Doublehelix
Loc: USA
New Control Room Construction
#447882 - 16/04/07 02:55 PM
I have been building a new control room and iso room for my basement studio now for the
last 25 years (well, it just seems that way!). We tend to see a lot of threads
on "big" studios, but thought I'd post something that us "home" guys could relate to. I have finally given up and hired a contractor since there never seems to be
enough time in the day to get things done. Once these rooms are done, I am also going to
re-do the live room, so there is a lot of work ahead of me! Here is a **basic**
sketch of the plans. These drawings show some *REALLY* splayed walls in the control room,
but this is no longer in the plans. Also, some of the dimensions have changed, although
when I resized the drawing to fit on the screen for the forum post, it is pretty hard to
read the numbers anyway.
-------------------- James
"Never interrupt your enemy when he is making a mistake" ~Napoleon Bonaparte~
Doublehelix
Loc: USA
Re: New Control Room Construction
[Re: Doublehelix]
#447890 - 16/04/07 03:17 PM
This project has its share of "issues" as do all projects like this. One of the biggest
issues that I have had to deal with is the existing HVAC ductwork. The existing ductwork
needed to be accommodated, so some interesting compromises existed. Here is
quick pic of the existing ductwork which you can see at the top left of the pic:  This ductwork extends down about
6" or so below the floor joists, and makes the construction of a ceiling a bit
challenging. I do not want to lose that 6" all the way across the room, so I decided
pretty early on that I needed to frame in the ductwork so that the ceiling would be lower
in the front part of the room. Here is another of my famous "quick sketches" of what I am
planning for the ceiling. This picture is a side view of the room with the floor at the
bottom, and the ceiling at the top. The red line at the top is the proposed plan for the
new ceiling.
Doublehelix
Loc: USA
[Re: Doublehelix]
#447895 - 16/04/07 03:21 PM
The first thing I did was to frame in the studio-to-live room window:
Doublehelix
Loc: USA
[Re: Doublehelix]
#447901 - 16/04/07 03:33 PM
Next came the floor. After doing a lot of reading and researching, I decided
*NOT* to float the floor. From what I understand, if you incorrectly float the floor, it
is worse than not floating it at all. I decided therefore that I would create a solid
floor, and fill the area in-between the floor joists with sand to make the *VERY*
solid. This was not an easy task in a basement since it involved hauling a
couple of thousand pounds of sand down to the basement in bags, 50 lbs at at time!!! Ouch,
my aching back! The first step was to line the cement floor with a vapor
barrier. I used 6 mil plastic sheeting as the barrier, and sealed the seams between sheets
with silicone. I then shot nails through the floor joists into the cement floor. All the
floor boards are treated wood.  Next, came the sand:
Doublehelix
Loc: USA
[Re: Doublehelix]
#447903 - 16/04/07 03:47 PM
The next step was to install the sub floor. I chose 2 layers of 3/4" plywood as I really
wanted this sucker to be sturdy. I sealed each seam with silicone.
Doublehelix
Loc: USA
[Re: Doublehelix]
#447908 - 16/04/07 03:53 PM
The next thing I needed to do was to install the HVAC ducts for the control room. I
installed 2 exhausts and 1 return. I cut into the top of the existing ductwork from my
post above, and installed the sheetmetal joints. I don't have any pics of this part yet,
sorry. I will try to get some shots of it when I next get down there with the camera.
After reaching this step... Things came to a GRINDING HALT! I took a new
position with my job (same company, new position) that had me soooo busy with training and
learning the new job, that things stayed in this state for about 2 months.
That
is when I hired the contractor!!! As of this morning, things are finally moving forward
again!
As we speak, they are down there sawing and hammering their little
hearts out getting the framing done. Should be complete by tomorrow, and I will post some
more pics.
Doublehernia
Loc: omotion (come on, do the Loco...
[Re: Doublehelix]
#447916 - 16/04/07 04:02 PM
My God! This has been going on for ages! I remember when you first started posting about
the rebuild, Eric didn't have bits of carpet between his teeth, Max had a beard and I was
still a flaxen-haired youth in my prime.
New job - that explains it!
