Funky Pie
Loc: Flintshire, on the edge of now...
"Claustrophobic" mixes
#166914 - 13/08/05 03:40 AM
Bit of an oblique one this and it may even be a stupid question, but bear with me:
Does anyone have any ideas for increasing the sense of stereo DEPTH in
recordings?
I record in a typical project studio which is nothing more than a
converted Potakabin. Because of these space restrictions, the only element recorded
"live" is the vocal. Everything else is either software instruments (ie, BFD for drums)
or overdubbed (guitars going through a Line 6 pod)
We record all kinds of
music but regardless of style or arrangement, the mixes always turn out spacially flat
because everything has been recorded in the sonic equivalent of a hermetically sealed box.
I hear commercial recordings that sound much more "airy" because they've had the benefit
of good mics recording in good rooms. I've tried to emulate space with some good quality
"ambience" reverbs but still everything sounds squashed together and two dimensional. Any
tips?
-------------------- As an impeccably dressed sage once said, "all art is quite useless".
Digital Emotion
Loc: Brooklyn NY USA
Re: "Claustrophobic" mixes
[Re: Funky Pie]
#166925 - 13/08/05 07:12 AM
Potakabin!!!!
What is it?
I have a feeling that I need one!
I can't remember what it is. Hold on, let me get high, then I'll remember what it
is.
Do you wanna get high?
Towelie
South Park, Colorado.
SOS Technical Editor
Loc: Worcestershire
[Re: Funky Pie]
#166931 - 13/08/05 08:03 AM
The perception of depth is governed by several things. The most obvious is room
reflections. You can create a sense of depth by using a good reverb to create realistic
room reflections -- it is the early reflectio pattern, density and level that are
important. The reverb tail doesn't contribute to the sense of depth at all.
Try
using a reveb program with very little rverb tail -- an ambience setting of some sort.
Next, EQ affaects depth perception. Distant sounds tend to be duller and thinner
than close sounds -- so some gentle and subtle EQ can help to create the illusion of depth
too. Conversely, bright, bass-heavy sounds appear to be very up-front in the mix.
Finally, compression. A lot of people over-compress everything -- and a lot of samples
are compressed at source too. Compressed sounds are inherently very 'up-front' too.
Hope that helps
hugh
-------------------- Technical Editor, Sound On Sound
archdake mkII
won't go away
Loc: Greece, west coast
[Re: Funky Pie]
#166937 - 13/08/05 08:55 AM
Hugh is right - just to add that in your case and in order for the digital reverb to give
its best it must be fed with a source that has as little colouration from the recording
room as possible. Whereas this is not a problem with good sounding rooms as they tend to
enhance the tone of the source (vocal, guitar etc), in small recording rooms things must
be mic'ed so as there's minimal room sound entering the mic. Baffles are your friend here.
You can even use the humble duvet or commercial solutions like Auralex.
James Lehmann
Loc: Europe
[Re: Funky Pie]
#166955 - 13/08/05 10:19 AM
Quote Funky Pie:
We record all
kinds of music but regardless of style or arrangement, the mixes always turn out spacially
flat because everything has been recorded in the sonic equivalent of a hermetically sealed
box. I hear commercial recordings that sound much more "airy" because they've had the
benefit of good mics recording in good rooms. I've tried to emulate space with some good
quality "ambience" reverbs but still everything sounds squashed together and two
dimensional. Any tips?
First
question - what are you monitoring on?
Two bits of advice:
1.
Try recording more live sources
ie Percussion, drums, guitars and keyboards; use
real amps and good mics & pre's. Even it the room isn't great there's nothing like a
mic'd-up sound to add space and depth where a sampled equivalent can't
2. Mix
through a good analogue board
Opens up a whole can of (analogue vs digital, mixing
ITB vs OTB) worms I know, but IMHO there's nothing like a real mixing desk to give a mix
the air, depth and gel you seek. I'd suggest starting with (1) but after you've tried that
you could easily take some tracks into another studio for a few hours and throw a mix
together on a decent board with a good engineer and see if you value the difference.
Of all the many tracks I listen to in the "My Sound Files" section of this Forum,
the vast majority would merit the same treatment outlined above; recordings that use only
software instruments and mixed 'in-the-box' rarely cut it for me.
Tomás Mulcahy
active member
Loc: Cork, Ireland.
[Re: James Lehmann]
#166968 - 13/08/05 11:48 AM
Good points so far, this may also be relevant. I have had this problem with Cubase in the
past. Just did a swathe of mixes in PT LE (with 002 and NS 10 M) and not only was it much
quicker to get the mixes to the "roughs" stage I had them in Cubase, but they sounded far
better. There was much more space in the soundstage. The mixes were wider, and the top end
was more open. Basically, PT sounds much better than Cubase VST!
-------------------- madtheory creations
Synths and pianos for Kontakt
narcoman
active member
[Re: Funky Pie]
#167033 - 13/08/05 03:08 PM
uh oh....
-------------------- Battenburg to the power of 20 - said by Richie Royale in a moment of genius. 4pm. Wed 16th Nov 2011. Remember where you were....
Jcar81
[Re: Funky Pie]
#167468 - 15/08/05 01:50 AM
You may already be doing this, but keep an eye on the gain structure within Cubase.
I use Sonar, which prevents signals clippig by applying some sort of limiter.
This is both a good and a bad thing - if it's going on and you don't know about it it's
mainly bad.
I'm not sure if Cubase is similar in this respect, but it's
certainly worth keeping individual channels with their outputs low enough to avoid
overloading any of the mix busses.
On the first SOS DVD Paul White had a good
technique for blending an ambience and a plate reverb to precisely control the ratio of
early to late reverb present in the tail. Pyschoacoustically speaking this gives you
control of depth of field very nicely.
A nearby sound will be brighter (as Hugh
mentioned), and contain less early reflections (back off the ambience reverb).
A far away sound will contain proportionally more early reflections (increase the ratio
of ambient reverb), as well as being duller.
Also you could try panning the
early reflections on individual tracks while leaving the plate centred, giving the
impression of different locations of the instruments.
You might be able to get
some nice pyschoacoustic effects going on to really create a sense of depth.
Cheers,
J
Paul White
SOS Editor-in-Chief
[Re: Funky Pie]
#167534 - 15/08/05 09:45 AM
The answer comes in several parts, but the first is to exclude as much room sound from
your vocals as possible, which means duvets or acoustic treatment. I think several other
readers have pointed this out too. The next requirement is a good quality reverb as these
enhance the sense of space and depth in a way that low horespower plug-ins can't match. If
you are working in a software environment, then I recommend the basic PowerCore systems as
these come with some seriously good reverbs. The last part of the equation is to try to
pick the best sounds at source rather than beating them into submission with EQ and not
overcrowding the mix with too many sounds. The holes are as important as the music. You
can add a little more transparency at the mastering stage by dipping the mid-range
slightly and adding boost above 10kHz to restore some shimmer, but this is more likely to
work if your mix already sounds great before you try to master it.
Tomás Mulcahy
active member
Loc: Cork, Ireland.
[Re: Jcar81]
#167555 - 15/08/05 10:39 AM
Quote Jcar81:
You may already be
doing this, but keep an eye on the gain structure within Cubase.J
You're right, I am. The same techniques used in PT
simply give a much better sounding result. And I am not convinced that good gain structure
would affect the width so dramatically. I might post examples, but as I said I have not
done an "Awesome DAWSum" type comparision. Perhaps it's time I got that CD to check if I
can hear a difference between different summing busses.
