Main Forums >> DIY, Electronics, Studio Design & Acoustics
        Print Thread
Pages: 1 | 2 | (show all)
Studio Support Gnome
Not so Miserable Git
Re: Plasterboard or Render? new [Re: Oliver21]
      #925859 - 12/07/11 08:35 AM
6x2 would do it, you would still need resilient channel though, as they'd be mounted on the same supporting wall structure, so effectively connected at both ends , and you would still have to upgrade the floor layer in the room above
if you don't know who i am, i aint gonna tell you.
Oliver21
member
Loc: Petersfield, Hants, UK
      #926284 - 14/07/11 12:43 AM
This maybe way off but I was thinking.
If the idea is to decouple the ceiling as much as possible from the walls would it help to line the joist hangers with neoprene, make sure the ends of the joists don't touch the walls and not nail them into the hangers so they are, in a sense, "floating"?
www.oliversheen.com
      #926305 - 14/07/11 08:16 AM
the square area of neoprene would be insufficient to resiliently support the mass of a ceiling without total compression.
a stiffer material would have to be used, and the compliancy of material you need has to be calculated based on the mass of the entire ceiling, and the number of joists, and so on... AND this all ignores the fact that you still need a second mass layer to form the other side of the M-S-M relationship with the floor above.. and a set of 20mm floorboards are not it... it would need upgrading there as well, which, yes , means modifying built in furniture, and doors and so on....
Oliver21
member
      #926454 - 15/07/11 12:40 AM
would the additional ceiling joists add a significant reduction (all other things you mentioned being equal) or do you think it would be worth the extra expense and hassle?
www.oliversheen.com
Oliver21
member
      #928118 - 19/07/11 07:31 AM
....urm, bump, I believe is an appropriate word under these circumstances?
www.oliversheen.com
. . . Delete This
Here be Dragons
      #928149 - 19/07/11 09:27 AM
with all the other compromises.... on balance, for the minimal difference it would make, i probably wouldn't bother...
no matter which route you take, the upgrade of the upstairs floor layer is NOT optional....
if you were building a separate free standing frame, then it's own joists would be necessary, but they'd be supported on the wall of the frame... not the existing structure..
and there are still questions about how the floor structure relates to the walls, where the joists go, whether the upstairs walls are structural or partition , whether there are voids that need dealing with...
like i said, it's all getting a bit site specific.... and critical to ultimate performance...
Oliver21
member
      #928798 - 21/07/11 12:42 AM
Right got it. took a while but sunk in now.Thanks for your patience.
OK given that digging the floor up above is probably not going to happen, is there any point in having resilient channel on the ceiling below as It won't achieve a proper mass-air-mass type thingy...
(I really thought that this was going to be my dream studio but maybe I'll have to wait until the next house)
www.oliversheen.com
      #928840 - 21/07/11 08:59 AM
there's still some benefit in doing so... but it will be further compromised...
the improvement to the floor need not be all that drastic... it needs to be airtight and have some mass... this can be achieved by sealing all the gaps, adding a layer of 2mm SBM5 barrier matting and 19mm t&G "quietboard" on top of it, and sealing it again ....
doors and built in furniture will require adjusting, but it is do-able....
Re: Plasterboard or Render? new [Re: Studio Support Gnome]
      #928842 - 21/07/11 09:02 AM
i'd choose to do that (and infill the joist voids with 60kg rockwool) , rather than add layers to the ceiling downstairs and then overlay that with further joists and channel.... because it makes least impact to the available height downstairs,
Oliver21
member
      #929082 - 22/07/11 12:39 AM
So the SBM5 would go on top of the existing floorboards then?
Luckily headroom in the garage is something I'm not short of (about the only thing as it happens) I have about 9' so that wouldn't stop me layering up the plasterboard. Given this, what would you put on the ceiling downstairs?
Cheers
O
www.oliversheen.com
Rate this thread
Jump to
Extra Information
1 registered and 14 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Home | Search | News | Current Issue | Digital Editions | Articles | Forum | Subscribe | Shop | Readers Ads
Advertise | Information | Links | Privacy Policy | Support
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
