Stevie B
new member
Re: Survey Of Working Dual-Core PC Music Systems
[Re: Blank]
#548027 - 21/11/07 01:21 PM
Hi,
Completed my new PC build about a week ago. Intel DP35DP Intel
Q6600 2GB Kingston DDR2 800MHz Ram 3x 500GB Western Digital Caviar Drives Arctic Cooling Freezer Pro 7 Asus 7300GT 256 Mb Passive Cooled Graphics card -
PCIe
Built to run Cubase 3.1 and Softsynths via my existing Delta 1010. Running
quietly, reliably and quickly!
Thanks to Martin Walker, Conz & Peter C for
their advice.
Would I change anything? Well, the Graphics card Has DVI &
VGA outs. I’ve two 19” LCD’s on VGA connectors. When using the DVI out via an
adaptor, that screen is slightly out of focus with a slight “shimmer”. (Tried adaptor
that didn’t suffer from this on my old video card – same results). Dedicated VGA out
is fine. I’m sure native DVI would be fine also.
AntiLuddites
Loc: Airstrip One (Oceana)
[Re: Stevie B]
#548729 - 22/11/07 05:39 PM
Old machine was P4 2.6. New machine: Carefully researched to be cheap, but with
maximum upgrade / overclock potential. Motherboard/chipset: Gigabyte
GA-P35C DS3R £70 Processor Intel: e2140 £40 OCUK Graphics card:
nvidia 7200GS £25 Scan Audio interface: EMU 1820m from old P4 DSP
card: On the Emu. Memory 2GB Geil 6400, 4.4.4.12 at 2.1v. £37 OCUK HD:
Seagate 400gig £50 from computer market. OS XP home £67 from shop  Cubase
4 Studio. Has worked vey well. increased the count of Nebula3 Analogue Channel
plugins from 4 to 14. This increases to 24 when the e2140 is overclocked from 1.6 to
2.8 GHz. (42Celcius on Intel fan at 100% proccessor). Latency: comfortably
records at 2ms. I'm extremely chuffed and smug.  Should I need more power, can slot in a cheap core quad Penryn in a year or two. Perhaps DDR3 memory as well, if economically viable. Note: the mobo does not
have onboard firewire. Very similar GA-P35c DS3 has buckets of USB slots and support
for DDR3 at up to 1333. I originally ordered one of these, but it was Dead On Arrival.
-------------------- With a boom-a-lacka, zoom-a-lacka, wee.
jaminem
active member
Re: Survey Of Working Dual-Core & Quad-Core PC Music Systems
[Re: Martin Walker]
#551556 - 29/11/07 06:11 PM
Been going for about 4 days no issues yet aside from some dodgy memory
ASUS
Commando Mobo (chosen for the 4 PCI 2.2 slots to take advantage of everyone flogging their
PCI Powercores cheap to upgrade) Intel Q6600 Kinsgton DDR2 800Mhz RAM ASUS
EN6200TC512 graphics 2 x Western Digital caviar 500GB SATA 2 X-Power PSU 450W
(20db) LG DVD Writer TC Powercore Element UAD-1 RME HDSP 9632 Cubase SL2.2 (still some way to proving if this can address all 4 cores but an upgrade
needed anyway at some point) Battery 2 Halion String Edition 2 EXS24 EVP73 WAldorf PPG/Attak
I should point out that I had to adjust the PCI
timing on my old P4 2.8ghz to stop the Poco and UADclicking when they both addressed
together. This doesn`t seem to be happening at the moment, so i'm leaving well alone.
Watcher Of The Skies
Loc: Cornwall, UK
[Re: Martin Walker]
#551816 - 30/11/07 02:26 PM
Replies moved from another thread started in al good faith by bluesdog on Quad-Core
systems, which would be better added to this existing one. MW Quote hifistud2:
OK...
Antec Take 4 case (4U) Intel DP35DP Mobo Q6600 proc 2GB
Kingston DDR2 800Mhz RAM (due an upgrade soon) Sapphire RADEON X1650 PRO 512MB DDR2
PCI-E DUAL DVI-I gfx card 2x Western Digital HD Caviar RE16/400GB SATA 7200rpm 16MB
1x Maxtor IDE boot drive, 120Gig - one that was just lying about. MOTU PCIx 424
audiowire card.
Thus far, it's running superbly well, no glitches under XP Pro
SP2 - and metering at roughly 23% of its hyperthreading forerunner, promising better than
four times the performance.
