Weedog
Loc: Melbourne, Australia
How much and what reverb to add?
#939925 - 10/09/11 01:39 PM
Hi all,
I just got myself a TC-Electroinc M-ONE XL Reverb unit and I'm a little
blown away by how many types of reverb can be set.
Can anybody please suggest
what style of reverb they use/prefer and when each might be used? (Small-large
room/plate/spring/etc...)
I'm normally playing small venues as either a duo or
a 4 piece band with crowds up to about 100 people and generally mixing the sound from the
stage.
Thanks,
Weedog
Re: How much and what reverb to add?
[Re: Weedog]
#939926 - 10/09/11 01:41 PM
Perhaps I will start here, but still would love to hear any personal preferences when
mixing live. http://www.soundonsound.com/sos/jul08/articles/reverb1.htm
TSH-Tim
Loc: Guildford
[Re: Weedog]
#939932 - 10/09/11 02:41 PM
Without being there any hearing what your hearing it very very hard to say....try a few
and if your still not getting what you want try something else
-------------------- PA Hire Surrey
Lighting Hire Surrey
shufflebeat
Loc: Manchester, UK
[Re: Weedog]
#939949 - 10/09/11 04:08 PM
Hi, Dog.
You'll probably end up with one or settings that you'll use all the
time if you're mixing yourself, a couple more if you get a regular sound engineer who
knows your set and features particular reverbs on specific songs.
In a small
band mixing from the stage like you're describing I'd be inclined to use a 'medium hall'
on main vocals, it's hard to describe how much but most folks (other than the singer) know
when it's too much.
If you're playing fast, detailed music like Irish trad long
reverbs on the general mix just muddy things up but a medium or small room can glue
elements of the sound nicely. It can be subtle and so difficult to judge from onstage and
behind the FOH. A longer 'Cathedral' style can put solo instrument playing a slow melody
into fantastic perspective.
Guitar based Indie/Blues tends to rely on the
guitarist to provide their own from the amp and vocals can often benefit from short
echo/delay which sets it apart from everything else.
Different units obviously
have different sounds and I'm not familiar with yours so I can only suggest general
principles.
Less is usually more.
-------------------- Ohm's Law states, "Your PA isn't as powerful as you think it is".
Dave Gate
active member
Loc: M6/M61/M60/M62/M65
[Re: Weedog]
#939950 - 10/09/11 04:13 PM
If we were still in the 1980s I would say loads, huge cathedral setting,on everything,
especially drums. Nowadays very little, short tail, mainly on vocals.
-------------------- Gear List: reverse only.
active member
Loc: Oxford, UK
[Re: Dave Gate]
#939954 - 10/09/11 04:38 PM
Quote Dave Gate:
Nowadays very
I agree, as a 'default' position. But it really is a case of
knowing what each of the controls does so that you can apply the appropriate effect to
enhance rather than muddy the sound. I practice with some simple solo sounds - eg. 'dry'
vocals, dry acoustic guitar etc - just to determine exactly how each control alters the
sound. Eventually, you'll do it like driving - without thinking.
... and if
anyone in the audience can say, "Ooo, reverb..." you're probably using too much. Of
course, some styles of music go hand-in-hand with a definite and pronounced reverb/echo
sound, but I don't think that's what you're asking...
active member
Loc: Sheffield, UK
[Re: Weedog]
#940036 - 11/09/11 07:53 AM
IMO... ignore the 'less and shorter reverbs nowadays' mantra. It's a self-fulfilling, self
imposed, artificial limitation.
Just do what the song, your ears and your
tastes tell you are right for the song.
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
Dave Rowles
Loc: Isle of Man
[Re: The Elf]
#940088 - 11/09/11 01:37 PM
Also, make sure to play around with the "pre-delay" setting, as this can help if you think
the reverb is muddying up the sound.
Reverb is personal taste and style. I go
for shorter (0.8-1.6s) room/plate verbs on drums, medium (1.2-2.2s) room/hall verbs on
rhythm/chord instruments, longer (1.6-3s) hall/plate on voices or tune instruments. But
then again, if you've got a slow ballad with long held notes you'll probably want a longer
verb, vs a stabby fast number where a shorter verb would be better. If you've got an 80s
rock band, you'll probably want to lengthen the drum verb. It's always got to suit the
style of the song. Also it depends on the verb unit as well, as some units are better at
different types than others.
Usually I'm a fan of "you should only notice the
verb when it's not there" sort of attitude, but it's so variable that you can't stick to
that rule. I'm also a fan of not going too far outside the venue. For instance, if I'm in
a small room I wouldn't go into long expansive verbs unless the style really suited that.
-------------------- www.exaviormusic.com
www.manninmusic.com Music Teacher, Isle of Man
Edited by Exavior Music (11/09/11 01:37 PM)
grab
Loc: Cambridge, UK
[Re: Weedog]
#940467 - 13/09/11 03:19 AM
My personal preference is plate rather than room/hall, especially on rock or
singer-songwriter (which is what I'm mostly doing). Since my ears and everyone else's are
used to that sound of reverb on recordings, I like something like that live. The exception
might be trad folk, I guess, for a more natural sound.
Still needs to be
appropriate for the venue though - too much or too long in a small room sounds artificial,
and as EM said, if you can hear the reverb distinct from the source then you've probably
got too much. (Unless you've particularly been asked for a reverb-heavy sound.)
Spring is typically for guitar amps. Never had much use for it on live sound.
DB111
member
[Re: Weedog]
#940478 - 13/09/11 07:58 AM
On reverb units, the mix controls that set the proportion of effected sound to dry should
really be marked not 1 to 10, or Zero to 100%, but more like, Needs more reverb, Needs more reverb, Needs more reverb, Needs more reverb, Needs more
reverb, Whoa! Way too Much, Whoa! Way too Much, Whoa! Way too Much, Whoa! Way too Much, Whoa! Way too Much, It is a matter of taste and style, and
there are distinctive types of reverb that are instantly associated with certain eras and
fashions in music. You just have to use your ears and cross compare with recorded
tracks that you are trying to emulate. Cheers Dave
Weedog
[Re: Weedog]
#940646 - 14/09/11 01:41 AM
Thanks everyone for their input.
I didn't get a lot of time to play with the
unit before a gig last Sunday, but I'll hopefully get another chance this weekend to have
more of a experiment with different types.
Thanks again,
