Mart[y]n
Loc: London, UK
CELLO!
#734103 - 12/05/09 01:48 PM
He guys I'm recording cello tomorrow. Any tips on mic choice, placement etc..?
I've got access to 57's, 58's, RE20 and maybe C414 or U87s.
Suuggestions?
Cheers in advance
Martyn
-------------------- Look Up. Captain Christ says you think too much about the wrong things. You sing about the wrong things. Take Extra Special Care.
John Willett
Loc: Oxfordshire UK
Re: CELLO!
[Re: Mart[y]n]
#734130 - 12/05/09 03:07 PM
This is how a cello radiates sound at different frequencies:- Left-hand images are the side view Right-hand images are the plan view You will see that there is no single
place for a microphone that gets all the frequencies the cello is radiating. Best thing tp do is to get the cellist to p[lay and listen with your ears - then place
the microphone at the point where it sounds best to your ears. I hope this
helps.
-------------------- John - Sound-Link ProAudio
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734131 - 12/05/09 03:07 PM
My first choice for micing a cello would be a ribbon mic (coles or even one of the cheaper
chinese ones like the Golden age etc). Second would be the U87. The dynamic mics mentioned
won't sound right I don't think. The ribbon mic will give you a sound that will fit better
into a mix and the brighter LDC will give you a more detailed solo sound. Try to keep the
mic at least 3 or 4 feet away and parallel to the cello table as a starting point.
jammy jamz
Loc: canada
Re: CELLO!
[Re: Rain]
#734161 - 12/05/09 04:11 PM
lucky Mart[y]n !! cello is my favorite instrument of all . i hope for you the player is
awesome. thats a treat to sit in a nice room with a great player.  what i would do if i was in your position, with your mic choices is: 1.
listen to the piece to be recorded, and figure out where abouts the frequency range of it
will be sitting the most. because, as that diagram shows how varied the projection of the
instrument is. 2. find the sweet spot, prob not less then 2-3 feet...(i say
prob, because of the no rules in music. uh rule.) and, then, 3.
if i was doing the session, i would use the 414 in a figure of 8 pattern with the blind
sides pointing at the cello, and the wall directly across from the cello, and then either
the 87, or the RE, facing the cello. i think its called the Bluemen theory of something.
anyways, you take the center channel, (87 or RE), and then double the 414
channel, and phase reverse it. i love doing this method for the weight it gives
the instrument.... L = 414 C = 87, or RE R = 414 copied, and
phase reversed. and pan till it sits right. this will be according to the full
mix...but, its fun to play with the cello just soloed. have fun man. color me
jealous. nice mic selection too.
-------------------- music is my girlfriend
Mart[y]n
Loc: London, UK
Re: CELLO!
[Re: Rain]
#734162 - 12/05/09 04:12 PM
Wow! Two great responses... The diagram John is brilliant, and makes me think about double
miking the cello for a more balanced and full sound.
Maybe a RE20 for the low
frequencies and a U87 for the mid and high? Placed in areas coinciding with the
diagram...
However Rain, you mention that the dynamic microphones probably wont
perform. I'm not sure if I can get hold of a Ribbon mic so short notice [on my budget!] so
maybe double miking with 2 U87's might be a good shout?
Mart[y]n
Loc: London, UK
Re: CELLO!
[Re: jammy jamz]
#734168 - 12/05/09 04:20 PM
Quote jammy jamz:
l 3. if i
was doing the session, i would use the 414 in a figure of 8 pattern with the blind sides
pointing at the cello, and the wall directly across from the cello, and then either the
anyways, you take the center channel, (87 or RE), and then double the 414 channel,
i love doing this method for the weight it gives the
instrument....
L = 414 C = 87, or RE R = 414 copied, and phase
reversed.
Hey dude cheers for the reply it came
exactly as I posted the other! D'OH!
Sounds like a good method, when you say
copy the 414 do you mean record it then copy the file to another channel?
To
put it in context it will sitting with an acoustic guitar and twin vocals so theres lots
of space, I'm sure you remember me talking about it in my vintage bob dylan thread
earlier.....
void(0)
jammy jamz
Loc: canada
Re: CELLO!
