Loc: Rochester, UK
Re: Project Ukulele
[Re: zenguitar]
#950795 - 01/11/11 08:24 PM
Indeed they are looking really good, but I think you should keep an eye on them. They seem
to be getting very friendly
-------------------- It wasn't me!
(Well, actually, it probably was)
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#950868 - 02/11/11 01:43 AM
Cured that, took the necks off again  It's fretting time !!!! OOOOOOH!!!!! First up, I took my nice StewMac fret
press over to Mark's. I bought it a while
ago, but this is it's first outing in anger so looking forward to pressing those little
frets in  And here's everything lined up ready to start cutting the frets.
There are loads of ways of going about it, but I still work the way I was taught by Norman
Reed. I use
the same jeweller's saw that I use for cutting pearl, but with a thicker blade. Yes, you
can cut the fret wire with side cutters, but that deforms the fretwire a little. You need
to allow a little extra overlap for that, and later on you need to stone/file away the
excess. So a little extra time spent cutting accurately saves a lot of time and effort
later. I use the callipers to measure the width of the fret slot, but with a
sneaky trick. For the first fret, I measure the width at the second fret. That gives a
little extra to allow for slight errors and gives a little flexibility when fitting them
too. Then I
transfer the measurement to the fretwire held in a vice. Not too easy to see here, but
there is a mark on the wire, honest!! Here it
is cut and placed on the neck to check size. And then stored in
that piece of wood I drilled and labelled a week ago  See, there
was a reason for it
Then it was 18 more
done the same way. Measure, mark, cut, and check. Once you get going it's pretty quick and
very straightforward. And once you have all the frets cut, it's time to fit them into the
slots. First of all I eyeballed the slots and had concerns about the depth of some of the
slots, remember that I cut them before I radiused the fretboards so was prepared to double
check. A few minutes with the neck in the vice and the saw soon made sure all the slots
were a suitable depth and I could get on with fitting them. Again, there are
several options for fitting frets and to be honest all are as good as each other. Some
people just press/hammer them in (and the slots were tight enough for me to do this if I
wanted), others like to cut the slots a little wider and glue them in with superglue or
epoxy, but I am in the camp that presses them in but lines the slot with wood glue to act
as a gap filler. So, here's the first slot loaded with glue and ready for fretting. And a few
minutes later, here's the fret neatly pressed into place and the excess glue cleaned
up. And the
other frets went reasonably smoothly after that. A few needed some gentle taps with the
hammer to seat the edges first, but then they pressed in easily. And I found it easier to
tap the edges in first on all the frets on the fretboard tongue. But I managed to get the
whole neck finished. All
looking good. Nice and neat, and only a small amount to be stoned/filed of the edges ready
for final levelling and finishing  All in all, a very good day  Andy
-------------------- When the going gets weird, the Weird turn Pro.
Frisonic
Loc: London, United Kingdom
Re: Project Ukulele
[Re: zenguitar]
#950874 - 02/11/11 03:27 AM
I'm already beginning to hear refrains of 'while my uke gently weeps'... That was a very
informative post! Thank you Andy.
-------------------- Strictly project and just for fun
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#951089 - 03/11/11 01:43 AM
Sure you don't mean 'While my luthier gently weeps'?  Remember, too much of A Good Thing is never enough.... A full set of
frets cut and ready to shoehorn into another neck, which I just happen to have lying
around. Looks good, but I
can think of something that looks even better... They'll both get
stoned tomorrow  Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#951182 - 03/11/11 02:13 PM
Quote zenguitar:
They'll both get
stoned tomorrow
Andy
This is an essential part of the
luthiery process I had hitherto been unaware of? So what are we talking here? A pourus
sand stone, An unforgiving granite? Or perhaps, being ukes, a rare, flaky Maui Wowie?
Loc: Rochester, UK
Re: Project Ukulele
[Re: Frisonic]
#951261 - 03/11/11 07:47 PM
Quote Frisonic:
Quote zenguitar:
They'll both
get stoned tomorrow
Andy
This is an
essential part of the luthiery process I had hitherto been unaware of? So what are we
talking here? A pourus sand stone, An unforgiving granite? Or perhaps, being ukes, a rare,
flaky Maui Wowie?
Or maybe just
skunk
Frisonic
Re: Project Ukulele
[Re: Folderol]
#951267 - 03/11/11 08:30 PM
Quote Folderol:
Quote Frisonic:
Quote zenguitar:
They'll both
get stoned tomorrow
Andy
This is an
flaky Maui Wowie?
