Spyder
member
Loc: Cambridge, UK
vocals and feedback - hyper?
#163546 - 04/08/05 08:34 AM
HI folks, last night my band did a gig which went well, but the sound man was
struggling to get enough vocal level without getting feedback. Now I know there are alot
of techniques to try to stop the feedback, but I was thinking about mics in particular.
The soundman used an SM58 on the vocals. Our female singer is not a belter and uses a lot
of subtlty in her voice. Would having a hyper-cardoid mic help to get more level on the
vocals. I think Audix do some nice ones. We could consider buying these and using them for
our gigs. Any thoughts? Would the difference be negligable next to all the other factors
which should be sorted?
-------------------- www.wildhope.com - pike in a lilypond
Loc: The wilds of Hampshire
Re: vocals and feedback - hyper?
[Re: Spyder]
#163598 - 04/08/05 10:48 AM
The Audix OM7 is great for quiet female vocals - it was the Cranes' sound engineer who
first introduced me to Audix mics and he was raving about the OM7. If you've ever heard
the Cranes you'll realise why. The OM5 is good too. The only thing with these
mics is that you need a PA with a reasonably good top end to make the most of these mics
because the upper mid-range is more recessed than the SM58. Cheers. James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Spyder
member
Loc: Cambridge, UK
[Re: Spyder]
#163607 - 04/08/05 11:02 AM
Thanks James. I remember seeing the Cranes many years ago. That sound is certainly in the
right direction. I'll have a look at those Audix mics then.
Guy Johnson
Loc: Pembrokeshire
[Re: Spyder]
#163814 - 04/08/05 06:55 PM
Just remember with the hypercardioids - don't point the rear of the mic directly at the
monitors, as there is a small pickup lobe pointing backwards. G
-------------------- PA stuff on FB
Spyder
member
Loc: Cambridge, UK
[Re: Spyder]
#164009 - 05/08/05 08:21 AM
Thanks Guy, I'll remember that.
active member
[Re: Spyder]
#164229 - 05/08/05 05:46 PM
hypercardioids - don't point the rear of the mic directly at the monitors, as there is a
And also remember with hypercardioids - don't point the front of the
mic directly at the monitors, as there is an even bigger lobe pointing forwards.
I'll get my coat.
active member
[Re: Spyder]
#164385 - 06/08/05 08:20 AM
Now trying to redeem myself here. Hypercardoids have a much tighter pickup pattern than
standard cardoids (though just how tight depends on the mic) and you need a much more
disciplined mic technique to use one successfully compared to a cardoid.
If
the singer tends to point the mic vaguely in the general direction of her mouth and wave
it around as part of her performance, then you will get large variations in volume. If
she sings straight into it at a fairly constant distance (except when backing off a bit
when singing very loud) then you'll be fine.
And always remember that if the
singer holds the mic right by the basket or cups her hand round the bottom of the basket,
then you are effectively turning the mic into an omni by preventing the sound waves from
reaching the back of the capsule and thus far more prone to feedback. This goes for both
cardoids and hypercardoids.
Spyder
member
Loc: Cambridge, UK
[Re: Spyder]
#164403 - 06/08/05 10:12 AM
Thanks for the tips Wonkey W. Our singer plays acoustic too so doesn't flouncy around with
the mic and is pretty good at staying on mic. If we have our own OM7 it will be used in
rehearsals too, so she will be able to get used to the pick-up pattern. What I
have found out though, is that the OM7 has a built in attenuator as its meant for very
loud bands on stage. Will a typical desk be struggling for gain? I think the OM5 has the
same sort of pattern with out the attenuation. Should I be going for this? Or is the OM7
even tighter and best feedback/vocal level mic out of the audix range? Anyone
for the EV 767? Senn E945? Beyer opus 69? or even Rode S1?
active member
[Re: Spyder]
#164629 - 07/08/05 04:35 PM
Don't think the OM7 is the right mic for a quiet singer. OM 5 or 6 would be better.
It's mainly the pickup pattern that will determine the anti-feedback
chracteristics of a mic. Paying more will get you a nicer sounding mic but you may still
have feedback problems in certain circumstances.
I've got an EV767 which is a
very nice sounding mic. It's the original version which has a bass roll-off switch. the
latest one is the EV767a which doesn't have this but I don't know what else changed. It
'super cardoid' pattern which is not quite as tight as a hyper but a bit more forgiving on
positioning compared to my Senn E855 for which you need to be right in front of the mic
for it to work.
