ghc
Well, yeah, again, electric shocks from mics !!
#576976 - 06/02/08 06:21 AM
Hi everyone !! Ok, if you are interested(and it is, i'm advising to read through it,
plenty of good info) i've posted this discussion before on 24/08/07 ''Electric shock from
mic while touching guitar, ......'' I just came across the same problem a while ago,
last week !! My mixer was plugged in to a socket in the wall, so as musicians, but
spread in different corners, different sockets (all on the walls). And, to stop the
mic from being electically charged, all i had to do was: Plug out my mixer which was going
to a socket in the wall, and in the same socket (on the wall) i plugged in an extention
lead, and then i plugged in the mixer in the extention+vocalists guitar ?! Sounds
strange to me but it worked !! Could anyone explain to me (and to all of us) why did
it work ?! I just can't understand it !! Lost !!  Thanks
guys !!
-------------------- Don't blame the world
Find a solution !!
SOS Technical Editor
Loc: Worcestershire
Re: Well, yeah, again, electric shocks from mics !!
[Re: ghc]
#577000 - 06/02/08 09:24 AM
Assuming the guitar amp was properly earthed, then by plugging the guitar amp into the
same mains extension as the mixer, you ensured their earths were at the same potential,
and thus no shocks.
I suspect the socket that the guitarist was using
originally had no earth, or a very poor earth.
There really is no excuse these
days for not checking each and every mains socket used in every venue with a simple socket
tester to make sure they are wired correctly and are safe to use.
It is also a
much better idea to run everything from the same socket or adjacent sockets, to reduce the
risk.
Hugh
-------------------- Technical Editor, Sound On Sound
Sheriton
Loc: Leicester, UK
[Re: ghc]
#577025 - 06/02/08 10:07 AM
Call me extremely pedantic...
It's very rare that a mic will ever give you an
electric shock. It's almost always the fault of the guitar / amp; it's only by touching
the earthed mic that this becomes apparent. It always winds me up when people blame the
mics rather than the true cause...
-------------------- There's nothing we can't face... Except for bunnies
Paul Soundscape
[Re: ghc]
#577029 - 06/02/08 10:10 AM
i dont think it has anything to do with the amp. i played at the colston hall in
bristol and i even had problems there, and my equipment is certainly earthed! It was
that our amps were plugged in to a different circuit to the mixing desk
-------------------- Live Sound and Studio Engineer
Loc: Worcestershire
[Re: Paul Soundscape]
#577042 - 06/02/08 10:41 AM
Quote Paul Supersonix Studios:
i
To be fair, it is most usually a problem associated with a
disconnected earth on guitar amps (to kill the hum, man!).
Quote:
my equipment is
certainly earthed!
I'm glad
to hear it, but can you be as certain that the socket you plugged it into is properly
earthed, or that the equipment, sockets, mains cables and plugboards that everyone else
uses are properly earthed?
The only way to be sure and safe is to test the
mains sockets you plan to use before using them, and check that everyone's equipment is
earthed correctly before allowing them to plug anything in.
Quote:
It was that our amps
Then there was a potentially lethal fault
somewhere in that building. The difference in earth potential between sockets should be no
more than a volt or two at most. To feel a shock when touching an earthed mic suggests
that an earth was missing from the singing guitarist's rig. If that's the case, then he is
playing on borrowed time....
Hugh
Paul Soundscape
[Re: ghc]
#577102 - 06/02/08 12:57 PM
yeah well as hundreds of professional touring chart topping artists play there every year
you would have thought that it would be properly earthed? maybe not,
the reason i
said it wasn't the guitar amp was because i was getting shocks(and i play bass and sing)
and so was our guitarist(who also sings) and its never happened before?
Edited by Paul Supersonix Studios (06/02/08 12:59 PM)
Loc: Worcestershire
#577112 - 06/02/08 01:24 PM
year you would have thought that it would be properly earthed? maybe not,
The first rule of not dying is to not make
assumptions like that. Faults happen. Things can change. When we rigged for some SOS
seminars at the old Wembley Arena site, I found four faulty sockets in the same conference
room -- a room that was used everyday by all and sundry. One socket had no earth, two were
live-neutral reversed, and one just had no power. It happens! Often, the screws clamping
the cables inside work lose or tarniosh and oxidise. Sometimes they weren't done up tight
in the firtst place, and as the cable oxidises the connection goes high-resistance. That's
all that's needed to make the safety earth next to useless! Sometimes someone else has had
a major fault and the cable or the socket has been damaged but not reported to be fixed.