[Re: Mart[y]n]
#734175 - 12/05/09 04:36 PM
Quote Mart[y]n:
Hey
dude cheers for the reply it came exactly as I posted the other! D'OH!
Sounds
like a good method, when you say copy the 414 do you mean record it then copy the file to
another channel?
void(0)
yep. exactly.
you will have two 414 tracks in the mix. the original recorded one, and the one you copy,
and paste into another track. plus the center channel. cool technique.
i've
tried it, and i love it, but, it is all subjective, or relative, or absolute luck (in my
case maybe)
i thought you wanted to go for the off the floor, live thing?
jammy jamz
Loc: canada
Re: CELLO!
[Re: jammy jamz]
#734190 - 12/05/09 05:20 PM
Mart[y]n
Loc: London, UK
Re: CELLO!
[Re: jammy jamz]
#734193 - 12/05/09 05:34 PM
Yeah the recordings ended up being recorded multi tracked and the result is becoming more
and more commercial. We tested early tracks on the radio and although they sounded vintage
they just did not hold up against other tracks.
I'll put up a link or something
when its done an dusted so you can see what you think...
Technique sounds good,
think I'll try it....
Setter
member
Loc: Tesside UK
Re: CELLO!
[Re: jammy jamz]
#734202 - 12/05/09 06:30 PM
Quote jammy jamz:
i think its
It's called Mid and Side, MS, or M/S and can be great. There are
many threads on this forum to give you a better idea as it can be a bit tricky to get your
head round. Basically the 87 or RE gets the basic sound (panned to the middle) and the 414
(panned to extremr left and right but inverted to one side) gives the extra stereo
information.
It's great for choirs and orchestras but i've never heard of it
being used this close to a solo instrument before. I'm sure some of the experts will be
along shortly.
J
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734213 - 12/05/09 07:33 PM
I'm not an expert but... Most dynamic mics I've heard don't really seem to suit solo
strings. Violins and cellos etc have very strong resonant peaks and they don't seem to
flatter them. An M/S stereo mic setup can sound really nice on a solo instrument in a good
sounding room but it really has to be a good room and a room you want to hear. As you can
see from the above charts (very kindly provided!) you need to get the mic (s) quite a long
way from the cello before you will get a balanced sound. The side mic (figure of 8) is
really only picking up the sound of the room unless what you are recording has a wide
spread i.e. choir, orchestra, drum kit (that's primarily why people use M/S in these
situations). I'm not sure it's going to help to record the cello in stereo, especially if
it's going to be used in context with a lot of other instruments. If you're recording
classical solo cello and piano in a nice hall maybe. Having said that, the advantage of MS
is that when you mix you can just get rid of the side mic and use the central mono (U87).
Hope you have fun anyway... I love recording cello. It's like having your own
private recital. I use a guy called Matthew Sharp who has 300 year old italian cello and
it shakes the house!
Good luck!
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734218 - 12/05/09 07:48 PM
Sorry martyn, missed the bit about 'just a guitar and two voices' - So pretty spacious
arrangement. What's the room like where you are recording? Is it the kind of ambience you
want for the recording or are you going to keep it dry and add reverb later? If the former
try the 414/U87 MS method ('proper' MS needs the mono mic (U87) to be omni), if the latter
mono U87 cardioid should do it. As mentioned earlier 'listen with your ears' (what a
lovely expression! Only a musician/engineer would understand that!) and place the mics
accordingly.
A recent project we did used a string quartet in a fairly busy
pop arrangement so that was what was on my mind - lucky enough to get to record the
strings at Abbey Road B and the in-house engineers just dangled an old Coles 4038 ribbon
mic about four or five feet in front of each player and it sounded perfect....
Edited by Rain (12/05/09 07:52 PM)
jammy jamz
Loc: canada
Re: CELLO!
