Main Forums >> DIY, Electronics, Studio Design & Acoustics
        Print Thread
Pages: 1
Barilla
member
Loc: UK
Alternatives to Auralex-type foam adhesive? Other methods for foam?
      #739500 - 31/05/09 08:25 PM
Just wanting to mount a few acoustic foam tiles on a sloping (plasterboard) celiling... I'm not too thrilled by the idea of using the usual Auralex foam adhesive (expensive and messy). Are there any good alternative methods?
I can hang panels on walls, but a sloping ceiling is obviously a different scenario...
Any ideas greatfully received.
B.
NTA
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: Barilla]
      #739521 - 31/05/09 09:46 PM
you can use pins or tacks to hold them up? thats what i do in my bedroom and i'll be doing the same in my new studio space, no mess!
. . . Delete This
Here be Dragons
      #739553 - 31/05/09 11:46 PM
flexible silicon bathroom sealant... the stuff that smells like vinegar (acetic acid) not the stuff the smells of ammonia
Barilla
member
Loc: UK
      #739614 - 01/06/09 10:09 AM
Thanks, both of you - I'll try the pins first and see how that goes.
B.
Glenn Kuras
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: . . . Delete This User . . .]
      #739664 - 01/06/09 01:19 PM
Quote idris y draig:
You don't think that would tear up the walls?
Glenn
www.GIKAcoustics.com
Now with offices in the USA and Europe
Mike Stand
member
Loc: UK
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: Glenn Kuras]
      #739755 - 01/06/09 06:43 PM
Yes it does make a mess of the walls. I have just found out the hard way.
I have just hung mine by sticking a kiddies coat hanger to the back and hanging it on a picture hook. There may be a way of adapting this for a sloping ceiling.
Mike
Weasel9992
Loc: Savannah, GA
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: NTA]
      #739758 - 01/06/09 06:53 PM
Quote OllieJW:
T-pins...the type you can find in a fabric store.
Frank
Frank Oesterheld - GIK Acoustics
Studio Support Gnome
Not so Miserable Git
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: Mike Stand]
      #740058 - 02/06/09 08:04 PM
there are two basic types of Silicon sealant.... one that smells of urea/ammonia, which sets fairly hard (although still somehwat flexible) and isa complete buggger to remove..... and yes, would tear up the walls..... and takes longer to cure, and isn;t as sticky,
OR the other kind that smells of Acetic acid/vinegar, is softer, stickier, and peels off the wall afterwards , pretty easily .
i use it ALL the time..... and I've probably fitted more foam in the last 10 years than most of you will ever see in a lifetime....
trust me, it works...
anyone finding silicon seriously difficult to remove is probably suffering from having used the ammonia smelling one.....
if you don't know who i am, i aint gonna tell you.
NTA
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: Studio Support Gnome]
      #740078 - 02/06/09 09:15 PM
Quote Max!:
Is there anyway to tell by just looking at the tube? chemical info? i have two tubes of 'UNIVERSAL ACOUSTICS COSMIC FLUID' Anyone have experience with this stuff?
      #740082 - 02/06/09 09:23 PM
the right kind
the wrong kind..... i think.. (packaging has changed since I mistakenly last bought the wrong one...
never heard of that cosmic stuff.....
Keith Baker
      #740863 - 05/06/09 12:01 PM
Apologies to OP for hijacking the thread, but does this also apply to attaching a sheet of Auralex foam to the front of a rockwool panel per the SOS style of broadband trap. £25 for a can of Auralex adhesive(and I guess I would need a few) is a bit eyewatering. I tried standard carpet adhesive on a couple but the foam is beginning to fall off, so false economy there.
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: Keith Baker]
      #740890 - 05/06/09 01:15 PM
if you're using a single piece of Auralex or other foam on the front, then you ought to be able to edge bond it to the surrounding frame using the silicon sealant..
actually i've not tried to bond foam to rockwool in the absence of a supporting frame work.... so couldn't say how using multiple bits of foam might work... ... it OUGHT to work... i've bonded foam to foam like that.... but you need to be careful about coverage , getting enough to hold it, but not so much that you negatively affect the gas flow impedance behaviour through the material boundaries.
Keith Baker
      #740953 - 05/06/09 03:19 PM
Thanks Max
I suppose edge bonding might work but I would be worried about central sag - the foam, not my stomach - that happened ages ago!
I've seen some people say you can use the spray adhesive for carpets but that you need to use quite a bit, which I didn't do because as you said I didn't want to create an impermeable film. Guess that's why it's falling off.
Perhaps Auralex adhesive is worth the money after all 'cos you don't need much to make a secure bond.
So you don't face rockwool traps with foam? I thought that was the way to increase the effective frequency range of the trap.
BTW should I continue this discussion on a new thread as I've jumped in on someone elses post?
Keith
Weasel9992
Loc: Savannah, GA
      #740993 - 05/06/09 04:56 PM
I've actually used spray adhesive to do pretty much what you're trying to do, and it worked well...initially. All the 2'x2' tiles fell off within a few months though.
Frank
Keith Baker
      #741023 - 05/06/09 06:13 PM
OK so that's what not to do but.........
What did you do when they fell off - aside from the odd curse
Does the Auralex spray adhesive actually work much better than the generic spray adhesive or is there a better way of attaching foam to rockwool.
BTW Barilla please tell me if you haven't concluded your question yet as I'm concious that I'm on your thread.
omnirife
      #743448 - 12/06/09 06:14 PM
Hello,
I am having this exact problem. I bought a tube of Auralex adhesive to put up some foam (I was planning to build home-made panels, as per my topic elsewhere on this board, but have got a pay increase so decided just to save time and buy some foam) and have found that it's not great at keeping it stuck to the wall. The tiles tend to slide down the wall before falling off completely. That Wickes stuff might be worth a go.
I am concerned because if the Auralex stuff can't hold a few small panels, there's no way it'll be able to hold up the whopping heaavy bass traps I purchased! May even have to resort to those 'T-pins' mentioned above.
I bought the adhesive for £13 from here:
http://www.studiospares.com/Aerosols/Auralex-Tubetak-Pro-Liquid-Adhesive/i nvt/461660
And then bought a glue gun for about £2.50 from B&Q.
Weasel9992
Loc: Savannah, GA
Re: Alternatives to Auralex-type foam adhesive? Other methods for foam? new [Re: omnirife]
      #743457 - 12/06/09 06:42 PM
Quote omnirife:
Which "whopping heavy bass traps" do you have? If they're panel traps then you're right...the glue definitely won't hold them. We usually recommend heavy-duty picture hanging hooks or something like that.
Frank
Nimhbus
      #996184 - 04/07/12 06:21 PM
Thanks for the replies, everyone - silicon sealant it is!
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 23 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
