active member
Loc: Devon
Fitting and cutting a replacement nut
#766160 - 29/08/09 02:38 AM
I promised to post something about cutting and fitting a replacement nut so here is the
1st instalment. James handed over his guitar a couple of days ago and I got the
new strings and a bone nut blank yesterday. So I spent a few hours today getting started.
The old nut is removed and I've already thicknessed the bone blank and I'll post some pics
with the details later. I also planed the bridge because it was way too high to take a
proper set-up and levelled, profiled and polished the frets. But to start off
I'm posting a pic showing the tools I'll be using. [image]  [/image] My recently acquired StewMac nut
tools are on the left. But you don't need those to do the job so I've also included my old
files and saws on the right. They have done a perfectly good job on hundreds of nuts over
the years. As I use the different tools I'll explain more about them and include pics. The
only unusual items there are the half pencil and the piece of string on the Brasso tin and
they are both very useful. Next post coming as soon as I've edited and uploaded
the pics. Andy
-------------------- When the going gets weird, the Weird turn Pro.
Stonehousestudio
active member
Loc: Exeter
Re: Fitting and cutting a replacement nut
[Re: zenguitar]
#766196 - 29/08/09 09:41 AM
Sticky these please!
active member
Loc: Devon
[Re: zenguitar]
#766349 - 30/08/09 01:44 AM
Consider it done. I've just edited some more pics to upload which I'll do
tomorrow together with the next steps. Andy
active member
Loc: Devon
next steps
[Re: zenguitar]
#766530 - 30/08/09 11:26 PM
The first thing to do is remove the old nut. [image]  [/image] Use a sharp blade to neatly and
carefully cut along the edges of the old nut so that you don't damage the finish when you
pop it out. Then place a block of wood against the old nut and give it a few gentle taps
with a hammer to pop it out. And don't throw away the old nut, you will need it later. [image]  [/image] [image]  [/image] Then it's time to clean up
the the nut ledge/slot. I use a very sharp chisel. Carefully removing the remnants of glue
from the end of the fretboard and ensuring that the bottom of the slot is good and flat
too. [image]  [/image] Until you end up with something
clean and level waiting for the new nut. [image]  [/image] You then need to thickness the
nut blank. For a Fender style slotted nut you need to ensure its a snug fit in the slot,
fitting well but without needing any force to get it in. For a Gibson style nut you can
use the old nut as a thickness guide. When I have a full workshop up and
running I use a bench mounted disk and belt combination sander for rough thicknessing and
shaping as it can save a lot of time. But for this example I'm using wet & dry paper and
working by hand. [image]  [/image] You need to take care to
ensure that you keep the new bone blank evenly thicknessed and perfectly flat. You will
see from the pic that I have a piece of plate glass set into my work bench. It's not
essential, but I have found that it's useful to have in the workshop whenever you need a
good, true, flat surface. Once you have the blank to thickness you then need to
flatten the bottom and ensure that it is square to the side. And don't forget to mark the
blank clearly on the good face so you don't forget which is which. [image]  [/image] In the next instalment I'll be
trimming the thicknessed blank to size, marking out and starting the nut slots, shaping
the back of the nut, polishing it nicely, then fitting the nut and finishing the slots to
the right depth. Andy
wave1
[Re: zenguitar]
#766557 - 31/08/09 07:04 AM
Thanks for this Zen - good stuff!
