rokuez
Loc: West Los Angeles
Atari the best midi triggering sequencer? Other Question's as well
#439805 - 28/03/07 04:09 AM
I have been reading a couple of post about the Atari with Notator and Cubase and I have
some general questions. When you respond to the questions please do so numerically so I
can tell which comment pertains to which questions. thanks. 1) With todays PC's
will the PC's timing ultimately become unstable once you are running tons of vsti's , FX
and what not? Basically the CPU gets overloaded to some extent to introduce timing
inaccuracy within the sequencing program? 2) I assume this timing instability
mostly occurs with high tempo drums , such as Drum n Bass percussion rhythms? 3) Is the atari, with the midi port expansions, basically the best Digitial midi
workstation for just handling midi? 4) Basically is the Atari the most rock
solid midi triggering sequencer that you can have? 5) If you are using an atari
to trigger a PC's VSTs, and two pieces of hardware that are being recorded into the PC via
a soundcard how can you keep the Atari timing? Sync it all via smpte? 6) If
you where using the Atari strictly for triggering , would u use notator or cubase and
why? 7) Is the Atari Falcon the speediest Atari you can get that will run the
last versions of notator and/or cubase for the atari? 8) If you are still using
an atari, or had used one please tell me about your rig and how you encorporated the
Atari. 9) If you had to buy an Atari rig , what would you get? Please include
all the extras such as midi port expanders etc
-------------------- E-mu Emulator Forum www.eiiiforum.com
David Etheridge
Re: Atari the best midi triggering sequencer? Other Question's as well
[Re: rokuez]
#439863 - 28/03/07 08:43 AM
Hi Rokuez, let's have a go at your questions: Quote rokuez:
I have been
reading a couple of post about the Atari with Notator and Cubase and I have some general
questions. When you respond to the questions please do so numerically so I can tell which
1) With todays PC's will the PC's
timing ultimately become unstable once you are running tons of vsti's , FX and what not?
Basically the CPU gets overloaded to some extent to introduce timing inaccuracy within the
sequencing program?
Yes.
From what I understand from the PC fraternity (and this was also mentioned in various
editions of Atari notes in SOS), the main processor iscycling away merrily looking at hard
drives, and connections to printers, the net, colour updates for the screen and 1001 other
internal things. Even when everything not essential to music making is ditched, there's
stil a helluva lot going on, and one of the problems with plug ins and VSTis can be the
order in which they're loaded. eg the setup won't work with plug ins A+B+C+D, but it might
do with B+D+A+C, or C+B+D+A, or a similar combination. What you may have to do is keep
reinstalling stuff until you get the right combination! So timing inaccuracies are
bcause the main processor's busy doing (many?) other things when it should be listeneing
to MIDI and/or audio.
Quote:
2) I assume this timing instability mostly occurs with high tempo drums ,
It can do, but basically any MIDI intensive data stream can cause
things to slow down: loadsa controller info such as volume, pitch bend, expression and
filter cutoff ALL AT THE SAME TIME and on the same MIDI buss. However, having said that,
using lots of mutliple MIDI outs on a system can help free things up quite a bit. And
don't even think of trying complete sound bank dumps within a song! Even my Atari stops
for a second to think about it, but that's the nature of the Sysex beast.
Quote:
3) Is the atari,
with the midi port expansions, basically the best Digitial midi workstation for just
handling midi?
Yes-but then
I would say that! Actually there's a story on the SOS site about using Ataris in studios.
The author (I think it was Paul Ward) said that one day he connected his humble Atari to a
Synclavier which masured the timing differences and showed the MIDI timing errors. Oh how
the Synclavier owner laughed at the evidence. Then some time later he connected up a then
state of the art Mac to the same Synclavier and checked the MIDI timing...... IT WAS
WORSE.
Quote:
4) Basically is the Atari the most rock solid midi triggering sequencer that you can
have?
Yes. End of story.
Quote:
5) If you are
using an atari to trigger a PC's VSTs, and two pieces of hardware that are being recorded
into the PC via a soundcard how can you keep the Atari timing? Sync it all via smpte?
Yes, and I would suggest using the
Atari as the master clock and the others as slaves. Using Unitor or Midex will solve this.
However, other folks here swear by using a hardware digital workstation such as a Tascam
2408 and then editing the finshed result on another platform. It's basically all down to
wht works for you and what you're happy with.
Quote:
6) If you where using the Atari strictly for
triggering , would u use notator or cubase and why?
I use Notator, because I use the score editing all the time rather than
grid eiting, and I like the pattern based nature of it which is very intuitive. It means
that you can break a song down into different sections (intro, verse, chorus, etc) and
just work on those sections. Cubase takes the 'non linear' approach and let's you record
tape machine style, where any track can begin or end at any point. Again it's what suits
you and your method of working. I'll also point out here that Cubase SX3 on a PC is a very
long winded way of working compared to Cubase on the Atari, and Notator is a much simpler
proposition than Logic on either a PC or Mac. The main point of the attraction of an
Atari is that the progs were written specifically with the Ataris memory limitations in
mind: it's lean, mean and there's no superfluous stuff. With PCs the embarassment of
riches that's the many meg (or even gig) of memeory means that all sorts of extra berlls
and whistles have been added that you may or may not need. A similat analogy may be
today's cars with satnav, electronic engine management, in car entertainment systems and
what have you: all very nice, but not actually necessary to get from A to B. And I
liemthe perversity of making great music using 20 year oild technology that doesn't
require endless tinkering and reinstalling jusy to get the damn thing to work!
Quote:
7) Is the Atari
Falcon the speediest Atari you can get that will run the last versions of notator and/or
Yes, but
Notator won't run on the Falcon. Logic and Cubase will do. A Mega STE will happily run any
of the sequencing progs and handle everything you care to throw at it. Tne TT is a nice
computer, but again, not everything will run happily on there.
Quote:
8) If you are
still using an atari, or had used one please tell me about your rig and how you
encorporated the Atari.
I
started off with a humble STFM with 1 meg that I still have and still works fine. I
started with Pro 24, the predecessor of Cubase, and it drove me nuts as it would crash at
the most unpredictable of times. I learned to live with it, but when I changed to Notator
and Unitor with 48 MIDI channels in 1990 I never looked back. In 2000 I upgraded again to
a 4 meg STE and added Log 3 which revved up the MIDI channel count to 96, and in the last
few years I've added even more synths: 20 at the last count. Notator drives them all
wonderfully, and I use Unitor to connect to a Fostex 80 multitrack tape machine (Who needs
'tape saturation emulators'? I have the real McCoy). Unitor is a totally brilliant,
reliable and idiot proof system that never lets you down.
Quote:
9) If you had to
buy an Atari rig , what would you get? Please include all the extras such as midi port
expanders etc
I would get
exactly the same all over again: a 4mB STE (the Mega STE's a wonderful beastie but the
harddrive fan can be noisy in the studio, although there are ways around this), running
Notator with Log3 and Unitor, and a hard drive system. I use the Syquest EZdrives, which
you can get for peanuts on ebay and I've never had one give me any problems. Ues,
even if I hard to start all over again I'd STILL go Atari!
Best wishes, Dave.
-------------------- Lots of Ataris which keep on going, 12 Kurzweil 1000 modules, a bunch of hardware synths. Still recording to tape -the old ways are best.....
Shingles
active member
Loc: Worcester, UK
[Re: rokuez]
#439993 - 28/03/07 12:00 PM
Here's another perspective: Quote
rokuez:
1) With todays PC's will the PC's timing ultimately
become unstable once you are running tons of vsti's , FX and what not? Basically the CPU
gets overloaded to some extent to introduce timing inaccuracy within the sequencing
program?
Yes, but that's not
all. Whn the PC is apparently doing nothing but output MIDI, there are background
processes running that have a fixed and higher priority than MIDI and so MIDI timing can
be affected.
Quote:
2) I assume this timing instability mostly occurs with high tempo drums , such as
Busy tracks and lots of CC messages can certainly lead to timing problems from MIDI
iverload, but the MIDI problems on Windows machines can affect the 'feel' and 'swing' of
basic four-step drum patterns when compared with solid sequencers. That's partly why I
ditched PCs for music a couple of years ago.
expansions, basically the best Digitial midi workstation for just handling midi?
Probably, but don't discount hardware
sequencers. For me, it's a toss up between my old Atari and a not-quite-so-old Yamaha
QY700.
have?
Probably, but don't
discount hardware sequencers. For me, it's a toss up between my old Atari and a
not-quite-so-old Yamaha QY700.
Quote:
5) If you are using an atari to trigger a PC's VSTs, and
two pieces of hardware that are being recorded into the PC via a soundcard how can you
Could do - or MIDI time code - but the VSTs will still be subject to
the timing problems of MIDI on a PC. And in this case, it's the timing on MIDI inputs to
the PC that is the problem, not on the outputs. Both Steinberg with their UMTS technology
in the Midex8 and Midex3 and Emagic with their MIDI interfaces addressed the timing on the
PCs MIDI outputs, but could or would do nothing about the timing jitter between incoming
MIDI messages and the arrival of those messages in sequencers, VSTs etc.