Hence my advice to check them before using them.
Quote:
the reason i said it wasn't the guitar amp was
because i was getting shocks(and i play bass and sing) and so was our guitarist(who also
Were both your amps plugged into the same mains extension plug
board by any chance? Or the same wall socket? If so, you've probably just identified where
the missing earth was.
Clearly, there was a serious and potentially fatal
fault somewhere. It could have been the earths protecting the sound desk, or it could have
been the earths protecting the guitar and bass amps.
In my experience,
shocks when touching a microphone are almost always because the mic body is properly
earthed but the guitar amp's earth is disconnected, so that the 'earthed' metalwork on the
amp (and guitar string earthing) floats up to half mains voltage (115V).
You
won't feel that while playing as long as you don't touch anything else earthed, but the
moment you do, you'll get the shock.
Now the missing earth might not be
because the safety earths in the amps have been deliberately disconnected -- it could just
as easily be because a mains cable or extension board has been damaged, or the wall socket
could be faulty, as I've explaiend.
It's a less common scenario, but
certainly still one worth investigating, that it could equally have been the other way
around -- the guitar amps were properly earthed and it as the mixing console earth that
was at fault. In that case, the mic's body would have floated to 115V, but you would have
got the same tingle effect through the grounded strings.
Sadly, without all
the same equipment set up in the same room in the same way, we'll only ever be guessing
what the actual problem was. But it would be foolish to dismiss it and not check
everything you can carefully.
As I said, the location of that discontinuous
earth (or earths -- there could be more than one fault here) could be at any of a variety
of places. The wall sockets, the extension cables, the mains plugs, the mains cables, the
pluig-boards, or inside the equipment itself. The only way to be sure is to check every
single mains cable you used, every extension cable, and every piece of equipment.
In fact, this really is something you should do regularly anyway. Cables get
snagged and cut, or tripped over pulling the wires from the plugs, and screw connections
inside plugs can work loose and wires corrode and oxidise.
If they all
check out okay, then it was probably the mains sockets in the venue -- it really isn't
that uncommon! Buy a tester, and make a point of using it next time. it only take a few
seconds. Also, to be almost completely safe, make sure you run all your own equipment
through an RCD, and persaude all the others in the band (and FOH) to use RCDs too.
Hugh
Paul Soundscape
[Re: ghc]
#577136 - 06/02/08 02:14 PM
ok thanks hugh that makes a bit more sense now, it was a while ago so cant exactly
remember where we were plugged in to but yeah i always use RCD's now.
it only
happened when we sang and touched our strings.
Cheers
Edited by Paul Supersonix Studios (06/02/08 02:15 PM)
Loc: Worcestershire
#577177 - 06/02/08 03:47 PM
it
only happened when we sang and touched our strings.
Yes, it would.
Normally, the strings are earthed
through the guitar cable's screen to the guitar amp, and from their to the mains safety
earth of the amp's mains lead.
The mic body is earthed through the mic cable
screen to the mixer, and from there to the mains safety earth of the mixer's mains
lead.
If one or other of those mains safety earths becomes high resistance or
disconnected, then the mains input filtering of the amp or mixer will tend to pull
everything connected to the now disconnected earth line up to half mains volts (115V in
the UK and Europe).
If you are playing the guitar while touching the mic body
as you sing, you complete a circuit, one side of which is earthed, and the other is
sitting at 115V. it doesn't matter which way around it is -- which side is still earthed
and which is floating -- the results ae the same.
If you're lucky it will just
tingle unpleasantly. If you're unlucky there'll be a bang and the gig will come to a
premature end... as will the person who formed the link in the circuit.
You
said this only affected you and the guitarist, and that's often the case. Vocalists
generally only touch the mic and nothing else -- so there is no circuit. Likewise keyboard
players generally only touch plastic keys, so there's still no circuit.
The
worst case scenario is when the circuit is formed across the hands -- one hand on the
guitar strings, the other on the mic. That way any current flow is straight across the
chest, through the heart, and is likely to stop the heart. One ex guitarist...
