Pitchfork
new member
Loc: London
Best Analog Filter in a Synth
#946273 - 10/10/11 02:34 PM
I was always looking for an analog style filter/sampler, and have looked at the Emax, and
dedicated filter boxes, but now thing that a Roland synth would be a good idea as it has
an Audio Input for running VST's through the filter, and its filter is analog with TVF and
TVA for that gating type sound..
Would the SH-09 be best for this? as I believe
the 101 never had a filter input at all..
I know it would be mono, but its
apparently a nice filter, and i think the Sh1 Sh2 also had this facility but they
obviously cost a little more.
Sam Inglis
SOS Features Editor
Re: Best Analog Filter in a Synth
[Re: Pitchfork]
#946279 - 10/10/11 03:03 PM
The filter on the SH101 robs the low end quite a lot when you turn the resonance up (at
least it does on mine), other than that it's good. I don't know how it compares to the
other SH-series synths.
hollowsun
Loc: Cowbridge, South Wales
[Re: Pitchfork]
#946280 - 10/10/11 03:22 PM
Moog filter Mooger Fooger pedal
-------------------- Website / Music Lab Machines / Blog
Pitchfork
new member
Loc: London
[Re: hollowsun]
#946281 - 10/10/11 03:33 PM
Thanks but does this moog have the TVF and TVA on it?
The emax has this and the
SH09 and also in the Morgana vst by 112db
I'm sure this gives the filter it's
gating sound of the filter opening and closing to produce that effect?
ken long
Loc: The Orient, East London
[Re: Pitchfork]
#946282 - 10/10/11 03:40 PM
4-Pole with Manual or Input trigger. Love
mine.
-------------------- I'm All Ears.
nathanscribe
Loc: Yorkshire, by gum.
[Re: Pitchfork]
#946303 - 10/10/11 05:19 PM
Quote Pitchfork:
Thanks but does
As far as I know, TVF ("Time variant filter") and TVA ("Time variant amplifier")
refer to Roland's mid/late 80s way of doing this digitally in the S & W series samplers -
never seen it anywhere else. Typically old analogue kit uses the terms VCF and VCA for
Voltage Controlled Filter/Amplifier.
However, if by those you mean filters and
amplifiers with envelope shaping of the filter cutoff, the answer is it's pretty common,
on old monosynths at least.
Basically, if you buy an old mono with an input,
you have a couple of different scenarios: either the input just goes to the mixer, or it
goes through the filter. If it goes through the filter, you may be able to use the
signal's overall level to control the cutoff of the filter - or not, depending on the
synth you're using the filter of. THe SH-09, for example, does have an envelope follower,
which means the volume of the input will sweep the filter up and down as it gets louder
and quieter.
Standalone filters also may or may not have this feature.
As for the amplifier, typically the filter will be gated on by the keys of the synth, or
external gate input, not the sound you're running into the filter. Again that depends on
what gear you're using.
The Moogerfooger has an envelope follower. It's
controlled with the knob marked "envelope" on the front panel.
Pitchfork
new member
Loc: London
[Re: nathanscribe]
#946305 - 10/10/11 05:29 PM
Quote nathanscribe:
Quote Pitchfork:
Thanks but
variant amplifier") refer to Roland's mid/late 80s way of doing this digitally in the S &
W series samplers - never seen it anywhere else. Typically old analogue kit uses the
terms VCF and VCA for Voltage Controlled Filter/Amplifier.
Your right, I was getting it wrong! it is
VCF and VCA that gives this almost gating type sound with just the filter running which I
like...
The models I mentioned, have this (I think the SH09 too), so can most
filters do this?