Or maybe just
skunk
That would be
far too crude for a fret job of this caliber Federol, surely? Anyway that's not a stone.
That's getting clubbed on the back of the neck with the butt of an AK47!
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#951298 - 04/11/11 01:51 AM
Norton sharpening stones!!! The herbal stuff is reserved for luthiers!!! I've
been aching all over for 2 days now. A result of the bench height and the chair height.
And getting back to stoning the necks... Here;s
the first all secure in the vice ready for me to run the sharpening stones along the edges
of the new frets. The edges of the frets have to be flush with the edge of the fretboard,
and the ends have to have a 30 degreeish bevel on them too. After
stoning the first edge. Then the second edge. Sighting down the 2nd edge. And then the same with the other neck. And just
for the fun of it, here are a couple of pics of the necks placed with the bodies. And after
that I trimmed out the headstock veneers from over the truss rod adjusters. And that means
the next step is to glue the necks to the bodies. And to drill the machine head holes for
the bushings. You can guess what I'm up to tomorrow  Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#951299 - 04/11/11 02:18 AM
Well they look nice and relaxed Andy. I should allow yourself a luthier moment on the back
of that session mate!
Loc: Rochester, UK
Re: Project Ukulele
[Re: Frisonic]
#951470 - 04/11/11 08:21 PM
Quote Frisonic:
Well they look
nice and relaxed Andy. I should allow yourself a luthier moment on the back of that
session mate!
Agree 110%
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#951512 - 05/11/11 01:29 AM
So, I've decided to award myself saturday and sunday off this week  Partly because I'm worth it, but largely because I didn't glue any necks today. And if I
glued them on saturday I would want to remove the clamps on sunday, which is a definite
no-no. But what I did do was get out the pillar drill and drill both headstocks
to take the tuner bushings. Ruth's was pretty straightforward. But mine needed a little
extra effort because one of the original holes was slightly out of place. So to tidy it
up, I re-drilled two of the holes all of the way through at the larger diameter for the
bushings. Then I improvised with the fret press to partially insert the bushings in those
holes before locating the tuners and drilling the pilot holes to mount them.
And then
I removed the temporarily fitted bushings without damaging the headstock veneer. So all
should be OK when it comes to finishing the headstocks later. And on monday I
will be fitting necks. Then it's time to make some bridges, fit nuts and saddles, and then
get started on final finishing. Almost there !! Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#951513 - 05/11/11 01:49 AM
In all that amusement about stoning them, did we all forget to mention how good the frets
look Andy? Have a peaceful and well earned weekend  Or fireworks if you prefer!  KABOOM!!!!
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#951962 - 08/11/11 12:40 AM
Ahhh!! Fireworks  I've always wanted to get a Class A Fireworks licence  Instead, I got back to work this afternoon. Started with a final test fitting of a neck
while the hide glue was soaking. Then once all was ready I started slowly heating the glue
while I removed the neck again. The neck bolts do the main work of attaching
the neck to the body but the tongue of the fretboard is glued to the soundboard. If the
neck needs to be reset in the future it can be removed quite easily. Just take the bolts
out and then heat the tongue of the fretboard to break the glue join cleanly. And now the glue has melted, all it needs is a few moments with a paintbrush, some nifty
work with an allen key through the soundhole, and some clamps. A few seconds
with a damp cloth to clean the join. And then wait until tomorrow. And after
that I test fitted the second neck. This time it wasn't quite so straightforward, the
curve on the front left a gap close to the edge that wouldn't close even with a heavy
clamp. So, the solution is to glue a couple of strips of bloodwood (matching the veneer
strip under the ebony) to the tongue. Tomorrow I'll carve/sand them back into a curve that matches the front. Then I'll glue
the second neck as well. Next task is to clean up the shelf where the nut fits
on both ukes, rough size the bone nuts, and mark and cut the string slots. Closely
followed by levelling the tops of the frets and re-profiling them. Andy
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#952192 - 09/11/11 01:25 AM
And so, after a little fine tuning, it was time to heat up the glue pot and fit neck
number two. And as a special
bonus you can see the first neck in the background. Ruth is very chuffed with it  Two scary things come to mind... The first is that the soundholes are too
small to get enough clamps in to glue the bridges, which means one thing... The b!oody
Go-Bar Deck of Doom once more!! Second, I'm getting very close to the point
where I have to learn to play the d@mned thing!! Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#952197 - 09/11/11 02:14 AM
Quote zenguitar:
I'm getting
very close to the point where I have to learn to play the [Email]d@mned[/Email] thing!!
