Main Forums >> Live Sound & Performance
        Print Thread
Pages: 1
orangefunk
new member
What mic for a sax?
      #67691 - 29/12/04 10:34 PM
My sax player is looking for a new mic for live use. We tried my SM58 today and it sounded very bright and all top end with no bass..
Any suggestions for a good live mic under £100 (high limit)
Cheers
O
Ultimate Fish
posting's fun
Loc: York, UK
Re: What mic for a sax? new [Re: orangefunk]
      #67778 - 30/12/04 10:22 AM
Get one of these: http://www.audiotechnica.com/prodpro/profiles/AT831b.html
and an AT8418 to go with it: http://www.audiotechnica.com/guide/other/misc/mounts/index.html
(it's a bit down the page) I've used this combination on sax and trumpet and it sounds good. It's a bit above your budget, but it'll do the job well.
need to get rid of this stupid sig...
Hugh RobjohnsAdministrator
SOS Technical Editor
Loc: Worcestershire
      #67799 - 30/12/04 11:35 AM
Quote orangefunk:
The SM58 is designed to be as a vocal mic very close to the vocalist's mouth. It has a deliberately rolled off bottom end which only sounds right when used very close to the source so that the proximity effect bolsters the LF.
So, if you placed the SM58 more than a few inches away from the sax, it would tend to sound very thin.
Secondly, the sax is a complex instrument in terms of where the different harmonic components are emitted fromthe instrument. Placing a mic in the bell (as most stage applications do) will tend to produce a very 'sqawky' bright sound. If you want a mellow sound, you have to place the mic further back and angled so it can 'see' the rest of the instrument body... but to do that you'll need a mic which provides a much flatter basic response.
I can't recommend any specific models in your price range, but look for a general purpose instrument mic, rather than a vocalist mic, and something with a flat response without too much proximity effect. A dynamic mic would probably give you a fuller sound than a condenser, although there are a lot of very affordable condensers around these days that sound excellent.
Hope that helps
hugh
Guy Johnson
Loc: Pembrokeshire
      #67941 - 30/12/04 06:11 PM
I use a TGX 45 vocal mike, and rolloff Tons of top.
It has a good bass response, and so can get you body . . .
G
PA stuff on FB
orangefunk
new member
      #67979 - 30/12/04 09:32 PM
thanks all... I think we're tending to favour a traditional mic over a clip on mic as you can do more with regard to getting different sounds by moving close and further away..
What about a Shure SM57?
Ultimate Fish
posting's fun
Loc: York, UK
      #68115 - 31/12/04 12:31 PM
The 57 is a good instrument mic. It really depends on how much noise is around and how much gain you want to achieve. A clip on mic is a good compromise in a noisy situation, but if things are a bit more mellow then a 57 would work well. You'll probably still find that you have to get quite close to it though.
Mr C
Re: What mic for a sax? new [Re: Ultimate Fish]
      #68185 - 31/12/04 05:02 PM
I would say your best bet is to use a Beta 57a. An SM58 is a good all round mic, it has a fairly flat response but as already stated it does have its bottom end rolled off around 200hz to provide more detail to vocals and speech, which as you know wont provide much weight to your sax. The Sm57 is very similar spec to the Sm58 its just designed more for pointing at drum skins and guitars etc. The Beta57a however will provide much more warmth in the places you need it. I will also add that positioning is just as crucial as using the right type of mic, this mic will work best around an inch or two from the source, i too would not recommend placing the mic into the bell after all the sax is an instrument that really projects its sound and this is where the most rounded sounds can be found.
Loc: Worcestershire
Re: What mic for a sax? new [Re: Mr C]
      #68353 - 01/01/05 10:26 AM
Quote Mr C:
An SM58 is a good all round mic, it has a fairly flat response but as already stated it does have its bottom end rolled off around 200hz to provide more detail to vocals and speech...
Sorry to be picky, but this isn't actually the case. The low frequency roll off is there to help reduce the chances of acoustic feedback in live stage applications. It certainly doesn't provide more detail to vocals or speech -- that is the role of the whopping +5dB presence peak that spans roughly 2 to 10kHz.
When used very close (ie under a couple of inches) to the source (ie mouth) the inherent proximity effect restores the LF response for the source, thus providing the required full bodied sound.
However, distant sources (such as the foldback monitors) are still heavily attenuated at low frequencies which is very handy since the mic's nominally cardioid polar response inherently opens out towards omni at low frequencies, thus providing far less rejection to the rear.
hugh
adrian_k
Loc: Gloucestershire
      #68824 - 03/01/05 11:18 AM
Based on your budget, how about an AKG C419?
I can't see any standard dynamic mic being satisfactory unless you can nail the player's feet to the floor, those I've played with say they can't play unless they can move...
cheers
Guy Johnson
Loc: Pembrokeshire
      #69090 - 03/01/05 11:18 PM
I have found that saxes with 'on board' mics never are as dynamic. With a fixed mic on a stand, the player can move in and out, and make a much more involving performance.
G
PA stuff on FB
Michael Harrison
active member
Loc: Glasgow, Scotland
Re: What mic for a sax? new [Re: adrian_k]
      #69128 - 04/01/05 01:53 AM
Quote dunch:
...because they sound like sh*t??!
