dickiefunk
Loc: Cornwall, UK
Need new silent power supply?
#746917 - 24/06/09 10:01 AM
I'm looking to buy a new silent power supply for my PC. What would you
recommend?
dickiefunk
Loc: Cornwall, UK
Re: Need new silent power supply?
[Re: dickiefunk]
#746927 - 24/06/09 10:24 AM
Here's some spec on my PC and usage.
Intel Core 2 Duo 2.4 gHz 4 GB 800 mhz
RAM Echo Layla 3G PCI interface Korg Kontrol Pad M-Audio Keystation 88ES
VSTi’s:
Garritan Steinway Pro, True Pianos, Sampletank 2XL, Garritan
Personal Orchestra, Superior Drummer 2.0, EzDrummer + Jazz, Vinatge Rock, Nashville &
Latin Percussion EZX’s, ManyBass, Many Guitar, VB3, Mr Ray mkII, Steinberg Virtual
Guitarist, Plugsound Rn’B Toolkit, Plugsound Fretted Instruments + lots of freeware
I also use IR reverbs etc.
Watcher Of The Skies
Loc: Cornwall, UK
[Re: dickiefunk]
#747091 - 24/06/09 05:26 PM
This is a tricky one DF. A 'silent' PSU is possible if it has a big heatsink
sufficient to dissipate all the heat it generates itself, but then you'll still have to
remove the extra heat generated by your CPU, expansion cards, hard drives, and so on, by
fitting a case fan to extract it. I'd go for a 'quiet' PSU (mine's a Seasonic
400-watt PSU model), temperature-controlled fans, and a decent case that makes sure you
hear as little as possible of the fan noise. Martin
-------------------- YewTreeMagic
Rain
member
Loc: Guildford UK
[Re: dickiefunk]
#747098 - 24/06/09 05:35 PM
Lots of good QUIET pc power supplies at quietpc.com. If you want a genuinely
SILENT psu try the silverstone 450 fanless. I've used one for a year or so now and it
works fine. Won't be ideal if your case requires the PSU fan for venting the case
though. BTW when did 'silent' stop meaning silent i.e. noiseless and start
meaning 'a bit quieter than very noisy'? Maybe at the same time as tiny PC speakers
started to be 'rated' at 800watts
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#747317 - 25/06/09 10:32 AM
Thanks for the replies.
I would like a decent budget quiet power supply
preferably under £50.
Any suggestions?
Loc: Cornwall, UK
[Re: dickiefunk]
#747461 - 25/06/09 03:19 PM
I'm very happy with my Seasonic 400-watt PSU, and when I bought it in December 2006 it
only cost me £40 including VAT. Martin
Mock Element
Loc: Newcastle Upon Tyne
[Re: dickiefunk]
#747522 - 25/06/09 06:27 PM
Bertyjnr2
[Re: dickiefunk]
#748084 - 27/06/09 04:36 PM
You cannot get a silent modern (300 watts +) PC power supply for under £50. They cost
£80 plus at least. Perhaps you mean 'quiet'.
Any model with a fan will not be
silent. Any model advertised as 'silent' with a fan is being dishonest. All modern PC
power supplies need some way of getting rid of the heat they produce, so they either use a
fan or a large heatsink (or rarely watercooling). They produce heat because they are not
100% efficient at converting your mains electricity to power your PC can use. The best
seem to be 80-90% efficient, and these come at a premium.
Even if the supply
has a large heatsink instead of a fan it's going to warm up the PC so you'd need some way
of handling that heat.
I have an Antec Phantom 500 watt. It has a fan which
only comes on when the PSU reaches a set temperature. You can get similar PSUs, but
browsing quietpc.com they've stopped selling them. Also Antec's website has removed the
Phantom line, although you can still buy it on the internet.
Trebor Flow
[Re: Martin Walker]
#748124 - 27/06/09 07:42 PM
Quote Martin Walker:
I'm very
happy with my Seasonic 400-watt PSU, and when I bought it in December 2006 it only cost me
£40 including VAT.