Quote:
6) If you where
using the Atari strictly for triggering , would u use notator or cubase and why?
Cubase, because a. I have it and b. I
know it.
Quote:
8) If you are still using an atari, or had used one please tell me about your rig and
how you encorporated the Atari.
Atari STE with Cubase and Steinberg Midex MIDI port expander. 15 Inch flat panel
monitor. Atari MIDI I/O to Axon AX100SB guitar to MIDI synth system. Midex MIDI I/O
to EMU E500Ultra sampler. Midex I/O to Yamaha AW16g digital audio worksatation for
Sync and MMC (Cubase is the MMC master, controling the transport of the AW16g. AW16g is
the sync master, sending MIDI timecode to Cubase). Midex MIDI output to Emu
Ultraproteus synth module.
Please include all the extras such as midi port expanders etc
See above.
-------------------- Nik
Godin, Axon, Tonelab, Repeater & the skin of my teeth!
rokuez
[Re: rokuez]
#440627 - 29/03/07 12:58 PM
Hmmm the info sounds good. Could you please answer back 1, 2, 3 order thanks. I definitely understand how even if the Atari is triggering the PC , the PC's internal
timing with triggering it's VST's and such could be off. <-- 1) There is for
sure no way to fix this syncing wise? I would just like to make sure because it is
demoralizing to know that the medium I record into , my PC, is innaccurate. Also to know
that when I take that sequencing load off of the PC by triggering it with the atari, that
I can't even record my 10 1/4 input tracks, and have it playing vsti's because at some
point it won't be accurate, sooner or later by too many tracks, fx, or vsti CPU load. 2) Also I've seen some post about people using a PCM card for a harddrive and
having the machine be a lot more silent? Care to fill me in a little bit . Could I do
this with the 4 mb Atari STE? 3) Is the Atari STE 4mb the one to go with
because all the notator and cubase program's version(s) run on it properly? All of the
latest Notator and cubase for atari can be run on Atari STE 4mb correct? 4) I've seen some websites (http://4mbste.atari.org/) for example that sell a 4mb
upgrade kit. So my question is this, If I where to buy a normal Atari ST from ebay, and
use this kit would I be lacking anything hardware spec wise from a normal Atari STE 4mb,
cpu wise , fron size buss wise type specs...? 5) Are PC's really an efficient
means of a large track recording medium, or sooner or later will they always foul
something up with CPU Load problems? I'm wondering because I have a RME Fireface 800 and
timing wise it seems like its on point. But i haven't loaded it up with a stress test to
check its timing accuracy. BASICALLY I'm wondering to have the advantages of the PC sound
plethora wise but to have its timing and hence sound never foul up the only for sure way
to do this would be having a separate machine other then the PC itself, recording its
audio. Hence the Atari would have its multiple midi outs , one for the PC, one
for the Drum machine, and one for the sampler . THE pc , drum machine, and sampler would
all be recorded by another machine ( say a tape machine, or a stand alone digital recorder
), slaved to the atari, with the atari triggering the PC , drum machine, and sampler. 6) I've seen some post that you can get an adapter to use the Atari on
a LCD screen. What adapter to you need, and what is the max LCD it will work for?
Shingles
active member
Loc: Worcester, UK
[Re: rokuez]
#440671 - 29/03/07 02:22 PM
Once again, my perspective may be different from David's, but:
Quote rokuez:
<-- 1)
There is for sure no way to fix this syncing wise? I would just like to make sure because
it is demoralizing to know that the medium I record into , my PC, is innaccurate. Also to
know that when I take that sequencing load off of the PC by triggering it with the atari,
that I can't even record my 10 1/4 input tracks, and have it playing vsti's because at
some point it won't be accurate, sooner or later by too many tracks, fx, or vsti CPU
load.
The PC is fine for
recording audio, and fine for triggering VSTs from MIDI internally. It is just not quite
so good when either triggering external sound modules from MIDI, or triggering its own
VSTs from external MIDI. It's the MIDI interface to the outside world that is the
problem.
I run my STe without a hard drive and it is silent.
Quote:
3) Is the Atari
STE 4mb the one to go with because all the notator and cubase program's version(s) run on
it properly? All of the latest Notator and cubase for atari can be run on Atari STE 4mb
correct?
Yes, so long as
you don't want to record audio on it. 4mb is just the memory size. 1mb is OK for most
things. I think maybe tha last versions of Cubase need the Atari to have 2mB
installed.
4mb upgrade kit. So my question is this, If I where to buy a normal Atari ST from ebay,
and use this kit would I be lacking anything hardware spec wise from a normal Atari STE
4mb, cpu wise , fron size buss wise type specs...?
To upgrade a normal STe 520 or 1040 to 4mB you
need 4 old fashioned 1mb memory simm modules. 32-pin I think. That site is just making it
easy for you so you don't have to hunt around on Ebay for som old simms.
There are
no other differences between a regular STe and a 4mb STe.
Older STF and STFM Ataris
are different.
Quote:
5) Are PC's really an efficient means of a large track recording medium, or
sooner or later will they always foul something up with CPU Load problems? I'm wondering
because I have a RME Fireface 800 and timing wise it seems like its on point. But i
haven't loaded it up with a stress test to check its timing accuracy. BASICALLY I'm
wondering to have the advantages of the PC sound plethora wise but to have its timing and
hence sound never foul up the only for sure way to do this would be having a separate
machine other then the PC itself, recording its audio.
The PC is fine for audio. So long as it is
configured right, you would have to have a LOT of tracks with a lot of processing for it
to start misbehaveing. It's the MIDI interface to the outside world that is the
problem.
Quote:
Hence the Atari would have its multiple midi outs , one for the PC, one for the
OK
Quote:
THE pc , drum machine, and sampler would all be recorded
by another machine ( say a tape machine, or a stand alone digital recorder ), slaved to
Just record the Sampler and drum machine
into the PC. No separate recorder required.
adapter to use the Atari on a LCD screen. What adapter to you need, and what is the max
The
adapters are available in a number of places. You can run any size LCD, but the resolution
will always be the 640x480 that is set by the Atari. On my LCD, some screen area is left
unused at the top and bottom, but it's much better than the old Atari monitor.
rokuez
[Re: rokuez]
#440957 - 30/03/07 03:46 AM
Quote: -------------------------------------------------------------------------------- THE pc , drum machine, and sampler would all be recorded by another machine
( say a tape machine, or a stand alone digital recorder ), slaved to the atari, with the
atari triggering the PC , drum machine, and sampler. -------------------------------------------------------------------------------- Just record the Sampler and drum machine into the PC. No separate recorder
required. ^^^According to what you said before however, the PC which is
having its vst's triggered externally by the atari would have its timing befuddled
correct? So the vst's would still sound off timing wise being that they are triggered
externally by the atari. Is this the correct setup to have no midi timing
issues; Have the PC triggering its own vsti's in its own sequencer program. Then slave
the PC with nuendo say to the atari via smpte (or MMC?), and still have the atari trigger
the drum machine and sampler being recorded into the PC. This would cause all
of the midi within the PC to be triggered properly, and it would cause all the external
gear to be triggered properly , and recorded properly right? Sorry if I'm
asking a lot of simple questions I'm a newbie to Atari's and to the whole midi thing in
general.
Shingles
active member
Loc: Worcester, UK
[Re: rokuez]
#440987 - 30/03/07 07:48 AM
Quote rokuez:
Is this
the correct setup to have no midi timing issues; Have the PC triggering its own vsti's in
its own sequencer program. Then slave the PC with nuendo say to the atari via smpte (or
MMC?), and still have the atari trigger the drum machine and sampler being recorded into
the PC.
This would cause all of the midi within the PC to be triggered
properly, and it would cause all the external gear to be triggered properly , and recorded
properly right?
Sorry if I'm asking a lot of simple questions I'm a newbie to
Atari's and to the whole midi thing in general.
Yup. That's about right. To get it as tight and consistant
as possible, I think in Nuendo and Cubase you can stripe an audio track with SMPTE. Give
that track its own audio output and sync the Atari to it. This way you can use external
MIDI sound modules and have no MIDI interface in the PC.
rokuez
[Re: Shingles]
#441137 - 30/03/07 01:11 PM
Quote Shingles:
Quote rokuez:
Is
this the correct setup to have no midi timing issues; Have the PC triggering its own
vsti's in its own sequencer program. Then slave the PC with nuendo say to the atari via
smpte (or MMC?), and still have the atari trigger the drum machine and sampler being
triggered properly, and it would cause all the external gear to be triggered properly ,
I'm a newbie to Atari's and to the whole midi thing in general.