Bob Moose
[Re: Pitchfork]
#946343 - 10/10/11 09:32 PM
As an alternative, you can build it as a very small analogue modular synth (it may cost
less than some pre-patched synths and you can choose all the components, in particular you
have many filter options). Module choice obviously depends on what you want to do
with it exactly. For example you can build an envelope filter (like the famous Mu-tron
filter) with 3 modules: audio input, envelope follower, filter
Best -j
Pitchfork
new member
Loc: London
[Re: Bob Moose]
#946344 - 10/10/11 09:43 PM
Quote Bob Moose:
As an
alternative, you can build it as a very small analogue modular synth (it may cost less
than some pre-patched synths and you can choose all the components, in particular you have
many filter options). Module choice obviously depends on what you want to do with it
exactly. For example you can build an envelope filter (like the famous Mu-tron filter)
Best -j
Bob, I wish I could, then I could have
maybe a 12-bit sound, some grunge and pick the filter - but as I have trouble wiring a
plug, I think this is way out of my league unfortunately!
ken long
[Re: Bob Moose]
#946349 - 10/10/11 10:02 PM
Quote Bob Moose:
For example you
Pitchfork
new member
Loc: London
[Re: ken long]
#946352 - 10/10/11 10:10 PM
I wish I could build this! especially as these are now upwards of £1000 s/h!?
Zukan
Zukan
[Re: Pitchfork]
#946412 - 11/10/11 09:14 AM
You can't go wrong with the Moog and Waldorf filters. They are real fun and pretty
potent. I have had Mutators in the past and they are fun too. Sherman is what
you want if you're into both extreme and sound design. Failing that, any of the
old synths with audio ins will be useful. Alternatively, and if you have a modular system,
then a dedicated filter module would be cool. There are many in this dept that would fit
the bill. Filters on synths can have a great impact on sound so long as you
ignore the rubbish names that manufacturers like to give them. The original
Emax had lovely warm filters, Ensoniq EPS had that throaty snappy filter, Roland always
went for smooth with variable slopes, anything Russian would make your eyes bleed
(Polyvoks)and so on. However, the older gear had some great filters. The SH09 was nice but
not an earth mover although the SH3a was a different kettle of fish and highly underrated
and cost little more than the 09 in sec hand. The, wait for this, Peavey (if you can find
one) filter bank had a lovely smooth slope and was gorgeous on pads and the like. MS20
sounds nice but you would need to buy the whole beast to use it, same as the ASR10.... I could go on all day as I'm a synth slut, but apparently I have to work. Wife
says it would be nice to eat meat this month.
-------------------- Samplecraze
Stretch That Note
ken long
[Re: Zukan]
#946423 - 11/10/11 09:46 AM
Quote Zukan:
MS20 sounds nice but
You can get a DP4 which will give you the
ASR filter (amongst many other goodies and *that* phaser)
Pitchfork
new member
Loc: London
[Re: Zukan]
#946434 - 11/10/11 10:14 AM
Thanks for this, I'd be looking for filtering and mangling long pads for ambient stuff,
rather like Irresistible Force does on his albums, "Flying High" and "Global Chillage"
I think both of these were done with an Emax and its filter, so it sounds nice
and warm, but in todays market, it would be great to put an Emax style analog filter on
the end of say Ableton with its own FX, using the VCF and VCA on a filter (I have ahd 2
Emax SE's by the way and although nice, are fiddly and limited by today's standards)
I have thought of the Sherman, but instead of warm, every single demo shows how
distorted and nasty it sounds, which is the opposite of what I want.. The SH-09 sounds ok,
but I bet there is better out there..
I'd love to do some hands on knob
twiddling while the sound is playing so not so bothered about MIDI and automation.
The Morgana by 112db VSTi has some controls and similar analog sound, which I
like, but its not that flexible, and crashes somewhat. So something analog and hardware
would be nice. Its just trying to track down online demo's or youtube videos to hear all
these
Edited by Pitchfork (11/10/11 10:15 AM)
Watcher Of The Skies
Loc: Cornwall, UK
[Re: Pitchfork]
#946458 - 11/10/11 11:07 AM
You could also investigate stomp box territory - Electro Harmonix have a wide range of
envelope filters and a good reputation to go with them: www.ehx.com/browse/envelope-filtersMartin
-------------------- YewTreeMagic
Loc: Cornwall, UK
[Re: Pitchfork]
#946464 - 11/10/11 11:21 AM
However, if you want to get into gated, filtered audio signals you’ll need to be able to
link the unit to a sequencer - perhaps Doepfer’s Dark Energy would fit the bill, as
it’s got an audio input and squelchy filters?