Hi Martin
I've got a S-12 Seasonic 430W PSU in my
PAQ PC.
Do you think it is powerful enough to run ALL six expansion slots
plus the GPU
I want to have the following on a Q9550/DP35DP mobo.
Radion HD4350 ATI passive cooled GPU (16x PCI-e 2.0)
UAD-1 (PCI)
UAD-1
(PCI)
RME Host card (PCI)
Powercore Express (PCI-e)
Duende (PCI-e)
UAD-2 (PCI-e)
I also have a Powercore firewire on the firewire bus but that
is self powered.
I also have 2x Seagate 1TB HD's
1x Pioneer CD-ROM
My concern is the S-12 not being powerful enough and also I wonder if a larger
power supply would run quiter if it was more highly rated or doesn't it work that way?
Everything runs great at the moment with all the above except the I haven't
bought the Duende or UAD-2 yet - I'm worried that might be to much for my S-12.
Any thoughts
Best
Trebor
Trebor Flow
[Re: dickiefunk]
#748229 - 28/06/09 11:38 AM
Bump
Mr Walker Sir, or anyone else who knows for sure, think I'll be OK?
I didn't want to start a new thread, just for this question - if I can tack it on
the end of this thread
Trebor
Peter C
active member
Loc: London, England
[Re: Trebor Flow]
#748319 - 28/06/09 05:59 PM
Hi, The actual power demand from your complete system but without the UADs
Duende and PoCo is under 150 at full blast. The UADs, at least,and the PoCo
and Duende, I beleve, are passively cooled with fairly small heatsinks, which limits their
power output (given ethat they don't overheat) to about 15W each. Maybe you can
get an accurate power consumption for these devices from the manufacturers website, but by
my calculations total demand on your system maxes out at under 250W. Peter
-------------------- PaQ
Trebor Flow
[Re: dickiefunk]
#748402 - 29/06/09 06:31 AM
Peter
Your right - UA state their UAD-1 consumes 14W (not sure about the
Powercore)
Thanks for your reply, just what I needed to know.
Trebor
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#748499 - 29/06/09 11:57 AM
Low noise psu's - Zalman, Bequiet! or Corsair (hxuk) range, being personal choice after
testing in the 500W - 800W ranges (and in that order of preference). All have 140mm fans
built in the current ranges and the Zalmans heatpipe design is quiet effective. Think they are all proberly more in the £80 - £100 price range, but they all come with
at least 5 years warranty and having seen the results of cheap psu's on the rest of the
system when they fail I tend to only go with the better brands in the market place these
days.
-------------------- ScanProAudio & 3XS Audio Systems
ScanProAudio Blog
Loc: Cornwall, UK
[Re: Trebor Flow]
#748572 - 29/06/09 02:44 PM
Quote Trebor Flow:
Hi Martin
I've got a S-12 Seasonic 430W PSU in my PAQ PC.
Do you think it is
powerful enough to run ALL six expansion slots plus the GPU
Sorry Trebor Flow - only just read your
query, as you posted it on a Saturday evening
Excellent response from Peter though, although he ought to know if he built your PaQ PC
Trebor Flow
[Re: dickiefunk]
#749391 - 02/07/09 06:46 AM
Thanks to all for the replies
Actually Martin, Peter only supplied the case -
I put the DAW together myself (nightmare actually - but that's another story.
The DAW is now supper stable and works great - it's just the PSU is getting noiser as I
load up the expansion cards.
I had this problem with my last PC - it had a
Blue Storm 500W PSU in it.
It appears to me, that so far with the PSU I have
had (being the Bluestrom 500W and now the Seasonic 430W) they are all super quite with
nothing installed except the GPU, then when I start installing all my DSP card slowly but
SURELY the PSU get's louder and louder as more power is need and more heat is created =
NOISE!!