Yup.
as tight and consistant as possible, I think in Nuendo and Cubase you can stripe an audio
track with SMPTE. Give that track its own audio output and sync the Atari to it. This way
you can use external MIDI sound modules and have no MIDI interface in the PC.
Let me just make sure I got
this right, sorry if it seems tedious.
1) The PC cannot trigger other pieces
of hardware precisely by outputting midi. Nor can the PC be triggered by an external midi
triggering source say the atari, maintain its vsti's audio precieness? <-- and this is
because varying amounts of CPU overhead-processing, which effects the PC's multiple
external midi output(s), or the CPU overhead interfers with the inward bound midi message
from the point when its received at the PC's midi input port, to when it actually reaches
the vst and makes it play a sound.
will be effecting when the
external midi message(s) gets triggered by the vsti.
2)
"I think
in Nuendo and Cubase you can stripe an audio track with SMPTE. Give that track its own
audio output and sync the Atari to it. This way you can use external MIDI sound modules
and have no MIDI interface in the PC. "
^^^ Maybe I do not simply
understand SMPTE properly but can you tell me if my interpretation is correct?
When you stripe an audio track with SMPTE that is like a click-track via 1/4
output to input which other pieces of gear say a drum machine can sync up to via a quarter
inch SMPTE input correct? When you say sync atari to it, are you talking about a scenario
where atari is the slave? That statement was confusing for me because I do not understand
the technical aspects of SMPTE used in conjunction with audiotracks. Could you please go
back over it in a more primitive manner please?
3) The Atari's
midi out has the PC slaved and synced to the Atari by the SMPTE's frame rate via a midi
cable. BUT The PC's midi melodies in nuendo for the VSTi's are programed/recorded in
Nuendo by midi tracks let us say , hence triggering the PC's vsti's internally but by midi
non the less <---- At this point the PC has no problem internally triggering its vsti's
by midi? Is this a difficult stress test to break?
3) Am I correct in saying
that by having the atari trigger the PC's vsti's, and having the PC record audio from
other gear (trigged by the atari as well) the timing would sooner or later not be solid.
<--- and this is because the PC handles triggering its VST's better when triggered
internally by nuendo's midi tracks rather than being externally trigged by the atari?
4) If number three is true. Then should I record the VST's melody into
nuendo having my main axe hooked up to the RME's midi in (or one of atari's out hooked up
to the rme's in) ? or should I just send the midi track data via atari to the PC via a
midi cable? I'm just kinda confused becuase if the PC triggers its own vst's internally
with more accuracy by having the midi coming from its own program then, it would be a
matter of slaving the PC to the Atari and just triggering the other outboard gear with the
atari, correct?
5) So Basically the Atari has nuendo slaved to it, hence
nuendo's midi tracks (internally triggering the vsti/ reason / or whatever mind you) , and
audio recording rate of the 1/4 ins are all step. Now I would want the drum machine and
sampler to not only be slaved to the atari, but also to have the atari triggering them.
Or should I just simply Trigger outboard gear with the Atari, and not even worry about
slaving the external sequencer of say a drum machine...?
6) I live in LA and
am going to post on CL looking for an Atari MEGA STE 4MB, what is the price range? What is
the price range for the notator and cubase dongles?
7) What is the name of
the VGA adapter so I can use a LCD with the Atari?
8) What is the largest PCM
card I can get to work with the Atari? This would effectively replace the harddrive and
quite down the machien, correct?
9) What LCD screen size would you say maxes
out the low resolution from the Atari? Say like a 21 in lcd is overkill for that
resolution , or perhaps a 17 in is perfect for that resolution and objects in notator or
cubase.
10) Can you use a trackball or modern day mouse with the Atari?
11) For the midi port expanders. One Expander say expander X will work in both
Cubase and Notator. OR will certain midi port expanders only work with one progam, like
ONLY notator.
12) Just to make sure the Atari STE Mega 4 mb system would be
the finest system just for running a midi sequencer program via notator or cubase.
13) Whats the latest OS that the STE atari should have? Whats the latest os for
notator and cubase (bear in mind i'm only using this for midi unless the new o/s's had
useful midi features along with their audio recording capabilities)
14) Is
there any difference between the 8 mhz and 16 mhz speed ? Do notator and cubase need to
be run in 8 mhz?
15) What is the resolution or PPQ of notator and Cubase?
16) Is it fair to say that because the atari has the built in midi port it
records your midi performance more accurately then say the akai mpc 4000 with its 960 ppq
resolution sequencer?
Basically I have an Emu SP 1200, an Emu Emulator
III giving me 10 quarter inch audio track inputs, as well as my PC running Nuendo, vsti's,
reason etc by an RME fireface 800 soundcard. I'm just looking for the most rock solid
timing for my system. All the advice and Any advice on how I should string it all together
is much appreciated.
Edited by rokuez (30/03/07 01:33 PM)
rokuez
[Re: rokuez]
#441179 - 30/03/07 02:48 PM
17) I read on another forum "Notator is supposed to be the tightest due to
the fact that it accesses the midi ports on a DMA level. Cubase was never as tight." [ http://www.gearslutz.com/board/showthread.php?t=58131&highlight=atari
] that Notator accesses midi ports at the DMA level, where as cubase didn't.
So Notator apparently was more precise and handled midi overall quicker. Is this true? 18) What are the most midi outs possible when using Notator? What are the most
midi outs possible when using Cubase?
David Etheridge
[Re: rokuez]
#441254 - 30/03/07 05:52 PM
Quote rokuez:
Yup. That's about right. To get it as tight and consistant as possible, I think in Nuendo and
Cubase you can stripe an audio track with SMPTE. Give that track its own audio output and
sync the Atari to it. This way you can use external MIDI sound modules and have no MIDI
You can do the same thing with Unitor and
Notator.
Quote:
^^^ Maybe I do not simply understand SMPTE properly but can you tell me if
is like a click-track via 1/4 output to input which other pieces of gear say a drum
machine can sync up to via a quarter inch SMPTE input correct?
Actually, no. It's much more precise that
that. SMPTE measures hours, mins, secs and frames very precisely and deals in the amount
of time elapsed rather than a particular tempo. This way you can have loads of tempo
changes in any piece and the tempo map via SMPTE will follow it exactly (to four decimal
places!)
Quote:
When
you say sync atari to it, are you talking about a scenario where atari is the slave?
Not necessarily. Syncing something
means getting them to run together, and which is the master and which is the slave is
entirely up to you. The Atari will be better for timing for all the reasons that we've
dealt with here and in other posts. It's doing just the one thing (MIDI sequencing) and
nothing else so there's no superfluous stuff going on in the processor.
Quote:
That statement was
confusing for me because I do not understand the technical aspects of SMPTE used in
conjunction with audiotracks. Could you please go back over it in a more primitive manner
please?
SMPTE timecode is an
electronic warble that's counting off time elapsed very quickly and precisely (as
explained above). Rumour has it that it was developed for the space program (firing your
retros excatly to time) but it's main usage is in TV and film work, to sync up video
recorders, audio track and everything else you can think of. When you stripe a track, that
becomes the master sync reference point, and everythign else will follow that and act
accordingly. I hope this explanation's a bit clearer.
Quote:
3) The Atari's
Not necessarily so. With Unitor and Midex the SMPTE code is output
through a seperate audio cable. Try thinking of it this way: The two programs are running
indepndently of each other, but the SMPTE code reference will tell Nuendo exactly how fast
to run to stay exactly in time with the Atari. Going back in time, SMPTE was used to
combine MIDI and audio on tape: You stripe one track of tape machine with SMPTE, and then
you can link it together with a computer to get the MIDI gear to run in time with the tape
and not have to record the MIDI gear's audio output to tape. Going back even further, you
could use SMPTE to control two 24 track tape machines and get them to run at the same
time.
Quote:
3)
Am I correct in saying that by having the atari trigger the PC's vsti's, and having the PC
record audio from other gear (trigged by the atari as well) the timing would sooner or
later not be solid. <--- and this is because the PC handles triggering its VST's better
when triggered internally by nuendo's midi tracks rather than being externally trigged by
the atari?
You've got me
there, as I still use nothing but hardware. Anyone else care to comment?
Quote:
5) So Basically
the Atari has nuendo slaved to it, hence nuendo's midi tracks (internally triggering the
vsti/ reason / or whatever mind you) , and audio recording rate of the 1/4 ins are all
step. Now I would want the drum machine and sampler to not only be slaved to the atari,
but also to have the atari triggering them. Or should I just simply Trigger outboard gear
with the Atari, and not even worry about slaving the external sequencer of say a drum
machine...?
I would trigger
everything from the Atari myself. In addition, I wouldn't bother trying to use the onboard
sequencer on a drum machine but simply use it as a sound module for drum sounds and
trigger that from the Atari.