[Re: Rain]
#734224 - 12/05/09 08:21 PM
no fair Rain. you just blew my mind with: string quartet Abbey
road B coles 4038 @ five feet maaaaaaaaan i can only imagine how freakin
awesome that was.  did it go
to tape? or digital? i ask because, in my imagination, its going to a 16-track 2"
machine. i suggested the M/S micing arrangement Mart[y]n, because, I think
it will help give you that sound that you're after. a nice room, tho, always always always
helps man Abbey road B. for the love of all things perfect. i am so happy to be able to talk shop with you folks, words will never be able to
express my appreciation of the knowledge, and ideas. and humour
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: jammy jamz]
#734231 - 12/05/09 08:58 PM
Hi J J You obviously haven't read my other posts about tape!  (hint -
prefers digital) Sorry to dispel the romance but it was all pro tools. Did go through
their very nice Neve desk though... and yeah the room sounds ok too  But full of
the ghosts of Rick Wright and John Lennon and others - seriously. Very tangible
atmosphere. Still, some of the other tracks (with violin and cello) for this
album have been recorded in my 7' x 11' back bedroom on a £70 chinese ribbon mic,
fireface and PC and the artist's manager said he preferred them to the Abbey Road
ones.... BTW It is an amazing forum and I learn things every time I log in
here.
Bradley Steenkamp
member
Loc: West Sussex
Re: CELLO!
[Re: Mart[y]n]
#734241 - 12/05/09 09:49 PM
I think the M/S idea with the U87 in the middle and the 414's is a really good idea. It is
completely risk free as long as you make sure you find a good position for the mics. You
don't have to use the 414 at all if you prefer the sound of just the u87. You can also use
the 414 for the stereo information at a level that is just right when mixing. I've used this setup on acoustic guitar more than once and it can work really well.
-------------------- www.bradleysteenkamp.com
Mart[y]n
Loc: London, UK
Re: CELLO!
[Re: Rain]
#734391 - 13/05/09 12:25 PM
JJ & Rain,
Represent my friends. Not to take away from everyone else's
great input though. Thanks for all the feedback. Don't think the room is going to sound
amazing, it really is a budget job [as in there is no budget - and not in a good way] but
I'm sure with the MS technique and a bit of cheeky mixing it'll sound sweet.
Abbey Road tales are lovely and have filled my spank bank for another week. Not to take
sides either JJ but I'm a Pro Tools man too..... but i think thats another conversation
for another thread!
jammy jamz
Loc: canada
Re: CELLO!
[Re: Mart[y]n]
#734404 - 13/05/09 01:17 PM
sorry for the un-intentional hijack.  im a digital fella too, but, one of my first experiences in a recording studio, i was a
singer in a RAWK band, and we tracked to 16 2" machine. those rolls going around, were
almost hypnotyzing, but, the card for track 8 would sometimes short out, and would have to
be pulled out, and reseated. it only affected the tracking once, but, it was delegated to
a 15 track, 2" machine, rather quickly. im looking forward to hearing your
mixes Mart[y]n. i will be putting some stuff up on my bands myspace page very soon as
well. its also acct. gtr, and cello, but, with an acct bass thrown in as well, and let me
tell you, gettin an acct bass, and a cello to sit right with each other without competing
for the low frequency energy,...was pretty hard to get right. i think im almost there
tho.
ROLO46
Loc: Cotswolds
Re: CELLO!
[Re: Mart[y]n]
#734486 - 13/05/09 04:15 PM
For proper MS its 2 identical fig 8'S Thats Blumlein But any M config mike can
be used as long as its the same manufacturer and same size for alignment Its
tweakable from coincident stereo to mono by manipulation of S. M=S=LH, M-S= RH
-------------------- I am the Walrus.
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: ROLO46]
#734540 - 13/05/09 06:13 PM
Hi rolo
I've never heard of the middle mic of an MS set up being a figure 8?? I
would have thought that would have defeated the phase cancellations that make the MS work.
That's why the mid mic should really be an omni. Ideally you'd like the two mics to be
identical but it's not at all essential. I've seen SDC mid and LDC side used together in
pro situations often too, although often it'll be something like two 414s or two U87s.
Blumlein's is totally different to MS and works in a completely different way. It
is a coincident xy technique with the two figure 8s at 90degrees.