Anyway, a word of warning, stress to your contractors that they must not join things up,
just because it seems like a good idea. Almost every studio build I have ever come
across, some chippy sees two window frames that are separate and decides that things would
be far better with a bit of cross-bracing and BANG goes your separation!
Doublehelix
Loc: USA
[Re: Doublehernia]
#447953 - 16/04/07 05:14 PM
Quote Not that fool again!:
It is funny that you mention that
since I have really had to stress this point to them. So far, they have followed my rules
and plans to the "t", but have asked me a few times if a couple of nails here and there
would hurt anything. Of course I replied "YES"! I told them that only a *single point* of
contact anywhere in the construction ruins the entire isolation. They are listening to me,
but are shaking their heads. I am sure they think I am being overly paranoid, which is
fine. As long as I am paying them, I can be as paranoid as I feel fit!
As an
update, they have made pretty decent progress in a single day, and are probably 75% done
with the control room framing, and it is only 1:15 in the afternoon. It is looking pretty
cool!
I'll take some more pics this evening and post them.
Doublehelix
Loc: USA
[Re: Doublehelix]
#448079 - 16/04/07 08:12 PM
OK, here are a few pictures from todays framing work... In this first picture,
you can barely make out the door frame to the right.  In this second picture, you
can see how we framed in the HVAC ductwork at the top of the picture. The bulkhead is a
pair of 2x8's, which should be plenty to support the drywall. You can also see how they
added the inner wall and the second widow frame. There is about a 6 inch gap between the
walls.  In this third picture, you
can see a closer shot of how we framed the HVAC ductwork. Those ceiling joists are only
there to support the drywall as everything is free-floating. Therefore we made them 24" on
center rather than 16".  This last picture of the set is
intended to show the parallel walls, but it is not really all that clear. As mentioned,
there is about a 6" gap between the walls all the way around, and no part of the new walls
are touching any of the existing structure. ("Room-within-a-room" design)
Doublehelix
Loc: USA
[Re: Doublehelix]
#448095 - 16/04/07 08:35 PM
Next Steps: The contractors *were* going to construct the walls for the iso
room tomorrow, but as it turns out, it would be best if they waited for a few weeks so I
can get some of the wiring, insulation and drywall work done. They are
scheduled to come back in 3 weeks (March 7th) to hang the 3 doors, frame out the iso room,
and create the window frame. In the mean time, I have custom ordered two of the
doors, which means 14 days until they arrive. So during this three week period,
I am going to install all the audio cables (tons of soldering), jacks and wall plates, all
the electrical wiring and circuits need to be installed, and then comes the fun part with
the insulation and drywall. If I can get all that done in 3 weeks, I will be
pretty happy!  I have an electrician scheduled to come out this week to install
all the electrical wiring. I already have a dedicated 20 amp circuit setup in the live
room, but I plan on adding three more 20 amp dedicated circuits: 1) Control
room equipment 2) Iso room plugs (amps, etc.) 3) Lights That should
give me *more* than enough juice. More to follow...
Glenn Bucci
active member
Loc: Pennsylvania
[Re: Doublehelix]
#448204 - 17/04/07 03:04 AM
Very cool Doublehelix. I have actually been to his studio folks, or I should say the old
studio. It's about time you got rid of all that junk in the storage room which is now your
control room. I am very happy for you mate.
-------------------- revelationsoundstudio.com
Doublehernia
[Re: Doublehelix]
#448211 - 17/04/07 07:09 AM
Tip for James:
Put the audio cabling in a duct that you can open all the way
around and have separate ducts for audio and digital stuff. Leave loads of space for
future ducts that you might wish to add. (Though I' sure you knew all that anyway, but
it's always worth mentioning!)
Doublehelix
Loc: USA
[Re: Doublehernia]
#448349 - 17/04/07 11:24 AM
Put
the audio cabling in a duct that you can open all the way around and have separate ducts
for audio and digital stuff. Leave loads of space for future ducts that you might wish to
add. (Though I' sure you knew all that anyway, but it's always worth mentioning!)
Thanks for the tips, and
yes, I have a pretty good plan for that I hope, but every best laid plan seems to always
show flaws in retrospect, so keep the suggestions coming!