Quote:
6) I live in LA and am going to post on CL looking for an
Atari MEGA STE 4MB, what is the price range? What is the price range for the notator and
cubase dongles?
It's probably
higher in the U.S. than Europe as Atari was far more prominent over this side of the pond.
Have alook on ebay and see what comes up. Better still, contactr Barrie at Keychange
(www.keychange.co.uk) who has all this stuff in stock and send worldwide.
Quote:
7) What is the
name of the VGA adapter so I can use a LCD with the Atari?
It's just called a VGA adaptor. Keychange do them,
so does Mario Beecroft in New Zealand. Barrie's price is around £15 /$30 ish, and they
work brilliantly. I use them myself.
Quote:
8) What is the largest PCM card I can get to work with the
Atari? This would effectively replace the harddrive and quite down the machien, correct?
Barrie can help you on this.
The Syquest EZdrives that I use are totally silent and (up to now) totally reliable!
Quote:
9) What LCD
screen size would you say maxes out the low resolution from the Atari? Say like a 21 in
lcd is overkill for that resolution , or perhaps a 17 in is perfect for that resolution
and objects in notator or cubase.
I find 17" okay. You can see the screen across the room as the text sizes are very
big compared to the midget stuff you see on PC and Mac resolutions. Remember that the
original Atari monitor was small in the extreme by today's standards. Anything bigger is a
bonus!
Yes. Atari did their own trackball which is now
rather rare but I've seen them come up on enay every so often, and there are PC mouse
adaptors also on the market.
X will work in both Cubase and Notator. OR will certain midi port expanders only work
with one progam, like ONLY notator.
Be very careful here. Basically Midex will only work with Cubase, and Unitor will only
work with Notator -although there is a file in Cubase to make use of the Unitor, but I
don't know of anyone who uses it. Some expanders are simple extra MIDI ports but (and this
is the important point) some expanders have th pogram dongle built in. The original Unitor
mk1 is the classic case here. The Mk2 has a seperate dongle port and works with Log 3,
which gives you another 3 extra MIDI outs and has the dongle built into it.
Quote:
12) Just to make
sure the Atari STE Mega 4 mb system would be the finest system just for running a midi
Yes, indeedy, and just to confuse you more, the Mega STE is supposedly
even better! This can have a hard drive built into the case, which may be noisy for studio
usage. Best stick with a basic 4mB STE for safety.
should have? Whats the latest os for notator and cubase (bear in mind i'm only using this
for midi unless the new o/s's had useful midi features along with their audio recording
capabilities)
TOS 2.6, which
is standard on mega STEs and can be fitted as a chip to ordinary STEs. You'll find that
the STE's own TOS will be fine for MIDI usage. For now, don't worry baout audio recording
on Atari unless you want to go down the Falcon route -and that opens up a whole new can of
worms!
Quote:
14) Is there any difference between the 8 mhz and 16 mhz speed ? Do notator and cubase
need to be run in 8 mhz?
You'll
find that the STE runs fine and I beleive the Megas run at 16mHz, but I'm not up to speed
on the full specs. Your Atari will be fine. I think there's more info on the FAQ sticky
thread at the top of the forum.
Can't answer for Cubase, but Notator
far and away exceeds the MIDI timing spec. That's one of the many things I love about it!
Quote:
16) Is
it fair to say that because the atari has the built in midi port it records your midi
performance more accurately then say the akai mpc 4000 with its 960 ppq resolution
sequencer?
Yes.
Phew!
David Etheridge
[Re: rokuez]
#441255 - 30/03/07 05:55 PM
Quote rokuez:
17) I read on
another forum
"Notator is supposed to be the tightest due to the fact that it
I believe so.
Quote:
18) What are the
most midi outs possible when using Notator? What are the most midi outs possible when
using Cubase?
Six in
Notator, using six inpdenet MIDI outs: the Atari's own one, two extras in Unitor (with two
extra ins) and three extra outs on Log 3. I think Cubase is slightly different. Any
takers?
Next questions please!
ThunderBall
Loc: Blighty
[Re: rokuez]
#441265 - 30/03/07 06:35 PM
I believe with Cubase you can run both the steinberg Midex(4 midi outs/2 midi in) and the
C-Lab Xport(modem port box 3 Midi outs) midi expanders,this would give you 8 outs in total
and 3 Midi ins,not sure on the timing/Reliability of the Modem port expander,though this
was supposed to be not as fast as the Unitor or Midex,but the Ataris are pretty rock solid
I doubt you'd notice any real problems unless running real heavy sequences
I
think notator can only handle 8 outs max(Log 3 Unitor and Clab Xport cartridges),although
with the Unitor combiner(which is an expansion which allows more xpanders to be routed
into into the same port),you could probably add more Unitor cartridges,for more Midi
outs/Ins????although not ever seen this being utilised,so can't vouch for it to work..
David Etheridge
[Re: ThunderBall]
#441275 - 30/03/07 06:54 PM
Hi Thunderball, Actually, Export wasn't very good timing wise because it uses the
modem port on the back of the Atari. While it's fine for oen MIDI output, it sweats a bit
with three. In fact the Notator manual recommends not using the Export extra two outs for
'time depndent material' (their words). I think this is why they developed Log 3,
which suffers from no such limitations. You can use all three for 9 MIDI outs (144
MIDI channels) if you're using Logic on the Atari, but very few people were mad enough to
do so (I mean use Logic, not 144 MIDI channels!) With earlier versions of Notator,
the Exprt outs were B, C and D, (A being the Atari MIDI out). From v.3.21 with the Log 3
support these are automatically re-mapped to the Log 3 outs, G, H and I. E and F are the
Unitor outs.
Hope this clears things up, Best wishes, Dave.
rokuez
[Re: rokuez]
#441410 - 31/03/07 04:07 AM
alright well it looks like I will go with the atari 1040 ste with 4 mb. I did get an
offer of someone selling me their "mega 4" is what he called it. I assume this has the
noisey fan for the internal harddrive? Also what is the difference between
Logic and Notator? Notator was for the 16 mhz ste mega? One more
questions I hope you guys can answer. If i have a SMPTE audio track which nuendo is
keeping time with, should I trigger the PC's vsti's with the atari , or by nuendo
internally within the PC? Also the SMPTE audio track comes outta the Atari
correct?
David Etheridge
[Re: rokuez]
#441432 - 31/03/07 08:23 AM
Quote rokuez:
alright well it
looks like I will go with the atari 1040 ste with 4 mb. I did get an offer of someone
selling me their "mega 4" is what he called it. I assume this has the noisey fan for the
internal harddrive?
Yes, an STE is
the one. A Mega ST would have been the earlier version of the Mega and some I beleive
(someone else correct me on this) were only 2 or 2.5 meg. The STE range are easier to
upgrade in memory using plug in SIMMs rather than having to solder them in. By all means
go and check out the Mega ST and see how noisy you think the fan may be if fitted-soem
Megas come without an internal hard drive.
Quote:
Also what is the difference between Logic
The difference is like having the Space Shuttle to go your local shops
in! It's supposed to be a 'logical' upgrade to Notator, but there's so much to get lost in
that you end up spending days exploring various setups and you forget what you wanted to
do in the first place. It can do a lot, but personlly I find it unbeleivably counter
intuitive. Remember that that's only my opinion, and obviously many others are using Logic
quite happily on other platforms. Mind you, you only have to look on this site to see all
the articles on how you fix this that and the other in Logic, and PC Publishing have
several books on Logic designed to fill in the gaps and eliminate the confusion (for
confused you certainly will be) about the whole program itself! Notator on the other
hand is relatively simple to understand and very intuitive. There's lots of help on the
notator website (www.notator.org) that explains all you need to know, and the notator
users group has lots of folks whocan answer your questions on all aspects of the prog. Notator was originally developed for the 520 ST and would run with only 1/2 a meg of
memory. Later versions would run happily on 1 meg, and the last version-3.21 would just
about run on a 1 meg ST(E). Ideally you should have 2 meg and up to run everything as it
has a tremendous amount of features that in the main work seamlessly. It's simply that it
will run quicker and cleaner on a 4 meg STE.
Quote:
One more questions I hope you guys can
answer. If i have a SMPTE audio track which nuendo is keeping time with, should I trigger
the PC's vsti's with the atari , or by nuendo internally within the PC?
I'd try both and see which gives the best results.
I'be inclined to go for Atari triggering myself.
Atari correct?
Yes, via the
Unitor SMPTE out if you're using Notator.
Best wishes, Dave.
feline1
active member
Loc: Brighton, UK
[Re: rokuez]
#441477 - 31/03/07 11:15 AM
The info on this thread might have been correct in about 1996, but not in 2007.
-------------------- ~~~ A weasel hath not such a deal of spleen as you are tossed with! www.feline1.co.uk ~~~
rokuez
[Re: feline1]
#441528 - 31/03/07 02:17 PM
Quote feline1:
The info on this
can you be more specific?
do you think the atari is the most rock solid midi sequencing program?