Hugh
jamaicanDave
[Re: ghc]
#577224 - 06/02/08 04:41 PM
never happened to me b 4 but thanx 4 posting that thread... it's gonna save me loads
of time in the future...cause i'm sure it'll happen
dmills
#577282 - 06/02/08 06:40 PM
i played at the colston hall in bristol and i even had problems there, and my
equipment is certainly earthed! It was that our amps were plugged in to a different
I
could tell you a few stories about that venue, but probably had better not.
Most touring acts will plug distro into the heavy stage power tie stage right (good for
400A or so IIRC) and forgo the use of the random 13A points except for back stage tea and
coffee.
That the earthing is a little suspect comes as no surprise (No
reflection on the house crew, council run venue and Bristol council, well 'nuff said).
I would heavily advocate always testing before you plug in anywhere, in any venue
and that the use of RCD protection on backline supplies is just good sense (along with FOH
if you don't trust things).
Note that most simple socket testers cannot
identify a neutral/earth reverse.
There are a scary number of dodgy sockets
out there, test everything and be paranoid, it's good for you.
Incidentally,
IME CEE form sockets are less likely to be miswired as people pay more attention to the
'industrial' power then they do to the domestic stuff (Good reason to use them if
available).
Regards, Dan.
-------------------- Audiophiles use phono leads because they are unbalanced people!
Paul Soundscape
[Re: ghc]
#577296 - 06/02/08 07:14 PM
the engineer was a right pr*ck he just said "deal with it". in the end our guitarist just
got so annoyed at the end of the set just smashed over the mic stand lol
DingoDave
Loc: Cardiff
[Re: ghc]
#577356 - 06/02/08 09:36 PM
Hehe my guitarist was getting static off his guitar in band practice dont know why it
happend, he was also using a mic at the time and quite close to the amp and socket. It was
amusing to watch when now and again hed jump in the middle of a song with a small yelp!
Paul Soundscape
[Re: ghc]
#577368 - 06/02/08 10:06 PM
haha yeah its not fun if your being shocked after a 30 minute set my mouth was burning.
seablade
#577418 - 07/02/08 01:18 AM
just got so annoyed at the end of the set just smashed over the mic stand lol
You are completely within your right
to walk out there.
NOTHING is worth the risk you just put yourself through(30
minutes???!!!!). If they have a problem with you walking out, tell them you will feel
happy to have the local inspector come in and make sure the building is up to code and if
that is the case you will come back. But until then something is very much NOT right
there and they are endangering lives like that. Honestly the engineer that says, deal
with it, to something like that needs to be fired on the spot. Maybe then he will learn
not to screw with electrocuting people.
Seablade
NOTE: I am
in the US, though I would imagine a similar safety inspection exists in the EU for such
situations.
dmills
[Re: ghc]
#577428 - 07/02/08 01:44 AM
City council venue Seablade, the place (a ~1,800 seat somewhat run down neoclassical pile
last time I was there) is owned by the AHJ! I understand that they have done some work on
it in the interim, but the real plan for as long as I can remember has been to replace it.
This is the council which owns another venue where you always had to ensure a
lantern was plugged into the first socket on the FOH bar and securely clamped to the bar
as that was the only one with the earth connected (Lots of moaning from us, zero action
from the council, and this is in 240/415V land)! Mind you, they also supplied me a 'street
lighting technician' to fill a rider requiring the venue to provide a 'lighting
technician', nice guy, but about as useful as a chocolate fireguard.
I do
wonder if that 'engineer' was actually a hired in PA company as I don't recall that place
having any PA worthy of the name (And from what I recall of working there a few times,
that does not sound like behaviour the resident chief would have accepted from his
people).
It does however sound like the sort of thing a pissed off third party
sound provider might perpetrate after a bad day.
Regards, Dan.
Loc: Worcestershire
[Re: DingoDave]
#577435 - 07/02/08 02:05 AM
Quote DingoDave:
Hehe my
guitarist was getting static off his guitar in band practice dont know why it happend
Not being funny here, mate, but
you are dismissing a seriously life-threatening situation here. You need to find out why
it happened. Something is UNSAFE in your rig.
Quote:
It was amusing to watch when now and again hed
I wonder how many people will laugh
when your mate -- OR YOU -- DIE!
