Patrice Brousseau
Loc: Montréal, Canada
Re: Survey Of Working Dual-Core PC Music Systems
[Re: Martin Walker]
#406315 - 15/01/07 04:26 PM
Here it is: - Gigabyte K8U-939 (Uli chipset) loaded with latest Uli
integrated drivers (2.20) - 2 Gb of Kinston DDR400 value ram - AMD X2 3800+
(Manchester at 2gHz) - Matrox dual-head G450 with 5.86 drivers and bus mastering
disabled - Echo Mia first generation (not Miamidi) with 6.08 WDM drivers (sometimes
using also the ASIO 6.14 ones) First, I had to tweak a bit (because I like to
tweak): I installed the AMD Cpu drivers followed by AMD dual-core optimizer and
MS Dual-core hotfix. I also tweaked the PCI latencies a bit, 48 instead of 64 for the
Matrox and 128 instead of 64 for the SATA controller (this way, the ASIO driver does not
dropout when streaming samples at 128 samples). I also made a dual-boot XP setup with one
being the DAW with minimum services and disabled unused hardware like NIC's, scanner and
printer. With my old Athlon XP 1600+ (MSI K7T Turbo LE, Via KT133A chipset, 768
mb of SDRAM) I had a project in Sonar 5.2 with a few tracks of audio, a lot of freezed
softsynths and a particularly cpu intensive plugin (FreeAmp 2) and I was unable to play it
without clicks and pops unless I the latency was at 92 ms or above. And even with latency
as high, there were sporadic glitches... Now, the same exact project plays at
2.9 ms without a glitch. If I unfreeze the disk streaming samplers in the project
(VSampler and sfz), I have to push the latency slider to 7-8 ms). CPU use is in the 20-25
range Another example: A testing project with a big piano and a lot of pedal
sustain (Vintaudio C7 6 velocities in VSampler 3.5: something like 3-4 Gb ) and a reverb
(Sonitus) as insert on the track plays nicely at 2.9 ms. At this latency, CPU use goes to
30-35. I wouldn't even think to try it on my old system To conclude: I'm very pleased by the performance of the beast. The only thing that bugs
me is that I can't play big samplesets in VSampler at 1.5 ms without a few clicks and pops
here and there
-------------------- Patrice Brousseau
phonic
[Re: Martin Walker]
#411865 - 26/01/07 12:56 AM
Just for the sake of summarization: Any latest words on the PCI-e issues of earlier
last year? Is anyone having these issues on Core 2 Duo systems? are there any other
recurring issues on any of the core 2 duo systems? thanks Jeff
colink
[Re: Martin Walker]
#414061 - 30/01/07 07:01 PM
I built my own in December
ASUS P5LD2 VM DH Mboard Intel Duo Core E6300 MAudio 1010 2 160GB SATAs 3.something GB RAM Nesteq fanless PSU Silentmaxx aluminium disc holders Quiet processor fan that I've forgotten the name
of. Big thing though.
Graphics I just use the onboard ones, and the front
panels are open to let air in and cool whatever needs cooled.
Running XP home
(with all updates) and Cool Edit Pro II, Floops, Notation and sometimes Sonar 6.
Built it no problem in around 2 hours, loaded software over longer period and no
problems. Fully back to working on music in a day.
The difference between this
and my previous 2.4 Pentium is astonishing. So much more processing power, especially
when running a bunch of Altiverbs, Waves or the like. Previously some songs would
literally stick until I 'locked' 10 or 15 tracks, which itself took a good 20 or 30
minutes. Now, I discovered by accident, it'll actually move without locking, and when it
comes to locking, what took 3 minutes to lock, takes 10 or 20 seconds.
I've
worked a number of 10 or 12 hour sessions on the system since December and I've yet to
have any problems.
loopgarou
[Re: Patrice Brousseau]
#414323 - 31/01/07 08:42 AM
Any chance of splitting this topic up with a section just for Windows laptops using dual
core? So many variables in the desktop system that don't apply to my notebook setup.