active member
Loc: Devon
[Re: zenguitar]
#766780 - 01/09/09 12:51 AM
As promised, here we go again. With the nut slot/shelf tidied up and the blank
thicknessed I trim the blank to the width of the neck. I mark it simply with a pencil.. [image]  [/image] .. and then I use a saw
to trim it down slightly oversize. I use a jewellers piercing saw with fine blades purely
because I have one anyway for inlay work, but any fine cut saw will do. Then I use files
and wet & dry paper to bring it down to the final width and match the profile of the
fretboard edges so it's nice and smooth to the touch with no rough edges. With
the nut blank at the correct width it's time for the half pencil. I hold the blank firmly
in place and use the half pencil to mark it with a datum line that is level with the tops
of the frets... [image]  [/image] ... like so, leaving a mark
like this. [image]  [/image] Although it is
perfectly possible to do the job without the reference line, it can save a lot of time
having the reference mark. It enables you to mark out the location of the fret slots and
cut them close to the final depth without having to do a series of trial fittings on the
guitar itself. Once I have the fret top datum line I mark another line about
0.5mm above it as a guide to the final slot depth. And about 1mm above that I mark another
line which is the guide for the top of the nut. [image]  [/image] Now I can put the blank into a
vice and file it down to the line ready for marking the fret slots. I don't file the top
flat, instead I ramp it so that the top is sloped. The highest point is the front of the
nut and it slopes away towards the tuners. Like this... [image]  [/image] With the blank at the
correct width and thickness and close to the final height it's time to mark and rough cut
the fret slots. Remember I said to keep the old nut? This is because it comes in very
useful for marking the slot positions on the new nut. I transferred over the locations of
the outer strings by eye and then used my StewMac string spacing rule to mark out the 4
inner strings. You can transfer over all 6 strings from the old nut or manually divide the
space equally if you prefer. The string spacing rule makes a very subtle
difference. If you space the slots equally it can sometimes feel as if the bass side
strings are closer together than the treble side strings because the strings are of
increasing thickness. The StewMac tool very slightly increases the gap between strings as
you move from treble to bass so that the gap between the strings are equal instead of the
gaps between the string centres being equal. [image]  [/image] With the slot positions
marked it's time to start cutting. I prefer to use a triangular file to notch the
locations before cutting. If you are slightly out of position on the first attempt the
triangular file makes it easy to 'ease' it back into line. Then it's time to grab the saws
and files and start cutting. I put the nut into the vice and use the saws and files to cut
the slots to the guide line I made earlier and then drop the nut into place on the guitar
to cut the slots close to their final depth. [image]  [/image] I try to get the angle of
the slot halfway between parallel to the strings and parallel to the break angle and
headstock. Once I've finished the photo description I'll draw some diagrams and give a
more detailed explanation of why. But with the slots cut close to depth I can
now trim the top of the nut down to it's final height. I do this with the files and wet &
dry paper. The aim is to reduce the height of the nut until the wound strings are sitting
halfway in and halfway out of the nut and the plain strings are just inside the nut. If
the strings are too deep in the nut you get friction problems. And after further trimming,
the nut looks like this. [image]  [/image] Now it's time to finally shape
and polish the blank ready for final fitting. I use files and wet & dry paper
to round the back of the nut as well as the sides. I just sand away until I have a nice
shape and feel. Like this... [image]  [/image] A lot of people will stop at
this point and move on to the final fitting. But I like to go a stage further and polish
the nut with 000000 wire wool like this... [image]  [/image] Which looks and feels a
lot better. But that's still not good enough for me. So I dig out the Brasso and a cloth
and give it a further polish so that it's perfectly smooth and very shiny. Like this... [image]  [/image] Partly it's because I
like to do a job right and bone looks and feels great when you give it this much
attention. But I also feel that if you can't be bothered to properly finish the parts a
customer can see, how can they trust you to finish the parts they can't see? And tomorrows
post will make that much clearer. Final stage for today is to finally attach
the nut to the guitar. All that's required are a couple of tiny drops of superglue. String
tension is more than enough to hold a nut in place. The superglue is just there to stop it
dropping off or slipping out of place. [image]  [/image] I put the nut in place by hand
and press it down until the superglue grips. Then I drop the strings in place so they can
clamp it overnight. Don't forget that superglues need to be left overnight to develop
their full strength even though they set in seconds. [image]  [/image] Tomorrow I'll finish off by
bringing the nut slots down to their final depth and reveal the Holy Grail, the difference
between a good nut and a great nut. Andy
active member
Loc: Devon
[Re: zenguitar]
#767060 - 02/09/09 12:20 AM
Final instalment. With the nut polished and glued in place it's time to tweak
the nut slots down to their final depth. The final depth depends on the guitar and the
players requirements and is measured as the clearance between the bottom of the string and
the top of the 1st fret. I was taught to start with a 0.5mm gap for the bass E string and
a 0.4mm gap for the treble E string and then work down from there. When starting out it's
best to use a set of feeler gauges to measure the gap. Once you are at that point you can
go lower but it's a matter of playing it by ear. Pop the string you are working on out of
the nut slot and make a couple of gentle strokes with the saw or file. Then pop the string
back into the slot and test. When the string buzzes against the top of the 1st fret,
you've gone too far. At that point you can either start again with a new bone blank, or
you can learn the art of filling the slot and re-cutting it  Having cut hundreds of nuts I no longer use feeler gauges, I do it all by eye now. And
one handy hint is to polish the 1st fret so it clearly reflects the string. I watch the
gap between the bottom of the string and it's reflection as I work lower. That gives a
very good visual guide. I also pluck the open string and watch it's reflection in the 1st
fret as that gives the best visual indication that you are approaching the point where it
might start buzzing. I also fret the string behind the first fret to see how it feels. It
should be no harder to press down than the same string barred at, say, the 5th fret and
then fretted at the 6th fret. Getting the nut slot depth right is really
important. Most mass produced guitars leave the factory with the 1st fret action too high.
