KarnEvil
Re: Survey Of Working Dual-Core PC Music Systems
[Re: Martin Walker]
#454439 - 30/04/07 08:53 PM
Thanks a lot, Martin!
I'll probably go for an Asus P5B Deluxe. Then we'll see.
In the worst case I would buy a new soundcard. But I would miss my Marc X very much...
I'll inform you about the results.
Best regards,
Norbert
Chopsy
member
Loc: Rochdale, UK
[Re: Martin Walker]
#455361 - 02/05/07 03:36 PM
Upgrading from a Dell Inspiron (Hooray!)
My choice:
Intel
e6420 Core 2 Duo Asus P5B E Artic Cooling Freezer Pro 7 Corsair 2gb 6400
DDR2 (twin xms2) Cas 4 Gigabyte 7300 GS gfx card Samsung P120 250gb SATA WD
Caviar 320gb Se16 SATA Seasonic SE12 Antec P150 case Samsung SH-S183L SATA
Optical drive
Soundcards: Edirol UA25 Firepod
So far
really stable with Live, though I need to test this setup thoroughly....
-------------------- "We deal in junk, you know; What we've got is what other people put in the rubbish bin." - Joe Strummer.
kevv69
[Re: Martin Walker]
#456039 - 03/05/07 07:47 PM
Here's my working system:-
ASUS P5W DH Deluxe Intel E6600 8 GB Dual
Channel DDR2 667 (Crucial CT2KIT25664AA667 1 x 250 GB OS HD (Western Digital) 2
x SATA 150 500GB HD (Western Digital) Asus EN7600 GS Silent graphics 2 x 19"
TFT Tascam US428, UAD 1, XP X64
The system is superb.....
However... I've had no joy with my Delta 66 soundcard under X64 The US428 is
running under X64 but it's not the greatest of units or low latency. Could use some
advice on a good PCI card (preferably with MIDI) that has proved X64 drivers. The
MIDEX 8 is history now too! The UAD1 card has X64 drivers but will not operate on
systems with more than 2GB, so my 8GB will not run a UAD1 as of yet.
Other than
these problems, the system is excellent!
Any advice on the soundcard situation
gratefully received.
K
maggotspawn
Loc: Los Angeles, California
[Re: Martin Walker]
#456517 - 04/05/07 07:26 PM
I just finished a budget build.
AMD Athlon 64 X2 4400
MSI K9AGM-FID microatx mobo
2 gigs of Mushkin DDR2 800
ram
1 Western Digital Sata II 160 GB HD
1 Western Digital Sata II 400 GB
HD
Lite-On DVD burner
Seasonic S-12 430 power supply
Apevia/Aspire
X-Qpack aluminum case
I'm running with the integrated graphics for now, but I might
be tempted to get a graphics cards at some point.
System is rock solid, ran
Prime 95 and Memtest without any problems. System runs at 35 C at idle and 45 C at load.
Projects that were at 35% CPU in Cubase, on a 2.66 Ghz Pentium IV run at 10% now. Very
pleased with it. I would have liked a Core 2 Duo, but was hampered by budget concerns.
System set me back
about $800, or 400 British Pounds...
Ximogen
[Re: Patrice Brousseau]
#458159 - 09/05/07 04:14 PM
I have found the following to be v. quiet (thanks to case and passive video card) and
performs without a glitch running Cubase 4.
Always difficult talking about
performance in terms of numbers but I am able to run several instances each of Stylus RMX,
DFH Custom & Vintage, Atmosphere, Trilogy, Miroslav Philharmonik etc. Plus a whole bunch
of audio tracks with Amplitube 2, Roomworks, etc with 4 to 6 ms latency (not sure how many
samples that equates to) without any problems.
Some of the performance gains
are down to the data disks being on a separate PCI express card in a RAID 0 stripe,
sustained sequential read and write of about 120MB per second compared to the 70-80 you
might expect from onboard SATA.
