Watcher Of The Skies
Loc: Cornwall, UK
DPC Latency Survey - please contribute
#588140 - 06/03/08 01:53 PM
Hi folks!
I'm publicising Thesycon's DPC Latency Checker ( www.thesycon.de/eng/latency_check.shtml ) in my next PC Notes column,
but various posters here are already finding it useful for exposing problems that may
cause audio clicks and pops, so it would be good if we could gather some initial results
from various systems to give us all an idea of typical figures and what happens to them
with rogue hardware.
DPC Latency Checker is a tiny 310KB Windows utility,
doesn't require installing (just double-click the file to run), and is really easy to use.
It polls the DPC (Deferred Procedure Call) latency once every second and displays the
results in a horizontally-scrolling graph. Hardware drivers issue periodic interrupts, and
Windows deals with these as soon as it can on a first come first served basis (the
DPC).
Unfortunately some hardware spends too long dealing with its DPC
routine - readings under 500 microseconds (the green zone) are fine; those between 500 and
1000 microseconds (or 1mS) are borderline, while those beyond these (the red zone) may
result in audio interruptions.
The beauty of this tool is that you can spot occasional
spikes above the norm and see how often they occur, which can be a great help in tracking
down the culprit. If you measure occasional high peaks you won't be able to run your audio
interface at such a low latency, and should disable individual devices one at a time in
Device Manager to find out which one is causing the problem.
Please post your
measurements here so we can build up a useful resource and possibly track down some common
causes for these spikes, including particular laptop models, MIDI interfaces, BIOS
revisions, wireless network adaptors, and so on
Please include:
1. Your PC hardware: CPU, motherboard, RAM, and
Windows version.
2. DPC Latency typical and peak values.
3. Any
other relevant hardware that might be responsible.
Many thanks!
-------------------- YewTreeMagic
Loc: Cornwall, UK
Re: DPC Latency Survey - please contribute
[Re: Martin Walker]
#588141 - 06/03/08 01:55 PM
OK, here we go with my results:
Hardware: Intel Conroe E6600 2.4GHz dual-core
processor, Intel DP965LT motherboard with Intel P965 chipset running 1066MHz system Bus,
2Gb Corsair PC2-6400 DDR2 RAM, and Windows XP with Service Pack 2.
XP General
install (Internet-enabled): typical 50 microseconds, occasional peak up to 100
microseconds
XP Music install (stripped-down music-only partition): typical
24 microseconds, occasional peak up to 65 microseconds.
Although both
sets of results are absolutely tiny, you can already see some measurable benefits from
employing a stripped-down music-only partition if you want to run your audio interface
down to a really low (almost real-time) latency.
Boywander
[Re: Martin Walker]
#588188 - 06/03/08 03:27 PM
Its a very cute utility, thanks! Now, i will publish my results only if you
promise not to make any wise cracks about my rusty old gear! Desktop - CPU
- Intel Northwood (Pentium 4 Single core) 2.4Ghz MotherBoard - GigaByte GA-8PE667 Chipset - Intel Brookdale i845PE Memory - 1.5GB DDR at 200MHz OS - XP Pro (SP2
for the Internet Boot / SP1 for the Music Boot) Main SoundBoard - FW Mackie ONYX
1640 Results - Internet Boot - around 330 microscnds with peaks up to
500. Music Boot - around 75 micros with peaks up to 100. ----------- Laptop
- CPU - Intel Dothan (Pentium M725 Single Core) 1.6GHz MotherBoard - HP Presario
2200 Chipset - Intel Montara GM-i825GM Memory - 1GB DDR at 200MHz OS - XP
Home (SP2 / SP1) Main SoundBoard - FW M-Audio Ozonic Results - Internet Boot - 180 up to 220 Music Boot - around 70 with noticeable peaks at
475. I would look into it but im throwing the damn thing anyway  , and i
will certainly use this DPC checker when laptop hunting.