Andy
I was wondering
when this would come up... I've never played one myself, except in the occasional guitar
shop. I know that's not cool but it's the truth. I don't even know what the tuning is...
I'm guessing not violin tuning (haven't bothered looking it up on line yet)?
. . . Delete This
Here be Dragons
Re: Project Ukulele
[Re: zenguitar]
#952319 - 09/11/11 01:42 PM
Quote zenguitar:
Second,
I'm getting very close to the point where I have to learn to play the
Andy
i know a bloke could Jake who
could help with that....
Loc: Rochester, UK
Re: Project Ukulele
[Re: Frisonic]
#952359 - 09/11/11 05:13 PM
Quote Frisonic:
Quote zenguitar:
I'm getting
Andy
I was wondering
Oh dear. I somehow got the idea you already
knew how to play them
Well, I've a suspicion that that playing might turn out to be more difficult than making
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#952440 - 10/11/11 01:08 AM
I shouldn't have any problem learning, as you all know I'm a long term fan of non-standard
guitar tunings. You just put your fingers where it sounds, kinda, OK. Innit? Meanwhile, at Ukulele Central... nuts. Or should I say, NUTS. That's right, nuts  Tidied up both nut ledges and then set about working on the over-sized blanks we
purchased. Trimmed the excess width and then sanded the bone blank to the right thickness
for the shelf. Here's the first
one finished, with the second as a reference. And here are
both finished and sitting pretty. Tomorrow I'll trim them both to width and
rough height, and then cut guide string slots so I can run some threads to the bridge and
start marking those out too. Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#952444 - 10/11/11 02:30 AM
That was quite a hair cut! I had a good guitar day myself today, in a trading sort of way,
so I'm far too blissed out to ask what cutting tool you used to trim the bones...
artzmusic
Loc: usa
Re: Project Ukulele
[Re: zenguitar]
#952446 - 10/11/11 03:17 AM
Andy, before you finish your project, just wanted you to know I've been among the
congregated throng peering in your window admiringly. Great work! You've got the patience
of Job.
And thanks for sharing.
Best,
Rick
active member
Loc: Devon
Re: Project Ukulele
[Re: Frisonic]
#952548 - 10/11/11 01:56 PM
I used the saw from my StewMac nut slotting set to trim to length. Other options include
the good old X-Acto style razor saw and the jeweller's saw with the heavier blade that I
used to cut the frets. Thicknessed the traditional way... sandpaper  Andy
active member
Loc: Devon
Re: Project Ukulele
[Re: artzmusic]
#952550 - 10/11/11 02:06 PM
Many Thanks Rick, Glad you are enjoying it, I wanted to show what could be done
with pretty basic tools and just a few hours a day. And hopefully a few people will get
the confidence to have a go themselves. Andy
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#952708 - 11/11/11 01:36 AM
Having grabbed my half pencil secret weapon, I marked both nut blanks. The main markings
are the edges of the fretboard so I can cut to width, and the level of the top of the
frets as a guide to the height. On this occasion
I marked the top of the frets, the top of the frets plus the thickness of a Stanley Knife
blade, and the top of the frets plus the thickness of 2 Stanley Knife blades. Remember, at
this pont the markings are there for guidance only, the final fitting will come later. With the top
shaped close to the line it was time to file the sides back to width. And then
it was time to dig out some more tools and mark out the location of the string slots. Now,
that's pretty subjective, you have to decide how close to the edge of the fretboard the
strings go, and you have to decide how to space the strings across the nut. Because the
strings are different thicknesses you have a couple of options, you can give them
equi-distant centres and unequal gaps between the strings, you can have unequal centres
but equal gaps between the strings, or something between the two. Personally, I use the
StewMac tool for marking out the string spacing which tends to even out the gaps between
the strings. Most luthier's sweeten the string spacing like that, it tends to look and
feel better. And with
shallow nut slots cut as a guide, it was time to start marking out for the bridge. I marked a centre
line, and then the notional scale length (2x the distance from nut to 12th fret). I need
to allow for the intonation which I'll calculate tomorrow. I also marked a couple of lines
following the edges of the fretboard because I plan to use them to design the bridges. Andy
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#952910 - 12/11/11 01:41 AM
I did some more research last night, and with some help from Left Brain Luthierie I came
up with some practical numbers to give me a good idea how much to allow for intonation so
I can come up with some realistic dimensions for the bridges. The approach is
that I will be making the bridge blanks without saddle slots. Once they are fitted and I
