Mixedup
active member
Loc: Cambridge, UK
DAW Features You'd Love To See
#920420 - 14/06/11 09:50 PM
I've been thinking of some features I'd like to see in my DAW of choice. I'd love to know
what others would like to see. Let's make this a wish list - rather than a slagging
off/championing of your favourite DAWs please!
Here are a handful to get you
started, mostly to help with mixing, though if you're composing, mastering, tracking or
whatever, feel free to add...
(1) Variable phase control on each channel -
instead of the regular phase flip control, why not have a variable phase control like
Little Labs IBP. Cost would be prohibitive on an analogue console, but there's no reason
not to include this in a DAW. I use them so much, it's a pain in the arse to take up an
insert with them. Ditto high/low pass filters.
(2) Wet/dry controls for each
insert slot. To make parallel processing a piece of cake with any plug-in rather than have
the developers have to write it into every plug-in.
(3) Solo for insert slots.
So you can eg rack up 4 different compressors or limiters on one channel and audition one
at a time, switch instantly between them, without having to fiddle with plug-in bypass for
each one.
(4) The option for multiple meters - eg peak and RMS at the same time
on every channel. Or to choose which channels display pre fader and which post.
active member
Loc: Devon
Re: DAW Features You'd Love To See
[Re: Mixedup]
#920435 - 14/06/11 11:56 PM
The biggest isn't really a DAW feature, it's an OS one... aggregate audio devices on
Windows. Grrrrrrr But beyond that, I'd love incredibly accurate but idiot
simple extraction of tempo/time signature from audio. So I can import/record a simple
guitar/vocal demo and easily get a template to sync everything else. And I do mean IDIOT
SIMPLE. Andy
-------------------- When the going gets weird, the Weird turn Pro.
grab
Loc: Cambridge, UK
[Re: Mixedup]
#920486 - 15/06/11 08:36 AM
Switch to Reaper.
1) "Take up an insert"? Number of FX is set only by what
your PC can manage. FWIW, this is true for most DAWs. If you need it on every channel,
add it on every channel.
2) Reaper does wet/dry out of the box.
2
and 3) Most decent DAWs don't limit you in setting up send FX. So you simply set these up
as send FX, and don't send the original track to the mix.
The_Big_Piano_Player
active member
Loc: Lincolnshire
[Re: grab]
#920507 - 15/06/11 09:16 AM
Quote grab:
Switch to Reaper.
Most decent DAWs don't limit you in setting up send FX. So you simply set these up as
I agree with the original poster... a
wet/dry mix would be handy on inserts, - send FX is a little fiddly if you only want it on
one track.
However, there's an argument that suggests DAWs are already
complicated enough, these days. If anything, I'd like some of the more obscure options
removed/hidden to make way for any new ideas. Most of the options on Sonar X1 I never
touch on a day-to-day basis. Some options never used.
-------------------- www.thediplomatz.com
Loc: The wilds of Hampshire
[Re: zenguitar]
#920509 - 15/06/11 09:18 AM
Quote zenguitar:
The biggest
isn't really a DAW feature, it's an OS one... aggregate audio devices on Windows.
Grrrrrrr
Blame
Steinberg for that. Microsoft had their own high performance system (Direct X) but
Steinberg couldn't seem to get their heads around it so they created their own much more
limited system which everyone seems to use these days.
James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Paul Nagle
member
Loc: Lancs
[Re: James Perrett]
#920517 - 15/06/11 09:55 AM
As a Logic user I really, really miss "transpose to scale". I'm still a bit amazed when I
realise it doesn't have it.
-------------------- http://www.bogusfocus.com/
active member
Loc: Sheffield, UK
[Re: Mixedup]
#920534 - 15/06/11 10:49 AM
Totally agree with the aggregated ASIO devices suggestion. We’ve been without that one
for far too long. Maybe Steinberg should be chatting with Microsoft to hand over future
development of ASIO? Although by track record I’d champion RME to take it on!