I also have plans for
a hollow conduit with small spring-loaded doors and insulation plugs into the iso room for
things like Leslie cables, or something odd that does not fit the plan.
All my
XLR panel mount plugs are all going to be converted to the Neutrik combo plugs (XLR *or*
TRS) which is much more flexible obviously. I have instrument lines, speaker lines, midi
lines and lots of Cat5 lines built into the plan, plus of course all the combo balanced
plugs mentioned above.
And as you suggest, each "type" of line will be in its
own conduit, and well sealed. I am also making sure that all of the electrical lines are
well away from the audio lines.
Doublehernia
[Re: Doublehelix]
#448376 - 17/04/07 12:19 PM
Quote Doublehelix:
. . . so
Lots of cold air for the machine room!
Space in the MR for guest
rigs?
Tie lines to other places and spaces?
Guitar amp iso boxes?
err, that's it for now!
Doublehelix
Loc: USA
[Re: Doublehernia]
#448412 - 17/04/07 01:19 PM
Yep!
Quote:
Space in the MR for guest rigs?
This is my home studio, no guests
allowed!!!
EVERYWHERE!!! Hehe... actually, a bit of overkill, but
ya never know, right? I am even fully wiring the air lock in case it gets called into use
(scratch vocalist/guitar amp???).
There are tie lines of every format going
from everywhere to everywhere!
Naw, haven't crossed that
bridge, and probably won't for a while. I haven't found the need for one so far, but ya
never know! I can always build one later if I feel the need.
The iso room is
really being designed more for amps than anything else. I have no need to isolate an amp
in most cases. There are times where there are multiple guitarists going at the same time,
and I have run amps upstairs when I really need to separate 2 guitars.
My
only slight concern is when I am miking a bass amp rather than going direct. If I use the
iso room for the bass amp, I would probably have to employ the air lock for a guitar amp
and put the scratch vocalist in the CR with me. Not ideal, but workable.
Quote:
err, that's it
for now!
Good stuff man,
keep 'em coming! Thanks!
Doublehelix
Loc: USA
[Re: Doublehelix]
#450652 - 22/04/07 04:01 PM
UPDATE:
The electrician came a few days ago and we mapped out the plan for
the electrical layout. As it turns out, it is more complicated than I thought, but that is
OK... I'd rather have it done right the first time.
I am going to do the
basic wiring, and then he is going to tie together all the ends.
One issue
that came up was trying to get junction and switch boxes that are deep enough to protrude
through two layers of 5/8" sheet rock, and still be able to firmly attach to the wall
studs. I was able to find some that fit the bill just perfectly, but they are a bit
pricey, and I needed 30 of them!!!
I am still trying to find a solution for
the wall boxes for the lights however.
Also, all the audio cable, connectors,
and wall panels will arrive tomorrow, so this next week is going to be a wiring and
soldering week. Yuck! I am so sick of soldering, and I have got about 5 million solder
points to do in the next 3-4 days.
I'll post some more pics later this week
as I get things going.
Glenn Bucci
active member
Loc: Pennsylvania
[Re: Doublehelix]
#450752 - 22/04/07 09:18 PM
Have you considered a new circuit breaker in your elecrical box for the room?
Doublehernia
[Re: Doublehelix]
#450822 - 23/04/07 07:49 AM
James, you might concider adding 'blank' electric cables that are marked at both ends for
future installations like additional lights.
Also possibly, limited tie lines
to rooms in the house.
Doublehelix
Loc: USA
[Re: Glenn Bucci]
#450954 - 23/04/07 12:44 PM
Quote Glenn Bucci:
Have you
From an earlier post:
Quote Doublehelix:
I have an electrician scheduled to come out this week to install all the electrical
wiring. I already have a dedicated 20 amp circuit setup in the live room, but I plan on
1) Control room equipment 2)
That should give me *more* than
enough juice.
Doublehelix
Loc: USA
[Re: Doublehernia]
#450956 - 23/04/07 12:51 PM
for future installations like additional lights.
Hmmmm.... I see where you are going
with this, but they would end up being buried by the sheetrock, so how will I remember
that they are there in the future? Also, how would I decide on where to run them?
Fishing cable later is not my cuppa, so I think it is a great idea on the
surface, but not sure how it would work out in the implementation.
