/outs etc.
tim233
Loc: London, Essex
      #1034825 - 23/02/13 11:42 AM
Ok got the audio into Logic now by changing settings in MOX - Utility / USB I/O / Mode1
desmond
      #1034826 - 23/02/13 11:50 AM
Quote tim233:
Ok, so in the audio drivers preferences, you have the MOX set as the audio input device, yes?
It's probably only a stereo signal anyway, so record-enabling a stereo track on inputs 1 & 2 should be hearing the MOX audio. Are they the only inputs listed?
Quote tim233:
Yes, but as I said in my last post, I was trying to keep things simple for now - one thing at a time. In short, you have to use Aggregate Devices to aggregate multiple audio interfaces into one big virtual one, then use that virtual one in Logic. This gives Logic combined access to all the I/O of all the audio devices in the aggregate device you created. You do this in the AMS Utility.
tim233
Loc: London, Essex
      #1034828 - 23/02/13 12:00 PM
Ok see my last post, Audio signal is there now thanks. I guess the Aggregate is the next step.
tim233
Loc: London, Essex
      #1034832 - 23/02/13 01:04 PM
Yes I have set the MOX as the Audio input device, and set the Saffire as the Audio output device (both are listed as input and Output devices)
desmond
      #1034834 - 23/02/13 01:17 PM
Quote tim233:
Ok you'll need to set up an aggregate device as I described in the previous post.
tim233
Loc: London, Essex
      #1035092 - 25/02/13 10:50 AM
Hi I've setup the Aggregate device in AMS, and made the MOX and Saffire sub-devices of the aggregate. The Aggregate now also appears in the Logic audio I/O preferences. Have set the ins/outs as thought logical but still no audio.
desmond
      #1035107 - 25/02/13 11:35 AM
Quote tim233:
Make sure you are choosing the correct inputs. If the MOX is the first audio device, then it's probably still inputs 1 & 2 of the aggregate device. If the saffire is first, then the MOX inputs will come after the saffire. So for instance, if the saffire has four inputs, the MOX will be coming up on inputs 5 & 6.
tim233
Loc: London, Essex
      #1035451 - 27/02/13 07:19 PM
Hi I tried that but still no audio. In fact I've tried many combinations. Can you just confirm what the Logic audio I/O settings should be set to, and also the settings on the AMS. Thanks in advance
tim233
Loc: London, Essex
      #1035462 - 27/02/13 09:51 PM
Ok I've sorted it I think! I hadnt stored the changes I previously made in the MOX utility USB (see above) so when powered down it reverted to original settings.
For info (and to help anyone else) the settings now are:
Logic Audio: both I/O = Aggregate Device
AMS setttings:
Saffire audio interface - sound output
MOX6 - sound input
Pages: 1
Rate this thread
Jump to
Extra Information
4 registered and 35 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