David Etheridge
[Re: rokuez]
#441569 - 31/03/07 04:51 PM
Quote rokuez:
Quote feline1:
The info on this
Ignore him. he'll go away.
.....and I don't think he's an Atari user either!
ThunderBall
Loc: Blighty
[Re: rokuez]
#441734 - 01/04/07 08:27 AM
Quote rokuez:
Quote feline1:
The info on this
do you think the
Yes...
Well put it this way...I've had 3
PC's in the last ten years,My Atari is still going strong in the studio,and I've lost
count the amount of times I've arsed about trying to put something right with the PCs,but
have never had so much as a squeak(that is if you include my Music ) out of the
ST,Whether its the best rock solid sequencer or not is a matter of opinion,but I doubt
you'll get a PC solution for the price of a train ticket!!!,
It beats any
comparible PC for timing imo,personally for me you wont find anything more solid,other
than maybe using a hardware standalone,and thats why many people are still hardcore users
of the ST...
feline1
active member
Loc: Brighton, UK
[Re: rokuez]
#441748 - 01/04/07 09:56 AM
I'm just pointing out that your generic handwaving criticisms of timing accuracy on a PC
may apply to Windows 3.1 with a Roland MPU401 interface etc etc, but it's not 1994 any
more. MIDI is protocol running at 31kbaud, modern gigahertz PCs (or Macs), with
a properly configured OS and modern drivers, can run MIDI perfectly well, you can get
interfaces with 16 or 32 output ports, you know! Keep up at the back there... Although personally, I do most of my sequencing on an Akai MPC4000. Moreover,
the Atari ST was no BBC B ... Mind you, we have two Sinclair Spectrums running here at Feline HQ...
David Etheridge
[Re: feline1]
#441802 - 01/04/07 01:37 PM
.......In answer to which I would refer you to other posts on this forum from folks who've
compared PCs and Ataris and found the Atari to sound 'tighter and more musical' when
sequencing (their words) when compared to PCs. Draw your own conclusions from this. Obviously it's down to individual perception, and I fully agree that you can have MIDI
interfaces with potentially thousands of channels. The point remains that for an
increasing number of posters here in Atariland, they're coming back to the Atari 'cos
they're fed up with their PCs. I work (if that's the correct term) with PCs at one of
the schools I teach at. These are running XP and Edirol modules through USB connections
and every week it's like trying to pull teeth just to get the buggers to even talk to each
other. The universal panacea seems to be to reboot, which quite frankly in 2007 is nothing
short of incompetence to my mind. And my Atari is still running happily for over ten
years since the last major crash!  Dave.
rokuez
[Re: rokuez]
#441839 - 01/04/07 03:15 PM
I'm looking at some pics of the atari mega, which someone has offered me. I am noticing
that the mega is more like a desktop version and it can have a keyboard that is attatched
to it ,rather then having the keyboard and the desktop as one unit. Like the atari 1040
ste. Could you please answer like 1 , 2 , and three again thanks. 1) If I buy this mega that I am being offered, can I use any keyboard with
it? 2) What is the longest chord I can have attatched to the mega? 3) With the Atari Mega can you take OUT the internal harddrive and replace it with a PCM
memory card reader? Thereby making the Mega completely quite. 4) What is
the PCM card reader you can have with the largest drive for an atari? 5) Ive
read about some atari's that have 16 mghz cpu's. Do they stil use the TOS o/s? 6) Are the 8 mghz cpu atari's more rock solid, then the 16 mghz atari's? 7)
For the atari mega's that had the " on board clock, optional Floating Point Co-processor
(FPU)" what exactly is that? 8) http://losangeles.craigslist.org/sfv/ele/303221001.html <--- could i
potentially buy that 520, upgrade it. And it would be no different then an Atari 1040
STE. 9) Just outta curiosity is the atari 1040 ste the atari that is most
optimized for running notator? why aren't the megas better? 10) For those who
ran cubase, logic , and notator did you really notice that notator was the most solid midi
program ? I appreciate all the info you guys! Also sorry ahead of
time for questioning you on wether to get the atari 1040 ste. I am just trying to get the
nicest Atari, memory wise, and Speed, and technical spec wise to run notator <-- which i'm
guessing must be the most rock solid midi program out there. . I just see all thse
others ones like someone offering me a mega, and then i read about the memory upgrades so
i'm not s ure what to do . wait and buy a 1040 ste, buy the mega and install the PCM card
drive, or get the 520 and install the memory upgrade, but i'm not sure if that would make
it the same as a 1040 ste. thanks
Shingles
active member
Loc: Worcester, UK
[Re: rokuez]
#441887 - 01/04/07 06:00 PM
Quote rokuez:
10) For those
who ran cubase, logic , and notator did you really notice that notator was the most solid
midi program ?
I'm not 100% sure, but I seem to remember a magazine - not SOS - proving that to be a
myth back in '93 or thereabouts.
Shingles
active member
Loc: Worcester, UK
[Re: feline1]
#441891 - 01/04/07 06:05 PM
Quote feline1:
I'm just pointing
out that your generic handwaving criticisms of timing accuracy on a PC may apply to
Windows 3.1 with a Roland MPU401 interface etc etc, but it's not 1994 any more.
MIDI is protocol running at 31kbaud, modern gigahertz PCs (or Macs), with a properly
configured OS and modern drivers, can run MIDI perfectly well, you can get interfaces with
Although
Moreover, the Atari
ST was no BBC B ...
Did they fix it in the last two and a half
years? I abandoned Windows PCs for music then for a hardware sequencer. At that time
Steinberg and Emagic were both selling MIDI interfaces with special time-stamping
technology built in to try to overcome this non-existant timing problem. They failed and
both products were withdrawn from the market.
Two years ago I was designing
soundcards for Windows PC and even then it was impossible to properly synchronise a MIDI
stream with an audio stream down USB 2.0 interfaces. And Microsoft had absolutely zero
interest in solving the problem, which is intrinsic to the Windows core.
David Etheridge
[Re: rokuez]
#441913 - 01/04/07 06:59 PM
Quote rokuez:
Could you
1) If I buy this
mega that I am being offered, can I use any keyboard with it?
I'm not sure. Some fixits have been available for
using a PC keyboard in the past, and I think they may have been mentioned on Tim's atari
MIDI world site (URL in the FAQs) Best check with Barrie at Keychange-he'll know.
Quote:
2) What is the
see above.
and replace it with a PCM memory card reader? Thereby making the Mega completely quite.
Quite probably. I think if you
look at the 'From old forum: Zip as main HD' thread, there's some info there.
Quote:
4) What is the
On theory at least a few gig, as folks on here
have built up to 5 gig hard drives, and I'm guessing the principle is the same. Anyone
know for sure?
Quote:
5) Ive read about some atari's that have 16 mghz cpu's. Do they stil use the TOS
o/s?
Yes.
Not more solid- the 16mHz models arejust rather faster in how they
work.
Quote:
7) For the atari mega's that had the " on board clock, optional Floating Point
Co-processor (FPU)" what exactly is that?
Dunno. My Mega STE has an onboard clock that date stamps files. Any
other Atari will tend to default files back to some date in 1987, if memeory serves. Back
to the future time!
STE.
Yes of course-but to save
aggro, wait for a fully loaded 4mB one to come up for sale.
Quote:
9) Just outta
curiosity is the atari 1040 ste the atari that is most optimized for running notator? why
No-they're bhasically all as good at running things. The Mega STE's just a bit faster
and has a few more OS tweaks. Nice to have but not essential to get you running.
Quote:
10) For
those who ran cubase, logic , and notator did you really notice that notator was the most
solid midi program ?
Not really,
each one has their fans. I love Notator, but there are folks here who are equally happy
with Cubase. Whatever lights you up, works!
You're very welcome-it's what this forum's
all about!
Very best wishes,
Edited by David Etheridge (02/04/07 03:42 PM)
David Etheridge
[Re: rokuez]
#442187 - 02/04/07 03:39 PM
Quote rokuez:
. I just see
all thse others ones like someone offering me a mega, and then i read about the memory
upgrades so i'm not s ure what to do . wait and buy a 1040 ste, buy the mega and install
the PCM card drive, or get the 520 and install the memory upgrade, but i'm not sure if
that would make it the same as a 1040 ste. thanks
Hi again Rokuez, just so you can be sure: Any STE can
be upgraded. I have both 1040 and 520STEs that have been upgraded to 4mB and they're
exactly the same-no problems, no differences. Most Megas that come up for sale will have
4mB fitted; the 2.5mB ones have usually by this time all been upgraded to 4meg. Have
a word with Barrie at Keychange on 00-44-1925-823334 and he can advise you all about PCM
card readers, silent hard drives and all the rest, and the chances are he'll have
everything you need right there and in stcok and can post worldwide- He's a real one stop
shop for all Atarians!