"The Blumlein
stereo set-up is a coincidence stereo technique, which uses two bi-directional microphones
in the same point and angled at 90° to each other. This stereo technique will normally
give the best results when used at shorter distances to the sound source, as
bi-directional microphones are using the pressure gradient transducer technology and
therefore is under influence of the proximity effect. At larger distances these
microphones therefore will loose the low frequencies. The Blumlein stereo is purely
producing intensity related stereo information. It has a higher channel separation than
the XY stereo, but has the disadvantage, that sound sources located behind the stereo pair
also will be picked up and even be reproduced with inverted phase." DPA mics info
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734542 - 13/05/09 06:36 PM
Aural Reject
Loc: Lancashire
Re: CELLO!
[Re: Rain]
#734546 - 13/05/09 06:46 PM
Quote Rain:
That's why the mid
It can be anything you want it to be (within reason).
Edit: And the
DPA site you've just linked to shows a cardioid mid mic
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734554 - 13/05/09 07:00 PM
Yeah what I really mean is that an omni sounds so much better! (You should always do what
I think is best  ) The DPA site shows a cardioid (fools!) but then says... "Normally a cardioid microphone capsule is chosen for the Mid channel, but omnis are
sometimes preferred to capture low frequency richness at distance." It will
sound better, believe me! Check out Michael Stavrou's great book, 'Mixing With Your Mind',
he will agree!
John Willett
Loc: Oxfordshire UK
Re: CELLO!
[Re: Rain]
#734555 - 13/05/09 07:01 PM
Quote Rain:
I've never heard of
This is what Alan Dower Blumlein himself used - two fig.8s in
MS at equal level give the same result as an XY Blumlein pair. The advantage of doing
this in MS is that the angle is easily narrowed or widened without touching the mics.
With an omni as mid - the result is back-to-back cardioids.
With a
cardioid as mid - the result is crossed super-cardioids. This is the most popular for
music recording. Though I have used an MKH 800 is super-cardiuoid mode as a mid recording
Chloe Hanslip in the Wigmore Hall not too long ago.
But with MS you can use
anything you like as the mid - the only fixed point is that you *must* use a fig.8 as the
side (+ve to left).
I really don't like using an omni as mid - if you need
the bass I would use an MS pair of cardioid + fig.8 and have a pair of omni outriggers to
fill in the bottom end. Also look at Alan Blumlein's "shuffling" method.
Aural Reject
Loc: Lancashire
Re: CELLO!
[Re: Rain]
#734558 - 13/05/09 07:03 PM
Actually I'd rather trust my own ears and use what's best for the job at hand  Books are one thing, reality can sometimes be something else. Omnis can be
disfavoured for various reasons, you might want to use a hypercardioid for other
reasons....blanket statements don't work for me I'm afraid
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734560 - 13/05/09 07:05 PM
See what I mean about learning something new everyday here?
Thanks John
John Willett
Loc: Oxfordshire UK
Quote Aural Reject:
....blanket
Same here.
Anonymous
Unregistered
Re: CELLO!
[Re: Rain]
#734569 - 13/05/09 07:18 PM
You can use any pattern as the mid mic.
It doesn't have to be omni any more
than it has to be fig-8. Omni has the advantage of supplying some of the LF lost in the
fig-8 mic (unless you're using a pre-EQ'ed fig-8 mic or or adding some LF to a natural
fig-8) but often I find that it can give too much room and the image can be a bit wooly
compared to fig-8 or other directional mid mics.
Whilst there are good
reasons for choosing mics from the same manufacturer or series, it's not written in
stone.
Neither is using only two mics of the same type, e.g. LDC, SDC,
Ribbon.
It's perfectly possible to mix and match makes, models and types as
long as you can physically mount the mics in the necessary configuration and you choose
mics whose frequency responses and polar pattern characteristics don't cause problems.
Using two mics from the same range usually/often simplifies mounting and will (hopefully)
provide a good match in characteristics.
up being a figure 8?? I would have thought that would have defeated the phase
Yes and no. Two fig-8 mics in MS was Blumlein's idea and is fairly common, e.g.
many stereo ribbon mics support this configration. The cute thing about it is that unlike
any other MS combination, the resultant patterns (see the articles below for an
explanation of that if needed) when the MS signals are matrixed are a crossed pair of
fig-8s. Combining the fig-8 Side with any other pattern of mid results in a matrixed pair
which is a combination of the two.