CASE: Antec P180B PSU: Antec NEO HE500
500W MB: Intel DP965LTCK CPU: Intel E6600 CORE 2 DUO 2x2.40 1066MHZ MEM: 2
x 1Gb DDR2 800 System HDD: WD Caviar RE WD3200YS SATA Raid 16Mb (on-board SATA) Data HDD: 2 x WD Caviar RE WD3200YS SATA Raid 16Mb (RAID 0) HDD Card for Data
drives: Adaptec 1220SA SATA 2 Raid Card DVD: Nec AD7170 GEN DVDRW Black 1 VGA:
MSI NX7300LE TD256E Nvidia PCI-Express 1 AUDIO: E-MU 1820m
Obviously you
pay a premium for the Raid edition drives, the Intel MB/Processor and decent memory but
you do get what you pay for. Having been working with PC hardware since the days of the
8086 processor I was happy to spec and build this myself but you should find that a decent
PC shop would put it together for you for £30-£40 it you buy the bits from them.
Cheers, Adrian
Bendybones
[Re: Martin Walker]
#459934 - 13/05/07 08:51 PM
Hi Martin - excellent article. I plan to follow it word-for-word!
No luck
trying to find that graphics card though.
Could u recommend a similarly
suitable spec or card?
I don't know enough about them to figure out what it is
about this one that I should look for.
Thanks alot, B
-------------------- MBP 2.4GHz, 4GB RAM, OS X 10.6.6, Saffire Pro 40, Sound Devices 552
Beardedone
[Re: Bendybones]
#460027 - 14/05/07 04:08 AM
Asus P5B-E Core Duo E6600 Asus 7300EN passive video card Scythe Nija
RevB Antec Take 4 Rackmount case Corsair HX520 PSU Corsair 2G 6400 TMX 800
MHz RAM RME Multiface II PCI Everything is working fine except I cannot
the my Multiface to work at 48 or 96 KHZ. I have the latest firmware update and RME
drivers installed. I am at a loss to know what to do to rectify the problem.  Gordon Sauvé Montreal
here come the drums
[Re: Martin Walker]
#460103 - 14/05/07 09:42 AM
Please help the none techi stuggle sometimes
GA-K8NF-9 NFORCE 4-4X AMD 64
Single ATI Radeon 300 SE M Audio 44 1x80gb Seagate ATA drive
(programs) 1x160gb Seagate ATA drive (data) running cubase sx3
I
bought the motherboard because it was upgradable to dual core.
I recently
found that when working on a remix with more audio tracks (40 and a few waves plug ins)
than I am used to, The CPU hits jumps from 50% to 100% and locks for 30 seconds when
trying to move over drum parts IE intricate detail , the CPU Cubase meter stays at 50%
after lots of head ache I came to the conclusion rightly or wrongly that it was a
graphics/sound conflict. Having done lots of forum browsing I have seen much talk about
my board not all good and frankly am more confused now than I was before I started
concerning the nforce4 pci issues. Bottom line is should I upgrade to dual core on
this board or ditch it altogether I appreciate it is not exactly coherent with the thread
but I am at my wits end and any help would be greatly appreciated.
I just
want do make music!
Watcher Of The Skies
Loc: Cornwall, UK
[Re: here come the drums]
#460201 - 14/05/07 12:50 PM
Quote here come the drums:
Bottom
line is should I upgrade to dual core on this board or ditch it altogether
Welcome to the SOS Forums 'here come the
drums'!
The NForce 4 chipset is well known for causing audio glitches on some
systems. Here's a quote from my September 2005 PC Notes column:
"However,
tests on various PCs featuring this chip set have shown processor overhead that was larger
than expected when the PC was running lots of plug-ins, as well as audio glitches unless
the interface buffer size (and hence latency) is increased. Some users have reported
having to increase buffer size as high as 2048 samples with an NF4 chip set, compared with
128 or 256 samples on a roughly equivalent PC featuring Nvidia's previous NF3 chipset.