In Cubase I’d like to be able to send an FX channel back to itself to create a
feedback loop. It seems that Steinberg are determined to save me from myself on that one -
bah!
I’d also like the ability to load multiple saved mixer channels in one
dialogue. I have a number of pick ’n’ mix FX channels saved, but I have to create a
‘blank’ FX channel and load each one individually. It would also be nice if Cubase
would create the channels for me at load time instead of me having to create them
up-front.
Maybe waveform displays could become a little more intelligent.
Sometimes I can HEAR differences in the audio, yet the amplitude waveform looks very flat,
making editing difficult. Rhythm electric guitar would be a good example. Maybe if the
amplitude waveform could be coloured according to frequency content? Where I can’t see
an obvious amplitude peak, a bright yellow portion of the waveform might give me a shot at
making a cleaner cut.
I’d also like ‘Create blank track based on the
track I’m sitting on'.
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
Mixedup
active member
Loc: Cambridge, UK
[Re: grab]
#920546 - 15/06/11 11:23 AM
Quote grab:
Switch to Reaper.
No. I already have it, and
although I use it from time to time, I find some features (these included) to be
inelegantly implemented. I also find Reaper to be deficient in some other areas compared
with my main DAW. Hence the idea of a thread simply listing useful features, rather than
descending into a 'which is the best DAW' thread yet again.
Ideally, I'd like
a nice, clean mixer-style GUI with several things instantly switchable/tweakable without
having to take up huge amounts of screen real estate with plug-ins. If I want variphase on
every channel and want to juggle more than one channel at a time, it's a pain to have to
work with separate plug-in GUIs. That would be like having a gainer plugin instead of a
fader, or a dedicated stereo pan pot plugin instead of a pan on the mixer.
Where there's a single parameter to adjust (phase, wet-dry, HP filter freq etc), it
makes sense to me to have the control embeded in the mixer rather than presented as a
separate plug-in.
True aggregate devices on Windows would be great, but let's
keep on-topic if we can - DAW features only. Here are some of the most useful features I
can think of that already exist but haven't been cribbed by all DAW manufacturers...
I love the edit as you record feature in Samplitude. I'd love to see that in other
DAWs. Ditto the object-oriented editing.
I love the elegance of the mix/edit
groups in PT, and also the implementation of VCA grouping.
I love the vocal
comping facilities in Logic.
I love the arrangement facilities (particularly
the Arranger Track) in Cubase.
I love the drum part editor in Cubase.
I love the remix facilities (ease of pitch/time manipulation on multiple tracks) in
Cubase.
I love the clip indication facility in Sonar.
And the
waveform display in Wavelab.
I hate the metering on pretty much all of them -
big potential area for improvement. Ditto the scoring facilities, particularly for scoring
drum parts.
onesecondglance
Loc: Reading, UK
[Re: The Elf]
#920574 - 15/06/11 12:51 PM
Quote The Elf:
I’d also like
‘Create blank track based on the track I’m sitting on'.
+1. like "duplicate track" without getting
all the actual parts that are on there.
-------------------- hourglass | random thoughts | doubledotdash!? collective
active member
Loc: Sheffield, UK
[Re: onesecondglance]
#920576 - 15/06/11 12:57 PM
...and I'd like the ability to hide tracks in Cubase's Arrange Page, just as in the mixer.
desmond
[Re: The Elf]
#920580 - 15/06/11 01:14 PM
Properly implemented, consistent patch management, meta-data and selection for plugins and
instruments.
Sam Inglis
SOS Features Editor
[Re: Mixedup]
#920582 - 15/06/11 01:16 PM
Perhaps one day Cubase will let us drag and drop tracks in the mixer... and display
inserts and sends at the same time...
nah, it's an impossible dream, surely.
Mixedup
active member
Loc: Cambridge, UK
[Re: The Elf]
#920584 - 15/06/11 01:17 PM
Quote The Elf:
...and I'd like
That's another one that's done perfectly in
PT, IMO. With the show/hide window on the left of the screen. I'd like the arrange and
mixer page track visibility to be linkable.