Nope. Even in the DPA link you give, a
cardioid is shown with omni mentioned as a possibility. It all depends upon what you want
to achieve. The theory stands up for all patterns.
in a completely different way. It is a coincident xy technique with the two figure 8s
at 90degrees.
..er...
Exactly like two fig-8 mics in MS then
I'd suggest reading some of Hugh's excellent articles on mic techniques - including MS,
and/or some of the many posts on this forum, and perhaps the following articles from the
AEA Website .
Basic Microphone Perspectives - A Review (Ron Streicher & Wes
Dooley)
The
Bi-Directional Microphone - A Forgotten Patriarch (Same authors)
MS Stereo - A Brief
Tutorial (Ron Streicher)
MS Stereo - A Powerful
Technique for Working in Stereo (Same authors)
... and if that got you
thinking ...
The Inventor of
Stereo : The life and works of Alan Dower Blumlein
and
The Life and
Times of Alan Dower Blumlein (IEE History of Technology) (IEE History of
Technology)PBHT0240
EDIT: (And whilst I typed out that lot and ate
dinner, everyone beat me to it )
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734571 - 13/05/09 07:25 PM
Points taken and I'm happy to bow to superior knowledge and experience. We all go by our
own experience and my use of MS is relatively limited and mainly to solo classical guitar.
I only mentioned it as I had a very interesting conversation with Michael Stavrou about
his favouring an omni mid mic in MS when recording John Williams solo guitar. I only asked
him as he got one of the nicest guitar sounds I'd ever heard - mainly due to it being John
Williams no doubt! I tried the technique myself both with cardioid and omni and preferred
the omni but obviously this is a specific circumstance, room, instrument etc. Wouldn't
normally go with 'blanket rules' but when something works and sounds great, maybe I get a
little carried away!
Martyn - listen to these other guys, not me!
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734573 - 13/05/09 07:28 PM
Why do I have to come up against all the geniuses?
ROLO46
Loc: Cotswolds
Re: CELLO!
[Re: Mart[y]n]
#734601 - 13/05/09 10:04 PM
MS looks complicated But on closer inspection its common sense Alan Dower
Blumlein, a minor deity in my book, all done mid (no side!)1930's. The anglo saxons
went ribbon , the saxons condensor Along with the Brit inventor of PCM also in the
30's Roger
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: Mart[y]n]
#734623 - 13/05/09 11:18 PM
Ovu/John/rolo46 or Roger /aural reject
Thanks for all the Blumlein links. I
shall delve into them when I get some time but before I do, could I ask a couple of quick
and possibly dim questions?
Firstly, I take it that you mean that a
coincident XY at 90degrees with figure-of-eight mics is pretty much the same as MS with
two figure of eight mics? If so, what, if any, are the differences?
Secondly,
when MS was first explained to me I remember that I was given a very definite reason why
it was considered technically advantageous for the mid mic to be omni that seemed to make
good sense at the time. Unfortunately, I can’t remember the reasoning now! Can you think
of any reason why I might have been told this?
Below is Michael Stavrou’s
take on this (recording a few feet from solo instruments), that reinforced that idea.
I’d be interested to hear your thoughts on what he says.
“Cardioid vs
Omni Ms
Some people seem to think that using a cardioid mic in place of an omni is
okay. Not so. In fact, it’s a really bad idea and I’ll tell you why. The left-to-right
image of the stereo is made up of the combined signal of the omni and each side of the
figure-of-eight.
Using a cardioid means that the left and right extremities
of the stereo are created by combining the beautifully flat response of the
figure-of-eight with an incredibly dull response of the off-axis cardioid. The end result
is a stereo image that loses reality as you stray towards the edges. What’s more, when
you collapse this picture to mono you lose all the definition from the sides – the image
will be thin and unrealistic.
The original idea behind MS was that, in mono,
you still got the whole picture – but if you use a cardioid microphone you only hear the
centre when you go to mono.”
Edited by Rain (13/05/09 11:22 PM)
jammy jamz
Loc: canada
Re: CELLO!