have applied the finishes I will fit the strings, finally finish the nuts, and then work
out the exact saddle positions for each string. With that done I'll cut the saddle slots
and then finally cut and shape the saddles to ensure proper intonation. So with
that in mind, after doing some numbers and marking out on paper, I measured up and started
cutting down the first saddle blank. Masking tape
comes in very useful with ebony. A pencil line on masking tape is a lot easier to follow
than a scalpel cut on the ebony itself. So after rough trimming to length I sanded one
edge flat and put a layer of masking tape over the top. Then I drew out the cutting lines
on the tape. Then I used saws to trim close to the cutting lines and a fresh sanding disk
on the bench belt and disk sander to sand back to the lines. At this point I
was joined by my new apprentice. And this is what I
was trying to take a picture of. The first blank ready for final shaping and fitting. Tomorrow I
intend to plane it to 9 or 10mm thick, sand a radius on the bottom to match the uke, and
start shaping. Usefully, I bought a pair of classical guitar bridge blanks and
they are big enough to get two uke bridges from each. So I have a couple of spares for
stock  Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#952913 - 12/11/11 03:03 AM
This is fascinating stuff. A question about mass produced bridges and intonation, if I
may, Andy: Given their machining etc. throughout the manufacturing process is all
consistent/sound, can mass producers of stringed, fretted acoustic instruments reasonably
expect mass produced, pre intoned bridges to meet acceptable standards of intonation? Or
for acceptably accurate intonation does every individual instrument need to be given
individual bridge adjustment? And if the latter then at what price point would you
consider the guitar industry stops producing acceptable instruments for, say, school aged
guitar lessons? I realise there is the whole set up to be considered as well but surely
without decent intonation no set up is going to deliver much playability above the basic
major and minor chords? No point in wondering much beyond the third fret anyway.
active member
Loc: Devon
Re: Project Ukulele
[Re: Frisonic]
#952948 - 12/11/11 01:34 PM
Hmmm... I've just had a think about that. Of course, a lot depends on how
accurate is acceptable especially in the current climate where most commercial recordings
are tuned to death. The standard slanted saddle is a compromise, and split saddles aren't
a lot better. So all acoustics are inherantly compromised to a greater or lesser
extent. In the past a lot of tuning and intonation problems were as much to do
with the accuracy of the fretting as they were with the accuracy of the bridge. Modern manufacturing means that even the cheapest guitar can have accurate frets. And
once you have repeatable, accurate, frets it is a matter of moments to put together a jig
that accurately locates the bridge with the saddle slot in the right position relative to
the twelth fret. So provided the factory has reasonable quality control, I see
no reason why even the most basic acoustic shouldn't have acceptable intonation given that
guitars are intrinsically a bunch of compromises anyway. And more importantly, even if it
isn't perfect, it should be close enough for a decent tech to make it even more accurate
if that's what a player wants. Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#952976 - 12/11/11 05:59 PM
Thanks for giving it some thought Andy. So this is good news! I guess what you are saying
is that there is no reason why any mass produced acoustic guitar shouldn't play there or
there abouts, out of the box, after a basic set up (assuming the production line was
properly set up in the first place and the manufacturer resisted the temptation to make
the body from cardboard or something). And if you are prepared to invest in a seasoned
luthiers skills then some bespoke fine adjustment to the bridge might improve things
significantly and shouldn't take too much of his/her time.
The sub text being
that intonation problems may often be due not so much to a dodgy bridge but poorly fitted
frets or an unadjustable/unadjusted truss rod?
Cool kitty BTW!
DaveFry
Re: Project Ukulele
[Re: zenguitar]
#953018 - 12/11/11 11:28 PM
Great inspiring thread  Seeing
as we're at the bridge making stage I thought I would post a picture for comparison of a
hand-made bridge I've just been given . It is a spare for the Dilruba I was given earlier
( http://www.soundonsound.com/forum/showflat.php?Cat=&Number=937480&
page=2&view=collapsed&sb=5&o=365&fpart=1#937480 ) It is made of
camel bone , since if it was made of ivory it would not be wise to tell everyone in the
current climate ! It is just a coincidence that they are traditionally made in the loose
shape of an elephant . All those little holes were probably done by hand . Pity it
is chipped at the top . BTW My apprentice in my avatar plays piano , she tried
bass once but got scared . Fantastic work , Andy .