The reason is simple economics, the skilled labour and time it takes to do it right cost
too much and when it's done by semi-skilled labour the cost of removing and replacing the
nuts where they cut too deep is even higher. The factories operate with such small margins
that the cost of replacing a badly cut nut could be more than they make in profit on a
guitar. Now, once the slots are at their final depth it's time to finish the
job properly. And that's what I meant by The Holy Grail. Far too often people don't pay
enough attention to the cutting and finishing of the slots. I've drawn a few examples on a
whiteboard and photographed it, as it was a lot quicker than trying to do the same on
PC... [image]  [/image] A/ shows a slot cut flat.
The problem here is that when the strings vibrates up it lifts away from the bottom of the
slot and buzzes in the slot. B/ shows the slot cut to match the break angle to
the machine head. While it solves the problem in A/, it introduces problems of it's own
that are less obvious but just as difficult. The first problem is that you can't guarantee
the break angle to the machine head, if the string doesn't wind down the post low enough
it no longer touches the slot at the back and can buzz in the slot again. It also puts a
lot of pressure on the front edge and over time it can wear it down. That will lower the
action further until it starts buzzing on the 1st fret. C/ is pretty much
ideal, it ensures that the string is pulled into the slot at the front and rear avoiding
buzzing and also minimising the risk of wear on the front edge lowering the action. In D/ I've tried to show how the bottom of the nut slot is still rough after you
finish with the saw or file when you examine it closely. That roughness is a
cause of friction and can lead to the string sticking in the nut even though the slots are
at the correct width. Regrettably, a lot of techs will cut the slots with saws and files
and leave them exactly as the tool finished them. However, a decent luthier will go a
stage further and finish the slots properly. The most common way is to use a piece of very
fine wet & dry paper folded in half. The fold is inserted into the slot so that some of
the grit polishes the bottom of the slot. But that is far from ideal, and the paper is too
thick when folded to use in the plain string slots. About 10 years ago I was
studying jewellery and silversmithing and came across the Jewellers Mop made from a piece
of string. [image]  [/image] It's simply a piece of
string doubled over, tied in a stopper knot just below the bend and with the individual
threads teased out below the knot. Jewellers use this with abrasive paste, like rouge, to
smooth and polish fine fretwork (small holes cut into metal). I put 2 and 2
together and started using a mop with Brasso to polish fret slots so that they are nice
and smooth. [image]  [/image] Just like that. And you can
see from the earlier pics how well Brasso polishes bone. This is something I've
kept to myself for a long time, but it is why I have so often been insistent that a well
cut bone nut is as good as anything else available. And in the last few years StewMac have
started to sell abrasive cord for exactly the same purpose. However,
the cord is nowhere near as versatile as the jewellers mop. You can load a mop with
whatever abrasive you need and it will go far finer than the cord too. So,
there you have it. How to make and replace a bone nut in next to no time. It's as good as
any alternative material in performance and sounds better. And my personal record for
making and replacing a bone nut for a strat is 15 minutes (that was with the use of my
disk and belt bench sander). And yes Jef, I was thinking of trying to beat that record at
the next Analog to Digital  Any questions, please feel free to ask. Andy
Stonehousestudio
active member
Loc: Exeter
[Re: zenguitar]
#767258 - 02/09/09 05:28 PM
Thanks Andy! That was brilliant, I really appreciate the effort mate and all
the tips. I think you're on a winner here mate. Next stop "The
Little Zen Book of Guitar Maintenance" available at all good book stores...
subsonicworld
Loc: London
[Re: Stonehousestudio]
#767282 - 02/09/09 06:30 PM
Yeah. This is top stuff. You didn't once write something about maintaining
motorcycles did you?...
-------------------- www.myspace.com/thegreatsojourn
Dan LB
Loc: Wicklow, Ireland
[Re: zenguitar]
#767298 - 02/09/09 07:36 PM
Thanks a million Andy. That's very useful! I never knew about the Brasso trick. I've
always left nut slots the way the file finishes them. Top job!
Dan
active member
Loc: Devon
[Re: subsonicworld]
#767348 - 02/09/09 11:47 PM
Quote subsonicworld:
Yeah. This
is top stuff.