This is serious and it happens everyday. And
if something nasty does happen, and it can be shown that you were aware of the fault but
did nothing to rectify the problem, it won't do you much good either!
Seriously
-- sort this out NOW. Get the gear checked. Get the room wiring checked.
Hugh
Matt P
member
Loc: Manchester, UK
[Re: ghc]
#577444 - 07/02/08 02:45 AM
I know it's been said a million times before, but surely we can all agree that this topic
warrants being made a sticky.
Also, Dan/Hugh/anyone, do you have a particular
socket tester that you recommend? I know for a fact that my rather basic Maplins jobby
(the name of which completely escapes me) will spot a disconnected earth, but won't pick
up on a reversed live/neutral. Dan, I think I've heard you talk about stuff Martindale(?)
before now?
seablade
[Re: dmills]
#577457 - 07/02/08 06:13 AM
Quote dmills:
City council venue
Seablade, the place (a ~1,800 seat somewhat run down neoclassical pile last time I was
there) is owned by the AHJ! I understand that they have done some work on it in the
This is the council which owns another venue where you always had to ensure a lantern
was plugged into the first socket on the FOH bar and securely clamped to the bar as that
was the only one with the earth connected (Lots of moaning from us, zero action from the
council, and this is in 240/415V land)! Mind you, they also supplied me a 'street lighting
technician' to fill a rider requiring the venue to provide a 'lighting technician', nice
I do wonder if that
'engineer' was actually a hired in PA company as I don't recall that place having any PA
worthy of the name (And from what I recall of working there a few times, that does not
sound like behaviour the resident chief would have accepted from his people).
It does however sound like the sort of thing a pissed off third party sound provider
Regards, Dan.
Again, yank over here sadly, but I would say
then the next step is to take it over the city. At least in the US this would violate
NATIONAL safety standards, so there is nothing stopping someone above the city from
shutting it down if need be. Again I would venture a guess in the EU that a similar
situation exists.
I know it sucks, but honestly they need to be forced to do
something. This is waiting for someone to die as described right now. No hyperbole at
all, it literally is a matter of waiting till the first person dies before anything is
done unless someone goes over their heads if the city is unwilling to do anything with
it.
Honestly, there have been venues I have told production companies never to
book again as they were dangerous along this level. This would certainly qualify, step
one is to never play it again, and make sure noone you know plays it until they get this
fixed. Step 2 would be to report it over the heads of the city IMO.
Seablade
seablade
[Re: Matt P]
#577458 - 07/02/08 06:15 AM
Quote Matt P:
I know it's been
said a million times before, but surely we can all agree that this topic warrants being
made a sticky.
Yea at this
rate, I gotta agree, something needs to be done to keep this perfectly visible, not sure
if a sticky thread is the right answer or not. Maybe an FAQ section along the lines of
Martin's computer FAQs? Ah well up for the mods/admins to decide not me.
Anyways to answer your other question I bought this kit for basic electrical analysis
that I carry with me.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=205783-7
2068-TK-30&lpage=none
I believe the socket tester in it wil check for a
live/neutral reverse, but I will double check tomorrow. At the moment I need to get some
sleep and don't feel like getting dressed to go out to the car to check.
Seablade
Nathan
Loc: lincolnshire government experi...
[Re: seablade]
#577544 - 07/02/08 10:44 AM
when i have this problem i use a multimeter and the odd radiator to find which earth is
bad and then i put a sticker on it saying "Faulty. This is not to be used until repaired"
then i tell the venue management what i've done and suggest that it's repaired. If i'm
feeling really bolshy i'll follow it up and report them to the local coucil, their
licensing authority or HSE if the sticker was removed without being rectified (i have done
this to a council venue whose 63Amp supply was LN reversed). if you knew what
you were doing and if you had the appropriate test gear, you could measure between the
earth connections on the stage and mixer supply sockets and see if there is a voltage
-more than 5 volts or so suggests a possible problem, double figures means a definite
issue with earthing in the building. i have found over a 120 volts on an earth in a
leisure complex venue. a missing or dodgy earth is potentially lethal should a
fault condition occur, and the venue would be fined heavily or shut down once HSE had been
in there should there be an accident (happened to a franchise of a food chain in my home
town after a lethal shock). also any venue needs an annual electrical inpection
to get their PEL, so it would be good to ask for a copy of the report for this
"council-run" venue -i think as a council they are obliged to supply one to a formal
request. stir up some mud, you might get things to happen before someone dies.  that aside, the usual reason for shocks on microphones is a removed earth on
guitar amp plugs -in this case it could be a bad earth from either side from the mains
sockets. anybody who lives in Bristol fancy verifying this? it does sound like
something does need to be done.