Sorry, I'll try something more constructive.
The C419 is a condenser, and as such requires phantom power. Being a small clip-on mic, it has a very slim cable (about 2mm thick) which terminates in a phantom power adapter; a kind of lengthy XLR barrel-type unit. This plugs into either your preamp, stagebox or another XLR to extend length.
I used these mics as part of an AKG drum mic kit a few years ago. Apart from not liking the sound (slightly hard & boxy; personal opinion) I found them to be quite fragile/succeptible to damage, and the attached cable seemed quite flimsy too.
The reason I state this is that if being used on sax, I'd personally be concerned that the player might stand on the cable as he's moving about (if so), and with the next movement damage the mic, cable or phantom power attachment. Something to consider...
Note - I'm typing this from memory; if any of this is wrong, I stand to be corrected!
Although I like AKG stuff, I thought they were an odd product; a bit flimsy for live use, and there are many better sounding mics which can be used in the studio. Still, each to their own.
Mike
www.ehsound.co.uk - Live Sound Hire & Services
James PerrettModerator
Loc: The wilds of Hampshire
Re: What mic for a sax? new [Re: Michael Harrison]
      #69290 - 04/01/05 02:03 PM
The AKG sax mic comes with a belt pack that either contains batteries or uses phantom power. To my ears an SM58 sounds better - the AKG needs major EQ to get a good sound. Some sax players don't like clip on mics because they use the proximity effect as part of their sound. Some sax players also like to quietly try things out off mic too. A Sennheiser 421 would be another suggestion. I've also used a Sennheiser 504 on sax with acceptable results.
Cheers.
James.
JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
morphsville
new member
Loc: Belfast
      #69379 - 04/01/05 05:44 PM
I helped a live engineer friend at a jazz festival once and he tried an Audix OM7 on sax and it sounded great, except it is a lot more directional than a 57 or 58 so the sound was jumping about as the player moved off axis...
He said his usual "go to" mic on Saxophones is the Audix D2 or D4
Ultimate Fish
posting's fun
Loc: York, UK
Re: What mic for a sax? new [Re: Guy Johnson]
      #69558 - 05/01/05 08:34 AM
Quote Guy Johnson:
G
That's true, but it does rely on the player having a good mic technique.
Guy Johnson
Loc: Pembrokeshire
      #69895 - 05/01/05 07:38 PM
Sure - buy the good players normally do have good mic technique, as do good singers . . .
Hmm . . . let's hope we don't get a repeat of a previous thread in the old Forum!
G
PA stuff on FB
Thomas Hobbes
      #70034 - 06/01/05 01:07 AM
Starting off, if you didn't like the SM58, you won't like the SM57, it is basically the same response plot.
Moving right along. I ahve had great success with using Sennheiser's e609-Silver for sax and horns. It is hyper-cardiod, so that will effect you if you sway alot when playing. Great off axis rejection, and yes typically used for electric guitar, short of an MD421, best mic I have heard for sax.
Guy Johnson
Loc: Pembrokeshire
      #70406 - 06/01/05 06:23 PM
The SM 57 has a better bass and treble-response, than the '58.
G
PA stuff on FB
Zarf
member
      #71336 - 08/01/05 08:26 PM
You could try the small MXL mic - MXL 603. They're pretty fair on sax, but I've never tried one live so don't know about feedback rejection. Maybe scour ebay for a used MD421?
Zarf
Guy Johnson
Loc: Pembrokeshire
      #71451 - 09/01/05 10:52 AM
I have 3 used 421's (no, I'm NOT selling them!) and they are brilliant mics - worth trying on anyhting, and often overlooked on recordings, too.
G
PA stuff on FB
Mr C
      #72082 - 10/01/05 06:25 PM
Yes the MD421 is a great mic but the brief was a microphone that costs no more than £100. You are suggesting mics that cost £200 - £300! Thats why i suggested the Beta 57a and it isn't exactly the same plot as an SM57. There are much better mics for the job but not for less than 100 quid!
http://164.109.27.207/microphones/models/beta57a.asp
Guy Johnson
Loc: Pembrokeshire
      #72252 - 11/01/05 12:11 AM
Phaaa! Briefs!! Panties!!!
Someone wants a good sound, they will have to spend some cash, and comparisons are also very useful.
G
PA stuff on FB
LawrenceH
member
Loc: Cambridge
      #72941 - 12/01/05 10:05 PM
Hi,
For under £100 I think the Rode NT3 is a very good choice, recommended to me in turn by a sax player on this forum. It has a lot more detail and is much smoother than an sm58 - however it depends what kind of music you play. They have a battery power option as well as phantom, and seem pretty robust. However it has quite a strong output at +48 so an older mixer might struggle with the gain range - I used mine into an old Spirit Live desk and the clip light was coming on with the gain at minimum. Oh and Digital village are doing them for £90 at the moment, an absolute bargain IMHO.
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 12 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, Paul White, zenguitar, Martin Walker, Forum Admin, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts,
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Home | Search | News | Current Issue | Digital Editions | Articles | Forum | Subscribe | Shop | Readers Ads
Advertise | Information | Links | Privacy Policy | Support
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