Watcher Of The Skies
Loc: Cornwall, UK
[Re: loopgarou]
#414368 - 31/01/07 10:38 AM
Actually that's a very sensible suggestion loopgarou, especially since so many people post
here asking for laptop models that work well with audio software/hardware. I'll start another sticky thread, but will I'll open it out to include all PC laptops,
since the majority of new ones are likely to be dual-core models anyway. Martin
-------------------- YewTreeMagic
Loudbox
new member
Loc: UK
[Re: Martin Walker]
#416716 - 05/02/07 03:28 PM
OK, finally got round to upgrading. I was going for a similar set-up anyway but after
reading Martin's article I decided to use pretty much the same components. Intel Core 2 Duo 6600 CPU Intel DP965LT 2 gig Kingston 800mhz DDR2 ram 128mb ATI Radeon pci-e grahics card. I'm running 2 x UAD cards and a
Powercore Element which fills my three PCI cards up leaving 3 pci-e sockets left for
future upgrades. My RME Fireface 800 plugs straight into the built in firewire. This set up worked first time with no hitches. I've put a Ninja Scythe Passive cooler on
the CPU. Completely silent and runs 5 degrees cooler than the standard Intel fan. Cheers Martin for the great article. Saved a lot of time, pain and expense!
Loc: Cornwall, UK
[Re: Loudbox]
#417345 - 06/02/07 08:39 PM
Glad you found it useful - judging by the mumber of people posting here who are using my
suggested list of components I expect this will become a popular machine  Martin
Loudbox
new member
Loc: UK
[Re: Martin Walker]
#417440 - 06/02/07 11:44 PM
Martin, the card you chose has a substantial amount of ram which is more than adequate for
DAW work. However it does borrow from the system ram when required. Is this a function you
can turn off? Or is a normal DAW environment never going to use the onboard ram? I
wouldn't really be comfortable letting my graphics card have access to large parts of the
ram. One of the cards you recommended (Ati X300) only has 16 - 32mb of on board ram I
believe).
It may also not be so applicable now but maybe if or when we start
to use Vista in a DAW setup.
neonknight
#421604 - 15/02/07 02:53 PM
Guys, can anyone have a look at this and tell me if this configuration makes any
sense
Moederbord Asus M2N-E
Voeding (power supply)
Asus Atlas A-45GA
Behuizing CoolerMaster
Cavalier 3
Processor AMD Athlon™ 64 X2 4200+
Grafische kaart (PCIe)
Asus EAX1300HM512 TD
Geheugen Buffalo 2 GB DDR2-667 Kit
thanks!
Biodiode
Loc: Costa Del Blackpool
[Re: Martin Walker]
#422272 - 16/02/07 11:18 PM
Just as a thought after reading your article Martin, as you have gone for silent running
what are your CPU temps, idle and on load when sequencing?
-------------------- http://www.biodiode.com
Loc: Cornwall, UK
[Re: Biodiode]
#422450 - 17/02/07 03:55 PM
Hi Biodiode! My figures are still a little bit 'in-progress', since Peter
Cyriax (the PaQ case designer) has recently sent me a 140mm fan to replace the 120mm one I
specified in my feature. With the 120mm fan idling at ~850rpm my E6600 CPU was
at ~38 degrees Centigrade, and when running two instances of the Prime 95 'torture test'
(both cores running flat out at 100%) the fan speed rose to ~1200rpm and both CPU cores to
62 degrees Centigrade (well within Conroe limits). However, with the 140mm fan
I've set this to idle at ~380rpm for even lower noise levels, resulting in CPU core temps
of 54 degrees C, and with the 100% torture test this rises to 58 degrees C and ~1000rpm.
Meanwhile both my hard drives are sitting there at around 30 degrees C. Martin
ShirStar
new member
Loc: Auburn, CA
[Re: Martin Walker]
#422943 - 19/02/07 04:47 AM
Recently finished building my own system due to a motherboard failure on my old system.
Followed MW's Dual Core DIY feature.
Motherboard/chipset: Intel
DG965WH/82G965 Processor: Intel Core 2 Duo E6600 Graphics card: on-board Audio interface: MOTU 2408 PCI-424 Any DSP cards: none
Unexpected
issues:
The so-called "conventional" PCI slots didn't support my 5 volt only
cards (MOTU PCI-324, Yamaha DS2416, AX-16).
The RAID utilities provided with
the Intel MB didn't work due the default BIOS settings. Got through my XP install only to
have to start again from scratch after a few BIOS tweaks.
My 10/100 Linksys
router was incompatitble with the Gigabit LAN in the Intel MB.
The location of
the IDE connector on the MB presented a few challenges. Standard IDE cables aren't long
enough.
My CPU reaches 100% when playing back audio via SoundForge.
WaveLab hangs when attempting to write a CD to my new Lite-on LH-20A1H.