-------------------- The Man in the Crowd with the Multi Colored Mirrors on his HobNail Boots
Boywander
[Re: Martin Walker]
#588196 - 06/03/08 03:41 PM
WoHoHo !! I did bother to check, It was the DVD Combo Drive - DPC Latency
went right down to a steady 35 micros - no peaks at all! Thanks Again!
ASG
member
[Re: Martin Walker]
#588206 - 06/03/08 03:59 PM
I've used this for a few months and here are my findings:
Hardware: Intel
Q6600, ASUS Commando motherboard with Intel P965 chipset running 1066MHz system Bus, 4Gb
Music-only DAW:
typical 20 microseconds, occasional peak up to 45 microseconds.
However the
biggest finding was the effect of enabling the ethernet controllers; typical rose to 250
and peak to 612. The Marvel Yukon ethernet controllers are normally disabled in the device
manager.
Loooking at the two controllers on my mobo in turn the biggest culprit
was from the Marvel Yukon 88E8001/8003/8010/PCI Gigabit Ethernet Controller producing
peaks of 500 microseconds every two seconds.
Less problematic was the Marvel
Yukon 88E8056 PCI-E Gigabit Ethernet Controller although interestingly this generated a
regular sawtooth pattern peaking at 400 microseconds every every 5 seconds.
Since I'll have to enable one of the ethernet ports once the Euphonix Artist controllers
arrive on PC I'll have to look at this again. There may be settings for these ports that
need optimising but until then I keep them disabled.
Regards, Andrew
cc.
getting into my stride
Loc: lisbon at the moment
[Re: Martin Walker]
#588235 - 06/03/08 04:54 PM
Are you meant to run it while the machine is idle? I get much lower numbers: 3us
mostly with peaks to 13us on my AMD X2 4400+ / Asus A8V.
I only ran it because
I also have the Marvel Yukon 88E8001/8003/8010 ethernet controller mentioned in the
previous post (and it is enabled).
markhodges
Loc: München
[Re: Martin Walker]
#588346 - 06/03/08 10:18 PM
I have
Intel E6600
Asus P5B Deluxe WiFi
2Gb 800Mhz CAS4 RAM
Windows XP SP2
Gigabyte geforce 7600 video card
Creamware SCOPE home PCI
card
I see an average of about 70us with a peak of 156us. I've made the usual
tweak of background services & turning off the on-board audio. I do have a firewall
and anti-virus running though as I keep the internet on.
If you get good
DPCLAT results but still get the odd intermittent click, another tool you might want to
look into is systinternals process explorer. If you double click on the system process,
look at threads and rank by cpu utilization, the module that is causing problems will
sometimes pop to the top of the list in time with the clicks.
Edited by markhodges (06/03/08 10:23 PM)
Loc: Cornwall, UK
[Re: Martin Walker]
#588347 - 06/03/08 10:20 PM
Thanks for the results so far - most illuminating
Boywander - that's a gratifying result. I wonder if your DVD Combo drive is the
offender, or its drivers, or a Windows setting? Let us know if you discover more.
ASG - network hardware seems to keep popping up as a major headache in some music
PCs, with wireless network adaptor being the worst offenders.
cc. -
personally I ran my tests while running my sequencer through a typical song. The
measurements when idle on my PC weren't really any different, but being in a real-world
scenario seemed the most appropriate method just in case anything kicked in.
mark - I use Process Explorer myself. DPC Latency is more likely to highlight hardware
device issues, while Process Explorer may also help you track down rogue software tasks,
but can be more difficult to use.
Keep those measurements coming!
hugol
Loc: London, UK
[Re: Martin Walker]
#588358 - 06/03/08 10:57 PM
Gigabyte P35-DS4 Rev 1.1
Q6600 2.4GHz G0 Stepping
2Gb 1066MHz
5-5-5-15 OCZ memory
2 x Pioneer IDE DVD writers
Hitatchi 7K250 SATA HDD
500GB
XP SP2 with all latest patches
Results:
1) BIOS F6
and above - regular peaks of at least 695us. Major timing problems with Cubase 4 and
pop/clicks when accessing HD and playing back.