Quote:
Also possibly,
limited tie lines to rooms in the house.
Now this is a GREAT idea! I hadn't thought of that, but
this is amazing! Thanks!
I can see myself needing a couple of mic lines in
case I want to mic a guitar cabinet with 2 mics, and then a third balanced XLR line for
the guitar signal (cable extenders convert the instrument signal to line level signal), so
I am guessing a 4-pair ought to suffice with Neutrik combo jacks.
Thanks for
the great suggestions! Really helpful!
EDIT: HEY!!! This was my
2,500th post! It's almost like a birthday or something!!!
Edited by Doublehelix (23/04/07 12:54 PM)
Doublehernia
[Re: Doublehelix]
#451311 - 24/04/07 07:26 AM
Well congratulations James (I think!)
I do not mean that you should have to go
fishing for cable in years to come, what I meant was that if you are running say three
cables to a set of lights, throw in another two that are just blank and marked at both
ends. Then, later, when the neons are just not right, you can quickly and easily add two
circuits of indirect lighting - or whatever rocks your boat.
Same goes for
AC, heating and anything else knocking around. Installation cable is cheap, but adding
circuits after the event is not!
Tie-lines - what about computers? At least a
network cable so that you can work on an edit or be exporting files and rubbish like that
whilst watch television in the evening.
That’s it for now, though I’m
sure I’ll think of more.
Doublehelix
Loc: USA
[Re: Doublehernia]
#451379 - 24/04/07 10:41 AM
I do not mean that you should have to go fishing for cable in years to come, what I
meant was that if you are running say three cables to a set of lights, throw in another
two that are just blank and marked at both ends. Then, later, when the neons are just not
right, you can quickly and easily add two circuits of indirect lighting - or whatever
rocks your boat.
Makes better sense now, and is a good idea.
I was actually down there last
night installing junction boxes and doing some wiring, and it is a real pain even without
insulation and sheet rock!
computers? At least a network cable so that you can work on an edit or be exporting files
and rubbish like that whilst watch television in the evening.
I actually already have network
cabling throughout the house. I wired the whole place back in the days before wireless! I
have Cat5 tie lines going to all 3 floors of the structure, so I am already covered
there.
Quote Not that fool
again!:
That’s it for now, though I’m sure I’ll think of more.
Keep 'em coming! Thanks!
By the way... "Who are you???" You know me by name, but I am not sure that
I know who you are. Did you change your alias from something else??? I feel like I should
know who you are, but as old age sets in, the first thing to go is the mind...
Studio Support Gnome
Not so Miserable Git
[Re: Doublehelix]
#451595 - 24/04/07 05:20 PM
think Scotland
think grumpy. (occasionally, sometimes also Brusque,
Pessimistic and Blunt.... )
Then don't refer to it again.... just
enjoy.
-------------------- if you don't know who i am, i aint gonna tell you.
Doublehelix
Loc: USA
Quote Max The Mac (C.S.I.):
think
Scotland
Ahhh!!! Got it!!! Say no more! Good clues!
Quote:
Then don't refer
to it again.... just enjoy.
Refer to what??? I have no idea what you are talking about...
Doublehelix
Loc: USA
[Re: Doublehelix]
#451952 - 25/04/07 12:51 PM
Over the last few days, we have made a lot of progress, even though *visually* things
don't look that different. We have been wrapping and insulating the HVAC
ductwork and copper plumbing... the copper pipe wrap is more to prevent condensation than
anything else... The electrical wiring is also almost complete, although I am
still struggling to spec out the appropriate lighting fixtures (I have another active
thread going on that one if anyone wants to add something...). Here are a
couple of closeup pics showing the junction boxes that I needed to use so that they would
stick out through the drywall enough to be able to layer 2 sheets of 5/8" drywall. For
those of you who are "math challenged", This means that 1 1/4" of the box needs to stick
out past the edge of the wall stud. These boxes are *really* deep, and have screw mounting
holes on the sides instead of nails. As it turns out, these boxes are harder to
find than I thought, and a bit of a pain to install. They have a small metal tab on one of
the corners that does not allow the box to mount flush to the wall stud when using the 1
1/4" overhang So for each box, I had to route out a small notch of the stud in order to
get the box to mount flush. You can barely see it at the bottom of the second picture.   Next up... Audio
cables (solder-city) and finish the HVAC ductwork, and somehow spec out the lighting
fixtures.