Although the vast majority of the problems reported by musicians relate to PCI soundcards
plugged into the legacy PCI slots on PCI Express-equipped motherboards, RME have reported
similar issues with their Fireface 800 interface, so other Firewire interfaces may be
affected as well."
You can read the whole column here: www.soundonsound.com/sos/sep05/articles/pcnotes.htm
In
March 2006 I wrote a PC Musician feature on 'Making the change to a Dual-Core PC', which
included this section concerning the switch from single to dual-core AMD X2
processors:
"This leaves the Nforce 4 chip set, which has proved very popular
with gamers but extremely troublesome for musicians installing single-core Athlon 64
processors. However, as I write this in early 2006, the latest news is that if you instead
install a dual-core Athlon X2 model the problems are significantly reduced — so much so
that some DAW builders are reportedly starting to use Nforce 4 Ultra motherboards such as
MSI's K8N Neo 4 Platinum model (with four PCI slots, two x1 PCI Express slots and one x16
PCI Express slot). Even Digidesign (normally extremely cautious to recommend the latest PC
technology) are recommending the Asus A8NE motherboard, again with Nforce 4 Ultra, for use
with their MBox and Pro Tools LE 7.0 for Windows XP."
The whole article is
here: www.soundonsound.com/sos/mar06/articles/pcmusician.htm
So
the simple answer is YES, upgrading to a dual-core processor should greatly reduce your
current problems.
Fingers crossed anyway!
-------------------- YewTreeMagic
here come the drums
[Re: Martin Walker]
#460241 - 14/05/07 01:31 PM
Thanking you very much Martin
Think I may have to purchase one like yesterday
then I will be back with a report on progress and performance for you to have a butchers
at is there any particular processor I would should go for?
Thanks again it is
much appreciating and in English. I can almost feel my head ache subsiding as I type,
until the install that is. lol
Thanks again
HCTD
Loc: Cornwall, UK
#461233 - 16/05/07 02:29 PM
is
Do a search here on the forums - prices are always dropping, and
the AMD X2 model that currently provides the best price/performance combination will no
doubt have changed since the last time I looked
Phunky
member
Loc: Hilversum, The Netherlands
[Re: Martin Walker]
#461525 - 16/05/07 10:40 PM
I've just build myself A new(partly)Dual-Core PC. X2 4600, Asrock Alivesata2 Glan(MB),
Asus Extreme AX300SE(Graphics), 2GB 667Mh Kingston Value RAM, 300Gb Maxtor HD. +-400
euros. I used my old box, DVD-RW, and one 80Gb HD. EMU 1820M soundcard with Behringer
ADA8000. Everything has been working smoothly for more than two days now. Very fast. A
project using 40-45% of the CPU on my Athlon 2100(2400 overclocked) 1Gb, is being reduced
to 10-15%.
-------------------- http://www.jesperbuhl.com
Rain
member
Loc: Guildford UK
[Re: Stevedog]
#461782 - 17/05/07 01:08 PM
Core 2 Duo 2.6GHZ Asus P5b deluxe 4GB RAM Windows Vista 64bit ultimate Asus GT 6700 graphics RME Fireface 800 UAD1 Cubase 4 Various VST
(all working in Vista 64)
I'm extremely pleased with this setup - works
beautifully!