(usual disclaimer but without him we'd be well and truly stuffed)
-then grab Notator with all the great features that it has and you're up and away. By the way, once you've got it, give me a shout if there's anything I can help you
with.
Best wishes as always, and thanks to all who posted here on this
absorbing discussion.
rokuez
[Re: rokuez]
#442555 - 03/04/07 02:02 PM
1) How do I get the latest version of TOS? 2) Barrie at Keychange on
00-44-1925-823334 <--- i tried calling him, but i'm in the usa. is he in the uk? how do
you make an international dial , with that kind of number? what do you dial in front of
it? 3) http://qaa.ath.cx/vn/standrack1.jpg <--- is a picture of my setup.
I'm looking to put the atari in a rack space, where my soundcard is below my desk. I was
wondering if i could use the atari with another mouse and keyboard that could reach on top
of the yamaha kx88 keyboard. Is the 1040 STE Atari's keyboard attatched to its
main case? 4) I noticed the pics of the atari mega, make it look like the
desktop that houses the motherboard is separate from the keyboard and monitor. Would this
make it a better rack mounted atari for running notator and cubase? 5) I
recalled from a previous post in this thread that you said some of the o/s features of the
Atari Mega where additional but not necessary. Do they interfere with the running, timing
or anything with notator or cubase. do they cause bugs with those programs or vice
versa? 6) Is it worth it going all out and getting a 16 mhz atari? 7) What where the 16 mghz versions just the falcons? Could they run notator and
cubase perfectly? Or where they overblown for those programs? I'm kinda confused why
the 1040 ste is the best for midi programs, i would assume that 16 mhz would be better
especially if using a bunch of outs, and notes. Is my error just assuming newer is
better? 8)Does the Unitor 2, Log-3, Combiner midi expansion setup get kind of
bulky? I'm just wondering because of how my setup is i may want to go with the atari mega
4, get a long qwerty keyboard cable for to sit atop the kx88. 9) Why have
harddrives if u can just use PCM card readers? 10) Does anyone use their atari
in a rack situation? 11) Care to post any pics of your atari and how it is
placed as a sequencer , in ure other arrangements of gear? Do you work with the atari
right in front of you?
David Etheridge
[Re: rokuez]
#444627 - 08/04/07 08:08 AM
Hi Rokuez, Quote rokuez:
TOS2.06 is fitted as standard in the Mega STE, and you can get the TOS
chips for fitting to a standard STE. Barrie can tell you more.
Quote:
2) Barrie at
Keychange on 00-44-1925-823334 <--- i tried calling him, but i'm in the usa. is he in the
uk? how do you make an international dial , with that kind of number? what do you dial
in front of it?
That's the correct
international number for you; 00-44 will get you the U.K. over here we dial 01925-823334.
Easy!
Nice
setup you have there-I only wish mine was as tidy! Barrie does rackmount kits for the
MegaSTE, although you could put it on the desk itself. A Mega STE keyboard would sit on
your KX88 fine.
Quote:
Is the 1040 STE Atari's keyboard attatched to its main case?
Yes, it's an all in one box.
Quote:
4) I noticed the
pics of the atari mega, make it look like the desktop that houses the motherboard is
separate from the keyboard and monitor. Would this make it a better rack mounted atari
Correct. The main processor is a seperate unit. It probably makes things easier for rack
mounting, although the cartridge port (where you add the MIDI add ons such as Unitor and
Log 3) will need some though as to placement. You don't want them hovering in space with
no support.
Quote:
5) I recalled from a previous post in this thread that you said some of the o/s
features of the Atari Mega where additional but not necessary. Do they interfere with the
running, timing or anything with notator or cubase. do they cause bugs with those
programs or vice versa?
No, they
won't interfere with any operating, although having TOS 2.06 let's you run accelerator
programs like NVDI. There's some controversy with NVDI, as you have to install progs very
carefully or the progs won't run correctly. It CAN be done, but I gave up trying, as it
all turned out to be too much like PC optimisation. So relax and use the Atari as is and
everything should be fine.
Nice but not essential.
Quote:
7) What where the
16 mghz versions just the falcons? Could they run notator and cubase perfectly? Or where
they overblown for those programs? I'm kinda confused why the 1040 ste is the best for
midi programs, i would assume that 16 mhz would be better especially if using a bunch of
outs, and notes. Is my error just assuming newer is better?
The Falcon is a very nice machine. However, Atari
made a big mistake in not making it fully backwards compatible wth the ST, so a lot of
progs won't run on a Falcon. Notator won't, but Logic and Cubase do. Go figure! I'm
not sure that 16mHz is a factor you need to worry about unduly. Because of the stone age
(by today's standards) speed, you have to remember that the Atari's only doing one
thing-MIDI- at a time, so doubling the speed doesn't make that much difference as far as I
can see, certainly not with the MIDI side of things. What you will find is that saving to
disk and general housekeeping is rather faster, but that's fine and it won't affect how
well the machine actually does what you want it to.
expansion setup get kind of bulky? I'm just wondering because of how my setup is i may
want to go with the atari mega 4, get a long qwerty keyboard cable for to sit atop the
kx88.
No. Unitor anjd Log 3
protrude about 7" to the left of the cartridge port, while Combiner sticks out about 4" at
the back from the Modem port (But see the remarks earlier about why Log 3 is a vast
improvement on Combiner). Unitor/Log 3 are fiited to the cartridge port on the left hand
side of the computer both on the STE and Mega.
Quote:
9) Why have harddrives if u can just use PCM
card readers?
Not sure about this
one! Hard drives came first, most Atarians use them, and it's a case of developers making
the hardware to fit a card reder to the Atari. I'd be delighted to be proved wrong, but I
don't think that currently there's anyone who would develop an interface, simply because
the Atari music market isn't big enough to warrant it. If anone knows different, then let
us know here.......
Quote:
10) Does anyone use their atari in a rack situation?
Barrie would be able to tell you, as he makes the
rackmount kits. I preseume that someone must do!
how it is placed as a sequencer , in ure other arrangements of gear? Do you work with the
atari right in front of you?
I'll try and take a pic of my setup, but basically my STE sits on a table behind my
master keyboard, with a Squest drive to the left behind Unitor/Log 3 and the monitor to
the right.
Hope this helps, Best wishes, Dave.
David Etheridge
[Re: David Etheridge]
#445752 - 11/04/07 07:32 AM
Hi again Rokuez, Quote:
9) Why have harddrives if u can just use PCM card readers?
I've just posted a new link in the FAQ
sticky-there's a new project link there for compact flash cards for the ST that looks
extremely promising.
Best wishes, Dave.
rokuez
[Re: rokuez]
#541088 - 02/11/07 08:19 AM
My first atari!
I got 2 keyboards, 2 mouse,
1 color monitor, atari 4 mb mega ste, atari backpack.
The floppy drive is broken on the ste.
Please answer back 1, 2, 3
1.Where can I get a new floppy drive for the
ste?
2. Can any of u comment of hybrid arts, any god links about them for
info , smpte tracker sequencer. I know it was lacking function wise compared to notator,
but
3.when recording a musicians midi was it better at that?
4.
How difficult is it to get a Hybrid Arts MidiPlexer?
5. I take it , in this pic I have a Unitor I not a Unitor
II. I would need a Unitor II to use it in conjunction with the Log 3 to get the most midi
ports correct?
Edited by rokuez (02/11/07 08:25 AM)
David Etheridge
[Re: rokuez]
#541241 - 02/11/07 02:35 PM
Quote rokuez:
My first atari!
2, 3
1.Where can I get a new floppy drive for the ste?
Try Barrie at Keychange
(www.keychange.co.uk) who has them in stock and sends worldwide.
Quote:
2. Can any of u
comment of hybrid arts, any god links about them for info , smpte tracker sequencer.
Look at Tim's Atari MIDIworld; all the
info on these progs are there. Note that they won't work with Log 3 and Unitor, although
some of them will work with C-lab's Export, which fits in the Modem port on the back of
your Atari.
Quote:
I know it was lacking function wise compared to notator, but
3.when
Not necessarily- all the Atari sequencers are very tight, but simply work in
different ways. If you see the sticky on name acts who still use the Atari, you'll find
various musos who are/were happy with the programs they used.
Quote:
4. How difficult
They seem to be rather rare, but do turn up occasionally. Try Barrie again, or try the
Atari MIDI users group on Yahoo. Someone there may well have one for sale.
Quote:
5. I take it ,
in this pic I have a Unitor I not a Unitor II. I would need a Unitor II to use it in
conjunction with the Log 3 to get the most midi ports correct?
Yes, so that you don't blow something up in either
of them! Unitor 1 works fine with the last version of Notator (3.21) but you'ld have to
use an Export rather than Log 3, which isn't as fast as Log 3 itself. This is not a
problem with those units, just the nature of the modem port on the Atari.