Paul Nagle certainly approved
of its filters in his SOS review:
“The 24dB/octave filter should certainly
test the ears of those who adamantly declare that only discrete circuits can sound sweet.
With its pleasing, even response and a resonance that wails like a tripping ocelot, the
filter should serve as a potent reminder that real analogue isn’t pushing up the daisies
just yet.”
www.soundonsound.com/sos/jan10/articles/doepferdarkenergy.htm
Thomann currently have it at just £326 inc VAT
Richie Royale
Loc: Bristol, England.
[Re: Pitchfork]
#946473 - 11/10/11 11:40 AM
I had some fun running a D10 through a Monotron, but it only has the LFO to control the
cut off, so not exactly what you want. The Novation Basstation Rack also has an
input, but not sure if it is controlled by the envelopes. The filter is pretty dirty to my
recollection.
-------------------- http://soundcloud.com/richie-royale
http://www.mixcrate.com/richieroyale
Pitchfork
new member
Loc: London
[Re: Richie Royale]
#946502 - 11/10/11 01:06 PM
I will have to check some of these out, and have only just discovered the VCF and VCA in
the Morgana VST sampler, which is nice (and which I remember from the E-Max) that it sort
of bubbles and gates/dips the sound as you wiggle the knobs (not sure on the exact science
of these envelopes) but its an interesting sound.. Hopefully as mentioned,
these would be included as knobs/sliders on older analog filters/keyboards to run sounds
through? I'm basically looking for a warm analog Emax Filter to run sounds
through without having the keyboard or rack!
johnny h
[Re: Martin Walker]
#946623 - 12/10/11 01:10 AM
Quote Martin Walker:
However, if
you want to get into gated, filtered audio signals you’ll need to be able to link the
unit to a sequencer - perhaps Doepfer’s Dark Energy would fit the bill, as it’s got an
Paul Nagle certainly approved of its filters
in his SOS review:
“The 24dB/octave filter should certainly test the ears of
those who adamantly declare that only discrete circuits can sound sweet. With its
pleasing, even response and a resonance that wails like a tripping ocelot, the filter
should serve as a potent reminder that real analogue isn’t pushing up the daisies just
yet.”
I would advise caution with the dark
energy. Very well constructed synth, especially for the price, but it doesn't actually
sound very good imo...
Pitchfork
new member
Loc: London
[Re: johnny h]
#946629 - 12/10/11 06:10 AM
Quote johnny h:
However,
if you want to get into gated, filtered audio signals you’ll need to be able to link the
in his SOS review:
yet.”
I'd heard exactly the same that
it wasn't that good I'm afraid so it maybe something I'll give a miss I would advise
caution with the dark energy. Very well constructed synth, especially for the price, but
it doesn't actually sound very good imo...
Paul Nagle
member
Loc: Lancs
[Re: Pitchfork]
#946638 - 12/10/11 08:00 AM
I'd suggest the "little modular" route also - you can put several filters in one of those
mini boxes and add envelope followers, LFOs etc. to taste. Some great choices of filter in
Eurorack format. One of my personal favourite "process anything" filters is
the Xone VF-1. Pretty sure I saw one of these in the SOS ads for around £150 and was very
tempted to buy a second one. It's stereo too and very smooth, with valve overdrive too.
-------------------- http://www.bogusfocus.com/
Pitchfork
new member
Loc: London
[Re: Paul Nagle]
#946639 - 12/10/11 08:02 AM
Quote Paul Nagle:
I'd suggest the
"little modular" route also - you can put several filters in one of those mini boxes and
add envelope followers, LFOs etc. to taste. Some great choices of filter in Eurorack
format.