ECK
new member
[Re: Martin Walker]
#472581 - 13/06/07 08:13 PM
Hi I am having the same problem as alex c Has anyone built a duel core system using
the Gina 24 with any success My system Intel 956 motherboard E6600
proceessor Corsair ram BFG graphics card thanks
paddy c
new member
Loc: UK
[Re: Martin Walker]
#479216 - 28/06/07 08:32 PM
Hi Martin read your article about old sound cards in new motherboards. I'm
planning to build a new pc E6600 and asus board I want to use my old but very nice
Terratec DMX 6Fire card. I contacted terratec to see if they could suggest any
compatible boards and their response..... this is an old card and it might work !!! well if i'm going to upgrade i need a bit more than that. Guys at my local computer fair
all said it 'would work' - but not sure they are the best people to talk to re DAWs. I have spent a great deal of time surfing for any info and had very little luck. has ANYBODY successfully used a DMX 6 fire in a new build E6600/ASUS ?? thanks
Loc: Cornwall, UK
[Re: paddy c]
#479422 - 29/06/07 11:16 AM
Hi Paddy - welcome to the SOS Forums! Glad you noticed that column - it
probably saved you some frustration in advance  As I said there, it's a little difficult to tell whether or not particular soundcard
will run successfully in a new motherboard, but your DMX 6Fire is at least five years old
(I reviewed it way back in SOS April 2002), so it's starting to look a little unlikely.
Why not tell us what Asus motherboard you're considering, and then someone may post who
already has that combination and can tell you one way or the other? However, it
was only £180 when first released, and you can get similarly performing soundcards now
£100 or so. Why not build your new machine and then try it - if it works then great, but
if not investigate a new audio interface? Martin
ErichS
[Re: Martin Walker]
#479887 - 30/06/07 03:12 PM
I agree with Martin, but I would like to add that you should give serious consirderation
to what interface you would get if the Terratec were not in the equation. You may find
that you would build a very different machine. Many newer interfaces are either Firewire,
PCI-E, ou USB. If you build your system with the intent of using your old sound card
(e.g. buying a particular motherboard because it supports PCI 2.1) you could overlook a
system that has better support for one of the newer technologies.
You can
see in my post a little higher up in the thread, I did everything humanly possible to keep
my old sound card. It was like an old friend and I knew what to expect from it, and there
were some features that I hated to loose. Now that I have moved to a new interface (RME
Fireface 400 - reviewed in this months SOS) I think it is the best thing I have done for
my recording chain in a long time. I dont know if it is the converters or what but it
sounds like I wiped off a dull film from my recordings and am hearing things in a
completely different way.
I'm not saying the RME is right the interface for
you but, as Martin mentioned, the newer interfaces are probably just as good, if not
better, than your older card and they will work with the newer computer equipment.
Edited by ErichS (30/06/07 03:13 PM)
Paradigm X
member
[Re: Martin Walker]
#481006 - 03/07/07 02:21 PM
Any reason why abit boards havent been mentioned ? Ive been specd a pc which
is virtually identical, with an abit mboard, seen asus mainly. But ive heard that asus
boards dont get on with the old gina24, which ive got. Might as well try a different type.
I might have to get a new soundcard too. Cheers all.
-------------------- http://www.paradigmx.com
hifistud2
Loc: Near Sunderland, UK
[Re: Martin Walker]
#482466 - 06/07/07 11:18 AM
Hmmm... here at Hi Fi Towers, I'm looking at going down the Q6600 route - Cubase 4 is
barfing badly with a mere 18 tracks of audio and a few plugins via my MOTU 2408 / 24I/O
424 interface setup on the current machine.
So, anyone got any info? Boards to
steer clear of?
-------------------- [url=http://www.facebook.com/pages/hifi-studios/117322741632389[/url]
Loc: Cornwall, UK
[Re: hifistud2]
#482527 - 06/07/07 12:42 PM
You could try the Intel DP975XBX2 (aka the 'Bad Axe 2') - one of the first Intel
motherboards to offer overclocking capabilities. I'm still happy with my Intel DB965LT,
and both of these support the Q6600. Martin
jasondfisher
[Re: KarnEvil]
#485768 - 13/07/07 05:36 PM
1. Q6600Processor Intel® Core™2 Quad Q6600 Quad Core processor with VT Each core
operates at 2.40 GHz 2 × 4 MB L2 cache 1066 MHz front bus 2.