Sadly, I will miss my DS2416. Also had to spend an unexpected $100 on LAN hardware
grades and $310 on a new MOTU PCI-424e card.
Loc: Cornwall, UK
[Re: ShirStar]
#423027 - 19/02/07 10:58 AM
Welcome to the SOS Forums ShirStar!
Sorry to hear of your problems - the
DP965LT motherboard I used provides standard 5-volt connector slots, as shown in this
photograph I took for my feature:
These slots SHOULD be compatible with
most PCI expansion cards of the 5-volt variety, with the notch further away from the
backplate, as shown in this photograph I took of my Echo Mia soundcard. More modern audio
interfaces like the ESI Julia shown beneath it provide both 3.3-volt and 5-volt notches
(you an read more about the differences in this PC Notes column from December 2004 ( www.soundonsound.com/sos/dec04/articles/pcnotes.htm ):
Trawling back for photos of your DS4216 DSP
Factory card it looks to have (as expected) a 5-volt slot, as does Motu's original PCI-424
card, so I'm confused as to why you couldn't fit these in the DP965LT board.
More info required
ShirStar
new member
Loc: Auburn, CA
[Re: Martin Walker]
#423799 - 20/02/07 03:14 PM
Thanks for the info...
Both my DS2416 and PCI-324 fit in the MB as expected.
The DG965WH appears identical to the DG965LT as far as the PCI slots. The problem is that
the DG965 series is PCI 2.3 (3.3v). The DS2416 and PCI-324 are 5 volt only cards.
I tried to boot with the PCI-324 card installed but it was not recognized. The PCI-424e
worked fine.
I tried to boot with the DS2416 installed and my system wouldn't
boot.
Cheers
Loc: Cornwall, UK
[Re: ShirStar]
#423854 - 20/02/07 04:55 PM
Thanks for the feedback ShirStar!
That makes more sense - it can be a bit of
a minefield out there, since apart from the physical notches/keys that determine a 5-volt
PCI, 3.3-volt PCI or Universal 5/3.3-volt designs, according to my researches some cards
seem to look like 5-volt only according to their notches, but are actually universal
cards.
By the way, according to the Intel web site the PCI spec for the
P965LT is actually revision 2.2, but this is academic if your two elderly cards don't
work.
Has anyone else experienced elderly PCI audio interface cards that
aren't recognised or prevent booting in a new PC?
Nick (sonar)
new member
[Re: Martin Walker]
#426178 - 25/02/07 03:54 PM
Hi forum, Forgive me if this is not quite on the correct thread - this is my first
post.
I was just about to make the plunge and build an exact copy of Martin W's
sos Dual core set up - However i believe that the Corsair "memory recommender" no longer
recommends that pc6400 to go with the Intel dp965lt probably due to voltage issues.
Martin as i guess many people like myself would like to build this box following
your recommendations - could you recommend an equivalent memory kit? Thanks
Loc: Cornwall, UK
[Re: Nick (sonar)]
#426501 - 26/02/07 11:59 AM
Welcome to the SOS Forums Nick! Loads of people have had success with the RAM I
specified in my article, despite the 1.8/1.9 volt issue, and by July 2006 Intel had
allegedly released a new BIOS update that was claimed to use the RAM's SPD (Serial
Presence Detect) feature to auto-select 1.8 or 1.9 volts. This was confirmed by other
builders who could now boot with 1.9-volt RAM for the first time after flashing this BIOS,
and this Corsair RAM/motherboard combination has since been employed successfully by a lot
of different builders. Indeed, on-line retailers are still selling this
combination e.g. www.overclockers.co.uk/showproduct.php?prodid=BU-004-OKSo,
unless you've discovered any on-line reports that disprove the success of this
motherboard/RAM partnership I'd go for it! Martin
Beardedone
#427192 - 27/02/07 04:14 PM
Hello all!
Thanks Martin for providing such a wealth of useful information and
advice on dual core builds.
I have a question regarding the current crop of
core duo-compatible motherboards and their ability to accept my RME Multiface II PCI
connector. I am concerned that motherboards with PCI slots will soon become unavailable
leaving me with an obsolete soundcard.