Peter's case is fantastic - and looks fantastic too, it really is
great at keeping noise supressed BUT my current PSU is letting the team down a bit, as
it's creating too much noise powering all my DSP cards. (I think I'm a bit unusual in
having 5 DSP cards and an audio interface)
I think I'm just a victim of
physics here - but after talking with Peter, we thought that maybe a bigger supply like
800W might be over the top in terms of power needed but would hopefully run quiter for the
same given load.
I think the theory being the difference between a mini going
down the motorway at 90mph and a BMW 6 series at 90pmh (well you get the idea :-)
I think I will give Peter K's idea a go and have a look at the Zalman range.
Thanks
Trebor
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#749406 - 02/07/09 07:54 AM
Ok I'm looking to order a power supply today. My old one is a Nexus NX-4090. Apparently I
need a pin adapter to plug it into my mobo (I think).
Question is what would
you recommend of similar quality (preferably better) for around £50 - £60?
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#749423 - 02/07/09 09:17 AM
For under £60 quid the only thing I can think of that'd I'd go with is the 450W Corsair
CMPSU-450HXUK which is a bit more powerful than what you have now (your current one's a
400w isn't it?) I think, with a good warrenty and quiet. I'd save another
tenner or so through go with a Bequiet! or Zalman personally through.
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: Pete Kaine]
#749517 - 02/07/09 02:02 PM
Hi Peter. Thanks for the reply.
Which Bequiet or Zalman psu would you recommend
close to my budget?
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#749520 - 02/07/09 02:09 PM
My motherboard is a Gigabyte GA-G33M-S2.
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#749545 - 02/07/09 03:32 PM
The gigas can be a bit awkward with Zalmans sometimes and as I'm not use to that board i'd
say the Bequiet (it's the cheaper of the two anyhow). 450W Be Quiet Dark Power
PRO BN071 Comes in at just under £70
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#749709 - 03/07/09 09:19 AM
How does the Corsair CMPSU-450HXUK and the Be Quiet Dark Power PRO BN071 compare to my old
Nexus NX-4090?
I noticed that the idle sound on my Nexus is 16.2 dB!
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#749717 - 03/07/09 09:38 AM
I've been doing a bit of reading and have decided to go for the Corsair CMPSU-450HXUK. I
spoke to one of the salesmen at SCAN and he said the Corsair and the Be Quiet psu's would
be on par performance wise! The 5 year warranty was also a deciding factor!
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#749728 - 03/07/09 10:14 AM
Having never used a Nexus brand psu before, I can't tell you. Can you Quantify that 16db
reading through. At what distance is that measured? Is that your measured reading or
marketing hype? Is it under full or partial load?
Very few if any of the
class leaders will quote sound measurement ratings these days as they are pretty much
subjective, and will vary wildly depending upon techniques used to test them and on system
enviromentals.
The Bequiet! 430 (a previous generation psu) against the
Silverstone Element @ 200W pull was about 5 db louder. The current dark power series
increases the fan size, and is far more efficient (87% as oppose to 80%) meaning less heat
and less rpm required.
The Element is the bench mark used by silent pc
review, and I've tested against it in a quiet room and it seems quieter underload (once
again, all subjective).
http://www.silentpcreview.com/article677-page5.html
I
don't belive for a second through that the Nexus does anything like 16db under half load
through.
*edit*
In fact your very psu is tested on that
site!
The nexus does 30db under 200w load meaning that the Bequiet and the
corsair will both be quieter than your current nexus.
http://www.silentpcreview.com/article204-page3.html
The
Bequiet! is the quieter of the two through.
*Second Edit*
You've
already purchased! Doh.
The Corsair is only about a Db more under testing we've done here, and to be honest you
won't tell the diffrence without setting up a microphone and monitoring it properly. The
extra 2 years on the warrenty through, is well worth it, and I know you'll be more than
happy with it.