Chipset Intel 975X 3. Memory Installed: 2048 MB DDR2, 667 MHz, (PC2-5300) dual
channel memory (two 1024 MB DIMMs) Expandable to: 4 GB (4 DDR2 DIMM slots) 4. Hard Drive 500 GB, 7200 RPM, SATA II hard drive 5. ATI Radeon X1950 CrossFire
video card with 512 MB graphics memory Included CrossFire cable enables dual card
configurations Ports: Dual DVI-I ports with HDCP via cable (VGA via adapter) 6.
Cubase 2.2 (probably not ideal but I just bit the bullet on this system) which I need to
upgrade to fully get the multiprocessor experience. I have had NO problems to date though
and am actively using it. 7. fw 1884
Mark Knutson
member
Loc: Minnesota, USA
[Re: Martin Walker]
#497684 - 07/08/07 01:53 PM
I built this in the first week of August, 2007. It is extremely snappy. I am running 13ms
of latency on asio drivers right now, and it seems ok, but I have done very little
recording with small projects, so the final usable latency may end up being greater.
I was proud and relieved that it worked properly from the first power-on forward,
but I have built enough of these that I know how to be careful. And some luck in not
having any defective parts.
Not sure if the mobo supports firewire. It has a
number of headers inside for extra USB ports, and maybe there is a firewire one. It
describes one in the manual, but the manuals are often for an entire product line so I
can't rely on that.
This PC includes a more expensive power supply that is much
quieter than normal, and a large and quieter CPU fan with heatpipes and a heatpipe fan
add-on for the video card as its fan was the noisiest part of the system at first. I
suppose these premium parts added about $130 to the cost of the system. Thing is, my pc is
lots quieter than a store-bought, unless its from a quiet-pc specialist, and those looked
awfully pricey to me as well.
Let me do a run-down in case anyone's
interested:
Core 2 duo e6750 $190 2gig ddr2-800 ram $120 Fancy cpu
cooler $35 Termaltech 430 watt Power supply $50 MSI P35 mobo $135 Zalman
vga cooler $50 Pioneer cd/dvd reader/burner $60 evga gforce 7600gt video $90
Total $730 Tax @ $47 Total $777. 563 euro, 380 british pounds.
I already had a emu 0404 sound card, and since I use outboard ADC and DAC, all I need is
something with a good asio driver and spdif in and out.
I felt with the CPu, I
found a price-performance sweet spot where the next most powerful cpu was $100 or 50% more
expensive. I did have my heart set on a core2 duo.
lpjc
new member
Loc: London
[Re: Martin Walker]
#501341 - 13/08/07 05:46 PM
I am putting together a system with reference to all the above kind help:
E6600
Dual Core Intel DP965LT Mobo 2GB Crucial 800MHz DDR2 (1.8v) WD 500GB SATA
16MB cache HDD Asus EN6200LE 64MB PCI-E Graphics Samsung SH-S203 S-ATA 20x20
Dual Layer DVD-Rewritable Antec Solo Quiet Mini Tower Case Seasonic S12 Series
430W PSU Thermalright XP-90 cooler
This will hopefully work with my Echo
Layla24 however I have a dumb question to which I have not been able to find a
straight answer immediately from the web:
I have ordered Windows XP Home SP2B
x32bit to "upgrade" from my previous Win2000pro and I am not certain that it will take
advantage of the "dual core" nature of my new processor. Can someone reassure me?
Also are there any other reasons that I should have gone for XPpro ?
(I
wanted XP for easy networking compatibility with other PCs in my household)
I
will of course post a result if the system works as I hope it should !! ;-)
UNIT393
All Funked Up
Loc: Australia
[Re: Martin Walker]
#504497 - 19/08/07 08:08 AM
Built my new PC 6 days ago and can now confirm that all is stable.
