Main Forums >> Live Sound & Performance
        Print Thread
Pages: 1
Weedog
Loc: Melbourne, Australia
How much and what reverb to add?
      #939925 - 10/09/11 01:39 PM
Hi all,
I just got myself a TC-Electroinc M-ONE XL Reverb unit and I'm a little blown away by how many types of reverb can be set.
Can anybody please suggest what style of reverb they use/prefer and when each might be used? (Small-large room/plate/spring/etc...)
I'm normally playing small venues as either a duo or a 4 piece band with crowds up to about 100 people and generally mixing the sound from the stage.
Thanks,
Weedog
Re: How much and what reverb to add? new [Re: Weedog]
      #939926 - 10/09/11 01:41 PM
Perhaps I will start here, but still would love to hear any personal preferences when mixing live.
http://www.soundonsound.com/sos/jul08/articles/reverb1.htm
TSH-Tim
Loc: Guildford
      #939932 - 10/09/11 02:41 PM
Without being there any hearing what your hearing it very very hard to say....try a few and if your still not getting what you want try something else
PA Hire Surrey
Lighting Hire Surrey
shufflebeat
Loc: Manchester, UK
      #939949 - 10/09/11 04:08 PM
Hi, Dog.
You'll probably end up with one or settings that you'll use all the time if you're mixing yourself, a couple more if you get a regular sound engineer who knows your set and features particular reverbs on specific songs.
In a small band mixing from the stage like you're describing I'd be inclined to use a 'medium hall' on main vocals, it's hard to describe how much but most folks (other than the singer) know when it's too much.
If you're playing fast, detailed music like Irish trad long reverbs on the general mix just muddy things up but a medium or small room can glue elements of the sound nicely. It can be subtle and so difficult to judge from onstage and behind the FOH. A longer 'Cathedral' style can put solo instrument playing a slow melody into fantastic perspective.
Guitar based Indie/Blues tends to rely on the guitarist to provide their own from the amp and vocals can often benefit from short echo/delay which sets it apart from everything else.
Different units obviously have different sounds and I'm not familiar with yours so I can only suggest general principles.
Less is usually more.
Ohm's Law states, "Your PA isn't as powerful as you think it is".
Dave Gate
active member
Loc: M6/M61/M60/M62/M65
      #939950 - 10/09/11 04:13 PM
If we were still in the 1980s I would say loads, huge cathedral setting,on everything, especially drums. Nowadays very little, short tail, mainly on vocals.
Gear List: reverse only.
Mike Stranks
active member
Loc: Oxford, UK
Re: How much and what reverb to add? new [Re: Dave Gate]
      #939954 - 10/09/11 04:38 PM
Quote Dave Gate:
I agree, as a 'default' position. But it really is a case of knowing what each of the controls does so that you can apply the appropriate effect to enhance rather than muddy the sound. I practice with some simple solo sounds - eg. 'dry' vocals, dry acoustic guitar etc - just to determine exactly how each control alters the sound. Eventually, you'll do it like driving - without thinking.
... and if anyone in the audience can say, "Ooo, reverb..." you're probably using too much. Of course, some styles of music go hand-in-hand with a definite and pronounced reverb/echo sound, but I don't think that's what you're asking...
active member
Loc: Sheffield, UK
      #940036 - 11/09/11 07:53 AM
IMO... ignore the 'less and shorter reverbs nowadays' mantra. It's a self-fulfilling, self imposed, artificial limitation.
Just do what the song, your ears and your tastes tell you are right for the song.
Dave Rowles
Loc: Isle of Man
Re: How much and what reverb to add? new [Re: The Elf]
      #940088 - 11/09/11 01:37 PM
Also, make sure to play around with the "pre-delay" setting, as this can help if you think the reverb is muddying up the sound.
Reverb is personal taste and style. I go for shorter (0.8-1.6s) room/plate verbs on drums, medium (1.2-2.2s) room/hall verbs on rhythm/chord instruments, longer (1.6-3s) hall/plate on voices or tune instruments. But then again, if you've got a slow ballad with long held notes you'll probably want a longer verb, vs a stabby fast number where a shorter verb would be better. If you've got an 80s rock band, you'll probably want to lengthen the drum verb. It's always got to suit the style of the song. Also it depends on the verb unit as well, as some units are better at different types than others.
Usually I'm a fan of "you should only notice the verb when it's not there" sort of attitude, but it's so variable that you can't stick to that rule. I'm also a fan of not going too far outside the venue. For instance, if I'm in a small room I wouldn't go into long expansive verbs unless the style really suited that.
www.exaviormusic.com
www.manninmusic.com Music Teacher, Isle of Man
Edited by Exavior Music (11/09/11 01:37 PM)
grab
Loc: Cambridge, UK
      #940467 - 13/09/11 03:19 AM
My personal preference is plate rather than room/hall, especially on rock or singer-songwriter (which is what I'm mostly doing). Since my ears and everyone else's are used to that sound of reverb on recordings, I like something like that live. The exception might be trad folk, I guess, for a more natural sound.
Still needs to be appropriate for the venue though - too much or too long in a small room sounds artificial, and as EM said, if you can hear the reverb distinct from the source then you've probably got too much. (Unless you've particularly been asked for a reverb-heavy sound.)
Spring is typically for guitar amps. Never had much use for it on live sound.
DB111
member
      #940478 - 13/09/11 07:58 AM
On reverb units, the mix controls that set the proportion of effected sound to dry should really be marked not 1 to 10, or Zero to 100%, but more like,
Needs more reverb,
Needs more reverb,
Needs more reverb,
Needs more reverb,
Needs more reverb,
Whoa! Way too Much,
Whoa! Way too Much,
Whoa! Way too Much,
Whoa! Way too Much,
Whoa! Way too Much,
It is a matter of taste and style, and there are distinctive types of reverb that are instantly associated with certain eras and fashions in music.
You just have to use your ears and cross compare with recorded tracks that you are trying to emulate.
Cheers
Dave
Weedog
      #940646 - 14/09/11 01:41 AM
Thanks everyone for their input.
I didn't get a lot of time to play with the unit before a gig last Sunday, but I'll hopefully get another chance this weekend to have more of a experiment with different types.
Thanks again,
Pages: 1
Rate this thread
Jump to
Extra Information
0 registered and 10 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, Paul White, zenguitar, Martin Walker, Forum Admin, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts,
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
