Main Forums >> Guitar Technology
        Print Thread
Pages: 1
giles
new member
Loc: belgium
Pitch bend pedal
      #940135 - 11/09/11 08:46 PM
I need to be able to play quarter tones on a fretted guitar and would like to be able to do this with a foot pedal. The desired effect should be like a pitch bend wheel on a synth keyboard. does anyone have experience with this and could they recommend a pedal?
. . . Delete This
Here be Dragons
Re: Pitch bend pedal new [Re: giles]
      #940147 - 11/09/11 09:19 PM
maybe the digitech whammy pedal.
but it'll require some serious hand/foot coordination to do much at any speed....
uphillbothways
      #940164 - 11/09/11 10:58 PM
If you just need the odd quartertone for Middle-eastern music, the Whammy should just about cut it. If you're playing modernist or jazz music based on quartertone scales, it probably won't. The Roland VG99 is a more sophisticated option, as it can pitch-shift each string independently and can be controlled over MIDI. Not cheap, but it's an extremely powerful tool. The VG99 does guitar-to-MIDI, so you could use it to control Pure Data or Max/MSP if you're doing anything microtonal.
zenguitarModerator
active member
Loc: Devon
      #940165 - 11/09/11 11:07 PM
Quote giles:
Either the Whammy pedal as already suggested, and I agree that it won't be easy to co-ordinate. Or get the guitar fretted for 24 notes per octave. Any decent luthier can do it, the fret positions are easily calculated. And if you need precise measurements send me a PM with the scale length and I'll calculate them for you.
Andy
When the going gets weird, the Weird turn Pro.
giles
new member
Loc: belgium
      #940191 - 12/09/11 07:41 AM
thanks for your replies, I have to be away for a week so I will return to this thread then.
Mixedup
active member
Loc: Cambridge, UK
Re: Pitch bend pedal new [Re: zenguitar]
      #942510 - 22/09/11 09:24 AM
Quote zenguitar:
Either the Whammy pedal as already suggested...
or better still the Morpheus Bomber. But the same practical problems still apply.
You *could* use a MIDI foot controller and use computer software to do the pitch-shifting.
AllyB
active member
Re: Pitch bend pedal new [Re: Mixedup]
      #943575 - 27/09/11 11:22 AM
EHX hog
just set the throw on the pedal adjustment to the bend you want.
Producer etc
artifus
Re: Pitch bend pedal new [Re: AllyB]
      #944315 - 30/09/11 04:48 PM
lofi diy option: cheap delay pedal that allows wet (delay) only signal out with zero repeats/no feedback. hack stereo jack onto delay time pot. insert expression pedal. practice foot. profit.
ohm's where the art is
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 12 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