Quote redleicester:
Compucase S411 rack Asus P5B-E Deluxe Q6700, previous Q6600 - Artic
Cooling Freezer 7 Pro cooler 4Gb Geil RAM
1x 80Gb SATA2 system drive for
XP32 and V64 1x 250Gb SATA2 Project drive 1x 250Gb SATA2 for samples 2x
500Gb SATA2 for more samples
1x Nvidia 7600GS 256Mb Silent PCIe for 2x 24"
TFT 1x Nvidia 7300GS 128Mb Silent PCIe for 2x 20" TFT
1x RME HDSP MADI PCI
running at 64 buffers for 1.3ms latency
1x TC Electronic Powercore Firewire
Dual Gigait LAN used for: 1x - NAS backup systems and MIDI-over-LAN 1x -
EuCon
Substantially faster than previous E6600 CPU, mucly helped by newer
coding in Nuendo 4 over Nuendo 3 (5% CPU usage in N4 over 16% in N3 at idle - was 30%+ in
N3 with E6600).
Still not quick enough for me, and possible to max out, but I
suspect I'm not representative of a "normal" user, given the I/O count (128 channels) and
requirements of music for media, plus the overhead from running EuCon.
Specifically chose Asus for the combination of good feature set with rock solid
reliability (had 20+ Asus mobos over the last few years, and never yet had a problem) - 6x
SATA ports, TI firewire chipset and dual Gigabit LAN were requirements.
Self
built and configured, not from retailer. Very stable, and exceptionally quiet, though not
a requirement as it sits in a rack in the machine room. Fine under both XP32 and V64,
though obviously plugin support for the latter, not to mention the Powercore are slow in
coming.
nickyquick
Loc: swiss alps
Re: Survey Of Working Multi-Core PC Music Systems
[Re: Martin Walker]
#555928 - 12/12/07 11:57 AM
This query from nickyquick about multi-core PC component choices and its replies has been
converted into a new thread so that it gets more traffic and replies. Here's the link:
www.soundonsound.com/forum/showflat.php?Cat=&Number=558214
MW
Edited by Martin Walker (17/12/07 03:02 PM)
nickyquick
Loc: swiss alps
[Re: Martin Walker]
#556933 - 15/12/07 08:17 AM
well i did want to come back and delete a couple of my posts to no avail.. a member told
me it's a bit formal around here.. no cheap fix seekers welcome.. but i'd thought that's
what this thread was for.. to help people.. anyway.. since I've apparently worn out my
welcome rather quickly.. as evidenced by the lack of further posts i'll just take my
leave.. it does make me feel rather important to have killed the thread all by myself..
lol.. and I'm still wondering if any of you actually make music with all these fancy
machines.. post a couple of links to you music please if we at least have that in common..
here's mine.. cheers.. thanks for the help.. www.soundclick.com/nickyquick.. www.soundclick.com/rapster.. www.myspace.com/rapstermusic.. www.myspace.com/nickyquick.. www.imusicscene.com/rapster..
PS.. I will indeed be back to post about my new machine as soon as it's built.. guess
that's all you wanted.. cheers..
-------------------- on the net:www.soundclick.com/rapster
Edited by nickyquick (15/12/07 08:18 AM)
Loc: Cornwall, UK
[Re: nickyquick]
#558233 - 17/12/07 03:13 PM
Don't be so hasty Nicky - you've not worn out your welcome at all. This is the first time
I've revisited this particular thread for a few days (I cover eight different SOS forums
as much as I can), and it is coming up to Christmas when everyone has loads of conflicting
priorities. Also, this thread is primarily intended for people to post the
specs of Working Multi-Core PC Music systems rather than queries about a possible new
system. So, I've created a new thread from your queries so it appears in the main area and
get more traffic and replies: www.soundonsound.com/forum/showflat.php?Cat=&Number=558214I suspect this will result in lots more replies for you. Hang in there  By the way, most of us do write lots of music with our PCs, but the SOS forums have a
dedicated Web Music forum so folk can post their links: www.soundonsound.com/forum/postlist.php?Cat=&Board=WEBThe
top sticky thread there has been running for years and contains absolutely loads of
member's web site links. Martin
-------------------- YewTreeMagic
nickyquick
Loc: swiss alps
[Re: Martin Walker]
#558840 - 19/12/07 09:05 AM
martin.. thank you.. for your patience and help..  I'll know
my way around here much better now..:-) I've ordered all the components.. some, like the
DP mobo are not in stock which tells me they are hot items lol.. hope to have it built by
the new year.. then i'll post the compatibility/performance info.. so I'm wishing you a
very merry christmas and a happy new year.. cheers..