-------------------- planet nine
lincoln, uk.
feline1
active member
Loc: Brighton, UK
[Re: ghc]
#577551 - 07/02/08 10:56 AM
Thanks to previous SoS threads on this, I now always bring my 'Martindale socket tester'
to everygig, and fit a couple of Wickes RCDs onto the bands' gear. Occasionally they trip out in the middle of songs, so the band can be a little "auch!
not that bloody thing that ruins our gigs!" but I just keep reminding them that leaving
the stage in an ambulance would ruin the gig even more.
-------------------- ~~~ A weasel hath not such a deal of spleen as you are tossed with! www.feline1.co.uk ~~~
Nathan
[Re: feline1]
#577563 - 07/02/08 11:12 AM
find an electrician friend to measure your gears leakage current feline -most PAT testing
gear will do this -see if you have some borderline equipment or if you have any congealed
beer in any of your socket strips...
lincoln, uk.
Paul Soundscape
[Re: Nathan]
#577571 - 07/02/08 11:23 AM
Quote:
I do wonder if that
nah it was the inhouse lampy i think.
they have some sort of turbosound rig in there, not very good though.
feline1
active member
Loc: Brighton, UK
[Re: Nathan]
#577589 - 07/02/08 11:59 AM
Quote Nathan:
find an electrician
friend to measure your gears leakage current feline -most PAT testing gear will do this
-see if you have some borderline equipment or if you have any congealed beer in any of
nah, the time it tripped, there
was spilt beer about an inch deep all over the stage and the 4-ways, so "go figure", etc
etc...
Nathan
[Re: feline1]
#577590 - 07/02/08 12:01 PM
heh, no argument
lincoln, uk.
chris...
active member
Loc: Glasgow
[Re: Nathan]
#577887 - 08/02/08 01:07 AM
Quote Nathan:
also any venue
needs an annual electrical inpection to get their PEL, so it would be good to ask for a
copy of the report for this "council-run" venue -i think as a council they are obliged to
supply one to a formal request
Yep - with very few exceptions, under Freedom of
Information they are required to supply any document held by the public authority.
The request for information must be somehow written down (email considered fine)
but technically doesn't have to be in any way "formal".
You don't have to
live in bristol - anyone should be able to email: foi at bristol.gov.uk and ask for a
copy of the report....
Loc: Worcestershire
[Re: ghc]
#577962 - 08/02/08 10:16 AM
As this is a topic that comes up regularly, and is 'mission critical' I have made it a
sticky as suggested.
hugh
The muso
Loc: Scotland
[Re: Hugh Robjohns]
#577963 - 08/02/08 10:19 AM
Quote Hugh Robjohns:
As this is a
topic that omes up regularly, and is 'mission critical' I have made it a sticky as
suggested.
hugh
Applause! Righto, is there prize for writing the best definitive Electrical Safety
guide?
PeteJ
[Re: ghc]
#577987 - 08/02/08 11:05 AM
Hi all, At the weekend I was getting small shocks from the main vocal mic (our singer
doesn't play any instruments or have anything plugged into mains). There was no unecessary
phantom power and the problem was only on the main vocal. I was splitting it into 2
channels and using 1 to drive monitors... could it have been something in the desk? Anyone
got any ideas how this can be fixed if i encounter it again? Cheers Pete
Sylle
[Re: ghc]
#577991 - 08/02/08 11:14 AM
Tried to search in this thread about it, but i was surprised to see that noone came with
the suggestion to put a DI between the amp and the guitar to prevent shocks. Of
course you have to plug the DI into the mixer or remotebox on the stage, just to even out
the differences in current between different outlets. But with that done, you won't have
any problem with shocks while grabbing your guitar and singing.