2) BIOS F4 or F5 - between
30 and 40us typically, odd peak to 77us. Has once or twice peaked to 252us on disk access
/ program load very occasionally.
3) The above measurements were with USB
connected Virus TI Polar turned off. With Polar on (and F5 BIOS) varies all over the
place between about 95us and max of 161us whilst playing back in Cubase.
Interestingly I haven't noticed any difference in DPC timings when disabling any device
including network aside from the Virus. I am currently discussing DPC issues with the
BIOSes >F5 with Gigabyte.
Cheers.
Edited by HL (06/03/08 10:59 PM)
_Nuno_
Loc: Cork, Ireland
[Re: Martin Walker]
#588359 - 06/03/08 11:00 PM
My Results:  Average latency of 10 microseconds, spikes to
around 20 microseconds. This system performs very well. E6600 Intel
DQ965GF MicroATX motherboard 80 GB Maxtor System drive 250 Maxtor audio drive 500 WD Caviar Samples drive 500 Gb Seagate backups Two Sweex Via PCI Firewire
cards One ST Lab External SATA PCI express card RME FIREFACE 800 Liquid MIx
BCF 2000 M-audio MIdisport 8X8 NI Kore My Dell laptop performs
not so well. I'll post that next.
_Nuno_
Loc: Cork, Ireland
[Re: Martin Walker]
#588369 - 06/03/08 11:27 PM
Here's the Dell laptop:  This is a Inspiron 1520 (I think the closest
thing now is the Vostro 1500) T7500 4 GB RAM 160 GB Hardrive I had to reinstall everything twice before I could get it like this. First time I had
huge latency spikes, now it stays at around 160-200 microseconds most of the time. With my
Fireface it plays well, but let's see with the Audiofire 2 that's arriving tomorrow.
markhodges
Loc: München
[Re: Martin Walker]
#588379 - 06/03/08 11:47 PM
Quote Martin Walker:
mark -
I use Process Explorer myself. DPC Latency is more likely to highlight hardware device
issues, while Process Explorer may also help you track down rogue software tasks, but can
True, however DPC routines sometimes have to pass work to other threads because of
constraints on what can be done at the DPC interrupt level e.g. accessing paged memory. A
driver will often create these threads with a higher than normal priority. I found using
process explorer to look specifically at the threads in the 'system' task can help
identify these worker threads and the driver responsible for creating them.
vriesjw
new member
Loc: haarlem, the netherlands
[Re: Martin Walker]
#588389 - 07/03/08 12:30 AM
Here are my (horrifying) results for my Music notebook and two other (non Music) notebooks
as well (ASUS and Sony) for comparison.
I. COMPAL Centrino Notebook CL50 (dual
boot configuration) CPU – Intel Banias Pentium M 750 @ 1700 MHz, 398,7 MHz FSB Mainboard – COMPAL CL50 Chipset - Intel i855PM BIOS – COMPAL v 1.60,
Insyde Software SMBIOS for Whitney Physical Memory – Kingmax Semiconductor, 1024 MB
(2x256 DDR-SDRAM PC2100, 133 MHz) Video Card - ATI Mobility Radeon 9000 Hard
Disk – HTS726060M9AT00 (60GB) Hard Disk - Maxtor (251 GB) DVD Rom Drive –
TOSHIBA DVD-ROM SD-R6112 Network Card – Realtek RT8139 Fast Ethernet Network
Card – Broadcom BCM4306 802.11g Wireless NIC Firewire – VT6306 VIA Fire II
IEEE-1394 OHCI Link Layer Controller OS – Win XP Home 5.01.2600 SP2, dual boot
(Music & Internet partition) DirectX- Version 9.0c
Results - Internet boot – typical around 400 microsec, frequently peaking up to 6225 microsec
Music boot – typical around 500 microsec, occasionally peaking to 2250 microsec ----------------------------------------------------------------------------------------