CPU - Intel
Core 2 Quad Q6600 (G0) MB - ASUS P5K Premium WIFI AP (intel P35) RAM - 2Gb
Mushkin XP2 DDR2-1066 VGA - BFG Geforce 7950GT OC 256Mb 1394 - ADS Tech Pyro 64
PCI HDD - WD5000AAKS, WD2000JB, WD740GD, WD360GD, Seagate 320G 7200.10 Opt -
Pioneer 212 DVD-RW PSU - Corsair HX520 HSF - Noctua NH-U12F
OS -
Windows XP Pro SP2 AI - Digidesign Digi003R / Pro Tools LE 7.3.1cs4
-------------------- Funk It
_Nuno_
Loc: Cork, Ireland
[Re: lpjc]
#504515 - 19/08/07 09:31 AM
Quote lpjc:
I have
ordered Windows XP Home SP2B x32bit to "upgrade" from my previous Win2000pro and I am not
certain that it will take advantage of the "dual core" nature of my new processor. Can
It
does. It wouldn't support dual processors, but dual core or hyper threading is fine.
Paul881
Loc: Heart of the Shires, England
[Re: Martin Walker]
#510971 - 30/08/07 02:20 PM
Just a quick question. If I chose a mobo like the ASUS P5W DH Deluxe, and I was looking a
CPU for it, is there any advantage to go with a quad Q6600 cpu instead of a dual e6600
CPU? These are £149 and £115 respectively at Micro Direct currently.
What
would be the performance difference between them?
Loc: Cornwall, UK
[Re: Paul881]
#511519 - 31/08/07 12:40 PM
It depends on the software you're using - according to many of my measurement a quad-core
PC seems to outperform a similarly-clocked dual-core PC by between 20% and 30% when
running typical audio software, although older software may not benefit the extra cores at
all. However, if you get a 30% improvement for just an extra £34 then that
sounds like a bargain to me! Martin
Paul881
[Re: Martin Walker]
#511944 - 01/09/07 05:29 AM
Thanks for your reply Martin, I use Sonar 6.2PE so I guess Cakewalk have optimised Sonar
to work with these new generation CPU's?
For an extra £34 it seems a steal!
Paul881
[Re: Martin Walker]
#512042 - 01/09/07 10:33 AM
In considering my options for storage, what are the pro's and con's of SATA vs Raid? Raid
appears to be mightily complex to set up - but probably more complex to read about than to
actually implement.
Loc: Cornwall, UK
[Re: Paul881]
#512731 - 03/09/07 09:53 AM
Have a read of this PC Musician feature for my thoughts on RAID:
www.soundonsound.com/sos/jul05/articles/pcmusician.htm
(hint - I don't think it's necessary for the majority of musicians  )
Paul881
[Re: Martin Walker]
#513774 - 05/09/07 06:43 AM
Many thanks Martin, excellent article - seems like I will be giving RAID arrays a miss.
 I can see that I may use up to 60 tracks with possibly up to 15 streaming mono
tracks (maybe a couple might be stereo). So I don't think I will get any way towards
needing RAID - especially at 24-bit/44.1kHz recording. And 7600rpm spin rate for the HD's
seems sufficient for me as well.
mqbernardo
Loc: Portugal
[Re: KarnEvil]
#522171 - 21/09/07 04:51 PM
hello! a bit OT (or maybe not that much...), but - regarding the increased preformance of
a quad versus a dual core - does that come with a much increased power consuption? any
help will be much appreciated.
thanks in advance,
miguel
Nanno
[Re: Martin Walker]
#529853 - 05/10/07 08:17 AM
Hi, first time posting here, so a warm hello to everyone! Have been reading the
dual core thread with a lot of interest and I finally upgraded from a AMD Athlon 4000+ to
a 4200+ X2 CPU (board: MSI K8T Neo 2 - socket 939 - KT800 Pro - AGP - no PCIe slots) as
this probably time to get a dualcore 939 CPU before the disappear. Everything seems
to work fine. Ínterfaces are Echo MIA PCI and Echo AudioFire 4 via a Dawicontrol (TI
chip) FW-PCI card.