nicky
Edited by nickyquick (19/12/07 09:06 AM)
S4410
new member
[Re: nickyquick]
#563034 - 03/01/08 05:31 PM
My system: Mobo: Gigabyte GA-P35-DS3 CPU:Intel Core 2 Quad Q6600 Ram:2gb Kingston ddr2 PC6400 Video card: Gigabyte 8500GT 256MB 2 Sata Hard
Disks:1x250gb Seagate ,1x500gb Westerrn Digital IDE Plextor dvd writer Scythe
Cama Cross cpu cooler Audio card:RME DSP9632(PCI) UAD-1x2(PCI) OS:Windows XP Pro SP2 Cubase 4.1,Wavelab 4,various plug-ins works
fine
KorgieMan778
[Re: Martin Walker]
#563308 - 04/01/08 12:24 PM
Hi! I use Pro Tools M-Powered 7.4.
I was just wondering - after reading
several threads about the Nforce4 chipset, I was a bit concerned about the following:
I use up to 16 instrument tracks, each with the free Expand! plug-in on
them.
With these instruments and plug-ins active (nothing is recorded on
them, yet), is it normal for the CPU meter displaying that it's peaking at 30%? When you
move the transport bar for instance, it moves a bit jittery (updates at about 15fps).
My setup consists of:
Foxconn K86100KMA motherboard
Nforce 410/6100-based chipset
Athlon 64 X2 4200+
2 GB PC3200 ram (double
channel mode - but defaults to 333mhz for some reason)
Windows XP Home SP2
Delta 410 soundcard (old PCI version)
Nvidia geforce 8800 GTS graphics card
any feedback would be greatly appreciated
cheers
-------------------- My Music Page:
www.soundclick.com/KnFn
Edited by KorgieMan778 (04/01/08 12:25 PM)
KorgieMan778
[Re: Martin Walker]
#563363 - 04/01/08 02:52 PM
Oops! It is the Foxconn 6100K8MA motherboard - my mistake! regards
AntiLuddites
[Re: KorgieMan778]
#563409 - 04/01/08 04:19 PM
Further to my positive comments on the Gigabyte GA-P35C DS3R.
The new 2.1
revision of the motherboard has both S/PDIF in AND out.
Note, no firewire
onboard.
DRUMZ
[Re: Martin Walker]
#570093 - 21/01/08 02:03 AM
Hello,I'm making a big leap from a pIII dual 1.0Ghz to: Motherboard : Asus P5K3
DELUXE wifi bios 0810 Processor : Intel QX9650 Memory : Patriot DDR3
1333 2Gb Graphics Card : Matrox Millenium P960 PCIe Audio Cards : Soundscape
Mixtreme (original)& Mbox1 DSP Cards : UAD-1 x 2 Case : Antec Take
4 modified for PSU PSU : Seasonic M12 700watts I'm moving slowly it
boots up with another video card,just waiting for the Matrox once I get that I'll put it
trough it's paces.It's been a long haul and i want to do it right.I would like to thank
the best Music Mag,SOS and the Staff plus all the people on this forum I really do
appreciate all the help and tips also support we give each other.  Peace
Out
Toaster
[Re: Martin Walker]
#570367 - 21/01/08 05:16 PM
Hi Guys,
Got my new machine built:
Q6600 quad Dp35DP MB 2Gb Corsair Cas 5 RAM 2 500Gb WD SE16 Drives 430w Seasonic PS Big Old
Antec Gaming Case with a 200mm fan in the top! 2 x 17" monitors (what fun that
is!)
Running SX 3.1 with Colossus, EWSO Gold, B4II, BFD and some other VSTi's!
It's running really well, and very quiet, I think it would be quieter in one of Peter's
cases, mayber after I've paid it off, I'll save up for one!
It does, once in a
while shut down for no reason, can't quite work it out, I ran MemTest on it, when I first
built it, for hours with no probs, I think maybe that when I chopped down XP with NLite, I
may have done too much, but it's not caused any sort of problems yet, just a little head
scratching!
Thanks again to all the guys (Peter and Martin especially) who
advised on my new build, well chuffed with it!
-------------------- 'What do you mean dynamics? I'm playing as loud as I can!'
Maxwell
[Re: Martin Walker]
#572440 - 26/01/08 06:58 PM
I have a question for those who have opted for Intel Core 2 Duo processors. Which chipset
these work on and does the CPU work well with Pro Tools?
I'm looking into
getting Intel Core 2 Duo E8400 3.0GHz (X38 chipset) so I will be able to happily game on
the machine as well.
