Zan Man
Max Power?
#877410 - 26/11/10 11:17 AM
G'day all........ While certainly not the biggest providers of sound re-inforcement
in the world (far, far from it), we are starting to acquire more stuff, as you invariably
do as the years go by. Most of the venue that we do are medium sized halls, ranging from
250 - 500 people capacity. These places, so far, just have the standard ring main supply
for mains power supply. With the stuff that we have, what is the amount of amperage in
reserve from the supply without the mains decideing enough is enough and tripping out. Is
there a formula for this? (never paid too much attention in physics and now it comes back
to haunt!)Stuff we have running at any one possible moment are two active stacks (powered
tops and subs per side), desk, outboard racks (comprising of 3 x 2 channel graphics 4 x 2
channel compressor / gates, fx units, radio mic base units), 4 x 2 channel stage monitor
amps and 2 active monitors. Plus, depending of the amount of stuff the band have, possibly
3 guitar amps, 2 keyboards for example, how much juice is this going to draw if it all
running at a reasonable sound level? We haven't experienced any trouble so far, but it is
something I would like to know. I do not have a 16 amp distribution board, but if I'm
"close to the edge" I will most certainly get one, probably a good idea anyway for gigs in
marquees etc but the places so far as I said only have had the usual ring main juice
supply. As a rough guide, am I anywhere near a 13 amp max?
-------------------- It's my most vivid memory - and you're telling me it never happened?
Mike Stranks
active member
Loc: Oxford, UK
Re: Max Power?
[Re: Zan Man]
#877435 - 26/11/10 11:59 AM
The best way to determine current/power used is with one of these: Mains Meter It'll show you either amps or watts - for your
purposes. You'd normally plug this direct to the mains and then run everything else from
that. The current drawn will depend particulary on how hard the amps are working so it's a
good idea to get someone to look at this at several key points throughout a concert. Don't forget you can use two adjacent (correctly wired) sockets to give you 2 x 13
amps. The only caveat here is that if the stage and the FoH are on different mains rings
then you make get an earth/ground loop when you interconnect them with your stage and FoH
gear. I'm not going to offer any advice on what the likely maximum current draw
is as I don't know your gear. I'd tend to quite happy as long as the peak amps is never
above about 11.5 - assuming all your cables are correctly rated. Always switch
on and off gear in a sequence rather than all at once - with amps last on and first off,
again in sequence. In terms of calculations: Watts (electrical) is
volts x amps Amps is volts divided by resistance Volts is amps times
resistance Resistance is volts divided by amps. So a 13 amp socket
delivers 13 x 240 = 3120 watts (electrical not Audio "RMS"!) HTH
Zan Man
Re: Max Power?
[Re: Zan Man]
#877571 - 26/11/10 09:15 PM
Thanks Mike....... Just checked the price of one of those meters, and they aint much more
than a tenner, so I will get me one of those..... When I do I will get around to letting
you know what we are drawing. Again, many thanks, oh knowledgeable one.
dmills
Re: Max Power?
[Re: Mike Stranks]
#877590 - 26/11/10 10:57 PM
Quote Mike Stranks:
Don't
forget you can use two adjacent (correctly wired) sockets to give you 2 x 13 amps.
Be very careful here, while it might
be true for two separate sockets provided there is not too much else on the ring (Watch
out for caterers), a standard double 13A socket is only actually rated for 20A total load
in most cases (The MK Metalclads are a notable exception).
Now the thing is
that fuses (and up to a point circuit breakers) respond to RMS current, so a short term
transient will be unlikely to case a problem, thus you can run far more then 3KW of
amplifier off a 13A socket without any real problem AS LONG AS THE RING IS NOT ALREADY ON
THE EDGE..... By the time you hit 500 capacity rooms you should be safely clear of
lighting rigs running from the ring main and the worst of the sort of 'caterer' that plugs
3 tea urns and a toaster into a 4 way, but being aware of things like large smoke machines
which can pull a lot of current is a good idea.
TBH at that level there should
be a dedicated 16, 32 or 63A supply available, I would look at a small distro board as
being a worthwhile investment.
-------------------- Audiophiles use phono leads because they are unbalanced people!
PSR
Re: Max Power?
[Re: Zan Man]
#877694 - 27/11/10 06:08 PM
(Some good advice from dmills.)
Forget the outboard quipment - that's only
peanuts in terms of power used.
Add up the power output of your PA amplifiers -
multiply by two.
Add up the power output of your guitar amplifiers - multiply by
three
Add these togther to get an approximate value for total watts needed.