Watcher Of The Skies
Loc: Cornwall, UK
[Re: zenguitar]
#920600 - 15/06/11 01:48 PM
Quote zenguitar:
I'd love
incredibly accurate but idiot simple extraction of tempo/time signature from audio.
[swift-hijack-mode] Andy -
have you ever tried the freeware MixMeister BPM Analyser? Standalone utility, but
works a treat! www.mixmeister.com/bpmanalyzer/bpmanalyzer.asp
Martin [/swift-hijack-mode]
-------------------- YewTreeMagic
Mixedup
active member
Loc: Cambridge, UK
[Re: Martin Walker]
#920608 - 15/06/11 02:05 PM
Quote Martin Walker:
Quote zenguitar:
I'd love
[swift-hijack-mode]
Andy
- have you ever tried the freeware MixMeister BPM Analyser?
works a treat!
I'd
thought he meant something more complicated than that, tracking tempo and time-sig
changes. Now *that* would be worth having.
The problem with tempo analysis
stuff is that, believe it or not, DAWs aren't consistent in their measurement of bpm.
Cubase and Logic seem to drift out over a 3m30s pop song for example. You would have
though that a measure of quantity over time would have to be identical, but it seems
not...
Anyway, nice idea... maybe you could take it to another thread to
discuss in more detail and keep this one for high level ideas? Spin-off threads to
discuss details would be welcomed, of course!
Mr Windle
member
Loc: Wiltshire
[Re: Mixedup]
#920627 - 15/06/11 03:16 PM
Here's one I touted in the Cubase forum and got quite a lot of support for (whether enough
to ever see it implemented, who knows?)
Anyway, I love to have some sort of
Humanise function for the selected MIDI tracks on the Main Arrange page.
Writing for media means lots of cutting and editing and so all tracks really have to be
hard quantised to the grid to allow this, otherwise, chaos!
So when writing
orchestral mock-ups, having a small degree of un-togetherness would be a good thing but
without the notes being moved on the grid. This way the mock-up can sound more realistic
but without the notes actually moving. This also helps when the MIDI file gets sent to an
orchestrator or copyist as they would be in the right place.
This Humanise
Function could work in the same way as the different Quantise functions and even have an
option to permanently alter the MIDI notes if desired. Options to Humanise All or
Humanise Selected Tracks.
Remember, you heard it here ...er... second.
W.
onesecondglance
Loc: Reading, UK
[Re: Mr Windle]
#920630 - 15/06/11 03:20 PM
so the basic MIDI data is rigid to the grid, but on playback it's humanised? sounds sensible. i know some VSTis already offer this as an option (e.g. EZDrummer) but
as a lot don't a system function for it would be helpful.
johnny h
#920647 - 15/06/11 04:09 PM
Quote onesecondglance:
so the
sounds
sensible. i know some VSTis already offer this as an option (e.g. EZDrummer) but as a lot
Ableton does this. All its midi functions apart from the groove
quantise are awful though.
desmond
[Re: johnny h]
#920648 - 15/06/11 04:12 PM
Logic does many of the things people have requested.
I thought the idea was
stuff that DAWs should have, not little features my particular DAW doesn't have that I'd
like...
active member
Loc: Devon
[Re: Mixedup]
#920676 - 15/06/11 07:06 PM
Quote Mixedup:
Quote zenguitar:
I'd love
I'd
You thought right, tempo map AND time-sig changes. Would be
useful in so many ways.
Andy
Andi
Loc: Berkshire, UK
[Re: Sam Inglis]
#920677 - 15/06/11 07:16 PM
Quote Sam Inglis:
Perhaps one day
Cubase will let us drag and drop tracks in the mixer... and display inserts and sends at
the same time...
Bloody Hell, it's like reading H P Lovecraft
in here!