Any feedback would be appreciated, thanks! This is my
first DAW build and I really want it to work out well
Edited by Maxwell (26/01/08 06:59 PM)
necromunger
[Re: Maxwell]
#572461 - 26/01/08 08:22 PM
hi
i whould look at using intel p31-p35 chipset for audio.
necro
Maxwell
[Re: Martin Walker]
#572473 - 26/01/08 09:09 PM
ok thanks necro ill look into that!
DRUMZ
[Re: Martin Walker]
#574553 - 31/01/08 06:54 PM
Well, after I set it up all seemed well until I tried to power down the computer and it
wouldn't it would just reboots.Then I powered it down took out the Soundscape Mixtreme
card boot it up,then shut it down it went fine.I guess what Paul said make sure the mobo
supports 5 volt PCI hardware.Also on the Asus site there wasn't any mention of the voltage
or PCI version,plus I've also emailed them but I've gotten no reply.
DRUMZ
[Re: Martin Walker]
#574569 - 31/01/08 07:23 PM
Sorry,I forgot I had to change the graphics card from the asus en8600 gt silent to the
matrox p690 pcie x16 since the asus is takes up 2 slots covering 1 of the pci slots.It may
just what some people need who want a single slot dual dvi card.  Peace.
markhodges
Loc: München
[Re: Martin Walker]
#574584 - 31/01/08 07:58 PM
A bit after the fact but I built the following about a year ago (except the case and PSU,
I just switched those last month):
Antex P182 Case
Corsair VX450
PSU
Asus P5B Deluxe-WiFi mobo
Intel E6600 dual core CPU
2Gb Corsair
PC2-6400 RAM
Artic Cooling Freezer 7 Pro CPU cooler
Gigabyte nvidia 7600GT
passively cooled graphics card
2 x 500GB samsung SATA drives
2 x 250Gb samsung
SATA drives
Sony CD/DVD drive & Matsui floppy drive / card reader
Windows
XP Professional
Creamware SCOPE home card + A16 converter
Presonus Firestudio
I did have a problem with clicks in the audio every 20-30 seconds, on both
interfaces, and even at quite high buffer settings (256 or 512 samples). This turned out
to be related to the intel SATA driver. I swicthed the drive interfaces to IDE in the BIOS
and the problem went away.
The other minor niggle is that the SCOPE card
only works in one of the two 'lower' PCI slots, and the third one is obscured by the
graphics card which is 2 slots wide, so I'll need a new thinner graphics card if I decide
to add some more DSP power.
The performance is great, I've set the scope
card to 64 samples latency and I can have my external synths + some creamware synths and
native VSTs all running into the cubase mixer with whatever VST fx I want to use + my TC
reverb and various plugins on the creamware card without a stutter.
Edited by markhodges (31/01/08 08:07 PM)
Nanno
[Re: Martin Walker]
#577275 - 06/02/08 06:20 PM
Working like a charm:
MSI K8T Neo2-F mobo, AMD Athlon 64 X2 4200+ (Toledo)
socket 939, 2 x Kingston ValueRAM PC3200 - 1024 MB, ASUS ATI HD2600 Pro graphics board AGP
x 8 (dual DVI), Echo MIA and Echo AudioFire 4 (via Dawicontrol firewire PCI-card with
TI-chipset), 2 x Samsung 320 GB SATA HDD
Edited by Nanno (06/02/08 06:21 PM)
Zaroff
[Re: Martin Walker]
#584216 - 24/02/08 08:54 AM
Just built this one, so far working perfectly. Asus Maximus Formula 2 x 2
Gb GSkill QX9650 2 x HD3870 Crossfire GC 4 HDDs Sata & Sata II RME
Hdsp 9632 Cosmos 1000 case & Real Power Pro 1 kW Very speedy, very stable,
very silent.
maggotspawn
Loc: Los Angeles, California
[Re: Martin Walker]
#588967 - 08/03/08 03:31 PM
MSI G33M, BIOS version 1.2 Intel Q6600 Quadcore G0 stepping 2 GB Mushkin DDR2
800 160 GB Western Digital SATA II HD 400 GB Western Digital SATA II HD Seasonic S-12 430 PSU Lite-On DVD Burner
Actually I just updated my mobo
and cpu, every thing else I had already. Had some minor problems: I couldn't load the
RAID/AHCI drivers at F6, I needed to slipstream XP with SP2 in order to load Windows.
Other then that the system flys. I did a minor overclock on stock voltage to 3 ghz.
Projects in Cubase that were hitting 90% cpu with an Athlon X2 4400 are down to 35%. Very
pleased, if one works with soft synths a quad core is a must...