Now here's my question: I just swapped CPUs without a
new install. WinXP SP2 did install new hardware, but I'm not sure if I need to turn a few
other srews to get the full benefit of the dualcore CPU. What about the hyperthreading
business? I think I read on a Steinberg note that I'm supposed to turn of hyperthreading
when using a dualcore CPU. If so, how would I do that?
Thanks for helping! Nanno
Loc: Cornwall, UK
[Re: Nanno]
#534163 - 15/10/07 05:05 PM
Hi Nanno! And welcome to the SOS Forums! After changing CPUs without
a fresh Windows install I'd perform a clearout of your Registry, which will still contain
references to the old processors - have a read of this PC Notes column for details: www.soundonsound.com/sos/jun04/articles/pcnotes.htmAs for
Hyperthreading, that Steinberg caution must be an elderly one, since musicians are now
routinely using quad-core and even octo-core processors with relatively few issues.
However, you won't have HyperThreading on an AMD-based CPU anyway (AFAIK this is an
Intel-only feature). Hope this helps! Martin
JMcCulloch
new member
[Re: Martin Walker]
#534368 - 16/10/07 09:47 AM
I've just built a system based on this:
Mobo: Intel DP35DPM (P35 chip with 1333
FSB) CPU: Intel Core2Duo E6850 S775 3.0ghz 4mb (dual-core 3.0GHz) RAM: 2GB
(2x1GB) CorsairTwinX XMS2, DDR2 Data HD: Samsung SpinPoint 500GB S300 16MB 7200RPM PSU: 430w Tagan EasyCon - TG430-U15 - 2Force Silent Modular PSU Graphics: 512MB
Gigabyte 8500GT PCI-E (x16) DVD-RW: Samsung SH-S203/BEBN 20x DVD±R, 16x Case:
Antec Solo Quiet Mini Tower ATX BLK
Highlights:
- the case is very
reasonably priced but has lots of options for making things quiet and easy to access
(although I had to butcher it a bit to get a full-length PowerCore card in the bottom
slot!).
- Samsung SpinPoint HD is brilliantly fast and silent! Also Samsung
SATA DVD is the fastest DVD reader I've ever come across.
- DP35DPM MoBo has 12
onboard USB 2 sockets and 2 FireWire - the FireWire are Texas Instruments chips too, which
is what m-audio recommend, so good for external audio interfacing.
Bewares:
- no PS2 connectors for mouse/keyboard, but an adapter can be bought for both into
USB for a few quid, but for initial installation you'll need a USB keyboard for the
BIOS
- no serial port, so old MIDI or Roland systems that use it will need a
USB-serial adapter
- no floppy drive header, so installing RAID/AHCI drivers
would be a right pain (slipstreaming) if that's how you want to work
Possibilities for further upgrade include going quad-core (the MoBo supports this) and
and extra Gig or more of RAM, depending on OS support.
But overall the system
is many times faster and smoother than my old P4 3GHz system, totally stable (so far) and
I'm very pleased! My CPU meter reads around 1/4 to 1/3 what it used to in Cub4.
All sourced from the usual, Dabs, Scan.
Bill
spjessop
[Re: Martin Walker]
#535401 - 18/10/07 11:29 AM
This is going to seem like a blot on this thread, but here goes anyway. My single core
system died recently so I embarked on a budget orientated refurb. As it was a s939 Athlon
system there are currently some excellent deals about for discontinued parts. Here
goes...
I gave my refurbed machine a run last night and it managed 3ms in / 5ms
out with no clicks or pops on an existing project. That's enough for my needs, and not a
bad upgrade for £150 worth of parts. This was with my Saffire Pro running on Bus
Power.
For what's it's worth this is what I used. Your needs may be greater
than mine.
ASRock 939NF6G-VSTA Motherboard - Onboard video running my 20"
widescreen monitor as the PCIe graphics card I bought was DOA. It has 1x PCIe and 2x PCI
expansion slots. The Mini ATX size was useful as my Antec Sonata II Case isn't the best
for cable management.