-------------------- Andi, www.thedustbowl.net Mixing, Mastering, Audio Editing at The Dustbowl Audio
wave1
[Re: The Elf]
#920716 - 15/06/11 10:26 PM
Quote The Elf:
...and I'd like
I do this by making a folder track at the
bottom of the arrange page called "mute tracks" or something similar. Not quite as direct
as your idea, but I find it does the job...
Ant Gamble
member
[Re: Mixedup]
#920719 - 15/06/11 11:08 PM
I Tried getting a few companies interested in these....no bites.
1.
Assigning notes/group of notes/control codes in a midi track to a virtual midi track. I
could record drums from my TD20, patch through to Superior/EZ/Addictive/whatever and
control velocity/panning/etc. of the 'virutal tracks' to effect kick drum volumes
independently from snare, toms, etc. non destructively. You can do it in cakewalk with
'split notes' cal routine, but control parameters get 'lost'.
2. MIDI ODBC
driver. I'm a programmer. I'd like to be able to execute SQL statements such as (simple
examples):
(a) Remove x-talk notes when recording from my TD20
Delete * from [Track1] Where [Velocity] < 10
(b) Change all notes
Update [Track1] Set [Note] = 'C5' where [Note]='C7'
(c) Minimum
length of a particular note (e.g. one mapped to a crash cymbal) 1 = 1 bar (0.25 = 1 beat
if timing was 4/4).
Update [Track1] Set [Length] = 1 Where [Length] < 1
and [Note] = 'D4'
For constantly performed procedures, you could have a whole
script and 'enable/disable' check boxes for each statement, rendered in real-time non
destructively. I hate messing around dragging/dropping with my mouse (especially since my
wrist operation). With this idea, I'd be able to write my own 'midi plug-ins' to do
anything!
By the way, (c) Ant 2009!!!
Edited by Ant Gamble (15/06/11 11:11 PM)
desmond
[Re: Ant Gamble]
#920721 - 15/06/11 11:15 PM
Quote Ant Gamble:
I Tried getting
1. Assigning notes/group of
notes/control codes in a midi track to a virtual midi track. I could record drums from my
TD20, patch through to Superior/EZ/Addictive/whatever and control velocity/panning/etc. of
the 'virutal tracks' to effect kick drum volumes independently from snare, toms, etc. non
destructively. You can do it in cakewalk with 'split notes' cal routine, but control
You
can do that in Logic, all in real time, and route individual notes to different
instruments etc.
Quote Ant
Gamble:
2. MIDI ODBC driver. I'm a programmer. I'd like to be able to
execute SQL statements such as (simple examples):
[Note]='C7'
(c) Minimum length of a particular note (e.g. one mapped to a crash
cymbal) 1 = 1 bar (0.25 = 1 beat if timing was 4/4).
Update [Track1] Set
[Length] = 1 Where [Length] < 1 and [Note] = 'D4'
The percentage of DAW users/musicians who can write sql is pretty
small. However, much of this you can do in Logic in a similar fashion with the transform
window.
shufflebeat
Loc: Manchester, UK
[Re: Mixedup]
#920724 - 15/06/11 11:37 PM
Quote Mixedup:
Where
there's a single parameter to adjust (phase, wet-dry, HP filter freq etc), it makes sense
to me to have the control embeded in the mixer rather than presented as a separate
plug-in.
Don't know about
other DAWs but his is already implemented in Reaper and it's something I find myself using
a lot.
Personally the most useful tool at the minute would be a time shift
function that allows me to slow the passage of time while I explore the possibilities of a
particular harmony without bottlenecking the whole day.
A room analyser would
probably be handy. Stick a named mic (RTA?)in various parts of the space, type in the room
dimensions, produce a sine wave and impulse by way of a named monitor, take a profile,
suggest solutions (possibly sponsored by Wickes Building Supplies).
-------------------- Ohm's Law states, "Your PA isn't as powerful as you think it is".