BillC
[Re: Martin Walker]
#589986 - 11/03/08 07:45 PM
Asrock 4CoreDual-Sata2 LGA775 Via PT880
2 x Elixir 1024MB DDR2 667 PC5300
Memory
Intel Core 2 Quad Pro Q6600
2 x Radeon Sapphire 7000 (1 AGP, 1 PCI)
2 x Acer AL1706 and 1 Samsung syncmaster deluxe..
Sonar Producer 6/XP Home
Tascam US428
the MB/Processor/Ram was 225.49 from Micro Direct and went into an
existing system. It fired up first time no problem. Ran XP install and asked it to upgrade
the existing system. The only issue was that I needed to set /pcilock to get the startup
stable, the displays would disappear regularly otherwise..
Whoops, no /pcilock did
not save me, the system is getting the graphics cards confused on startup.... This is NOT
a working quad system... watch this space..
Edited by BillC (11/03/08 08:31 PM)
andrewm
[Re: Martin Walker]
#591079 - 14/03/08 02:57 AM
Hi
ive finally decided to build my own DAW and after much research and looking
at the successful systems on this thread ive decided on the following
Antec
Sonata Designer 500 case Q6600 quad processor Dp35DP Mobo 2Gb Corsair Cas 5
RAM 250Gb WD SE16 HardDrive 500Gb WD SE16 HardDrive I was also looking at
the emu1212m for an audio interface, which seems to be highly recommended and at around
£100 very good value.
So ive got the basics, but im unsure on a couple of
things. First of all the graphics card. I dont plan on using the pc for anything other
than audio work (ie gaming) so i dont want to spend massive here. Im also not sure on a
good cd/dvd drive. Any suggestions?
Being a student off to Uni in september im
looking for the best compromise between price and quality. However, i realise that a
stable, working DAW is the most important thing, so if there looks like any problems, or
anything ive missed, feedback would be much appreciated.
thanks Andrew
maxread
[Re: Martin Walker]
#591446 - 14/03/08 07:49 PM
I'm trying to get 3 x Delta 1010s to work at 96KHz with a quad core Q6600(!). After having
tried every trick in the book, the problem I still have is random clicks that occur even
when the system is not playing back audio (in other words they're not "drop-outs" ) but
seem more frequent when the CPU is under load. Very frustrating indeed. I've tried 2
different boards; Asus P5K Standard and a Gigabyte GA-P31-S3L with exactly the same
results. The 3 cards worked OK in a GA 3PXSL-RH AM2 (AMD Dual core) system at 96KHz
but I need more power! Any ideas anybody?
Oh yes, XP Pro with all the
latest updates etc. and tweaks, Cubase 4.1.3
lazyrich
member
[Re: necromunger]
#596183 - 27/03/08 03:41 PM
Quote necromunger:
hi
necro
Anyone got a successful system based on
intels P31 chipset? I'm trying to upgrade on the cheap, and it strikes me these might
actually be a better option then a cheap P35 as they do PATA without an additional chip,
so one less thing to cause problems.
Fibreman
[Re: Martin Walker]
#598170 - 01/04/08 11:38 AM
Being quite capable of bending spoons and stopping watches, I plumped for a dual core
system from Millenium Music:
Asus P5K-e motherboard Intel Core 2 Duo E6600
2GB Ram DDR2 800 Nvidea 8500GT 512Mb 80GB Windows Drive 320GB Audio
Drive Windows XP Home 19" Monitor with Focusrite Saffire Pro 26 i/o running Sonar 7
plus quiet case, quiet heatpipe cooling, acoustic
treatment on the case.
This is my first personal machine. Used to use the
band's old Pentium 3, hundreds of megahertz...
I'm totally happy with it. It
seems fast, mega stable, and most importantly given the small space I work in - and
provided you're not using the DVD drive - really inhumanly quiet, exceeded all my
expectations on that front. The Saffire preamps and AD/DA converters sound great, is easy
to use - only the Alesis i/o 26 really matches up to it, and that's a messy desktop unit,
natch. More extensive hardware/software metering on the Saffire would be nice.
It took a little bit longer to arrive than expected (4 weeks instead of 3), but to be
fair to Millenium that was down to availability of parts, and they sneaked it out last
minute before Easter, that was really nice of them!
I'd heartily recommend the
pro-build solution for anyone not confident in sorting their own out. I'd be quite happy
putting the hardware together, but for me I wanted the software to be utterly stable and
ready to go, at the end of the day i'm a musician not an I.T whizz. Spending all easter
sussing out the inner complexities of XP's inner sanctum isn't my idea of fun!
Zohar
member
[Re: Martin Walker]
#603179 - 12/04/08 03:24 PM
does anyone know the difference between the deluxe/pro/premium/e versions of the asus p5k
mobo? i was offered the pro version, and i think it fits my planed q6600 sys, but im not
sure. i need Firewire competability and this one has 2.