-------------------- Music is it's own reward .
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#953030 - 13/11/11 01:34 AM
Nice bridge Dave, a wonderful collection of drones and sympathetic strings  And as for the Apprentice, she climbs everywhere so it's often safer to have her in
sight on the workbench than creating mayhem out of sight  And as for intonation... in my experience loose truss rods are top of the list, closely
followed by unrealistic demands for perfect intonation. One of the great strengths of the
guitar is that it's a 'both hands on the strings' instrument; whilst it is notionally an
Equal Tempered instrument, in the hands of a skilled/talented player the tuning can be
'sweetened' according to how you play. The harder you press the strings down, the sharper
they go. Or, in other words, tuning and intonation depends on the player as much as it
does on the construction and set-up of the instrument. Show me a perfectly
intonated guitar and I'll find you a guitarist who would still insist on replacing the nut
with an Earvana nut  Meanwhile, time to make a pile of ebony shavings... First step is to mark a
cutting line with a scalpel. And
here's the blank planed down to just under 9mm thick. Then I
marked out the 'wings' on the side, started the cuts with scalpel and razor saw, and
worked away with the chisel. Didn't take too long to make an impression, and here it is in
place on the uke so you can see how it's looking. I decided
to stop there and leave sanding the bottom of the bridge to match the curve of the top
until Monday. But for a comparison, here's the rough shaped blank next to the other bridge
blank. Once the bottom of
the bridge is shaped I'll finish shaping the wings, cut the groove to create the tie
block, and inlay a bone strip along the back edge. Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#953033 - 13/11/11 02:11 AM
Quote zenguitar:
And as for
intonation... in the hands of a skilled/talented player the tuning can be 'sweetened'
according to how you play. The harder you press the strings down, the sharper they go. Or,
in other words, tuning and intonation depends on the player as much as it does on the
Can't argue with that! I of course have only been asking about
this because I need all the help I can get, plus I do play a lot of open chords higher up
the fret board...
active member
Loc: Devon
Re: Project Ukulele
[Re: Frisonic]
#953100 - 13/11/11 02:16 PM
Quote Frisonic:
I of course have
only been asking about this because I need all the help I can get, plus I do play a lot of
open chords higher up the fret board...
It's worth sitting down with a chromatic tuner and spending some
time playing every string at every fret to see how accurate the tuning is. And also
experimenting with pressing the string lightly to the fret, and pressing harder to see how
much difference that makes. Try your favourite open chords up the neck and check the
strings individually whilst holding the chord.
Then put a capo on, fine tune,
and repeat. And do that for the capo at different frets too.
Generally, get to
know the neck a lot better. Learn the areas of the neck/strings that are prone to going
sharp or are very sensitive to how hard you fret the string. Just knowing that can be
enough to get you adjusting the way you play subconsciously. If you find one string that
tends to be sharp, experiment with tuning it a couple of cents flat. Effectively
re-distributing the tuning errors across the neck.
It's certainly a worthwhile
exercise.
Andy
artzmusic
Loc: usa
Re: Project Ukulele
[Re: zenguitar]
#953106 - 13/11/11 03:47 PM
As an ex pedal-steel player I can tell you there are dozens of tuning charts out there
where certain strings are tuned a bit sharp or flat to give proper resonances when played
together. Pianos too.
Interestingly, now playing jazz on my Cordoba, and using
an octave technique quite often, I must detune the G string a bit so that around the 12th
fret it will sync to the E 1st string. So, as Andy says, tunings should always be varied
depending on the acoustic guitar's native intonation and to accomodate the particular
playing style.
Then you really will enjoy playing more because she'll be
singin' to you!
(My Gibson es175 has a floating bridge in addition to
adjustable saddles which allows for perfect intonation settings and hence the sweetest
sound!)
Rick
Loc: Rochester, UK
Re: Project Ukulele
[Re: artzmusic]
#953158 - 13/11/11 10:02 PM
Now this is an interesting twist to the thread. As rather a novice guitarist, I often find
myself with a death-grip on the guitar, resulting in me pressing far too hard on the
strings. Mostly it's not much of a problem, but the A and especially the E(6) string go
very sharp when I do that. I did try tuning them down a touch, but then I find that when
I'm actually playing decently (for a change) they are now too flat.
