Main Forums >> Keyboards & Synthesis
        Print Thread
Pages: 1
musicstephen
foot controller/expression pedal/cv pedal
      #801573 - 07/01/10 03:23 PM
Hi all,
I play keyboards and am looking to add an expression pedal to my setup. I would ideally like to have just a pedal, without all the extra buttons that you can get on some boards. I believe I have about 3 options:
1. I have a fatar studiologic-2001 keyboard, which has 2 CV (Control voltage)inputs on it. Does anyone know of a pedal that I could connect up to the CV inputs?
Would this work for me, sorry for mentioning this in advance:
http://www.behringer.de/EN/Products/FCV100.aspx
2. I could use an expression pedal hooked up to one of these, but this is a bit too expensive.
http://www.midisolutions.com/prodped.htm
3. My prefered route would be to have a pedal that would output midi data directly, so that I would hook this up to my midi in my imac. Or a pedal that would output to USB, so that I also hook up to my imac.
I believe this would work, but also a bit pricey just for my use as an expression pedal:
http://www.ikmultimedia.com/stealthpedal/features/
Are there any options out there that I have missed? Let me know if you need anymore info about my setup. I do not have anything that accepts an expression pedal as an input.
Thanks for your help,
Steve
Fetchez la vache!
chris...
active member
Loc: Glasgow
Re: foot controller/expression pedal/cv pedal new [Re: musicstephen]
      #801583 - 07/01/10 04:19 PM
Quote musicstephen:
Would this work for me [...]:
I have one of those behringer pedals, bought in a hurry when I needed something that could operate as an old-fashioned audio volume pedal.
Recently tried setting it to CV mode, connected to the volume/expression pedal input on my Fatar/Studiologic SL-880. It sort of worked, but only generated midi controller values from 0-15 (or maybe 0-31, I forget). Which made it pretty useless.
I can see no relevant settings on either the keyboard or pedal
Bob Moose
      #801585 - 07/01/10 04:21 PM
Hello,
You can also use this:
http://www.doepfer.de/we.htm
It's only 40 euros, but requires some DIY work (read the downloadable PDF for further information).
They also make a 75-euro version with 16 analogue inputs:
http://www.doepfer.de/pe.htm
Best regards
-j
musicstephen
Re: foot controller/expression pedal/cv pedal new [Re: Bob Moose]
      #801590 - 07/01/10 04:34 PM
Thanks Chris, I was hoping to get a litle more expression from an expression pedal!
Thanks Bob, I may have to look into this if nothing else comes up.
Cheers
Fetchez la vache!
active member
Loc: Sheffield, UK
Re: foot controller/expression pedal/cv pedal new [Re: chris...]
      #801596 - 07/01/10 04:46 PM
Quote Chris Edwards:
Quote musicstephen:
I had this problem with my Yamaha control pedal - it just needed a different wiring configuration that I sussed with a couple of crododile clips before soldering up an adaptor cable.
My Yammy pedals are built like tanks - glad I chose them, but it was long ago.
Pages: 1
Rate this thread
Jump to
Extra Information
0 registered and 2 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Home | Search | News | Current Issue | Digital Editions | Articles | Forum | Subscribe | Shop | Readers Ads
Advertise | Information | Links | Privacy Policy | Support
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