Doublehelix
Loc: USA
[Re: Doublehelix]
#452183 - 25/04/07 10:40 PM
Here is a question that I just thought of based on a comment Max made about compromising
the integrity of the sound proofing layer:
Should I be using surface-mount wall
plug junction boxes rather than having them mounted to the studs and sticking through the
dry wall??? This would apply to lighting switches and light mounting schemes as well.
I am all of a sudden concerned that I am going to be creating HUGE holes in my
soundproofing using the method I am currently using.
HELP!!!
[Re: Doublehelix]
#452225 - 26/04/07 01:05 AM
let me put it like this.
I'm in the process of building my new place,
having moved late last year.
ALL my electric services are surface
mounted. there's just one cable inlet in each room, where the main power supply enters
the building.. and where it's parallel enters the workshop/live area. I'm routing data and
audio cables thru the discretely hidden ventilation system .
All services are
trunked on the surface, but it will be arranged so that it's all hidden behind acoustic
treatment devices, except where unavoidable, or desired.
absolute bare minimum
diameter holes, JUST big enough to pass a cable/cable bundle through... No holes in
straight lines between rooms.... and all sealed up tighter than a duck's nether regions...
each build is unique , and there are a range of techniques that are available
to the designer... and it's applying those techniques in the most effective manner, that
really decides how the end result will perform....
it's attention to
detail.....
the larger the holes and the larger the number of holes
you cut in your sheet rock, the greater the risk of it seriously adversely affecting the
performance of your walls.
there ARE fire and acoustic rated hoods and rear
assemblies , but it's simpler, and more cost effective in most cases, to simply not cut
those holes in the first place. Especially as many of those "acoustic rated" hoods,
really aren't much use.... there's a WORLD of difference between what we studio
denizens consider effective, and what domestic installers consider effective...
a little common sense, and some devious planning , making the space and acoustic control
devices work FOR you in terms of aesthetic concealment , and tasteful mountings is all
that's really required....
When pondering how it's done, in "LARGE"
establishments...... where all these nice brass switch plates are set in to the wall,
you need to remember that the wall you see is usually NOT the soundproofing...
in smaller places, like yours , and mine ( no offence intended) other techniques
need to be used.
Max
Doublehelix
Loc: USA
[Re: Doublehelix]
#452230 - 26/04/07 01:27 AM
Damn you for being so right!!!  I was thinking about your comments on the lights, and all of a sudden it hit me that I
am going to be cutting a bunch of holes in the sheetrock to run both electrical *and*
audio lines. I also remembered Rod's words in his book about even a small gap
at the bottom of the sheetrock by the floor that goes unsealed is the same as making a 6
inch hole in your wall. Your comments make a *lot* of sense, and I think I am
going to have to take a step or two back and rethink a lot of the wiring issues. A true thank you Max, your words are truly words of wisdom (you must have heard them
from someone else!!!  ).
[Re: Doublehelix]
#452267 - 26/04/07 08:17 AM
mate, that's WHY people pay me to do their studios for them.  Max
Chris Poulter
new member
Loc: Petersfield
Do you have enough height to put in a suspended ceiling? I've just put one in to use as
a huge basstrap and it makes stuff like lighting much easier.... You don't need
that much extra space - would have though 6" is enough to get what you need in. Plus you
can stuff it with rockwool for extra trapping like I did. Chris
-------------------- Freelance Producer / Engineer | www.hernestudios.co.uk | FREE Listening sessions - see www.thelisteninggroup.org
Doublehelix
Loc: USA
[Re: Chris Poulter]
#452352 - 26/04/07 11:13 AM
Hey Chris:
I am severely cramped for ceiling space, so a suspended ceiling
won't work for me. I am using a resilient channel design instead which allows me to keep
most of my ceiling height.
