Jack Ruston
Re: Bob Clearmountain v Line 6 POD
[Re: Mixedup]
#919419 - 09/06/11 09:58 PM
I'm slightly reluctant to weigh in on this for various reasons. But anyway... IN MY OPINION I totally agree with Bob. Simulated guitar sounds are terrible
to mix. They just wont 'come forward' properly. It's as if they dont move the cone as much
as a speaker captured with a mic. And for me there's the rub. It's not the simulation of
the amp that's so wrong (although I do believe a great real amp is better than a great
simulated one). Because if you run simulated sounds at high level into a real cab you can
get sounds that work properly. OK they might not be quite what you expect...They might in
some cases be better but the component we dont yet simulate properly is the speaker, and
to be more specific the speaker distortion. The difference is that with the real speaker,
as it distorts, in addition to distortion we get a limiting. And the charachter of this
limiting is that it seems to allow highs, mids and lows of the sound to push up against
the end stops. To align. To glue toghether. I've recently been playing around
with running the unsimulated output of a dummy load connected to a valve head into speaker
impulse responses. Invariably my first reaction is 'wow this sounds good, It's so cool
that we can do this'. And the second I then switch out the real cab I feel a wave of
disappointment as I realise how much better it is. Every time. I believe the problem is
probably to do with the fact that the sine sweep just cant make the speaker extrude in
the right way. Of course this is a bugger, because the one thing a lot of us
want to do a lot of the time is get a really great 'silent' guitar sound. My experience of
this is that at the moment at least, you can't. But I do believe we will see
this as and when people turn increasingly clever technology at the problem of speaker
simulation rather than amp simulation. I was rather hoping Anamod might have a crack at
it. I did email them about it. NB. I'm not saying that people don't use these
sounds on records. Fake amp to real speaker gets used a lot and has done since the 80's.
Fake amp with simulated speaker gets used too. But I agree with Narcoman...These sounds
are not great. I don't believe they're on Slash's record, put it that way. J
-------------------- www.jackruston.com
. . . Delete This
Here be Dragons
[Re: Jack Ruston]
#919470 - 10/06/11 07:29 AM
the other thing that no modelling device can replicate , is the acoustic linkage between a
real amp/cab and the instrument itself... it's one reason why i always ALWAYS play in
the room with the amp..... (obviously with ear defenders, over in ear monitors, or high
isolation cans of some sort,.... ) (or failing that, run the main monitoring system
real hard in the control room, but even that is just not the same.... )
that connection between the speaker and the instrument body&strings affects
not just the tone, but the way you play,..... no pod, or v-amp, or motherload system does
anything to replicate it, nor could they..... it's a very directly , fundamentally
physical thing.... is different for every guitar, and varies depending on position
relative to the speaker and the room you're in.... that's why some "virtuoso" type
people spend time in sound checks , looking for the sweet spots on the stage, and marking
them.... so they can get that linkage to work with them in their performance.... and
the same applies to studio playing...... or it should at any rate.....
this may not necessarily relate to things being "unmixable" but it definitely does
relate to the acquisition a "GREAT" recording of a performance, and indeed , simply
quality the performance itself...
TheChorltonWheelie
[Re: Jack Ruston]
#919474 - 10/06/11 07:53 AM
Quote Jack Ruston:
I totally
agree with Bob. Simulated guitar sounds are terrible to mix.
You're not agreeing with Bob though, Bob's
comments were made 10 years ago, on 1st generation modelling hardware, so you're comparing
apples with oranges.
There are plenty of commercial releases that show that
these guitar plug-ins work, and do sound good, as well as the plethora of YouTube demos by
both professionals and home enthusiasts alike, so the notion that they're simply "usable"
is, quite frankly, laughable. For the record, I have Twin, a Bassman and an Orange
Thunderverb amongst other amps, so I know what a great sound is, and, I'm not biased
towards plug-ins either.
TheChorltonWheelie
[Re: Jack Ruston]
#919479 - 10/06/11 07:56 AM
Quote Jack Ruston:
I don't
There we have it.
Modelling is only "usable" at best,
and Brendan's a liar; I think we can lock this topic now that we've sorted all that out.
. . . Delete This
Here be Dragons
my my, aren't we a grumpy wheelie  FWIW, i think Jack's personal opinions are at least worth listening to.... and usually bang on the money..... and his work load and client base bear out the
results. i don't ALWAYS agree with him, but it's rare, and usually down to a
personal preference choice rather than an absolute....
Jack Ruston
[Re: Mixedup]
#919515 - 10/06/11 09:01 AM
Look, I put 'IN MY OPINION' in caps for a reason. This is a controversial issue which is
why I was reluctant to get involved. I fully respect your experience with this technology.
For what I do, I don't prefer it. You may find that for what you do it's every bit as
good. I would never claim that you're wrong. Its a matter of subjective opinion. Yours is
every bit as valid as mine and I'm not trying to change anyone's mind.
narcoman
active member
Quote TheChorltonWheelie:
There are plenty of commercial releases that show that these guitar plug-ins work, and
do sound good, as well as the plethora of YouTube demos by both professionals and home
enthusiasts alike, so the notion that they're simply "usable" is, quite frankly,
laughable. For the record, I have Twin, a Bassman and an Orange Thunderverb amongst other
amps, so I know what a great sound is, and, I'm not biased towards plug-ins either.
Again - the thread mentioned
great. All sims miss
1. being in a room - even when they have it it's a
convolution and that's not the same. I move my amps around the room to make them sound
different - yes even spot mic'ing.
2. different speaker voicing - Of the many amps I
have each speaker sounds different. Plugins "model" a handful
3. different mics -
let's not get started on mic modelling!