One of my personal favourite "process anything" filters is the Xone
VF-1. Pretty sure I saw one of these in the SOS ads for around £150 and was very tempted
That sounds nice, and it does the VCF
and VCA filtering? does this sound smooth and thick/analog instead of distortion which
alot of the boxes seem to do these days!
Paul Nagle
member
Loc: Lancs
[Re: Pitchfork]
#946654 - 12/10/11 09:46 AM
It's definitely smooth and fab-sounding without adding massive amounts of colour. Some
might see that as a disadvantage I guess but I find it perfect for much of my external
processing of loops etc. from Logic. If you want 24dB you have to switch to mono but for
most general purpose filtering 24dB is often too much. Similarly it has MIDI control (I
confess I never use this) and I'm pretty sure you can get gating via MIDI or at least some
kind of on/off action. I really should read my own review.  The
overdrive is very nice and you can have a little or a lot - you don't have to use it at
all. A much underrated piece of kit I'd say, I'd have not known anything about
it if one didn't arrive for review but I'm jolly glad it did.
Chevytraveller
member
Loc: London
[Re: Zukan]
#946669 - 12/10/11 10:31 AM
Quote Zukan:
MS20
sounds nice but you would need to buy the whole beast to use it....
You can always buy eurorack modules in
a small case. You can get the MS20 filter here
Still love the SEM style filter on my Telemark..
LP/BP/HP and patchable inputs
-------------------- MBP 17", PC 100(Nubus Protools) Motu 896, X-Station, Logic9, Reason6, Korg legacy, ACE, Alchemy, Emax II, E-Synth, Evolver MEK, Waldorf Pulse and Blofeld, AS Telemark, AS Leipzig-S
Loc: Cornwall, UK
[Re: Pitchfork]
#946681 - 12/10/11 11:09 AM
Ah, the Nagle has landed  Do you want to stand by your positive words about the Dark Energy filters in your SOS
review, or have you changed your mind?  Martin
Paul Nagle
member
Loc: Lancs
[Re: Martin Walker]
#946825 - 12/10/11 10:20 PM
I do like the sound of the Dark Energy filter and got some great squelchy acid sounds from
it. But if I had to choose a little synth with a great filter it'd be the Vermona Mono
Lancet. It has an awesome Moogy sound and its filter happens to fit my taste better. The
downside is that you need the modular expansion to access it, never tried that myself
alas. A +1 to the Analogue Solutions MS20 filter. Totally excellent. I had the rack
version briefly but for some reason it never sounded as good - Filtered Coffee was it
called? Sorry, rambling now...
Bob Moose
[Re: Pitchfork]
#946833 - 12/10/11 11:01 PM
Quote Pitchfork:
Bob, I wish I
could, then I could have maybe a 12-bit sound, some grunge and pick the filter - but as I
have trouble wiring a plug, I think this is way out of my league unfortunately!
Oops, sorry I was actually talking
about ready-to-use modules, like Eurorack modules. You do not have to wire anything, only
to plug patch cables between modules.
The stombox solution is great too. Look
for envelope filters, some of them are really good. Most of the time they have a limited
frequency sweep range, but it may be ok for your applications. For example check the EHX
Q-tron series, the Lovetone Meatball, the Barge Grinder, the 3Leaf GR2, the Mu-tron 3
filter (second hand of course) and the Maxon AF-9.
The differences between stomboxes
are: available filter modes (LPF, BPF, HPF, etc); optical filter or not; filter slope
(usually 12dB/oct on pedals); frequency sweep range(s); envelope direction switch;
presence of attack, decay and resonance controls. Some models have a side-chain input that
can often be useful.
-j
TrickyDicky
[Re: Bob Moose]
#946951 - 13/10/11 12:45 PM
Its a shame there isnt a hardware stand-alone box for the Emax filters as they are very
popular and analog with that warm creamy sound, without getting the full keyboard
I think they are SSM? but am not sure where you would get those analog filters today in
a filter box?