Cheers, Gordon
daposti
member
[Re: Martin Walker]
#427435 - 28/02/07 01:13 AM
Just built a dual core system.. Asus M2N-E Socket AM2 NF570ULTRA Audio
Lan USB2 2000FSB SATA ATX Corsair 2 x 1 GB DDR2 667 MHz 2x128Mx64non-ECC 2x240 DIMM
Unbuffered CL5 AMD Athlon 64 X2 3800+ Dual Core (2.0GHz) Socket AM2 L2 cache Retail
Boxed Processor Asus EAX300SE-X TD 128Mb Radeon X300SE 128MB DVI-D/VGA PCI-e Ebuyer Extra Value 17" 400:1 8ms (1280x1024) Black MultiMedia TFT Monitor 3 Years
Warranty First impressions. Stable no crashes as of yet. SX installed no
problem and clear playback at 6ms with an m audio soundcard. Not to sure about these
people rabbiting on about buffers and poor latency sounds to me like they haven't selected
the right drivers. I'm gonna through all i can at it tomorrow see if it keels over and
splurts. My graphics card gets a good high resolution that doesnt effect system
performance. Favorite game call of duty wouldn't load thats a shame but apart from that
i'm chuffed to bits. The tft was a bargian at 75 quid also. I might get a quiter fan,
heatsink if such a thing exists and a faster dvd burner thats a bit of a bottle neck only
8x, from old system. Ok thats all before I bore you to death.
Rob R
[Re: Martin Walker]
#427900 - 28/02/07 09:33 PM
Hi, I'm thinking of putting one together, don't want full on power but it's better than
the AMD64 3000+ yeah? i have HDDs in the current one, plus, as quoted elsewhere on a
thread of mine, my Delta 24/96 card...
opinions on this.. it comes to about 550
or so? thanks!
# Intel CPU Core 2 Duo E6400 2.13GHz 1066FSB LGA775 2MB
cache Retail inc.Fan (3yr Manufacturers Warranty) £117.50 #
550W
Titan Silent Neon PSU PFC 12cm SATA ATX 24Pin w/ detachable 4 pin section £20.29 #
Asus Extreme 7300GS 256MB DDR2, PCI-E, DVI, HDTV Out, Retail £36.10 -
just wanted that in case i indulge in some older games.. tbh, i'm not too bothered
nowadays, but it's a nice to have #
2x Samsung Original 1024MB DDR2 800
PC6400 RAM memory £124.80 #
250GB Western Digital Caviar SE16 SATA
II 300 7200rpm 16MB cache Hard Disk Drive oem £38.99 #
Arctic
Cooling Freezer 7 Pro P4 upto 4.4GHz (socket 775) £14.20 #
Coolermaster RC-631 Mystique Black tower case NO PSU £57.95 #
Asus
P5B Skt 775 Intel P965 Core2 Extreme / Core2 Duo 1066FSB PCI-E x16 SATA RAID Giga LAN 8
ch. Audio ATX Motherboard £63.45
-------------------- cheers, Rob
Nick (sonar)
new member
[Re: Martin Walker]
#429244 - 03/03/07 05:36 PM
Thanks Martin, Parts on order.
alex c
[Re: Martin Walker]
#431730 - 08/03/07 11:10 PM
Hello all--a question for martin. I have just built a new system as below PAQ case Asus P5BE plus motherboard E6600 core duo 3x WD 250 gig
sata2 drives 2x 1gig corsair ddr2 800mhz memory Gigabyte graphics card
(256mb) First up -- I love the PAQ case -- it is indeed super quiet and in fact
as martin said in his review you find yourself saying is it switched on? Just a
tiny low level noise in the background - definately able to record in same room as PC now
-- Highly recommended!!! Only problem is my Echo Gina 24bit soundcard -- I just
cannot get it to run -- Keep getting error message "unable to load DSP" -- I have tried
everything I can think of -- reinstalled various versions of drivers --different PCI slots
-- Changed memory settings manually - Checked hard drive settings--The card will play back
audio fine but when I try to record, it comes out metallic and flanged sounding both with
analog and digi inputs -- the card works fine in my old machine with an ASUS P800 mobo so
must be something on the new set up. I see a previous poster on this forum said
he could not get an Echo Mia card to run on a particular ASUS mobo -- Do I give up and buy
a firewire card -- any advice u can give would be appreciated.