You didn't once write something about maintaining motorcycles did
you?...
Nah, that was
some other bloke. If I'd written Zen and the Art of Motorcycle Maintenance it would have
actually been about Motorcycle Maintenance not about angst. But seeing as you mentioned
it, here's a really handy Motorcycle Maintenance tip...
If you ride in the
winter, get one of those hand pumped pressure sprays they sell in garden centres. Fill it
with water and a few drops of washing up liquid and put it in the garage. When you get
home from work just give it a few pumps and then spray the engine and underside of the
bike before garaging for the night. And while the bike is drying, top up the sprayer. That
will help prevent the ravages of winter salt.
Quote Dan LB:
never knew about the Brasso trick. I've always left nut slots the way the file finishes
them. Top job!
Dan
Cheers Dan, I'm not surprised that you never knew the Brasso trick, I am not aware of
anyone else doing it. I only worked it out myself because I spent a year at art college
studying jewellery and silversmithing AFTER I trained as a guitar maker. You could also
use the jewellers rouge paste that Dremel dealers sell in small packs. It's cut is more
aggressive than Brasso which can be useful. The saw StewMac supply for 10 gauge slots has
a very coarse cut, a far lower teeth per inch count than an X-Acto saw blade. So it might
be worth making a second mop to use with the rouge, which I have done in the past.
Another tip for X-Acto saw blades is to stone the set off the teeth at one end of
the blade. That way you can cut 9 gauge slots with one end and 12 gauge with the other,
for example. I have a very nice backsaw that I keep for cutting fretslots, the kerf was a
little too big initially but a light stoning made it perfect.
Andy
Jumpeyspyder
Loc: Yorkshire
[Re: zenguitar]
#767445 - 03/09/09 10:30 AM
Fantastic Zen  Although am disapointed that you missed the step that involved the
coffee in the first picture.  I now very tempted to try making new bone nut on the cheesegrator. Is there
an alternative to a full set of proper nut files ?
active member
Loc: Devon
[Re: Jumpeyspyder]
#767689 - 04/09/09 12:01 AM
Don't worry Jumpey... I drank the coffee and a few more besides. Great coffee
is another of my passions. [image]  [/image] These are some basic files you
can pick up for around £1 per set. Two are simple rat-tail files (one diamond the other
traditional) that have a round section that tapers down. The other is a flat file that is
ideal for cutting grooves. All are very cheap to buy, a local model shop is the
perfect place to find them. And all 3 will do a good job if you work carefully. One of the
tricks you can learn is to rock the file from side to side to make a slot slightly
wider. All bone blanks are a lot wider than the neck. One handy hint it to use
the piece or pieces you cut off to practice on with your nut files. And when we had a
greenhouse in the past, I used to get old bones from the butcher. I would boil them up
hard for an hour or so to get rid of the meat and fat and then cut them down into blanks
and leave them to dry out in the green house. That gave me plenty of blanks to work on to
get to know bone and my files/saws. Andy
Dan LB
[Re: zenguitar]
#768358 - 07/09/09 12:27 AM
Zen, I had the Brasso out today!. Our guitarist has been consistantly breaking strings in
rehearsal. The strings kept breaking at the saddle so I reckoned I'd try your mop trick to
smooth out the slots in the saddles. So far so good. Cheers!
Dan
octavedoctor
Loc: Bridgend, Cardiff and Bristol
[Re: zenguitar]
#778052 - 11/10/09 10:02 PM
Damn fine work Andy, almost exactly as I would have done it. however i gave up on the old
half pencil a while ago; I now use a billet of the graphite composite I use for making
graphite nuts.
-------------------- http://www.edgeguitarservices.co.uk
active member
Loc: Devon
[Re: octavedoctor]
#778077 - 12/10/09 01:37 AM
Cheers Doc  Andy
shufflebeat
Loc: Manchester, UK
[Re: zenguitar]
#797153 - 19/12/09 12:11 AM
Very informative and well thunk through, Zen.
I like the sound of the Brasso
string, I'll give that a go. Until now I've been using an old fretsaw (or maybe it's a
coping saw) with a piece of the appropriate wound string clamped into it instead of a
blade. Seems to work ok and profiles the bottom of the slot ideally.
-------------------- Ohm's Law states, "Your PA isn't as powerful as you think it is".