Also, is memory from
G.skill good?
Thx,
Z
v.a.s.t.
new member
[Re: Martin Walker]
#604218 - 15/04/08 03:44 PM
I have just build DAW with Core 2 Quad and IP35 chipset:
Intel Core 2 Quad
Q6600 (4x2.4GHz, 8MB L2 Cache)
Abit IP35 Pro P35 motherboard
DDR2 4GB
Transcend JetRam Kit 800MHz
ASUS EN8600GT/Silent graphics card
RME
Fireface 400
Windows XPSP2 with DAW optimizations
Cubase 4.1.3
So
far it seems to work perfectly even with low latency setup (128 samples on 44k).
Projects which had close to 100% CPU usage after unfreezing all tracks on MacbookPro
(Core Duo 2.16GB, running XP on bootcamp) now use about 30-40%
Spatchman
[Re: Martin Walker]
#605616 - 18/04/08 02:36 PM
Hi there, sorry this is my first post but I've just read all the way through this thread
and thought I'd post while it's still fresh in my head. About a year ago I
upgraded to duel core... Motherboard: MSI K9N-Neo AM2 motherboard nForce 550
Chipset CPU: AMD64 X2 3800+ Memory: 2GB Corsair DDR2 XMS2 6400 Graphics Card:BFG 7600GT 256MB PCIe Hard drives: 2X Seagate Barracuda SATA II
Drives. Optical Drive:LG DVD burner. Power: 400W Q-Technology (Not
Q-Tech) Fans: Nexus quiet fans Soundcard: Terratec DMX6Fire 24/96 PCI
Monitors: 2X Roland DS-30A 24Bit Digital This system worked fine and
I never noticed any excessive CPU use when working in Cubase SX 3.1. I wanted to keep the
DMX6Fire from my old system because it had everything I needed, I liked the way the
software control panel is layed out and it sounded awesome using the digital monitors
hooked up via co-ax. However, it wasn't until I started getting back into
playing the guitar that I noticed how bad the inputs were. I'm getting system noise
through all the inputs. The typical scratchy noises when you drag a window around on
screen and grunting and grinding when the HDD's do anything all combined with a constant
broadband wash. I use guitar rig and this broadband sound in the background
renders it barely usable, especially for recording. Just to be clear, this noise is
present through the Mic in, Line in, Phono in on the breakout box and even present on the
rear input on the card itself. I've tried A ridiculous number of things... Moved cards around... IRQ table showed all the pci slots were on the same irq with
the graphics card. Disabled and removed everthing that is possible... no
difference. Played with PCI latencies... No difference. Turned the
hardware acceleration down for the graphics card... no difference. Tried a
power supply conditioner... it may have removed a tiny amount of noise from the wall
socket but everything else is still there. Tried a new nexus power supply, no
difference. Borrowed my mates abit an9-32x motherboard which is tested as being
compatible with the 6fire... no difference! Tried screened sata cables in case
it was interference from that. Removed breakout box from case, coated and
earthed the lead from the pci card to the breakout box with a layer of copper and
aluminium tapes, then insulated it and earthed it to the case... No difference. Etc, I even tried praying. The only thing which had any difference was the
spread spectrum in the bios. I never knew what this was for until I tried it and it
basically reduces interference internally. Which lead me to think it was all
internal and nothing could be done. Further reading pointed towards the PCIe problem. I can accept that the soundcard is out of date and perhaps more modern ones will
have balanced inputs and better grounding and now I know more about it I am prepard to get
something a bit better. I'm prepared to pay extra for better inputs. I guess I've
learned that this card is no good with a PCIe motherboard but what concerns me is if I'm
going to replace it, will I just get the same problem again if I carry on using a PCI
soundcard? I've been looking at M-audio and such like. I know it's a tough
question but what would be better, an external USB audio interface or PCI... or PCIe? I'm
lost.
Zohar
member
[Re: Martin Walker]
#605951 - 19/04/08 03:10 PM
Got my new PC and its working great! Intel Q6600 Asus p5k premium
p35 mother b. 2x2048 ddr2 800 pc 6400 Ram by g.skill Grpe Point of view geforce
fx7600 gs 512mb graphics card Samsung 320gig HD HD321kj 16mb sata 300. 24'' wide
samsung monitor GHMX 73 Silentmaxx ita2767 box GHN 450w be quiat Strait power
BQT E5 windows xp home Takes all the old projects from my centrino laptop
with barely any sings of activity. Now i just have to find some interesting
projects to work on.......