2GB Crucial DDR RAM - I had 2x 512MB so bought another
two. You need to activate 400 speed in the BIOS for some strange reason as it defaults to
333. I assumed at first that my new sticks were incompatible with the original ones, but
this turned out not to be the case.
AMD Athlon 64 X2 3800+ - I picked up a new
one on eBay for £30. Works fine with my existing Zalman cooler.
Seagate SATA
80GB Boot Drive - The manual states that Windows will install without needing a floppy for
drivers, and this was indeed the case.
Belkin FW400 PCIe card - Works fine with
my Saffire Pro.
Netgear Wifi - This is disabled in my music partition, but
doesn't seem to cause me any problems either. This was left over from my dead system.
There are various other SATA drives I have in there for Audio and Scratch. The
only real pain was having to put two IDE drives into USB caddies. That's no big deal.
For the paltry amount it cost me to refurb this I'm very pleased. I had pretty
much written it off as a music PC (I record with my laptop anyway), but it works fine.
It's not as powerful as a decent Core 2 Duo, but was vastly cheaper than building a new
PC. It's more than usable, and has a much lower load in Sonar as well.
My
lesson learned is to stick to Intel in the future I think. AMD chipsets and sockets are a
total mess at the moment. I could find only one Motherboard that worked with my Processor
and RAM, wheras refurbing a dead Intel P4 machine a couple of years ago (which uses PC-133
RAM) was a piece of cake.
KaYoS
[Re: Martin Walker]
#536785 - 22/10/07 01:35 PM
Ive just built a new system Amd Athlon 64 6000+ x2 cpu 2Gb ddr2 ram Nvidia 7200gs Pci-e Graphics card (2 monitors, one 19" and one 17") Asus M2N -E Sli
motherboard, with Nvidia nforce 500 chipset Hiper power 580w psu Many and varied
hard and optical drives! M-audio 1010lt sound card Im running 64 studio
and i produce dance music, using some sound modules (E-mu orbit v2, E-mu planet phat and
my trusty old Roland u220) as well as several soft synths. It easily handles
having ardour, rosegarden, jamin and many soft synths running at once, with a latency of
2.9ms. I do not notice any problems when recording from all my sound modules
and soft synths at once, also all the hardware was correctly set up, with no need to
recompile my kernel. This was allways going to be my linux daw, so it was
designed with that in mind, only problem was Nvidia sata raid, but that was easy to fix.
-------------------- There are 10 kinds of people who understand binary; those who do and those who don't
beatz01
[Re: Martin Walker]
#539966 - 30/10/07 01:13 AM
Quote Martin Walker:
..my
suggested list of components..
Forgive my ignorance but i'm new to SOS (great form btw) so could anyone hint me on
where to find that list ?
Thanks in advance !
Frank
Loc: Cornwall, UK
[Re: beatz01]
#540087 - 30/10/07 11:55 AM
Frank - The on-line version of my PC Musician feature on 'Specifying & Building A
Dual-core Desktop PC' can be found here:
www.soundonsound.com/sos/feb07/articles/pcmusician_0207.htm
I'll be publishing some updates to the list shortly though, since nine months is an
extremely long time in the world of PC components
Blank
[Re: Martin Walker]
#544020 - 10/11/07 12:14 PM
Mine is a quad work flawlessly since a month
Board is a p5k-se cpu is a
q6660 2.4 4 gb of kingston ram ( 667 mhz) 2 x 500 gb seagate barracuda hd
Using it with powercore firewire, tried a couple of soundcard with ( rme fireface,
motu traveller, m audio audiophile firewire)Never crashed.
For uad pci
users that need many pci slots, I did build a system like mine but with a Asus commando as
mobo, rock solid too, work without a trouble with the 4 uad card.
Note that
the ram is at 667 mhz cause it looks like the beos is downclocking the ram to 533 by
default to get the 1066/533 ( 2/1) ratio with the fsb.
regards
-B