4. how you mic it. I do all kinds of cool
stuff to get QOTSA or Johnny Cash tones! None of it doable in a sim
They are
merely "usable". Nothing laughable about it. Guitar Rig is my pet hate - nothing, I mean
nothing, comes out of that without a fekking horrible 3k hype. Nasty.
We're
talking about GREAT guitar sound here - things that make your jaw drop..... but as Jack
says it is subjective. No sims here. That simple.
narcoman
active member
Quote narcoman:
As I say,
useable and good. But never great.
Remind me to tell Brendan O'Brien that his guitar sounds are merely "useable",
I'm sure the Boss and Slash will drop him like a hot potato when they read your critique.
Well I've sold more
product than him. .....
although not rock records
and _ahem - a response to your ACDC ITB 'ness
www.soundonsound.com/sos/jan09/articles/itfraser.htm
So. Not only were those tones from a classic mic' up job, I still don't like em!!! . Cream on
your pie?
Dear loves,
I've mixed some of the biggest
soundtracks around and in that role I've been sent all manner of stuff. Some of it sounds
an utter disgrace when it gets here - badly set up samples and the like. Now - using a bit
of turd polishing and hard work I make some of these sonic disasters (but often
compositional wonders) sound a hell of lot more "it" than they did when they arrived. That
goes for "guitar rigs" and "amp farms" too. They're hard work to make them shine -
especially if the recording team have gone to the bother of recoding a great drum sound
fer real.....
If the sessions allow I've taken the speaker sims off and
played them out through amps in a room (re-amping baby, re-amping).
When
guitars get sent from decent players, with decent recordists and production crew in charge
- they're just "push the faders up an the records there". Same with real drums against BFD
. Same with a real hammond versus a Korg. You cut the corners early on - you make my life
harder and I charge you more.
As Jack says - it's obviously subjective and
this is MY opinion. My opinion is the only one I have and it's the one that earns me
money.
Here's a little reality trip : I endorse a few products out
there, most interestingly a well known brand of pretty decent plugins. I go on about how
they're the bees knees in my promo duties. Now - here is the rub. I don't actually use
them that much. Why? Cuz I've access to better most often. "But Narco - you git, why
endorse it then?".
"Because, in the sad corporate world we live in",
replied a now very uncomfortable Narco, "it gets my name into the ears of many of those
decision makers out there in "we need our stuff mixing" land.
Or
do you think CLA REALLY thinks the Waves plugins are awesome? ....
welcome to the world of commerce......
TheChorltonWheelie
[Re: narcoman]
#919546 - 10/06/11 10:00 AM
Quote narcoman:
and _ahem - a
<a href="/sos/jan09/articles/itfraser.htm"
target="_blank">www.soundonsound.com/sos/jan09/articles/itfraser.htm</a>
. Cream
on your pie?
No, not at
all, and I think you'll find that's wrong; the reason I know modelling was used is quite
simple, Angus told me. I say he told me, he told anyone that has seen the Live @ River
Plates DVD.
TheChorltonWheelie
[Re: narcoman]
#919549 - 10/06/11 10:10 AM
I'd also ask some questions regarding "great guitar sounds":
1. It's purely
personal, one mans water etc. A great sound to me is Nile Rodgers 70's Chic recordings,
but I'd say that it you were to ask 10 respected guitarists to quantify a "great sound"
they'd all say something different. 2. The production of modern music is as much part
of the trend as the musicality itself, and therefore who exactly is listening out for
these "great guitar sounds".
As an example, I can still listen to the 20 year
old "The Extremist" and admire the "great guitar sound", in the same way that I can listen
to the recent Stones record and deteste their production values.
narcoman
active member
I'd
1. It's purely
Totally right on!!!
narcoman
active member
Quote narcoman:
and _ahem - a
. Cream
on your pie?
No, not at
Plates DVD.
not seen it. Bu
tI'll check it.... sure he wasn't taking the piss?
TheChorltonWheelie
[Re: narcoman]
#920030 - 13/06/11 07:53 AM
Quote narcoman:
not seen it. Bu
Granted, it's widely accepted that
Angus isn't playing with a full set of marbles these days, Malcolm even less so.......
4TrackMadman
active member
[Re: Mixedup]
#920133 - 13/06/11 04:09 PM
Maybe they reamped Angus' stuff after he passed out? I've done some records
where we kept everything via DI while the musician was there and went nuts afterwards.
Right now I am working on a commmercial CD and all the lead guitars are actually ending up
on sims and they sound great, but again we're talking that they have to cut over several
layers of live miked guitars.
-------------------- www.descentintomadness.com
dubbmann
active member
Loc: 3rd stone from the sun.
[Re: Mixedup]
#922505 - 25/06/11 03:39 PM
i have to add to my earlier reply on this topic (in which i defended direct recording of
FX units, though not necessarily amp sims, which i don't really use). having been
watching a bunch of YouTube vids of 60s and 70s rock bands like Humble Pie, Free, and
Budgie, if that's the guitar sound you're after, there really is no substitute for playing
a good guitar in front of loud amp. the resonance and re-inforcement of the sustain
between the amp and the guitar strings is a massive effect that i doubt any IIR/FIR
digital filter can capture, especially since it's so dependent on the particular
guitarist's technique and preferences. you can use your fretting fingers like individual
envelope generators (synth-speak, for all our guitar-only members) and watching masters
like paul kossoff, steve marriot, and the guy from budgie is just inspiring. not enough
to go buy a big stack and blow my hearing out but it's more tempting now than it was
before. fortunately for me (and my neighbors and the local police) i don't really play
that kind of guitar, but man i love the sound!
cheers,
d
-------------------- "Patsy had the drug tolerance of Keith Richards and the moral rectitude of Brian Jones." - Dr. Walter Bishop, "Fringe"