Klockwerk
Loc: Central Ohio USA
[Re: Martin Walker]
#614759 - 12/05/08 07:51 PM
I'm posting this primarily because I believe this will be the last system I can build for
use with my parallel port MOTU MIDIExpressXT (verified working on long sysex dumps). Gigabyte GA-EP35-DS3R (p35 +ICH9R chipset) Q9450 2.66 Quad core (2 gig
Patroit 9600 DDR2 mem) MSI NX8600GT video + 2 monitors (1 in portrait mode) 1212m E-mu (love it, have another pc/1212m connected via ADAT) I believe this
is one of the last motherboards to include a parallel port (addon cards don't work with
the ExpXT). You can't buy a USB MIDIExpressXT from MOTU anymore, which makes me worry
about all my MIDI gear in the future. You can buy the parallel port adapter here - http://www.pccables.com/cgi-bin/orders6.cgi?action=Showitem&partno=07123&r
site=f.07123I'd give this system a huge, but qualified recommendation, as
you will need to update the BIOS to fix a latency problem.
I'm up on XPpro-SP3 using Sonar6p.
-------------------- Klockwerk
jayzed
member
Loc: North London
[Re: Martin Walker]
#616423 - 16/05/08 10:44 PM
Thanks to some great suggestions and help from people on this site I am now the proud
owner of this system:
CPU QX9650 Mobo ASUS P5E ASUS video, basically
a rebranded NVIDIA GForce 7100GS EMU 1820m PCI card for audio UAD-1e DSP plugin
card
I am currently running 2G of RAM, I had heard of problems using 4G with a
UAD card and didn't want to take the risk right away with a mostly new system.
I run Windows XP, recently upgraded to SP3.
I will say that at first I was
getting alarmingly high CPU temperature readings. Intel suggest a maximum of 65 deg C and
I hit this before actually running any apps. I decided to deal with this later, (possibly
by re-attaching the heatsink or maybe getting a different heatsink) and started working
with the processor throttled back to under 2GHz.
I should point out that these
temperatures were measured using CoreTemp (the free utility). The ASUS provided temps were
ridiculous - CPU at 21C, Mobo at 35C. Logically, this didn't make much sense as 21C
couldn't have been far from ambient in the recent heat.
Firstly, this machine
has stunning power compared to my dear departed, a 3.4GHz Prescott (which, incidentally,
ran over 70C most of the time). I don't yet really need the extra power. With my largest
projects from the old machine, I was hitting around 10-15% on all cores, even with the CPU
throttled back. I was actually going to get a Q9550 but couldn't get hold of one - I had
some work that needed doing so stumped up the extra cash for the QX9650. I'll have
to say, the extra power is not really necessary for me - I would have been happy with the
Q9550 or even the Q9450. I've always felt that overclocking was silly for music due to
stability and lifespan problems and also because it took time away from music to do the
fine tuning. However, it's stupidly easy to do basic overclocking with this ASUS P5E
board. Just for kicks, I ran the ASUS overclocking software and using only the auto
settings I can easily run this board at about 3.2GHz with temperatures no higher than 56C.
I easily run a 2ms latency on the 1820m without more than a 1-2 % increase in CPU from a
latency of 20ms, and that much increase in the CPU is intermittent! I have nothing to
worry about on the Delayed Procedure Call front, either - absolute maximum of 72
microseconds.
Which brings me to the interesting bit - it seems that my cooling
system works much better after being run for a week or so. I don't know if this is normal
but maybe it's that the heatsink compound I used, Arctic Silver, gets better with use? Or
maybe the temperature sensors need bedding in? Either/or, I'm quite happy about it as the
high temps were worrying me for a bit. I'd assumed I'd stuffed up on the heatsink mount
somehow, although like most newbies I suspect I put too much compound rather than too
little. Oh, I'm using one of those Ninja heatsink with piggyback mount fans and it's also
very good. Quiet and obviously, now, efficient.
Anyway, I LOVE this machine -
stable as a rock, except occasionally when running Kore 2 (par for the Kore-se:-)) as
either stand alone or plug, with everything else it's yet to have an untidy end to an app,
let alone crash the machine.
Another little story - originally I had decided on
a well thought of DP35DP Mobo and bought one but it was DOA (I guess I was unluckly
there). As I hadn't built a machine for nearly 10 years it was a bit of a nail-biter.
Anyway, thanks to help on this forum, I determined it was the board and went to buy a
Gigabyte 35 something but couldn't get hold of one quickly enough. Another suggestion from
the forums was this P5E. I can't say how grateful I am for the help and how happy I am
with this beast of a machine.