{mutter}{mutter}Never have this trouble with my keyboard{mutter}
active member
Loc: Devon
Re: Project Ukulele
[Re: Folderol]
#953183 - 14/11/11 01:39 AM
Quote Folderol:
I can fix that
Map after touch to pitch bend
Andy
Loc: Rochester, UK
Re: Project Ukulele
[Re: zenguitar]
#953387 - 14/11/11 08:24 PM
Quote zenguitar:
Quote Folderol:
I can fix that
Andy
Funny you should say
that... One of my soundfont players does exactly that. It doesn't have MIDI filtering
... but my sequencer does
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#953427 - 15/11/11 12:51 AM
So... what's scarier than a luthier who understands MIDI? How about sticking
sandpaper to the front of a uke to sand the bottom of the bridge blank? The front
itself is the perfect template for sanding the bridge to fit. But you have to take care to
avoid pressing too hard, and you have to work slowly and patiently. And this
was where I had one of those Good News/Bad News moments. The bad news is that sanding like
that made me feel my tendonitis. The good news is that it meant I had a real incentive to
keep a loose grip and not press too hard. And after a couple of changes of
sandpaper it was a nice fit. And
time to mark out the channel that separates the saddle from the tie block. Then I cut carefully along the marked lines with a scalpel and cleaned out the slot with
a real router. Not one of those fancy powered ones, a real, old fashioned, manual one.
You'll remember it from when I was cutting the channels for the inlayed rosettes for the
soundholes. I was soon down to the level of the wings I cut last week. So I took the wings
lower again and carried on cutting the channel. It's not quite finished, but here's the
bridge in place to let you all see how it's getting on. Tomorrow I'll get
the groove to full depth, knock up a jig to drill the holes in the tie block for the
strings, and maybe even inlay the bone and veneer strips along the back edge. Andy
Frisonic
Re: Project Ukulele
[Re: zenguitar]
#953428 - 15/11/11 01:01 AM
Phuque Me, that's scarier than watching one of those operating scenes from a House
episode! PS I know very well that all you luthiers are well into your MIDI
sonic trips Andy! Why wouldn't you? Everybody else is
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#953636 - 16/11/11 01:46 AM
And (almost) live from the Operating Theatre at Hector's House... More Ukelele
based shannanigans. After some relaxing work with the razor saw and chisel
taking the bridge wings lower there were no more excuses. Time to drill the string holes
in the tie block. You see, the problem is that the holes aren't parallel to the top of the
block, they come in at an angle from the back to come out at the bottom of the slot. So I
cut the slot a little deeper and decided to knock up a quick jig. Plane the
correct angle along a piece of scrap, and then pin a support to hold the bridge. Then it's
just a matter of marking out the centres at the right string spacing from the
drawing... Clamp
the bridge to the jig and get ready to drill... And here it is
finished with 4 neat holes that appear right at the bottom edge of the slot. Perfect
And after a
relaxing cigarette it was tme to rummage in the offcuts bin. A piece of thin bone (an
extra thin saddle blank) used for a previous inlay and some pieces of blue and green
purfling later, it was time to mark out the tie block ready for binding the back edge. The
bone is nice and hard, doesn't show the string wear so much and is a nice decorative
touch. I've
marked the lines with a scalpel and then chalk to highlight it. Tomorrow I'm cutting the
binding ledge the old fashioned way, with a chisel and scalpel  Andy
Loc: Rochester, UK
Re: Project Ukulele
[Re: zenguitar]
#953784 - 16/11/11 05:27 PM
Very nicely done, and keeping to the minimalist technology I see
active member
Loc: Devon
Re: Project Ukulele
[Re: zenguitar]
#953851 - 17/11/11 01:37 AM
First job today was to cut a strip of bone ready for the tie block. Then it
was out with the scalpel and chisel to cut the channel. And once it was close I grabbed my
nut and saddle files to shape the ledge neatly. Those files are great for this, one is
course and medium, the other is fine and extra fine, but they all have the edges ground
smooth so you can use them as a guide against one edge of the shelf while you sand the
other surface. And after a
few test fittings and final filing, it was time to glue the bone and purflings. And to make
sure that it sat perfectly square, I clamped it in a vice once I had the tape securely in
place. Tomorrow I'll sand it neatly and generally finish off shaping the bridge. But until then
I can make a start on the second bridge. Here's the blank ready for trimming down. And
like the first I trimmed to width and length before marking out for thicknessing. And
then grabbed the plane and got it to about 10mm thick. The blank wasn't quite as thick as
the first, so less shavings this time
This
is the West African Ebony, I chose it for mine as I love the orange grain which is more
visible than that in Ruth's bridge. Andy