In thoery you can take up to 3000 watts from a 13A socket, and rings are often
rated 20 or 30 amps so you can have perhaps 6 or 9,000 watts total over a number of
sockets - need to examine the fuse box if possible. I really wouldn't recomend taking more
than 2000 watts off any one socket since dirty ones tend to over heat and eventually the
13A fuse can blow.
BUT 1. If you have an old fashioned lighting rig (not an
LED one) then you need to take this into account (- which is why I used to wire in tails
when the venue provided a box - we had about 3K PA and 20K of lights)
2. Many venues
have crap wiring (I call it "landlords wiring" because he did it himself rather then
calling the electrician - see most pubs in Britian). So best not to pull everything off
one socket.
Hope this helps.
-------------------- The PSR
Edited by PSR (27/11/10 06:11 PM)
Mike Stranks
active member
Loc: Oxford, UK
Re: Max Power?
[Re: dmills]
#877755 - 28/11/10 08:58 AM
Quote dmills:
Quote Mike Stranks:
Don't
Now the thing is
Thanks for that Dan. All good stuff!
Prior to this helpful info from you I'd
just accepted the standard nostrum that each 13amp socket can deliver... well... 13 amps!
Your caveats and explanations are helpful and informative - I have read learnt and
inwardly digested!
Cheers.
Mike - still learning after 40 years doing this
stuff!
Scatamonkey
Re: Max Power?
[Re: Zan Man]
#973159 - 29/02/12 06:23 PM
I read so many things on this forum and think - how has my rig lasted so long without
catching fire !!!  I have 2 1900 watt power amps that are always running pretty close to redlining of one
power board out of one 13amp plug socket...which also has a 150 watt monitor amp, my EQ
and a laptop plugged into it...and sometimes a desktop fan to keep the amps cool!!! I know 1900 watts doesn't mean exactly "1900" watts at all times, but I bet its
over the 3KW maximum that Ive just learned is all you should put through a standard 13amp
socket!
Loc: northampton uk
Re: Max Power?
[Re: Zan Man]
#973163 - 29/02/12 06:59 PM
As well also to have a UPS keeping comms systems, READING LAMPS(!) alive in the event of a
blackout whether caused by you or not!
Back in the day we had a CTH 30W PA with
floating car battery so that we could announce a "Don't panic Mr Mannerin" message.
Mike Stranks
active member
Loc: Oxford, UK
Re: Max Power?
[Re: Scatamonkey]
#973200 - 29/02/12 10:00 PM
Quote Scatamonkey:
I read so many
things on this forum and think - how has my rig lasted so long without catching fire !!!
one power board out of one 13amp plug socket...which also has a 150 watt monitor amp, my
EQ and a laptop plugged into it...and sometimes a desktop fan to keep the amps cool!!!
socket!
I think you're confusing
"output power watts" with the power consumption of the amp.
Assuming we're
talking about your Numarks then, according to the manual, the max power consumption is
10amps. That's 2.4KW per amp - maximum. The reality is that even when working hard, most
amps draw well below their rated value. As long as you switch amps on one at a time you
should be fine, BUT don't just hope or, heaven forfend, go on my sayso!. Get one of
those meters I mention earlier in the thread and check out what the load per socket is
like when your system is working at normal levels.
... and of course, regularly
check all mains plugs and sockets for integrity - all fuses at rated values, all earths
securely fastened, all screw terminals nice and tight and no 'whiskery' bits of wire
evident in plug or trailing socket housings.
dmills
Re: Max Power?
[Re: Zan Man]
#973218 - 29/02/12 11:43 PM
Amplifiers do not run anything like full power all the time (nothing like it), and 1/8th
of full output for an average over a few tens of seconds is generally considered typical,
so those 1900W amps are probably putting out ~220W or so on average, and assuming a
typical sort of efficiency will be drawing maybe 500W average from the supply over a few
second integration time. I doubt they are power factor corrected so that might euate to
750VA or so, but still that is only about 3A.
The peaks might be very much
higher, but fuses and (to an extent) circuit breakers respond to RMS current not peak, so
as long as the voltage drop stays reasonable on peaks you can power a hell of a lot of PA
off a 13A socket.
I used to routinely run 6kW of Camco off a single socket,
and sometimes 12k off a double with never a problem.
Power, especially time
varying power, is not simple.
Regards, Dan.
Scatamonkey
Re: Max Power?
[Re: Zan Man]
#973223 - 01/03/12 12:28 AM
Thanks Mike and Dan for the peace of mind - I did have a wee mini panic when I read all
that, but I was pretty sure about the "amps not putting out maximum" all the time bit! Still, always better to check with the experts...thats you guys by the way!