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#749794 - 03/07/09 02:28 PM
Thanks Peter! Look forward to trying it out on Monday!
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#852319 - 08/08/10 07:01 PM
Hi guys,
I've been really busy doing some serious upgrading to my system over
the past year and have been extremely pleased with the results!! Following my latest
upgrade (new cpu cooler) I've now noticed that my current power supply is the noisiest
part of my PC. At the moment I'm using a Corsair 450w.
Other components
in my PC have also changed :-
Mother Board :- Gigabyte GA EQ45m CPU :-
Intel Q9550 CPU Cooler :- Gelid Tranquillo Silent Case :- Fractal Design Define
R2 Graphics :- Gainward nVidia 8400 GS
I would finally like to upgrade my
Corsair 450w power supply to something quieter.
What would you recommend for my
current setup?
necromunger
[Re: dickiefunk]
#852326 - 08/08/10 07:42 PM
i have a be quiet dark power pro 1200w in my server and its very quiet but its huge. i guess that's overkill for what you need but they have fan volume/db level on all
there power supplies if that helps. http://www.be-quiet.net/be-quiet.net/index.php?StoryID=17&ProductID=10
&websiteLang=en#
Pete Kaine
Scan Computers
Loc: Manchester
[Re: necromunger]
#852401 - 09/08/10 10:14 AM
I like Bequiet's but they have this crazy imcompatability with some Gigabyte boards where
they will reboot if you try and copy more than a couple of gig's from drive to drive. I've
seen it on all the X58's and some of the older p45's. I don't know if that would affect
the OP but I've grown a little wary of them these days
ScanProAudio Blog
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#852402 - 09/08/10 10:18 AM
Quote dickiefunk:
I would
finally like to upgrade my Corsair 450w power supply to something quieter.
What
would you recommend for my current setup?
Personally I go with Enermax Modu's all the way but they are not
a cheap option. The build qulity is outstanding through and they are very quiet.
The current SPCR recomended list has the Nexus 430 as it's overall best low power
psu.
http://www.silentpcreview.com/Recommended_PSUs
If you think
you can get away with 430W again (i.e. no major upgrades in the future) I'd be tempted to
say go with that as I have it in my media center and it's great and indeed quiet to
silent. It's not got a lot of overhead through and I still went with a Modu 82+ for my
audio rig.
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#852471 - 09/08/10 02:33 PM
Hi Peter, Thanks for the continued advice  I've been checking out the psu's you mention and the Enermax Modu 87 500w
(£102) and the Nexus Value 430 (£60) look to be the best options. Have you had a chance to try these out?
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#852487 - 09/08/10 03:40 PM
Yeah, the Nexus has a very, very low rpm fan that never really picks up so remains pretty
much silent. It's not a firm I've dealt with a lot through so I don't know how reliable
they are which is why I don't whole heartedly recommend them. From what I've read they are
supposed to be an ATNG power design with uprate cooling and ATNG's are reasonable builds
but nothing special from what I've read.
They could be great but I've learnt
in the past that great psu's can suddenly turn to trash half way through the expected life
cycle so I don't get too excited until they have proven themselfs in the field.
The one i've been playing about with has performed well through, and I think i about a
year old now. A fairly safe bet on a low powered machine and I think your's would be
alright with it.
The Enermaxs on the other hand I've had a lot more
experiance with. I built a P4 machine about 7 years ago that has pretty much been on 24/7
the whole time since then and in that time it's gone from a gaming box to a vsti
processing box to a server system and it's never had a power related issue.
They build and design all their PSU's from scratch and whilst they cost more than most
other firms they rarely break inside of their expected life cycle, they are quiet as you
like and they give a very good stable power output.
I would have acturly said
go for the 525W Enermax Modu82+ as that's about £80 and is the one I use on our audio
systems here where I can.
The one you listed is rated as being 5% more
efficent so should give off less heat and have a longer life expectency as well as costing
slightly less to run but I don't know if it's worth the extra £20 odd for the pleasure!