Stonehousestudio
active member
Loc: Exeter
[Re: shufflebeat]
#816452 - 03/03/10 06:43 PM
I'm looking forward to seeing some of this in action on Saturday...
active member
Loc: Devon
[Re: zenguitar]
#816554 - 04/03/10 01:06 AM
guess I'll have to stay sober !! Andy
Stonehousestudio
active member
Loc: Exeter
[Re: zenguitar]
#817299 - 07/03/10 05:08 PM
I thoroughly enjoyed having my two favourite Forum mods on hand at the A2D show
yesterday. I say it here as I got to see Andy and Max both hard at work slaving
over various axes and getting stuck in with tremelo systems, intonation, nut cutting and
beverage drinking... The pair of them are like a comedy duo / wealth of
knowledge. "Thank you" both for all your help with the event and the feedback
we have already received from people on the day about you both has been fantastic. Nice one boys!
Bod
Loc: Leicester, UK
[Re: zenguitar]
#930015 - 25/07/11 02:33 PM
Thanks for the guide ZG.
I've recently attempted to replace the nut on a Squier
Telecaster as the non-wound string slots were cut too low causing buzz on the first fret.
I initially wanted to shim it to raise it but broke it trying to lift it from the slot.
Anyhow, I purchased a premade nut, and took great care in sanding it to the
correct thickness for the slot. After doing this I discovered that it wouldn't seat
correctly because the bottom of the nut slot was curved. I attempted to sand it to match
the curve, but had real trouble getting it to match the curve of the slot and ended up
taking too much off, which meant that I had exactly the same buzz problem I had to start
with. Doh.
Before I try again with a new nut, are there any tricks to matching
the curve? Do curved nut slots generally match the radius of the fingerboard?
Cheers, Bod.
active member
Loc: Devon
[Re: Bod]
#930211 - 26/07/11 12:07 AM
You are welcome Bod, glad you found it helpful. Those radiused Fender nut slots
are a real pain. It's not simple getting a flat bottom on a nut blank, but it is
straightforward and can be done by anyone with patience. But those radiused slots are a
little harder but still do-able. Generally, the saddle blanks with a radiused
bottom are a reasonable fit already. So once you've thicknessed them to drop in the slot
they are pretty close anyway. Close enough to get away with more often than not. But what
I do to smooth the bottom for a better fit is to use a piece of 600 to 800 grit Wet & Dry
paper and use the radius of the fret board to help out. I wrap the Wet & Dry paper around
the fret board close to the saddle slot, and then carefully run the saddle blank over it a
few times taking care to keep it perpendicular and not round the bottom of the blank in
the wrong plane. I have also used the same technique with coarser Wet & Dry paper to sand
a radius on the bottom of a flat nut blank with good success too, finishing off with the
finer paper. And if I have any doubts about how well the curves match when
fitting, I would use a smear of PVA wood glue along the bottom of the nut instead of a
couple of spots of superglue as the PVA has better gap filling qualities. Does
that help? Andy
Loc: Rochester, UK
[Re: zenguitar]
#930449 - 26/07/11 07:15 PM
Quote zenguitar:
But what I do to
around the fret board close to the saddle slot, and then carefully run the saddle blank
over it a few times taking care to keep it perpendicular and not round the bottom of the
blank in the wrong plane. I have also used the same technique with coarser Wet & Dry
paper to sand a radius on the bottom of a flat nut blank with good success too, finishing
off with the finer paper.
match when fitting, I would use a smear of PVA wood glue along the bottom of the nut
instead of a couple of spots of superglue as the PVA has better gap filling qualities.
Does that help?
Andy
Sneaky! I love it
-------------------- It wasn't me!
(Well, actually, it probably was)
CraigCyril
[Re: zenguitar]
#971959 - 24/02/12 04:59 AM
Nuts can be made from a variety of materials and require adjustment or replacement when
wear and tear creates problems. Many nuts are very easy to remove. Using a block of wood
to distribute the impact, a small tap of the hammer will pop them loose if they sit with
only one side against wood. Thanks.
Toby Warren
member
[Re: zenguitar]
#983775 - 23/04/12 11:34 AM
Thanks for posting such detailed advice! Please check out my post. I'm having a few
problems with a really nice guitar I own. I think you of all people might have some good
advice for me. Thanks Toby
kalasweeet
[Re: zenguitar]
#1046457 - 03/05/13 01:08 PM
I'd like to show you my general process in actually making a replacement nut. Of course, I
can't go into all the details of fitting a new nut because there are so many possible
difficulties that can crop up, especially with older instruments. As a repairman, my goal
is to be anonymous, so I rarely change the style from that of the original manufacture.
Read More:
Packers Movers Delhi | Chennai Packers Movers