Loc: Cornwall, UK
[Re: alex c]
#432041 - 09/03/07 03:29 PM
Hi alex! And welcome to the SOS Forums! I'm pleased you agree with
me about the PaQ case  Your Gina24/Asus P5BE might be a fundamental incompatibility (several of the Echo cards
don't get on with the Asus A8V for instance, and won't boot up at all with one in any PCI
slot). However, if your card will play back audio then it's almost there, so this doesn't
sound like so bad. I would personally email Echo and ask them if they've had
any other reports of this combo having problems. Martin
alex c
[Re: Martin Walker]
#432237 - 09/03/07 11:20 PM
Hello Martin, Thanks for the reply -- actually I had already e-mailed Echo
technical support --but they took a few days to reply so thought I could get a quicker
answer here  ( U didn't let me down)--but now the postcript -- Echo have indeed replied to
say it is an incompatability issue and it looks like the Gina will not work with this
Mobo/configuration -so a warning here for anyone thinking of upgrading be prepared to
spend more than u originally allowed for. Oh well -- I was thinking of
upgrading the card anyway - it has now been forced upon me I suppose - a firewire or
perhaps the new RME PCI-express when it is released. Thanks for your help -
alex c.
Paradigm X
member
[Re: alex c]
#433935 - 14/03/07 07:49 PM
Quote alex c:
Hello Martin,
Thanks for the reply -- actually I had already e-mailed Echo technical support
--but they took a few days to reply so thought I could get a quicker answer here ( U didn't
let me down)--but now the postcript -- Echo have indeed replied to say it is an
alex c.
Many thanks
for posting this.
Im just about to buy a dualcore pc after five years of
loyal service of my AMD 2200+ 1.8Ghz
Im expecting a big increase in
performance.
But i was hoping to transfer my gina24 PCI card over and it
looks like ill have to be careful.
Sorry to hear about your problems !
Thanks,
Ben
edit: ive also been recommended a 6600
processor two with 2 gig of corsair ram. Only difference is an abit mobo has been
recommended rather than an asus. Ive had an asus in this one for years and its been great.
Ill email echo about abit compatibility. Im not building it personally, but once i get one
(hopefully working!) ill post it up
Cheers
Edited by Paradigm X (14/03/07 07:52 PM)
Twigman
[Re: Martin Walker]
#437437 - 22/03/07 04:49 PM
New system: Asus P5W DH Deluxe i975X motherboard Intel E6600 Conroe Noctua
NH-U12F CPU Cooler (idle 24C 100% load 40C) 2048MB DDR2 533RAM Asus EN7600GS512
Silent PCI-e m-Audio Audiophile 2496
Old system Asus P5LD2 945P
motherboard Intel P4 3.2HT Gigabyte Silent Blue CPU cooler 2048MB DDR2
533RAM Asus 6600GS PCI-e m-Audio Audiophile 2496
Both systems use
Antec TX1050 case and Antec Smartpower500PSU
Both running Sonar6 rewired with
Reason3 Projects that dropped out or ran at c90% CPU on old system now use 20-30%
CPU. My track count has soared and I'm a happy bunny although I'd love a better audio
interface and better AD/DA converters with super accurate sampling clock...........never
ending money pit...
Mixboy2105
[Re: Martin Walker]
#441742 - 01/04/07 09:21 AM
Hi Martin,
I can't seem to find the article of the Dual-Core system that you
specidied. May I kindly ask which month's issue was it? Or even better, could you post
it in this thread?
Hardy Heern
new member
Loc: British Isles
[Re: Mixboy2105]
#441782 - 01/04/07 11:35 AM
Mick'sBoy,
Martin's first part of his PC build was in Feb07 issue and the
second was in Mar07.
Martin, if you're reading, how about a sticky thread on
'Free samples' (in line with your, excellent, 'Free software' one)?
regards
Frank
PS, will post my dual PC spec soon. I have
MOBO, drives, CD-ROM, case etc but waiting (maybe forlornly!) for an imminent (2nd
Quarter?) price cut on E6600!  . Memory
and fan to come too as my, long time, supplier of PC bits don't seem to hack it on Memory
prices anymore. Still they do an amazingly cheap (£26) case with a Quiet 400A power
suppy!! OK it's not the very quietest, I suppose, but it's certainly the Quiet/Price
combination winner (AFAIK) so I got that and the other stuff from them.
BTW, I got chewed up, in an unpleasant 'zero tolerance' manner for mentioning them in a
post a few weeks ago which surprised me, very much, as I see this supplier and others
mentioned all the time by others. I'm still not sure what the policy is!