------------------------------ II. ASUS Centrino Notebook M6N (only for wireless
internet use) CPU – Intel Banias Pentium M 750 @ 1500 MHz, 400 MHz FSB Mainboard ASUSTeK Computer Inc. M6N Chipset - Intel i855PM BIOS – American
Megatrends Inc. 0208, 6-5-2004, SMBIOS Version 2.3 Physical Memory - 512 MB (2x256
DDR-SDRAM PC2700, 166 MHz) Video Card - ATI Mobility Radeon 9700 (M10 NP) (RV350) Hard Disk - IC25N040ATMR04-0 (40 GB) Hard Disk - Samsung (120 GB) DVD Rom
Drive – TOSHIBA DVD-ROM SD-R2512 Network Card – Broadcom BCM5788 NetXtreme
Gigabit Ethernet Network Card – Intel PRO/Wireless 2200 BG Firewire - RL5c552
IEEE-1394 Controller OS – Win XP Prof 5.01.2600 SP2 DirectX- Version 9.0c Results – typical around 82 microsec with occasional peaks up to 285
-------------------- III. SONY VAIO Notebook VGN A217S (only wireless internet
boot) CPU – Intel Dothan Pentium M 735 @ 1700 MHz, 398,7 MHz FSB Mainboard –
Not specified Chipset - Intel i855PM BIOS - American Megatrends Inc. R0080F1,
28-9-2004, SMBIOS Version 2.3 Physical Memory - MB (2x256 DDR-SDRAM PC2700, 166
MHz) Video Card - ATI Mobility Radeon 9700 (M10 NP) (RV350) Hard Disk - TOSHIBA
MK1031 GAS DVD Rom Drive – TOSHIBA DVD-ROM SD-R6112 Network Card – 82541 EI
Gigabit Ethernet Controller Network Card – Intel PRO Wireless 2200BG Firewire
– PCI7x20 1394a-2000 OHCI Two Port PHY/Link Layer Controller OS – Win XP Home
5.01.2600 SP2 DirectX – Version 9.0c
typical around 170 microsec with occasional peaks up to 285 microsec
I
have also used Process Explorer to find any clue for the DPC's, but no specific
conclusions can be made for the COMPAL CL50. Still no solution for the problem.
Jacob
-------------------- Pentium M 1.7 G, 1G RAM, WINXP SP3 dual boot, 60+250+2x500GB HDD, 7200 rpm; Yamaha 01X; Studio Manager/mLan Tools 2.0; Cubase 4.5; Yamaha CP300
ErichS
[Re: Martin Walker]
#588417 - 07/03/08 04:51 AM
Very interesting utility! My System: Pentium Core 2 Duo, 2.4 GHz ASUS P5B Deluxe motherboard (P965 chipset) 2GB Corsair DDR2 800 RAM 2 Western
Digital 250GB HDs Antec Neo 550 (550 watt) power supply ATI Sapphire Radon 1300
graphics card PCI-e 16X Belkin Wireless network adapter RME Fire Face 400 Windows XP professional I use this computer as a music workstation and
general use/internet system. So far I haven't had any problems with droupouts or clicks
etc so I don't bother turning of the network adapter or any services such as the firewall
or virus scanner. When I first ran the DPC Latency Checker things were crusing
along at 5 to 80us then BAM! Two spikes - 2000us then 5300us -  ouch!
They reoccured every 20s or so. The first thing I turned off was the network
adapter and the spikes disappeared. Without the network adapter enabled
latancy is 10-80us I don't know if it will change the way I work but it is nice
to know if problems arise.
lachris
Loc: Asker, Norway
[Re: Martin Walker]
#588425 - 07/03/08 08:01 AM
My laptop: Dell Precision M6300 T7800 C2D 2.6GHz CPU 4GB RAM 200GB 7k2
rpm HD DVD +/-RW Intel a/g wireless Nvidia Quadro FX 1600M display
adapter Motu 828 MkII Windows XP Pro SP2
My dpclat results: repeating 200us with regular peaks up to ~2000us every 15 seconds with some higher
peaks, I think the record is currently ~15000us!
And I experience drop outs, or
more like strange noises, regularly in Sonar 7 PE, even at low CPU load and high buffer
size settings.