Mixedup
active member
Loc: Cambridge, UK
[Re: shufflebeat]
#920726 - 15/06/11 11:45 PM
Quote shufflebeat:
Don't know
about other DAWs but his is already implemented in Reaper and it's something I find myself
using a lot.
Not in my
version! Unless you misunderstood what I meant.
The room analyser idea... why
would you want that in you DAW? You analyse it, fix it... and then don't really need it
again.
Mixedup
active member
Loc: Cambridge, UK
[Re: Ant Gamble]
#920728 - 15/06/11 11:48 PM
Quote Ant Gamble:
2. MIDI ODBC
examples):
It's not SQL, but you can certainly do this
sort of task in Cubase's Logical Editor. Macros are handy too.
Mixedup
active member
Loc: Cambridge, UK
[Re: Mr Windle]
#920729 - 15/06/11 11:52 PM
Quote Mr Windle:
Anyway, I love
to have some sort of Humanise function for the selected MIDI tracks on the Main Arrange
page.
Yes, would be nice to
apply that to several tracks at once. I take it you've already investigated (a) the
transformer MIDI plug-in, and (b) the MIDI Track Inspector/MIDI
Modifiers/Random/"Position" option?
shufflebeat
Loc: Manchester, UK
[Re: Mixedup]
#920735 - 16/06/11 12:13 AM
Quote Mixedup:
Quote shufflebeat:
Don't know
using a lot.
Not in my
Is this what you mean? (from reaperuserguide375c.pdf)
11.9 Showing FX Parameter Controls
The menu option Show FX parameters when
size permits can be used to add to the mixer panels FX controls for those parameters
specified in the Envelopes window (see Chapter 9). To select those parameters that you
wish to have displayed, click on the track's Envelope button to open its Envelopes window,
then check the UI box for each parameter that you want displayed.
In the example
shown on the right, the plug-in ReaEQ has been added as an FX to a track called Vox.
As well as the plug-in itself appearing in the mixer panel (at the top) we have also
decided to show controls for two of that plug-in's parameters, Band 2 Gain and Band 3
Gain.
To remove an individual control from the display, hold the Alt key while you
click on it.
In my experience the best way is to hit the 'envelopes' button,
choose the parameter you want then tick the 'UI' box on the right.
Quote Mixedup:
The room
analyser idea... why would you want that in you DAW? You analyse it, fix it... and then
don't really need it again.
Because I imagine (in my innocence) that most of the elements required are already in
place in most DAWs so it wouldn't take much bolting together but it would allow you to,
er, analyse it and fix it and then not use it again.
active member
Loc: Sheffield, UK
[Re: wave1]
#920743 - 16/06/11 05:55 AM
Quote wave1:
Quote The Elf:
...and I'd like
Good idea. Yes, I do this too (and I disable the tracks as well), but
it gets messy and I often want to keep tracks together (e.g. DI and amped guitar tracks),
even though I may not be using them.
4TrackMadman
active member
[Re: Mixedup]
#920745 - 16/06/11 06:45 AM
1) How about a licensing/validation scheme that doesn't cause you hair loss?
For that I give props to Reaper.
Dongles, eLicensers and all other junk
keeps the paying user away from their purchase. Steinberg for example kept me away from my
music for 7 days this last month and could only offer a partial solution to an XP bug in
their eLicenser.
2) Tempo/meter feature that could program a whole song by
inputting data parameters in a program window.
What I mean by that is saying
4bars 3/4 meter at 120bpm, 3bars 7/8 at 130bpm and so forth and handle mixed meter tempos
gracefully in chunks as a guitarist would in a riff oriented fashion, then the arrangement
is created for you so you won't have to count bars, etc.