How many mics have you got on stage in total? How much
foldback? My 12-piece band has 4 vocal mics and 5 instrument mics open all the time (7 if
we put something on the kick and snare) and we can usually get pretty loud without
feedback occuring.
Spyder
member
Loc: Cambridge, UK
[Re: Spyder]
#164730 - 07/08/05 10:03 PM
Hi WW. We are visiting local pub sized music venues. We have two vocalists, one drums and
the lead singer plays electro-acoustic too. Last week we had mics on snare, kick, guitar
amp, backing vox and lead vox, i.e. 5 mics in all. Two monitors, positioned for the two
singers. Next week we will be setting up our own PA in a pub. So not a complex setup
by any means. Two monitors again for the two singers.
[Re: Spyder]
#164874 - 08/08/05 11:54 AM
I tried the OM7 side by side with an OM5 and didn't notice a major difference in
sensitivity - maybe it is just designed to handle a higher sound pressure level. We chose
the OM5 for my wife's band because it suited her voice better than the OM7 but all voices
are different so you really need to try a few alternatives. We actually have as many
problems with acoustic guitar feedback as with vocal feedback now. Cheers. James.
SonicOddity
Loc: Helsinki, Finland
[Re: Spyder]
#168094 - 16/08/05 11:02 AM
Just throwing in the obvious point here. If the sound's ok you don't necessarily have to
change the mic. One good thing to try out is to route the vocs to group in addition to the
actual vocal channel. And the group to master of course. You don't need to raise the gain
(and be more prone to feedback) but still get some more volume.
Also I've
noticed people tend to use excessive compression on live vocals when there's no need for
it. It's so often that I see ratios of 10:1 with threshold of -15, no compensation and
tech-hippie scratching his head wonderin' where's the vocals. In those leds
blinking...
Also get some parametric EQ on those monitors and apply sort of
comb-filtering on feedbacking freq's (f.ex. 200,400,800,1600,3200,6400 so on..). Should
help if artists on stage can cope with it.
And yes: OM-series number 5 and 7
are great. So upgrade is always an upgrade.
Edited by SonicOddity (16/08/05 11:04 AM)
Spyder
member
Loc: Cambridge, UK
[Re: Spyder]
#168548 - 17/08/05 06:22 AM
Thanks for all the suggestions. I'm borrowing an OM5 & 7 this weekend for a gig so I can
try them out in anger. I'll let you know how we get on.
Guy Johnson
Loc: Pembrokeshire
[Re: Spyder]
#168693 - 17/08/05 11:45 AM
" good thing to try out is to route the vocs to group in addition to the actual vocal
channel. And the group to master of course. You don't need to raise the gain (and be more
prone to feedback) but still get some more volume. " ?? You'll still get
feedback in the PA if the gain (and therefore volume) is pushed too much, whether it's
done by pushing just one fader, or more! G
SonicOddity
[Re: Spyder]
#168720 - 17/08/05 12:24 PM
Depends what is feedbacking. If you run your monitors from aux sends of FOH then its good
idea to keep the gain at lower settings and push the PA harder after the aux send. IMO the
gain is the crucial thing here. Assuming that the PA and the monitor system is set up
correctly. Anyway, this is as far as I know, very used trick to get vocals up. I've even
seen some smaller venues with permanent strips on their group 2 saying "voc boost"  . Try it.
Works fine 4 out of 6.
By the way another problem might be too little
gain-too small amps. Its usually good practice (depending on the desk) to drive the single
channels gain to somewhere around +6 or so. Hell, those old Soundcraft xxxB-consoles
sounded good only when the channels were peaking with full gain.  No need
for compressor there....
-------------------- I'm improvising here... in a foreign language...
Edited by SonicOddity (17/08/05 12:29 PM)
Nathan
Loc: lincolnshire government experi...
[Re: Spyder]
#169047 - 17/08/05 11:58 PM
when SEs refer to "the gain", they generally mean the amplification/attenuation of the
path in question. i think someone was referring to the gain control or gain
knob there
-------------------- planet nine
lincoln, uk.
SonicOddity
[Re: Spyder]
#169085 - 18/08/05 04:28 AM
It's difficult to get understood when writing in foreign language. Anyway, when I say
gain, I mean usually the active part of the structure which, I suppose, is the gain knob.
I always see fader as "less significant" part of the signal path.Might be wrong here but
still get my gigs done without feedback and get more clients and keeping the old ones
every now and then
What I meant when talking about the groups:Back off the gain knob
of the vocal channel a bit and route the vocals to group in addition to the channel.
Edited by SonicOddity (18/08/05 04:31 AM)