I have disabled everything possible to disable in the BIOS, and
the remaining unneccessary (and some necessary...) devices in device manager. I have tried
reinstalling several times. I have tuned Windows according to the SOS advices and I have
tried all available versions of the BIOS.
Conclusion so far: This laptop is not
usable for music production.
-------------------- /Lachris
(Mutlicom Kunshan D900 (=Clevo D901C), Motu 828 MkII, Sonar 7 PE)
onesecondglance
Loc: Reading, UK
[Re: _Nuno_]
#588430 - 07/03/08 08:30 AM
Quote Nuno_:
Here's the Dell
laptop:
the Vostro 1500 is essentially
an Inspiron without the colourful exterior... but these are fantastic results. my priority
at the mo is to get my soundcard working and then i will gladly run the utility to see
what i get from my (almost identical) setup.
-------------------- hourglass | random thoughts | doubledotdash!? collective
cc.
[Re: Martin Walker]
#588432 - 07/03/08 08:39 AM
cc. -
Mine are very different. Running
a typical song (maybe 50% cpu load) I get around 30us with spikes to 130us - 10x higher.
_Nuno_
Loc: Cork, Ireland
[Re: onesecondglance]
#588434 - 07/03/08 08:43 AM
Quote onesecondglance:
Quote Nuno_:
Here's the Dell
laptop:
It takes some work, but you can get it to work. My first install
would not play well with my FF800 or my NI kore, but this one does.
I forgot
that mine has the Gforce 8400 128 MB graphics also. I just installed windows, chipset,
then soundcard driver and graphics. I think it was in that order.
table for two
active member
[Re: Martin Walker]
#588437 - 07/03/08 08:50 AM
Heya M
Just to post my reslts on a NON audio pc
Dell
Latitude D410 laptop : Intel Pentium M 750 1.86GHz, Intel 915 chipset, 512MB DDR2 mem, XP
Pro SP2.
With ALL drivers installed
Office and other non audio
software installed.
NO XP tweaks
Antivirus turned ON
Firewalls
turned ON
Bluetooth turned ON and wiriting now on this forum
280mS-394mS max 1091mS
"This machine should be able to handle real-time
streaming of audio and/or video data without drop-outs."
Can confirm that enabling wifi shoots it beyond 16000mS,
and even
after turning wifi off it takes a fair while to settle down.
Houndawg
new member
[Re: Martin Walker]
#588444 - 07/03/08 09:10 AM
Great idea to bring awareness to this fantastic utility. As a part-time DAW builder, this
tool has been incredibly useful to my work.
I built a new system for own use
quite a while back, using the ASUS P5W DH motherboard. This motherboard has an additional
hard drive controller by JMicron, and I initially had my audio drive (Western Digital SATA
74GB Raptor) connected to the JMicron drive controller.
During initial testing,
I was getting audio drop-outs that I could not account for. Using the the DPC Latency
Checker, I could easily see that I had a major problem with a kernel-mode device driver.
Having already disabled all other non-essential onboard devices, my first thought was the
JMicron controller, and I was right.
After I moved the audio drive to the
primary drive controller, the drop-out problem completely disappeared, and I confirmed
smooth DPC performance by the DPC Latency Checker.
This tells me that the
driver for the JMicron controller for this motherboard is not well suited for digital
audio purposes, thank you DPC Latency Checker!
I should also point out that
the ASUS P5W DH (BIOS 2302) otherwise performs INCREDIBLY well and is super stable running
Sonar 7.0.2 on Windows XP SP2 (and recently with SP3 RC1).
The DPC Latency
Checker doesn't even peak above 39 micro seconds when running on this system. (Intel Q6600
"G0" @ 3.0GHz CPU, 2GB Corsair DDR2-800 CAS4 RAM)
-hounDAWg
Loc: Cornwall, UK
[Re: Martin Walker]
#588506 - 07/03/08 11:47 AM
Thanks for all these results folks - we have already established beyond doubt that for an
audio PC:
a) Having Wi-fi enabled is a no-no.
b) Occasionally a
rogue BIOS update can cripple performance.
c) Some hard drive controllers
need to be avoided.
d) Some laptop models may be fundamentally
unsuitable.