-------------------- www.descentintomadness.com
Mr Windle
member
Loc: Wiltshire
[Re: Mixedup]
#920777 - 16/06/11 09:24 AM
Quote Mixedup:
Yes, would
be nice to apply that to several tracks at once. I take it you've already investigated (a)
the transformer MIDI plug-in, and (b) the MIDI Track Inspector/MIDI
Yes, investigated these but they either:
a) work on a single track at
a time - I'd like a big macro setting to fiddle with and hear the effect over the whole of
the string section/brass/orchestra etc.
b) change the actual position of the
notes and for the reasons stated before, that's a no-no.
W.
Sam Inglis
SOS Features Editor
[Re: Mixedup]
#920783 - 16/06/11 09:56 AM
OK, here's two features I'd love to see in DAWs that as far as I know most don't have:
(1) the ability for plug-ins (including off-line plug-ins) to write automation
data.
(2) support for AppleScript or whatever the PC equivalent is.
Mixedup
active member
Loc: Cambridge, UK
[Re: Sam Inglis]
#920789 - 16/06/11 10:33 AM
Quote Sam Inglis:
(1) the ability
for plug-ins (including off-line plug-ins) to write automation data.
You mean like Vocal Rider and the BlueCat
stuff? Yes, very cool feature and not enough of them have that. Not enough have MIDI
output either so that you can at least record MIDI data (eg some gates double as MIDI
triggers, very useful).
What is AppleScript?
Sam Inglis
SOS Features Editor
[Re: Mixedup]
#920790 - 16/06/11 10:44 AM
AppleScript is a scripting language that enables you to create complex macros. I used to
use it a lot with BB Edit to do complicated text manipulations.
Mixedup
active member
Loc: Cambridge, UK
[Re: shufflebeat]
#920796 - 16/06/11 10:54 AM
Quote shufflebeat:
Is this what
Nearly, but not quite. Thanks
for making me aware of it — which I wasn't — but that's pretty much the same thing as
Cubase Quick Controls. Would also be useful to decide where in the mixer everything was
displayed - almost as if you were designing your own GUI as you would in Reaktor,
Synthedit etc.
Fair enough. The elements are all there (apart from the mic) in
some of the DAWs, but you're talking about a hit one button facility? Could be useful. I
like Fuzzmeasure Pro for this, but might be useful to have an instant facility for
this.
Also for capturing impulse responses for the convolution engines which
seem to be in all DAWs now.
Mixedup
active member
Loc: Cambridge, UK
[Re: Sam Inglis]
#920798 - 16/06/11 10:58 AM
Quote Sam Inglis:
AppleScript is
a scripting language that enables you to create complex macros. I used to use it a lot
Ah... so similar to incorporating SQL, or like when you use VBA
in MS Word, Access and Excel; or like programming in Flash etc? ie a 'Basic' style
computer language. Logical Editor in Cubase not good enough for you then?
ConcertinaChap
Loc: Bradford on Avon
[Re: Mixedup]
#920825 - 16/06/11 12:47 PM
I must admit, I'd really like to see a nice, full featured programming language in a DAW.
Back in the mid 80's I was quite a fan of AMPLE (even had the Music 2000 MIDI interface
for controlling synths). I loved the Forth-based language, though nowadays with modern
processors I think I'd prefer something with a proper block structure like C or Pascal.
Given a decent API for the DAW's internals and plugins and ideally an Eclipse-based IDE
the possibilities would be endless.
-------------------- Put the fun back into dysfunctional.
Mr Punch's Studio
Mixedup
active member
Loc: Cambridge, UK
[Re: Mixedup]
#920826 - 16/06/11 12:49 PM
I've only just seen the announcement about Harrison Mixbus v2.0 which incorporates a lot of the mixer
features I'd like to see. Will have to try that out when it becomes available for Windows.
Sam Inglis
SOS Features Editor
[Re: Mixedup]
#920828 - 16/06/11 01:03 PM
AppleScript isn't really a proper programming language. It's more like a way of recording
and editing sequences of actions: open this menu, select this item, hit this button, then
do this... but it's fairly simple, it works, and it's a lot more comprehensive than the
macro support in Cubase.