Welcome to Atari land, and you have a great looking setup there!
Best wishes,
rokuez
[Re: rokuez]
#541263 - 02/11/07 03:32 PM
I appreciate the quick feedback Dave. I'm fairly certain that this this Unitor I and Log
3 have already been connected and turned on while plugged into the mega ste 1. Should I be worried? 2. Are they both busted? All three? 3. How do they break when one does that. 4. If they are broken (I hope the
Log 3 isn't which one breaks when they are both connected and turned on) how do I fix
it? 5. When I try running Notator I get these four bomb icons that pop up. I
understand this is in the manual I just haven't had a chance quite yet, sry. 6.
Anyone in california LA want to sell me a midiplexer(I already got a smpte tracker
dongle), notator manual, smpte tracker manual, vga adapter, or floppy replacement for the
mega ste?
David Etheridge
[Re: rokuez]
#541470 - 03/11/07 10:28 AM
Quote rokuez:
I appreciate the
quick feedback Dave. I'm fairly certain that this this Unitor I and Log 3 have already
Not
really.
Quote:
2.
I wouldn't think so. If the STE fires up to desktop, then it probably is okay. Now try
firing up with JUST the Log 3 and load Notator; if it loads up, it should be fine. Clean
the cointacts to the cartridge port and Log 3 and Unitor with isopropyl alcohol on a
cotton bud or Q-tip; sometimes the screen will freeze on loadup because of dirty
contacts. Now try booting up with just the Unitor and see if you get into Notator
that way. If they boot up fine, nothings' broken. The manual advises NEVER to plug either
Log 3 or Unitor in while the Atari is on. Indide them is an epoxied chip that verifies the
data, and I'm guessing that a power surge corrupts/erases(?) it. If the worst comes to the
worst you'll simply have to get another one (I've seen them very cheap on Ebay, and
Barrie's prices are very reasonable).
See above.
Quote:
4. If they are broken (I hope the Log 3 isn't
which one breaks when they are both connected and turned on) how do I fix it?
In a word, you can't as far as anyone knows,
because the dongle chip is sealed in nuclear bunker style! The folks on the notator users
site reckon that there's no-one left in the original company who can remember how it was
done!
Quote:
5. When
I try running Notator I get these four bomb icons that pop up. I understand this is in
This is one of those annoying Atari error codes
which I can't remember what it signifies. There are details on Tim's Atari MIDIworld
somewhere (I think) which says which number of bombs are which. Try e-mailing Barrie and
he can probably tell you. Try switching off, wait 30 seconds for the memory to clear, and
reboot, and it should go away. Report back if it keeps happening and we'll go from
there.
Quote:
6.
mega ste?
Try the Notator
users site for a manual download -I think someone there's scanned it. Otherwise sign up
for the Notator users group (www.notator.org) and see if anyone across the pond can help
you with that. The atari MIDI users group you'll find on Tim's site, and there will almost
certainly be someone there with the items you want.
Best wishes,
rokuez
Loc: West Los Angeles
[Re: rokuez]
#541864 - 04/11/07 09:29 PM
Status Update.  I got SMPTE tracker to open and run. The SMPTE tracker bugs me
how my floppy drive cannot be accessed but I just press cancel and it drop me into the
program. I hook up the hybrid arts dongle by powering it from the keyboard, and using a
cable that allows me to plug the dongle into one of the two modem ports.   I cleaned the contacts on the Log 3 and Combiner and when I
hook just the Log 3 up to the Atari and ran notator.prg I get these four bomb symbols, and
it crashes back to the folder. When I try to run Softlink it says not enough memory and I
must click on abort. Please respond back using 1, 2, 3… 1. Any idea why
notator is not running? I’m beginning to think that there are programs
starting up that are taking all of the available memory. 2. If this is a good
theory how would I check this out and free up memory? 3. Is there anyway to
turn up the mouse sensitivity in GEM? 4. The hard drive is quite noisy. I
remember reading a thread about a modification that can be done so that you can use a
memory card reader, with memory cards in place of the hard drive. Any link to this would
be greatly appreciated 5. After I order a floppy drive I’ve heard that some
chips can still be bad on the mobo, and they made need replacing. Any idea or link of
where to find out more about this? 6. Any idea of where to get a new fan to cut
down on noise? The power socket in the back is a little loose. If when I turn
the power switch on the Atari doesn’t power up I must lift the jack because the socket
is loose and then the power comes on. I’m also thinking about getting the internal
battery on the mobo replaced. This internal battery keeps the correct time. 7. Are there any Atari technicians in Los Angeles? I’m in West LA. 8. Can I just buy a Hi-Res SVGA Adapter from the local electronics store or do I truly
need a special adapter from keychange? I recently got a modem for the Atari.  9. Is it possible to hook up to the Atari to a lan line or a
router? Or is the modem the only way to get on the net?  Observe the cable that connects to the back of the modem and
then goes to a smaller jack at the end of the wire. This smaller jack is a modem jack.
To connect my Hybrid Arts SMPTE tracker dongle up I must use this very same cable and
connect it to the modem port on the back of the STE. 10. Is this the only and
proper way to connect the SMPTE tracker dongle the a mega ste? I remember
reading that when Notator was used with Expander, which connected to the Atari via the
modem jack, there where timing issues. I want to make sure that I’m connecting the
dongle to the right jack so that I don’t introduce timing lag. 11. Where
does the midiplexer connect to? 12. Can I just use a normal phone line as a
keyboard line extension, sense the keyboard uses a phone jack? As of now I’m
currently looking for the following please contact me if you have them and are interested
in selling Atari ST Hi-Res SVGA Adapter, Unitor II, Midiplexer
for Hybrid Arts SMPTE Tracker, Manuals for Notator, Manuals
for SMPTE Tracker, Trackball Mouse, Mouse chord extension,
and Keyboard Chord extensions.
-------------------- E-mu Emulator Forum www.eiiiforum.com
David Etheridge
Re: Atari the best midi triggering sequencer? Other Question's as well
[Re: rokuez]
#541889 - 04/11/07 10:51 PM
Quote rokuez:
Status Update.
I got SMPTE tracker to open and run. The SMPTE tracker bugs me how my floppy
drive cannot be accessed but I just press cancel and it drop me into the program. I hook
up the hybrid arts dongle by powering it from the keyboard, and using a cable that allows
You've been busy! There might be a problem with
the SMPTE track dongle, but I'm guessing. Just to rub salt into the wound, SMPTE track is
now a free download from Tim's Atari MIDIworld, called Edittrack: three different versions
and docs for download. Try http://tamw.atari-users.net/editrk.htm
and you'll get the
details. Now, when I downloaded it and tried the progs on my mega STE it wouldn't work at
all. I think that it doesn't like TOS2.06 which is fitted to mega STEs, so this may (only
may) be your problem here.
1. Any idea why
Have a
look at see if you have any accesories running. They'll be in the top left hand corner of
the screen under the Atari symbol. It's a sad fact that some Notator setups don't like
accesories unless installed in a particular fashion. http://www.notator.org will give more details on this. Also, have
a look at the downloads section and load some anti-virus software, which checks the boot
section of the disks. The previous owner might not have done this, so there could be some
crap on the disks that prevent proper loading. If in doubt, download the latest version
from the Notator website on a new disk and see how that goes.
Quote:
I’m beginning
to think that there are programs starting up that are taking all of the available
memory.
2. If this is a good theory how would I check this out and free up
memory?
This shouldn't be the case.
The last version of Notator (3.21) wil run -just- on a 1 meg ST, which is why I suggested
checking for accessories that may using using up extra available memory. Softlink should
give you a display of available memory; if less than 1 meg then something's up in the
memory chips.
Quote:
3. Is there anyway to turn up the mouse sensitivity in GEM?
When you get Notator up and running, you'll find a
feature called 'dynamic mouse' that should be what you want.
Quote:
4. The hard drive
is quite noisy. I remember reading a thread about a modification that can be done so that
you can use a memory card reader, with memory cards in place of the hard drive. Any link
to this would be greatly appreciated
Yes, there are spome around, but some of them connect to the cartridge port
which you need for the dongles, so that idea's not practical, unfortunately. I would
suggest a Syquest 135MB EZ drive which is silent and only makes a very little noise when
writing to disk. I use mine all the time and it's wonderful. You can get EZ drives very
cheaply on ebay, and Barrie can supply the connectors and software to run it with.
Quote:
5. After I order
a floppy drive I’ve heard that some chips can still be bad on the mobo, and they made
need replacing. Any idea or link of where to find out more about this?
Barrie again, he knows all about this stuff.
get a new fan to cut down on noise?
Barrie again.
Quote:
The power socket in the back is a little loose. If when I turn the power switch
on the Atari doesn’t power up I must lift the jack because the socket is loose and then
the power comes on. I’m also thinking about getting the internal battery on the mobo
Gte the power socket sorted, as any internal
arcing can damage the bits inside. A decent tech should be able to change the battery for
you, as it's only a coin type battery. You may even be able to do it yourself if you're
technically minded.