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: Pete Kaine]
#852526 - 09/08/10 05:45 PM
Hi Peter,
I noticed that whilst the 525W Enermax Modu82+ is a little quieter
than my Corsair 450w it is noisier than the Nexus and 525w Enermax Modu87+.
This has certainly given me something to think about!
Pest
Loc: Sherwood Forest
[Re: dickiefunk]
#852532 - 09/08/10 05:58 PM
Hi:
I'm with with Pete Kaine and also recommend Enermax - they are built
extremely well and VERY quiet.
I have done proper electrical measurements on PC
power - unless you run some insane overclocked multi graphics gaming rig you should never
trouble a well made 500W PSU in terms of consumption.
The reason I have an 850W
Enermax is that at anything up to half load the fan is at absolute minimum; and only
speeds up gradually at loads over 400+ W. My DAW is therefore as silent as I can
reasonably get it - which is great. I have a core i7 940 12G RAM with 4 HDD + 2
opticals and a PCI sound card. 12 out of 14 USB in use. My case does not use the PSU
for cooling as the PSU gets air from outside; the case is cooled by case fans as it should
be.
I'd rather have an overspec'd PSU that runs well below rated load than
stress a lower spec. model; and you get 5 years guarantee. I regularly monitor my
case and component temps and things are cool and quiet even on the hottest days. As
the one you want is modular that can also help with tidier cable runs.
Got mine
from SCAN when I rebuilt the DAW and its seen many hours use every day since.
Pest
-------------------- Imagine what you will know tomorrow...
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#852540 - 09/08/10 06:23 PM
My budget is very tight so the 800w Enermax at £170 is
too expensive. The 500w Enermax is £96 and this may also be outside my budget making
the Nexus Value 430 the only option but I'm selling a few things so may be able to stretch
to the Enermax 500.
Thought I should mention that I will be using the following
external hardware I'll be using :-
Focusrite Saffire Pro24 DSP firewire
interface Cubase 5 USB key M-Audio Keystation 88ES USB controller keyboard Korg Pad Kontrol USB controller 2x Viewsonic 19' monitors
The internal
hardware is:-
Gigabyte GA EQ45m S2 mobo Intel Q9550 cpu Gelid
Tranquillo cpu fan 2x WD Caviar Black HD's Gainward nVidia 8400 GS 256mb passive
graphics card Pioneer cd/dvd drive 2x 2gb DDR2 RAM (adding more soon)
Would the Nexus Value 430 be powerful enough?
Pest
[Re: dickiefunk]
#852547 - 09/08/10 06:47 PM
Hi dickie: No I wasn't suggesting you get an 850W PSU; I was recommending
Enermax as the best quality IMO. Yes the 430W model will be powerful enough but
I would definately get the Enermax 500 if you can. Enermax Regards - Pest
OldSchoolProducer
[Re: dickiefunk]
#852555 - 09/08/10 07:52 PM
My brother recently wanted to upgrade his computer (for gaming) so I got him a be quiet
700W PSU. I'll tell you now that thing is pretty much silent when he turns his computer
on, it gets louder under load but is still pretty decent. Haven't actually seen the
Enermax or Corsair models running but doubt they are quiter as this is not their main
purpose. Would definately recommend the be quite range!
-------------------- -If it's not broke, don't fix it!
Pete Kaine
Scan Computers
Loc: Manchester
[Re: OldSchoolProducer]
#852628 - 10/08/10 09:20 AM
Quote OldSchoolProducer:
My
brother recently wanted to upgrade his computer (for gaming) so I got him a be quiet 700W
PSU. I'll tell you now that thing is pretty much silent when he turns his computer on, it
gets louder under load but is still pretty decent. Haven't actually seen the Enermax or
Corsair models running but doubt they are quiter as this is not their main purpose. Would
I use to use them, but I find them problematic with Gigabyte
boards (arm load sag under mid to long term constant load). The current Bequiet! range are
Topower (P8) psu's with uprated fans and the only real benifit of the Bequiets over the
Tagans & Mushkins which are based around the same range is that the fan is never
really run above 2/3 load so comes across as being quieter.