Best regards Sylvester
mpostor
member
Loc: S.W. London
[Re: Sylle]
#578064 - 08/02/08 01:39 PM
That won't fix any problems with earthing on the mains sockets, though... You
could still injure/kill yourself. Although, on the bright side, that annoying
hum will have been stopped...
dmills
[Re: ghc]
#578120 - 08/02/08 03:29 PM
Dodgy socket wiring would be my bet for the shocks from the (non guitarist) vocal mic. Get a simple three lamp socket tester, and use it every time, you will find some amazing
things.
On the subject of guitars, I have one that has had a low value class Y
cap added in series with the lead that connects the bridge to the screen. It has
little effect on the screening, but means that the path to the amp will be too high
impedance to deliver a belt that is likely to be fatal (Cheap insurance, and I commend
this modification to the house).
Not of course that this makes lifting the
safety ground safe, but it does provide some protection against muppetry.
Regards, Dan.
The muso
Loc: Scotland
[Re: dmills]
#578133 - 08/02/08 03:54 PM
Quote dmills:
Not of
course that this makes lifting the safety ground safe, but it does provide some protection
against muppetry.
Regards, Dan.
LOL. Good one. Should be in 'Top Tips'.
PeteJ
[Re: ghc]
#578176 - 08/02/08 05:15 PM
Cheers Dan, I'm not totally sure what you mean by the socket tester.. the only power
she could have been connected to was from FOH.. on it's own feed from the distro... maybe
test that output? I don't get how we didn't encounter the same problem with other (vocal)
mics. Cheers Pete
Loc: Worcestershire
[Re: PeteJ]
#578178 - 08/02/08 05:25 PM
Quote PeteJ:
getting small shocks from the main vocal mic (our singer doesn't play any instruments or
By small shocks, do you mean static 'zaps' -- short, sharp zaps that are not
continuous -- or do you mean half mains voltage continuous electric shocks?
The former is caused by clothing or flooring, generally and isn't lethal but can be
startling. The latter is potentially lethal...
I'm ubnclear when you say you
got shocks but the singer doesn't play anything. Was the singer getting shocks too?
Quote:
There was no
unecessary phantom power
Phantom power is DC and low voltage, so it's not a factor in this.
Quote:
and the problem was
That is very odd... and quite unlikely if it is real faulty-earth style electric shocks!
But could be possible if it was static shocks.
Quote:
I was splitting it into 2 channels and using 1 to
Do you mean two channels of the same desk,
or split to two different desks?
Quote:
Anyone got any ideas how this can be fixed if i encounter it
again?
Check all the mains
earths on all the equipment, mains leads, and distro boards. Check the wall sockets at the
venue before using them. And power eveything via RCDs.
hugh
PeteJ
[Re: ghc]
#578227 - 08/02/08 07:23 PM
Thanks Hugh... Static shocks I reckon. Sorry about the confusing bits.. I just mix
the band so when I said myself and the singer it was me during soundcheck and her during
the show. Maybe it was floor / clothing related.. I'll check out what she's wearing next
time. Any other ways of minimizing this? Changing cables / stands / mics? The channel
thing was just that I had to mix mons + foh from the same board so I y-split the main
vocal into 2 channels of the same desk - then used one for out-front and one to send to
monitors with different eq. Thanks for your help.. best Pete
Loc: Worcestershire
[Re: PeteJ]
#578382 - 09/02/08 10:48 AM
Quote PeteJ:
Static shocks I
reckon.
Yes, sounds more
likely.
Quote:
I'll
check out what she's wearing next time. Any other ways of minimizing this?
Can't do anything with the mics/stands etc.
They have to be earthed for safety. Best to check your lady singer for static-inducing
underwear before every gig
hugh
The muso
Loc: Scotland
[Re: Hugh Robjohns]
#578391 - 09/02/08 11:19 AM
Best to
check your lady singer for static-inducing underwear before every gig
hugh
You could always attach
some of those static tails you used to see under the rear bumpers of cars in the 80's.
hifistud2
Loc: Near Sunderland, UK
[Re: Hugh Robjohns]
#578412 - 09/02/08 12:31 PM
Something I've made a point of for years. Sometimes a visual
check alone is not enough, as you're doubtless well aware. However, no matter how the
check is carried out, I find the best option is to ensure it's removed, and held in safe
keeping pending further investigation.
-------------------- [url=http://www.facebook.com/pages/hifi-studios/117322741632389[/url]