Blue Lizard
member
Loc: Cleethorpes, UK
[Re: Doublehelix]
#452480 - 26/04/07 02:53 PM
+1 on the surface-mounting option; my room is walled with double-plasterboard/barrier-mat
sandwich on resilient bars (even my studs are on neoprene, and the res-bars screwed
through neoprene pads to the studs!) and I used trunking and surface mount boxes (MK) for
all my electrics and lightswitches ( pic ). Looks very neat
You'll need some double-length cavity fixings to secure the boxes, and just make sure
you mark where your studs are... you don't want a cavity fixing to connect with one and
scupper the isolation of your inner wall.
-------------------- "It's not pretty, also you can't dance to it." - Frank Zappa
www.bluelizardstudio.com
Edited by Blue Lizard (26/04/07 02:58 PM)
Doublehelix
Loc: USA
[Re: Doublehelix]
#455843 - 03/05/07 01:34 PM
Well, I haven't updated this for a while, so I thought I'd give an update. Have
been busy wiring (both electrical and audio) which should be done by this weekend. (I hate
soldering) I have opted to go for PUTTY PADS which
are a fire stopping product that wraps around the backside of the electrical boxes.
Apparently they are awesome at stopping sound transmission through the all boxes. Maybe
not as good as surface mounts as Max suggests, but nonetheless, I have decided to go this
route. It is on order, and should be here today or tomorrow. I have also
completed installation and insulated all of the HVAC ductwork, which was a total pain. I
am glad that part of the job is done! The contractor is due back on Monday to
finish framing out the iso room and the air lock, as well as widening the existing air
lock door frame from 32" to 36" in anticipation of the custom doors that still have not
arrived!!!  Starting next week, the wall construction begins in earnest. I have on order: -3 cases of Green Glue -2 cases of acoustic caulk
(OSI SC-175) -Backer rod -Putty Pads for the electrical boxes as above -Lights Unfortunately, the local vendor where I previously bought my Owens
Corning 703 rigid fiberglass no longer deals in OC products. Dang! They are now almost
exclusively a Johns Manville Dealer. They are offering this product as a replacement to
the OC 703: SPIN-GLASHas anyone had a chance to use this stuff, and
can you comment on it? More pics coming after this weekend! Thanks!
Doublehelix
Loc: USA
[Re: Doublehelix]
#469238 - 04/06/07 08:53 PM
Well, it has been a month since I updated this thread, so I thought it was time to post
*something* so you don't all think I am a *total* slacker!!! Since my last
post, all my doors are in, and all the wall materials are in (4 cases of Green Glue --I
needed 4 instead of three, acoustic caulk, backer rod, putty packs, etc.). I
have also finally finished all the electrical wiring!!! Woo-hoo!!! What a pain in the
rear! Since all of my lighting is going to be surface-mount, I had to wire each lighting
fixture with a dedicated lead rather than daisy-chaining them together. All told, I used
over 500 feet of 12/2 wire for the three rooms!!! I am almost done with the
audio wiring, which seems like is taking forever! All of the HVAC is now
complete, including a whole new fresh air return for the live room. As soon as
the audio wiring is complete (later this week), we will begin the process of insulating,
and then FINALLY, the drywalling! I will try to post pics as these things
develop, but the last few weeks have been very hectic, with a week-long holiday, plus
planning a graduation for my son, etc. Hopefully, we can pick up the pace again now! Anyway, here are some more pics: New ductwork with
extensions to stick down through the 2 layers of drywall (There will be 2 exhausts and a
single cold-air return in the control room):  Control Room cold air
return:  This shows some of the
insulation on the existing ductwork:  Here is the new cold air
return for the live room:  Wiring, wiring, everywhere!  Here are a couple of the boxes that I
made for my audio wiring bays. I have a couple of other large "square" boxes that I made
as well. All of the other audio wiring will terminate in "standard" wall plates.
Doublehernia
[Re: Doublehelix]
#469239 - 04/06/07 09:03 PM
Just don't give yourself a double hernia!