Boywander also makes the very sensible suggestion of using DPC
Latency Checker when evaluating new laptops - if you pop it onto a USB stick you could
even run it on shop models.
tft - thanks for the reality check with your
decidedly non-audio laptop and wi-fi results, but it's microseconds, not milliseconds -
16000mS would mean your laptop would grind to a complete halt for 16 seconds
Keep those results rolling in and we'll see what else we can deduce.
table for two
active member
[Re: Martin Walker]
#588541 - 07/03/08 01:01 PM
cc.
[Re: Martin Walker]
#588608 - 07/03/08 03:04 PM
I just tried my Dell Latitude D520 (T5500 1.66GHz), on Vista Home Basic straight out
of the box with everything enabled I got ~1000us with occasional peaks of 1600us. Turning
off the wifi (intel pro wireless) takes it down to around 200us with frequent peaks of
1000us. I haven't tried any music apps on it though.
necromunger
[Re: Martin Walker]
#588662 - 07/03/08 05:49 PM
hi amd athlon 2.6 1.5 gig 333mhz ram 80 gig ide hdd x2 256 agp 8
card with fan  abit nf7s mobo motu pci 424 card 24 io 2408mk3 fire wall
on internet connected radio playing current latency between
80-196 absolute maximum 355 no radio current latency between
31-78 absolute maximum 103 necro
Boywander
[Re: Martin Walker]
#588700 - 07/03/08 07:54 PM
Combo drive is the offender, or its drivers, or a Windows setting? Let us know if you
discover more.
Its a very
problematic Drive, an old Toshiba ODD-DVD SD-R6252. it has a few well known and documented
issues. I dont know why i had it enabled, since it barely works anyway. so i guess its the
physical (faulty) drive thats the offender here.
Chopsy
member
Loc: Rochdale, UK
[Re: Martin Walker]
#588711 - 07/03/08 08:25 PM
Hi
What a great utility, I seem to get an average of 10 microseconds with a
peak of 24, absolute max of 36 - running on a lean xp pro sp2 setup. I had Zonealarm,
Avast, and network card running.
Main components:
Intel e6420 Core 2
Duo Asus P5B E Corsair 2gb 6400 DDR2 Gigabyte 7300 GS gfx card Samsung
P120 250gb SATA WD Caviar 320gb Se16 SATA
-------------------- "We deal in junk, you know; What we've got is what other people put in the rubbish bin." - Joe Strummer.
Binman_UK
Loc: Liverpool
[Re: Martin Walker]
#589027 - 08/03/08 08:13 PM
I've got the following:
Dell Inspiron 9400 (latest bios and drivers)
Onboard Intel Graphics
Core Duo 1.6GHz
1GB RAM
60GB HDD (Not sure of
the speed... presume it's 5400rpm)
NEC ND-6650A DVD +/-RW
Ricoh F/W Controller
(eek!)
Windows XP
Tested using my FocusRite Saffire Pro 26 i/o,
recording 3 tracks in Cubase SX3 at 96khz.
I've disabled the dvd drive,
ethernet, wireless and the sd card slot. I've also disabled some services, such as the
windows firewall and there are no other antivirus/firewall applications running.
The
wireless causes peaks of approx. 2000 microseconds if enabled!
With all this
disabled, I get:
Average: 200
Max: 700
Considering I've
got the dreaded Ricoh firewire chipset, I'm acually reasonably happy with this. I don't
get any audio dropouts, which is better than most are getting.
I'm going to do a
complete re-install sometime soon and make XP as lean as possible.. hopefully I can
significantly improve on the 700 peaks I'm getting.
I'm just waiting for the new
quad-core Penryn laptops to become available and I'll be getting rid of this laptop anyway
Hope this helps.
Cheers,
Binny
Binman_UK
Loc: Liverpool
[Re: Binman_UK]
#589064 - 08/03/08 10:50 PM
Oh.. forgot to mention.. I've got 4ms latency selected for the Saffire Pro 26.