Loc: Cornwall, UK
[Re: Hardy Heern]
#442193 - 02/04/07 03:56 PM
Quote Hardy Heern:
Martin, if
you're reading, how about a sticky thread on 'Free samples' (in line with your, excellent,
That
would be a more suitable sticky for the Music Recording Technology forum, but a good idea
nevertheless.
_Nuno_
Loc: Cork, Ireland
[Re: Martin Walker]
#443734 - 05/04/07 08:48 PM
I just assembled a new daw
Core 2 Duo 2.4 E6600
Intel D946GZ board with on board graphics
2 Gb Micron
DDR2 533 RAM
1 PCI Firewire 400 Belkin card with a VIA chipset
1 80 GB 7200
SATA Maxtor Drive
1 250 GB 7200 SATA Maxtor Drive
RME Fireface 800
Now I had some trouble setting up this system but 24 hours later it is working
flawlessly.
I experienced clicks and pops in Cubase whenever I moved the
scrollbar or there was any major graphical movement going on. I started investigating the
on board graphics and discovered that it uses this DVMT technology that dynamically
manages the RAM the graphic suck up. I disabled this in the BIOS with no success but once
I uninstalled the Intel Graphics Media Accelerator driver all clicks and pops were gone
and I can now run a Cubase project that would only run with a 512 samples buffer on my old
P4 3.2 with 1Gb of RAM at 48 samples with 50% CPU usage
If anyone uses a board with this DVMT thing just uninstall the driver if it gives
you trouble and you should be fine.
Edited by Nuno_ (05/04/07 09:00 PM)
bluesdog
[Re: Martin Walker]
#444568 - 07/04/07 10:32 PM
Just want to say: THIS IS A VERY GOOD THREAD. I learn so much from here. Kudos ALL
-------------------- k k
Dennis Spank
member
Loc: Discipline
[Re: Martin Walker]
#444640 - 08/04/07 09:00 AM
My new system:
Asus P5B Deluxe WiFi/AP motherboard Intel E6600 2gB
Ballistix DDR2 PC2-6400 RAM Asus EN7600GS512 Silent PCI-e Zalman CNPS9500-LED
Aero Flower Cooler Antec Solo Quiet Mini Tower Case Seasonic S12-430 V2 PSU
I'm also running a Hammerfall Multiface DSP sound card.
First off, I
have to say that the Antec case is reallly good for 50 squids. Nice shiny black finish,
good hard drive mountings and very quiet. Also has a couple of handy USB and firewire
ports on the front.
Construction of all these components was straightforward
(put the PSU in *before* the mobo and CPU cooler!) and it's gots me lots of flashing LEDs.
Wooh.
So far everything keeps cool and quiet and all music software is running
fine with the Hammerfall Multiface - Cubase 4, Wavelab 6, Reason.
I have a
dual-boot setup with Windows XP Professional on one partition and Windows Vista Business
on the other. I've been comparing running Cubase 4.03 on both OSs with some interesting
results...
In XP, I can set the Hammerfall to a low latency of 32 or 64 samples
and Cubase 4 plays fine (with "Multi-processing" ticked ON in Cubase's device setup.)
However, in Vista I can only go down to a 128 sample latency and I'm still getting
crackles and pops when playing back in Cubase. I actually have to *disable* the
"Multi-processing" option in Cubase to get a better result.
Does anyone know if
this is because Cubase 4 needs to be re-written for Vista?
DB
-------------------- Ouch!
_Nuno_
Loc: Cork, Ireland
[Re: _Nuno_]
#444693 - 08/04/07 12:06 PM
Quote Nuno_:
I just assembled a
new daw
Core 2 Duo 2.4 E6600 Intel D946GZ board with on board
graphics 2 Gb Micron DDR2 533 RAM 1 PCI Firewire 400 Belkin card with a VIA
chipset 1 80 GB 7200 SATA Maxtor Drive 1 250 GB 7200 SATA Maxtor Drive RME Fireface 800
later it is working flawlessly.
whenever I moved the scrollbar or there was any major graphical movement going on. I
started investigating the on board graphics and discovered that it uses this DVMT
technology that dynamically manages the RAM the graphic suck up. I disabled this in the
BIOS with no success but once I uninstalled the Intel Graphics Media Accelerator driver
all clicks and pops were gone and I can now run a Cubase project that would only run with
a 512 samples buffer on my old P4 3.2 with 1Gb of RAM at 48 samples with 50% CPU usage
gives you trouble and you should be fine.