Doublehelix
Loc: USA
[Re: Doublehelix]
#496698 - 05/08/07 02:49 PM
OK, I know it has been a while since I have updated this thread, and I apologize. I have
been busy with several remodeling projects at the same time, plus the "real job", the wife
and kids, etc., so it seems as if the studio is always pushed to the bottom of the
list. Most of the recent work has been involving wiring anyway, which is not
very exciting to photograph! Anyway, the wiring is done (except for one wire
that I did not plan for, and I needed to order some more as I was short, and a few more
putty pads that are also on order), and we have moved into the insulation phase, with
drywall to follow this coming week. Here are a few pics: This picture shows some of the wiring. Notice the area where the audio cables are in
close proximity to the electrical cables. This is the one are in the entire project that
has this "problem", and I am a bit worried about it. (I have a whole other thread on this
topic going here). There is about 6 inches of space between the wires (the same gap as the
wall gap). You can also see some of the putty pad work on the wall boxes.  Here is
another wiring pic. As you can see, I have run out of putty pads, and have more on order.
Should arrive in a day or so. The red arrow is pointing to an additional ground wire that
I have installed on the studio wall plugs as a star grounding system (isolated ground).
This wire is in *addition* to the normal ground wire in the electrical cable. I used a 12
ga. THHN wire from all of the receptacles that are then tied together at a separate ground
panel, and then finally tied into the main ground. (Thanks to Rod's book for the
drawings.) I also added another copper ground stake that is driven 8 feet into the ground
out in the yard, and tied this into the breaker panel. The existing wiring was grounded to
the copper water pipes in the structure, and I wanted to have things more firmly grounded
than that.  This pic shows the
resilient channel that I had to use on the ceiling on the back half of the control room
ceiling. This is the only part of the construction that is not free-floating, but I really
needed the ceiling space, so I opted to go with resilient channel for this one area.  This shot shows
some of the insulation work that has begun:  More
insulation:  This shot
shows one of the Cat6 headphone stations, and is a pretty good shot of the putty pads.  The
insulation will be completed this weekend except for those areas that still need putty
pads and the one area for the new wire that I have on order. Then we finally
move onto drywall!!! Yipeeee!!!!
Doublehelix
Loc: USA
[Re: Doublehelix]
#501080 - 13/08/07 12:16 PM
Another small progress report, and a few more pics. It seems like we are working so hard,
but the progress is not as quick as I would like it... Such is life. We added a
few more audio wires and finished all the putty pad work, then it was off to "insulation
hell" for a couple of days. I hate insulating, let me tell you! Anyway, these few rooms
are quite well insulated! I have insulation stuffed anywhere and everywhere, it is
probably a bit of overkill in a few areas, but I am thinking that it is better to have too
much rather than too little, eh? Anyway, here are a few pics: This first picture shows the outside wall filled with insulation, and the
inside wall still just bare studs:  One of the side
walls:  In this picture,
insulation has been added to the inside wall:  More
insulation! (Did I mention that I hate insulation?)  Here you can see the
other side of the control room, with the door opening just visible on the left:  Here is the ceiling
with resilient channel on the back half of the CR:  Here is the a closeup
of the window frame so far:  And now the window
frame with an insulating layer of neoprene rubber around the inside:  Here is the airlock.
The door opening to the left leads to the control room, the door opening to the right
leads to the iso room.  Believe it not, we are
ready for drywall! I have been saying that for about 6 years, but we are actually going to
begin with the drywall as the very next step. Wish us luck!!! We are gonna need
it!
Doublehelix
Loc: USA
[Re: Doublehelix]
#502072 - 14/08/07 08:52 PM
Look at this picture of the layout of my resilient channel on the ceiling. While doing some reading on resilient channel use, it seems pretty important to make
sure that the drywall screws do not go into the wall (or ceiling) studs. Did I
install the RC in the wrong direction? Should I have hung the RC so that it is arrayed
perpendicularly to the support boards (parallel to the floor joists) rather than the way I
have them now? Will that be strong enough? See the pic below:
Doublehelix
Loc: USA
[Re: Doublehelix]
#502700 - 15/08/07 10:26 PM
Anyone with any comments on the RC?
Steve Hill
member
Loc: Oxfordshire
[Re: Doublehelix]
#502896 - 16/08/07 10:05 AM
No, you've done the RC right (or at least the same way I did it!). Screw the drywall to
the RC in between the ceiling timbers and you should be fine.
It's a good plan
to mark the position of the ceiling timbers on the walls as you go along, so you know what
line to avoid!
It's looking good.
-------------------- Dynamite with a laser beam...
