Main Forums >> Production - Mixing, Mastering, Gear & Techniques
        Print Thread
Pages: 1
Li-rocchi
Loc: Norwich, UK
A quick question for Samson S-Patch Plus patchbay owners....
      #1034917 - 24/02/13 12:25 AM
Hi all
I've just bought a couple of these secondhand and wanted to check something out. How recessed are the front panel switches on yours? Do they stick out much? Are they easy to slide across?
On mine, you have to get your finger nail in there to slide the switch across. The tip of the switch is almost flush to the front face of the panel.
Just wondered of that's the same on all units?
Many thanks
Max
Scramble
active member
Re: A quick question for Samson S-Patch Plus patchbay owners.... new [Re: Li-rocchi]
      #1034918 - 24/02/13 12:35 AM
I've got a few of these. The switches stick out a little bit. Not very much, a millimetre or two, but enough to make it easy to use your fingernail to slide them. You don't have to get your fingernail 'in there', ie. inside the groove where they are located, to slide them.
But it is a fingernail job, you can't use your finger.
active member
Loc: Sheffield, UK
      #1034940 - 24/02/13 10:50 AM
Yes, that's as they should be.
Li-rocchi
Loc: Norwich, UK
      #1035110 - 25/02/13 11:40 AM
Nice one - thanks for the clarification. Nice to know mine are as they should be....
@Scramble - yep, what you describe sounds the same as mine.
On another note, I'm quite keen on checking the bays to make sure all the connections are ok and working as they should. Can anyone recommend the best way of going about this?
Cheers
Max
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 22 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