Just wanted to add that I came to the conclusion the problem
wasn't the advanced graphics driver but that I had disabled hardware acceleration for the
graphics card. I noticed that if I did that even with the driver uninstalled the clicks
came back, so I installed it again and enabled accelaration and everything is fine.
I am very pleased that I can use 48 samples buffer size up to the mixing phase.
Dennis Spank
member
Loc: Discipline
[Re: Dennis Spank]
#444711 - 08/04/07 01:33 PM
Quote Dada Beatnik:
In XP, I can
set the Hammerfall to a low latency of 32 or 64 samples and Cubase 4 plays fine (with
"Multi-processing" ticked ON in Cubase's device setup.) However, in Vista I can only go
down to a 128 sample latency and I'm still getting crackles and pops when playing back in
Cubase. I actually have to *disable* the "Multi-processing" option in Cubase to get a
better result.
Does anyone know if this is because Cubase 4 needs to be
DB
To answer my own question to some extent - disabling "Desktop composition" in
Vista (Aero glass features) certainly improves things and I can set the "Multi-processing"
option back on in Cubase.
But what kind of a monster machine or graphics card
do you need to be able to run Vista Aero with all apps?
kamrai99
Loc: Toronto, Canada
[Re: Martin Walker]
#448441 - 17/04/07 02:34 PM
Hi All I just assembled a new DAW - it took a few hours (4-5) to build and setup but
I did take my time as it's the first one i've built myself:
Intel Core2Duo
E6600 2.4Ghz. Asus P5B-VM. 3GB DDR2 667mhz. Seagate Barracuda 500GB
7,200rpm. Western Digital Raptor 150GB 10,000rpm. nVidia Geforce 7600GT
256MB. M-Audio Audiophile Firewire. 19” Widescreen TFT. Antec NSK2400
Case, 380w. Aiwa Amplifier, Aiwa Monitors. Samson CO1U Studio Condensor (main
mic) Roland Edirol PC-300 MIDI Controller
Keyboard.
SOFTWARE: Cubase SX3. SoundForge 6.0. Using
predominantly the following VSTi's: Korg – M1, Wavestation. Novation – Bass
Station, V-Station. Kontakt 2. Battery 3.
DRIVE ALLOCATION: SEAGATE 500GB: 1. 100GB – OS, Apps. 2. 200GB – Storage. 3.
200GB – Spare.
RAPTOR 150GB: 1. 150GB – Cubase Project data, Bank,
Audio files.
I have found this drive setup to be most efficient,
especially using the Raptor to feed into Cubase - works like a dream. The processor is
perfect for the multiple simultaneous VSTi's & plugins I invariably use, especially when
coupled with the multiple audio tracks (again running from the Raptor). The case is more
than powerful to run the system.
The Mic does need improving upon, as do the
monitors, but apart from that the quality of the system is great. The Audiophile Firewire
soundcard is superb too.
Any thoughts on the system? Recommendations/criticisms
or stories about experience with similar components are more than welcome. I have been
running this for only a week and have yet to come across any major issues.
ErichS
[Re: Martin Walker]
#449210 - 19/04/07 04:14 AM
Hi Everyone,
I just built this system ~2 week ago. Having a problem getting my
old Yamaha DS2416 working correctly
The new system is configured follows:
Pentium Core 2 Duo, 2.4 GHz ASUS P5B Deluxe motherboard (P965 chipset) 2GB Corsair DDR2 800 RAM 2 Western Digital 250GB HDs Antec Neo 550 (550 watt)
power supply Antec Solo case ATI Sapphire Radon 1300 graphics card PCI-e 16X Yamaha DS2416 Audio interface Yamaha AX44 IO Windows XP professional Sonar 4 Producer
Computer runs great but…. Installed in this
computer, the DS2416 keeps cutting out. At first I thought this was the usual issues with
buffers etc in the audio program , but I have found that it happens any time the card is
activated and just sitting idle (e.g no audio playing).
This became evident
because I kept hearing randomly spaced clicks through my headphones while the card is
active, with or without audio playing. I verified that the clicks were due to the dropouts
by playing a single wave file while keeping the master fader on the software mixer
(DspCtrl) down, and watching the meters on the outputs. This way I could see the audio
activity and still listen for the clicks. For every click, the meters would drop out
indicating no sound.