[Re: Rain]
#734642 - 14/05/09 02:12 AM
fellas, i just want to say that it makes me feel very happy and privileged, to
be a part of this thread with all y'all. yes, i said y'all.  what a community this is, and im lucky to be a part of it.
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: ROLO46]
#734668 - 14/05/09 08:04 AM
Quote ROLO46:
MS looks
complicated
Not to normal people it isn't! It's the
other way round. Looks simple but on closer inspection is quite complex and subtle! As
soon as I hear the term 'matrixing', I can feel some of my brain cells giving up and going
into hibernation!
JJ - yes a privilege indeed for all of us. In the old days
the only way you'd ever learn this stuff was by working at somewhere like the BBC or Air
studios.
John Willett
Loc: Oxfordshire UK
Re: CELLO!
[Re: Rain]
#734751 - 14/05/09 12:33 PM
Quote Rain:
Ovu/John/rolo46 or
Roger /aural reject
Thanks for all the Blumlein links. I shall delve into them
when I get some time but before I do, could I ask a couple of quick and possibly dim
questions?
Firstly, I take it that you mean that a coincident XY at 90degrees
with figure-of-eight mics is pretty much the same as MS with two figure of eight mics? If
0VU posted the link to Ron Streicher and Wes Dooley's AES paper
on stereo.
It clearly shows what happens to the resulting patterns using omni,
cardioid and fig-8 as the mid mic. It also shows what happens at various levels of the
side mic.
This was one of my favourite papers on stereo and well worth reading
- it should answer all your questions.
It's HERE.
Mart[y]n
Loc: London, UK
Wow. Anyone remember the scene in The Matrix where they just plug the dude in, then he
knows kung fu?
I feel like Ive just done that and became some kind of authority
on MS Technique! Well not an authority but I definitely know a lot more! Luckily my cello
session got moved to Friday so plenty of time to brush up.
Cheers for the
knowledge guys!
jammy jamz
Loc: canada
Re: CELLO!
[Re: Mart[y]n]
#734780 - 14/05/09 01:17 PM
there is no spoooooon,
but, hopefully, there will be cello, in the mix.
and of course, by hopefully, i meant there will be.
i knocked over the vase.
Edited by jammy jamz (14/05/09 01:20 PM)
abba_x
Re: CELLO!
[Re: Rain]
#734940 - 14/05/09 08:52 PM
Quote Rain:
“Cardioid vs Omni Ms Some people seem to think that using a cardioid mic in place
of an omni is okay. Not so. In fact, it’s a really bad idea and I’ll tell you why. The
left-to-right image of the stereo is made up of the combined signal of the omni and each
side of the figure-of-eight.
extremities of the stereo are created by combining the beautifully flat response of the
This supposes that you are using a cardioid mic in the 'M' position that has poor off
axis frequency response. This is not true of all mics, especially more expensive mics and
mics that you often find being used for this type of recording.
Consider a
coincident cardioid technique. Any instrument in the middle of the image is usually
hitting both mics at at least 45 degrees. This does not result in instruments in the
centre of the image sounding "thin and unrealistic". However this technique, along with
M/S using a cardioid mid mic, will show up the limitations of some mics.
Best
regards
ROLO46
Loc: Cotswolds
Re: CELLO!
[Re: abba_x]
#735123 - 15/05/09 12:53 PM
All flavours of mic can be M My personal fav is a fig 8 Even the feared
hypercardiod can be used including the new gen Shotguns from DPA and Schopes. Its all
a question of subjective sound That and mono comp is the beauty of MS.. Did a
big band last weekend Double fig 8 MS covered band and audience well Did singing
bowls Tuesday, close with MS fig 8s, result detail and ambience. Roger
Rain
member
Loc: Guildford UK
Re: CELLO!
[Re: ROLO46]
#735245 - 15/05/09 06:25 PM
Roger - could I ask out of idle interest what mics you used for the fig 8s?
Setter
member
Loc: Tesside UK
Re: CELLO!
[Re: Rain]
#735359 - 16/05/09 08:06 AM
Quote Rain:
Ovu/John/rolo46 or
Roger /aural reject
For M/S one mic points directly at the
centre and one points 'across'. For Blumlein it ois rotated 45° so the mics point to the
edge (or so) of the soundstage.
J