Binny.
vriesjw
new member
[Re: vriesjw]
#589165 - 09/03/08 01:47 PM
Additional result for my Music laptop: I. COMPAL Centrino Notebook CL50 (dual
(Music & Internet partition) DirectX- Version 9.0c Earlier Measurements
- Internet (non music) boot – typical around 400 microsec, frequently peaking up to
6225 microsec Music boot – typical around 500 microsec, occasionally peaking to
2250 microsec New, additional measurement - Internet (non music) boot with
radio disabled – typical steady around 400 microsec, occasional peaks up to 1182
microsec So, it seems that my internet boot without radio behaves somewhat
better than the lean music boot  jacob
post version
Loc: whitehorse, yukon
[Re: Martin Walker]
#589178 - 09/03/08 02:38 PM
Intel core2duo E6850 3ghz asus motherboard 4gb pc26400 ram
4 * 350 gb seagate hd
2 x nvidia 7500 graphics cards
yamaha mlan system with TI chipset on
motherboard
one detachable linksys usb wireless node
A maximum
with wifi 128
A maximum without wifi 41
-------------------- "A warning , with love and peace"
post version
[Re: Martin Walker]
#589205 - 09/03/08 03:39 PM
i mean nvidia 7600s
Shifty
[Re: Martin Walker]
#589240 - 09/03/08 06:15 PM
Hp NX7400 Laptop - 2.0Ghz Core2Duo T7200, 2Gb Ram, Windows XP Pro, EMU1616 PCMCIA
soundcard Basic Install, fairly stripped down. With no soundcard
plugged in : Reading between 4 and 10 typical, with a peak at 17 With Soundcard Plugged in (and song running at 224 samples/6ms) : Reading
Between 85 and 95 typical with a peak of 105 Adding WiFi and Ethernet: Reading between 123 and 184 typical with a peak of 754 The surprise culprit
seems to be the Broadcom 440x Ethernet card - It's just as bad as the Wifi Card
Blink
Loc: London, UK
[Re: Shifty]
#589242 - 09/03/08 06:27 PM
Dell Vostro 1500 laptop.
T7300 2x2.00Ghz
4Gb Ram (3.5Gb Showing)
Windows XP Pro
Music boot:
Normal 90uS
Peak 168uS
(Edit: realised I had the network controllers installed. As soon as I disabled those,
it went down to averaging around 30uS)
Normal Boot
Normal 190uS
Peak 337uS
My desktop surprised me - It is permenantly online using the
onboard NIC, has AV and firewall running and no tweaks on it whatsoever
Abit
Fatal1ty AN8-SLi
Amd Athlon 4000+
2Gb RAM
Windows XP Pro
Normal 15uS
Peak 52uS
-------------------- Is thinking about starting a new project
Edited by Blink (09/03/08 06:31 PM)
_Nuno_
Loc: Cork, Ireland
[Re: Blink]
#589298 - 09/03/08 10:57 PM
Quote Blink:
Dell Vostro 1500
laptop. T7300 2x2.00Ghz 4Gb Ram (3.5Gb Showing) Windows XP Pro
Music boot: Normal 90uS Peak 168uS
network controllers installed. As soon as I disabled those, it went down to averaging
around 30uS)
Normal Boot Normal 190uS Peak 337uS
Good results. I'd like to get my
inspiron like that. What drivers have you installed on it?
Also, what soundcard
are you using with it?
Loc: Cornwall, UK
[Re: Martin Walker]
#589440 - 10/03/08 12:48 PM
This is all interesting stuff folks, and it seems to be making people more aware of rogue
hardware devices, which can only be a good thing. jacob - the fact that your
Internet-enabled setup has a lower DPC Latency than your stripped-down music partition
should hopefully help you track down the culprit. Shifty - With Chopsy getting
10 typical and 36 peak with a network card running, your results of 85/105 jumping to
123/754 with the Broadcom 440x Ethernet card suggest that not all ethernet cards are equal
in the eyes of the musician  Martin
Blink
Loc: London, UK
[Re: _Nuno_]
#589450 - 10/03/08 01:01 PM
Quote Nuno_:
Good results.