I have tried everything I can think of to fix the problem
including:
-reseated card -tried different PCI slots -updated
motherboard BIOS -reloaded Yamaha drivers (latest drivers from 2002!) -disabled
all startup items in Windows -disabled onboard sound and all un-needed hardware -lowered CPU/FSB speed -used a utility to change PCI latency
Admittedly
the DS2416 is an old card, and I was afraid it might have problems in a new system. Now
I’m looking at the MOTU Ultralight or RME Fireface 400 (not sure if I can justify the
$$$ for the RME)
Erich
Loc: Cornwall, UK
[Re: ErichS]
#451052 - 23/04/07 04:08 PM
Welcome to the SOS Forums ErichS! Ironically I discuss this very issue of PCI
Soundcard compatibility issues in my latest PC Notes column (May 2007 SOS, which came out
last week), and specifically mention the problems faced by some musicians attempting to
install their elderly Yamaha DS4216 card. In fact, other people haven't been
able to boot up their dual-core PCs at all when a DS4216 is plugged into any of its PCI
expansion slots! Martin
ErichS
[Re: Martin Walker]
#451784 - 25/04/07 04:43 AM
Quote Martin Walker:
Welcome to
Ironically I discuss this very issue of PCI Soundcard
compatibility issues in my latest PC Notes column (May 2007 SOS, which came out last
week), and specifically mention the problems faced by some musicians attempting to install
In fact, other people haven't been able to
boot up their dual-core PCs at all when a DS4216 is plugged into any of its PCI expansion
slots!
Thanks for the welcome and the information. I have scoured the web trying to find out
if anyone has tried the DS2416 in a new computer. I feel better knowing this was not just
a problem with my setup.
Meanwhile, I opted for the Fireface 400. Just
recieved it today and so far it is working perfectly. I'll put it through it's paces in
the next few days and let everyone know how the system is performing.
Thanks, Erich
KarnEvil
[Re: Martin Walker]
#454065 - 30/04/07 08:49 AM
Hi Martin, I've had a PC based home studio for years now and every time I plan
an upgrade, I begin with reading Martin Walker's reviews and articles. This tradition has
helped me to build fully reliable systems (2 desktops and a fine laptop with Echo Indigo
IO) so far, thank you!  So now
I want to upgrade to Dual Core with a Core 2 Duo processor and I'm hesitating on which
motherboard to choose. I have an old (only 5V) Marian Marc X soundcard, which I 'd like to
keep, because it's been working reliably for years now. First I thought of building a
system on an ASUS P5B Deluxe, because I've always used ASUS boards, but then I read your
article about your Intel DP965LT system, and I was quite impressed with that. But then I
read the latest article about PCI issues (May 2007) and decided to do a little research on
what kind of PCI standard Intel and Asus are using. Soon I found that there is revision
2.2 in each Asus P5B-type board, and after some hours I learned that Intel's DP965LT board
uses revision 2.3 under the name 'conventional PCI'. Now it would be clear that I should
choose Asus P5B Deluxe, but I've just read here that it won't work with an old 5V Yamaha
card... Now I'm totally confused. I might choose the P5B because I know of two Marian
Marc A cards (the same make, similar to Marc X) working pair in a P5B motherboard. Any
opinions? Thans in advance, Norbert Varga from Hungary
Loc: Cornwall, UK
[Re: KarnEvil]
#454211 - 30/04/07 02:02 PM
Hi Norbert! I personally ruled out the Asus P5B beaus ealthough it was
excellent value for money it had no on-board Firewire ports, which means having to buy a
Firewire card and using up one of your expansion slots. The P5B-V versiondoes have two
Firewire ports, but no serial/parallel ports (which may or may not sway you), while the
P5B-E does has one Firewire port, as does the Deluxe version (which also adds Wi-Fi
support), but only has one PCIe slot  Echo PCI cards seem to have problems with the P5B board according to alex c previously
on this thread, but I've checked, and as you mention it's PCI 2.2, so it theoretically
ought to run the 5-volt only cards like your Marian Marc X, and the Yamaha DS4216
mentioned by Erich S above (perhaps the DS4216 takes exception to a few motherboards like
the Echo range, unrelated to the PCI revision). I've just searched this thread
for others who've chosen the Asus P5B, and Static 2313/Ronny Pries/Dada Beatnik have all
had great results with RME HDSP9632 and Hammerfall cards, Alexandra Studios with a Motu 24
I/O, Doublehelix with a Lynx AES16, kamrai99 with an M Audio Audiophile Firewire, so this
motherboard does seem to be generally proving fairly compatible. Hope this
helps! Martin