Try asking on Tim's site -he'll
know most of the Atari guys in the U.S.
local electronics store or do I truly need a special adapter from keychange?
I very much doubt the former, as the Atari
market is miniscule and probably not worth the trouble. Barrie does them and they're
fail-proof in my experience. You may find someone in the U.S who makes them-ask on Tim's
site.
Quote:
I
lan line or a router? Or is the modem the only way to get on the net?
I beleive that some folks have linked their Ataris
on networks to both Macs and PCs in the past. Look on the Atari launchpad site, which
should have details of web browsers for Ataris. Mind you, the info will be fairly
selective -you won't get cosmic colour grphics into a 4 meg machine without a lot of
clunking! Go to: http://gem.win.co.nz/hall/ for the full details.
Quote:
Observe the cable
that connects to the back of the modem and then goes to a smaller jack at the end of the
wire. This smaller jack is a modem jack. To connect my Hybrid Arts SMPTE tracker dongle
up I must use this very same cable and connect it to the modem port on the back of the
STE.
10. Is this the only and proper way to connect the SMPTE tracker dongle
the a mega ste?
Probably, but keep
in mind my earlier comments about STE compatibility.
Quote:
I remember reading that when Notator was
used with Expander, which connected to the Atari via the modem jack, there where timing
issues. I want to make sure that I’m connecting the dongle to the right jack so that I
Export goes into the modem port and offers three independent MIDI outs. Unfortunately,
because of the speed rate of the Atari modem, only the first of the three ports will give
you accurate timing. That's not to say that the others won't work at all, it's just that
they won't be able to hack drum parts with lots of 16th notes and stay in time. Things
will be simply happening to fast to send down the MIDI pipeline via the modem port. In
fact the Notator manual suggests not using the Export ports C and D 'for time dependent
material' (their words). Log 3 replaces Export and solves this at a stroke.
Quote:
11. Where does
the midiplexer connect to? 12. Can I just use a normal phone line as a keyboard line
I'm afraid that's outside my experience so I don't know. Barrie
might be the guy to answer that.
Phew! now you can go and have a cup of
something refreshing
-------------------- Lots of Ataris which keep on going, 12 Kurzweil 1000 modules, a bunch of hardware synths. Still recording to tape -the old ways are best.....
rokuez
[Re: rokuez]
#549403 - 24/11/07 01:14 AM
I just cleaned off the atari mega ste with simple green. It was pretty grimey I had to
get in there with Q Tips etc. Check the original image at the top of this thread to see
the before pic w/o the simple green. Here is the after image.  I also got in contact with The Ox that Rocks who has replaced
his mega ste's fan with one that runs at a lower noise level. I still have to get the
correct model number from him and then I will order that. He says his mega ste is
completly silent! I just changed the floppy pins from DS1 to DS0. Thanks
protek! 1. Can you please verify that my other jumper settings are correct? http://www.freewebs.com/computolio/SMD340.TXT . I have JUMPER BETWEEN 4 & 5 | MODE IS SWITCHED BY INTERNAL SENSOR (DEFAULT & JUMPER BETWEEN 2 & 3 | 2M MODE IS SET BY HDI = LOW (DEFAULT) Now When I boot up with the Atari the light comes on for the floppy drive and then
after a bit it recognzies the HD. It sounds like it is checking the drive for a floppy
drive. 2. Is this normal? Before I used to have to hit escape so
that it would stop checking the old broken floppy drive. After it boots up the
screen reads Unit 0 is Seagate Unit 1 is not responding 3. Unit 1 refers to another HD not the floppy? Now when I test the floppy
drive with some old floppy formated from XP it reads  4. Does anyone have links for software so that I can format a
floppy and finally get some things over to the atari from the net. I would really prefer
some software that can format a floppy on win XP for an atari. Current
setup  I'm thinking about getting PEST so that I can use a USB mouse.
5. Are there any other options or DIY links? I miss the look of the
old floppy face plate.  I tried to fit it on but it wouldn't go. 6. will
Armorall help out the atari mega ste at all ? 7. Where can I get the tos 2.06
chips? Do I just pop them in, or do I have to set jumpers / solder?
David Etheridge
[Re: rokuez]
#549528 - 24/11/07 04:39 PM
Hi again Rokuez,
you've been busy!
Quote rokuez:
I have
(DEFAULT)
I notice that
the site you quote is actually about settings for Amiga and not Atari, so be careful. If
everything's working as it should, fine. Mind you I know nothing about jumpers and all the
electronics bit inside. I just know which buttons to press on the top!
I would
suggest again checking with Barrie on this -he'll know.
Quote:
Now When I boot
up with the Atari the light comes on for the floppy drive and then after a bit it
recognzies the HD. It sounds like it is checking the drive for a floppy drive.
2. Is this normal?
Yes. With TOS 2.06 as fitted to the Mega STE it boots from the hard drive right away.
With some earlier versions of TOS you need a floppy disk with the right progs on it like
coldboot, where you press the rest button on the back, and it then boots from the hard
drive.
Have you gor any progs like HDutility? This will allow you to check your STE
for fitted hard drives and allow you to format and partition them.
Quote:
Before I used to
have to hit escape so that it would stop checking the old broken floppy drive.
Then I would suggest getting a
replacement drive.
Quote:
After it boots up the screen reads
Unit 0 is Seagate
floppy?
Could well be, unless the
previous owner had an external SCSI (or in this case ACSI) drive connected. As a guess
(and it is only a guess) I'd say there's some data on your internal hard drive from the
previous setup. As that previous hard drives not there any more, it's still trying to find
it, hence the 'not responding' message.
Quote:
Now when I test the floppy drive with some old
The 'not responding' message probably means that the floppy drive is shot. If you've
formatted the disks on your PC as DOS the Atari will read them fine -you don'ty have to
format them seperately.
Even so, there is a prog called DFormat (which I think is on
the Atari Launchpad site) that can format floppies with a PC boot file and Apple File
Exchange for Macs, if you need to do that.
that I can format a floppy and finally get some things over to the atari from the net. I
would really prefer some software that can format a floppy on win XP for an atari.
See above -you shouldn't need
this.
Quote:
Current setup
mouse.
Have a look at the FAQ sticky at the top of the
Atari forum here -the atari users forum will give you info on lots of hotrods and mods if
you're that way inclined.
Quote:
I miss the look of the old floppy face plate.
I
I think you'll find that most replacament drives need you to saw the
little loop out of the drive hole (bottom right on the aperture, and common practice with
replacement floppy drives). This was where the eject button used to stick out, and that's
why your drive plate won't go. While floppy drives from other manufacturers other than
Atari can be used, the eject buttons slightly different, so that's why you end up having
to carve the casing a bit.
Quote:
6. will Armorall help out the atari mega ste at all ?
It's just a plastic
cleaning/polishing solution, so it'll just add a shine to the casing. Don't get it inside
the works, however.
Quote:
7. Where can I get the tos 2.06 chips? Do I just pop them in, or do
If you have a Mega STE, you already have TOS 2.06. No problem.
Otherwise, I notice from the pics that you appear to have a colour screen. If this is
the case you're running in medium resolution and some Atari progs don't like this at all,
being designed to work in mono (black and white -it uses less memory).
So you might
want to consider a VGA or SVGA monitor and adaptor lead. The results are infinitely
better.
Best wishes,
Neo-Classical Guitar...
active member
Loc: Bradford, West Yorkshire
rokuez - check out these new bits of hardware...
[Re: rokuez]
#549586 - 24/11/07 09:01 PM
David Etheridge
Many thanks NCGM!
rokuez
[Re: rokuez]
#551692 - 30/11/07 07:57 AM
Thanks Neo-Classical Guitar Man. I believe I've found a solution for the loud Mega STE
fan with the help of The Ox that Rocks. He recomended http://www.papst.de . Once there go to the top right hand corner and
click on english. Now in the menu click on Products then compact fans. Finally click Go
to Products for the Axial compact fans & select your dimenion(s).
I've
been doing some thinking about storage mediums. CF Card, Satandisk, HD, & Paskud.
Are there any I missed?
1. I've read someone comment that you can only write
to a cf card 1,000 times?
2. I've read that Satandisk is slow?
3. What is the fastest to slowest? CF, HD, Paskud, Satandisk??
4. A CF
Card works by IDE to cf... cf what exact? I know of model No. STCI4402, then what you
connect a card reader? if so which one?
5. I'm trying to setup a notator
rig should I just go with a HD sense i'm going to have a very silent fan? Is a good
megaste HD fairly reliable and silent? Not an original granted. A HD will make sounds
when writting i.e saving/loading only?
6. Any specific recomendations for
atari mega STE hd's?
Edited by rokuez (30/11/07 07:59 AM)