I'd like to get my inspiron like that. What drivers have you installed on it?
Also, what soundcard are you using with it?
I am running an Edirol UA-101 and the drivers that came on the
CD. the machine is about 3 months old, so I am not sure how new the drivers are.
Disabling both the network controllers made a big difference (especially the broadcom
one).
I am also using a little app (can't remember the name now - will check
topnight), which keeps the processor running flat out - not sure if that makes a
difference
Shifty
[Re: Martin Walker]
#589578 - 10/03/08 06:06 PM
Shifty - With Chopsy getting 10 typical and 36 peak with a network card running, your
results of 85/105 jumping to 123/754 with the Broadcom 440x Ethernet card suggest that not
all ethernet cards are equal in the eyes of the musician
Yeah - it's the
last thing that I'd check when choosing a laptop to be honest !
Luckily I
don't have much need for the Ethernet or Wireless cards when making music, so it's not a
massive issue (and there's not a lot I can do about it on a laptop!). At least it's not
something like a USB controller or disk controller that's causing the jumps.
I'm not sure that the EMU1616 adding such a big chunk of latency is a particularly good
thing either. I'm able to get a soundcard buffer size of 224 samples (5.6 ms) but no lower
without clicks , which is slightly disapointing for a modern machine.
The
NX7400 even has a TI chipset for the PCMCIA card as well
Ah well, at least it all works without pops and stutters!
Edited by Shifty (10/03/08 06:11 PM)
OneManBanned
Loc: Salisbury
[Re: Martin Walker]
#589606 - 10/03/08 08:11 PM
The PC i'm on at the mo (admittedly not my main music pc which i'll check later..):
Intel Conroe E6400 2.13GHz Mobo: Gigbyte 965P-DS3P Ram: 2gig DDR2
PC2-5300 (333MHz) Windows XP pro Service Pack 3
Typically: 10 - 15uS with
occasional peaks to 22uS
Maxium: 135 uS
I presume maximum reading
should be taken with no programs running. So reading was taken in the time it took me to
write this with just DPC latency checker and firefox running.
lachris
Loc: Asker, Norway
[Re: Martin Walker]
#589774 - 11/03/08 11:22 AM
My laptop: HP Compaq nc6220 Pemtium M 1.86GHz 1GB RAM 60GB Ultra
ATA-100 5400 RPM 8MB CDRW/DVD-ROM combo Intel a/g wireless Built-in Intel
display adapter Windows XP Pro SP2
My dpclat results: Repeating 20us
with no peaks. Except when I move the mouse, it goes to 2-400us (rarely above 275us)
Everything on. Nothing disabled.
Ruaridh
Loc: Central Scotland
[Re: Martin Walker]
#589863 - 11/03/08 02:30 PM
Finaly getting the chance to play with my Compaq
nx6310 laptop. (Thanks to TFT)
Coupled to an M-audio NRV10 (firewire) I played a Cubase Studio 4 song
with 24 audio tracks playing and 8 simultanious audio tracks recording. All networking
off. No audio tweeks yet. The machine took it in it's stride.
I got:
Typicaly 75(ish)
Max: 168
With all networking turned back on -
though nothing conected - I got:
Typical 140
Max: 224
Moving the
mouse made no difference.
The ONLY time I saw it go into the red was when I
pressed the wireless activation button after I had re-enabled the networking.
Task manager showed Cubase at about 10-12% CPU ussage.
NRV10 set to 64 samples at
44.1 KHz. Cubase showed Input latency 3.9ms, output 3.9ms.
I'll try it on the
desktop PC later on.
-------------------- Ruaridh (Pronounced "Rory").
Cubase 5 AMD Athlon X2 64 5200+. 2 Gig RAM. 2x7,200 IDE drives. Windows XP home sp2. Terratec EWS 88 MT. Guitars, Marshall Amps, Beer.
Edited by Ruaridh (11/03/08 02:37 PM)