The good Corsair
models (some TX) are based around the Seasonic 650 MII which were at one point a few years
back pretty much the best quiet psu's going and are worth getting on those grounds,
althrough just plumping for the seasonic would be the better choice if you were doing
that.
The Nexus are oem units uprated by Nexus who are a silent fan company and
do some of the better fans on the market right now. It down to those that the units are
quiet as that is the selling point (like the Bequiets!).
Then the's Enermax.
Most of the other brands you've heard of use a selection of OEM plants in Taiwan and mod
those standard designs. Enermax develop solutions and build in house and they set out to
build the best unit they can from scratch. Yes they cost more than most other firms but
that's because they don't cut corners on the process.
PC power & cooling
use to be like this and built outstanding psu's but since the OCZ take over it seems to
have slipped a bit. Seasonic and Antec are both in house and solid buys as they develop
and sell through to other firms and do the job right althrough in Antecs case they don't
tend to focus so much on the cooling noise levels.
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: dickiefunk]
#852682 - 10/08/10 12:11 PM
I have just been speaking to a guy over at Quiet PC and he recommends the Scythe Kamariki
psu. It does looks like it is very quiet on the chart on their website :- http://www.quietpc.com/gb-en-gbp/products/powersupplies/kamariki4The 550w version looks like it would be quieter than the 450w until it goes over
450w. I can't seem to find any reviews on the Scythe Kamariki? Any
thoughts on this one?
Ramirez
Loc: Llithfaen, Cymru
[Re: dickiefunk]
#852686 - 10/08/10 12:24 PM
Hi, I don't know if this is pushing the forum rules, but I do think it's
relevant, so my apologies if I'm in the wrong. I have an unused Corsair 650w
supply that I bought from Scan. It didn't fit in my Antec rackmount case, but I didn't try
fitting it until it was too late to return it. It's this model - http://www.scan.co.uk/Products/650W-Corsair-CMPSU-650TX-SLi-XfireSingle-12
V-Rail-80plus-Efficient-120mm-Quiet-Fan-ATX12V-v22and I've just noticed
it's dropped quite a bit in price since I bought it a few months ago! PM me if
you're interested. Aled
-------------------- Bill Withers while Tom Waits, and Stan Getz
Pete Kaine
Scan Computers
Loc: Manchester
[Re: dickiefunk]
#852689 - 10/08/10 12:36 PM
Quote dickiefunk:
I have just
been speaking to a guy over at Quiet PC and he recommends the Scythe Kamariki psu.
Any thoughts on this one?
As they are the UK distro for Scythe I'd question how bias'd they might be on the
matter!
They sent us a sample. I tried it, and wasn't that impressed with it.
It got slung it in a system under my desk when the Hiper power in it died and is still
going 6 months later.
The's a review here: http://www.hardwaresecrets.com/article/762 which states it's from a
range based around the Topower unit that the Bequiet! uses or might be based around a
sirtech unit, but the's not a lot in either of those quality wise.
ScanProAudio Blog
dickiefunk
Loc: Cornwall, UK
[Re: Pete Kaine]
#852697 - 10/08/10 01:00 PM
Quote Pete Kaine:
As they
are the UK distro for Scythe I'd question how bias'd they might be on the matter!
To be honest from the dealings I've
had from Quiet PC over the years they haven't been biased towards Scythe.
Quote Pete Kaine:
They sent us
a sample. I tried it, and wasn't that impressed with it. It got slung it in a system under
my desk when the Hiper power in it died and is still going 6 months later.
Have you been able to compare the
Scythe to the Nexus Value 430 and Enermax Modu87?