Stratt
Loc: Northampton, UK
[Re: Martin Walker]
#617118 - 19/05/08 11:42 AM
Hi all
I've just upgraded from Asus P4C800E-Deluxe with P4-3.2GHz Northwood
and ATI Radeon 9600Pro to the following:-
Motherboard: Asus P5K/P35 chipset
(4Gb Corsair 800MHz ram)
CPU: Intel E8400 Wolfdale (no overclocking)
Graphics:
Gigabyte 8500GT passive graphics.
Audio: 2 x Creamware Pulsar II/Scope Project, 1 x
Yamaha SW1000XG
Windows XP Pro installed with no networking at all. Nlite
used to slipstream SP3 and remove all but essential drivers and components. Only six
services running. Processor running at max 41 deg C, Zalman CNPS8700LED fitted.
Everything is SATA and no floppy. Disabled on-board LAN, Firewire, floppy controller and
JMicron Raid controller in bios.
Projects that would previously flicker at
around 50% processor usage are now registering hardly anything. No clicks or pops when I
move windows around while playing audio. So far stability is excellent.
Regards
Stratt
Edited by Stratt (19/05/08 11:46 AM)
Imran500
[Re: Martin Walker]
#618403 - 22/05/08 08:59 PM
Ordered a Dell q9300 2.5ghz Quadcore, 2GB RAM, 2x160GB HDs on Monday and to my great
suprise they arrived today! I've spent the day bunging programs on it in a
state of fear/excitement My old P4 2.8ghz with 2GB RAM was failing after : 4 instances of Line 6's Gearbox 2 Stylus RMX tracks (not instances just two
grooves) 3 instruments on Garritan Personal Orchestra. This new one has
been put to the test and let's just say it's like comparing the Millenium Falcon to a
wheezy old bloke on a pogo stick. So far : 4 instances of Gearbox 9
tracks (two instances) of Stylus RMX 7 instruments on GPO 5 instances of
Autotune 4 instances of Waves RChannel thrown in. Get this - it's
hitting 25-30% on the CPU meter!!!!  Frankly it's f*****g outrageous how much more powerful this is than my old
computer. Now I can sit back and comfortably get on with my rock-orchestral
compositions without worrying about things like bloody bouncing. I'd say to
any PC musician out there if you are upgrading forget dual core just go for the quad - you
simply won't regret it.
Richard Graham
Loc: Gateshead, UK
[Re: Stevie B]
#624716 - 09/06/08 01:39 PM
Cheap upgrade time.
Q6600 (£140), MSI P6NGM Motherboard with built in passive
graphics (£30), 2GB Corsair RAM (£30), 160GB SATA drive (£30). £240 inc. vat and
delivery. Case, audio drive, CD burner, soundcard, psu etc from old machine.
Job's a good 'un.
Works fine with XP, Reaper, NI Guitar Rig 3 NI Xpress Keys
etc.
-------------------- Battle flags are flown at the feet of a garden gnome.
Chaparazzi
member
[Re: Martin Walker]
#624735 - 09/06/08 02:37 PM
Working a treat (with a bios upgrade!)
Darc Studio+ PC
2.4 Quad
Core Intel DP35DP Main Board 4GB RAM XP Home PCIe Graphics
Motu 828 MK2
2xPCIe UAD (finally working with bios update)
Works a
treat!
Matt
-------------------- Amazing take, spot on, just perfect....right....one more time.
Mock Element
Loc: Newcastle Upon Tyne
[Re: Martin Walker]
#626774 - 15/06/08 10:52 AM
ASUS P5WDG2WS Professional 0905 Intel Core 2 Duo E6600 Corsair 6400C4 XMS2 4x1GB
Modules Radeon 7000 64MB PCI Graphics Card Siig 3 Port PCI Firewire Card Using
PCI-X slot Onyx 400F
All working fine. Would like to know the
impacts of PCI performance in comparison to PCI-Ex performance in terms of how the
firewire protocol is used. Would the bi-directional data transfer of PCI Express have any
benefits even though the bandwidth would be wasted on a FW400 interface?
Mostly
it is working fine, just need to use 256 buffers most of the time. If working at 96Khz the
latency is low 3 ms. If at 44.1K it is around 7ms. Would like to think I could get it
performing at a lower buffer size with less impact on CPU. Depending on the project it can
happen. 64 samples is an absolute no no. Immediate pops and glitches. Is it even
possible for a IEEE1394 interface to achieve such low buffer sizes?
DRUMZ
[Re: Martin Walker]
#626785 - 15/06/08 11:39 AM
Hey, Guy J imagine when you upgrade to a quad-core here you'll be happy for awhile.PEACE OUT