~Paul
Loc: South Herts/North London
[Re: TrickyDicky]
#947070 - 13/10/11 10:52 PM
I quite like the sound of the Dark Energy. Both as a synth and it's filter alone. But I
guess we all have our own preferences. Quote TrickyDicky:
am not sure where you would get those analog filters today in a filter box?
You could well be right. I think there
are a few variations of the SSM based filter though. But fortunately parts for some of
them at least are not impossible to get. I've built a few Shruthi-1 monosynths, and these
can be configured with various different analogue filter boards. And I chose to make one
with the SSM2044. http://mutable-instruments.net/shruthi1 The same company also
came up with the Sidekick, which can take the same filter boards as the Shruthi synth.
This is basically a filter box with added shenanigans for extra sonic tomfoolery. I've not
built one of these yet though.. http://mutable-instruments.net/sidekick
But yes, it's
another DIY job im afraid. Although you do occasionally find prebuilt ones on the site for
sale.
-------------------- Paul
Pitchfork
new member
Loc: London
[Re: ~Paul]
#947178 - 14/10/11 04:20 PM
Thats interesting..
So how much are these 'kits' and how much would it cost
to get one built?
I think this is the SSM Filter that the Emax has :
SSM2044
http://mutable-instruments.net/shruthi1/build/ssm2044
Is
this what you are saying is in the two build kits that you linked to? The "Sidekick" seems
to be the slightly better and more intriguing of the two..
If this was an
exact analog SSM chip then it would literally be the "filterbox" part module from the
Emax!! - I take it these have analog ins and outs to process signals? (or maybe mono?)
~Paul
[Re: Pitchfork]
#947309 - 15/10/11 02:05 PM
Hi Pitchfork. Yes there are 2 different products, but both can use the same analogue
filter boards. The Shruthi-1 is a hybrid (digital & analogue) mono synth. Where as the
Sidekick is not really a synth, and more of a filter box, but with LFO's that can go into
the audio spectrum, so I think it can be useful as a standalone 100% analogue drone box
too.
Both Sidekick & Shruthi have analogue inputs, so you can filter
anything you like. But the sidekick has no midi control, unlike the Shruthi, which has
full midi control of everything, including it's filter.
And yes, it's a real
SSM in there  In fact there are 2 SSM's in there, but the other is a more commonly available
part used for VCA duties.
The hard part is getting one! Neither Sidekick or
Shruthi-1 with SSM are available as kits. You buy the PCB's then source the rest
yourself, which will involve 3 or 4 different suppliers.
I've not built a Sidekick
yet. But the Shruthi-1 with SSM that I built probably ran me around £200'ish. Secondhand
ones occasionally crop up, but will usually go for a little more. And new ones built by
Mutable Instruments are more, maybe £280+, I don't recall now. but they don't appear on
there very often.
I've built 3 Shruthi's (actually 5, but I sold 2). One with
the standard SMR-4 filter, which actually sounds really good. Another with the Roland
IR-3109 based filter, which has a very nice recognisable character (and is perhaps my
favourite of the 3). And of course the SSM. Which is nice and characterful, but not my
favourite.
Incidentally, both Shruthi and Sidekick are mono.
Hope that helps!
vinyl_junkie
active member
Loc: Kent, UK
[Re: Pitchfork]
#947355 - 15/10/11 10:56 PM
Just get a mini modular case or something, a bunch of different filter modules, some
evn's, LFO, env followers (if you are that way inclined) and a MIDI/CV gate converter to
trigger the env's and off you go.
They look pretty snazzy
No one mentioned the Akai MFC-42... sounds alright that
does.
I hated the Dark Energy... Horrid sounding one osc that always seemed
to be over driving, over powering something, really not to my taste.. too much emphasis on
"Moog" and analogue "phat" done badly.
Filter was probs the only good bit on it
and...meh
Edited by vinyl_junkie (15/10/11 11:05 PM)
johnny h
[Re: vinyl_junkie]
#947403 - 16/10/11 01:15 PM
Quote vinyl_junkie:
I hated
the Dark Energy... Horrid sounding one osc that always seemed to be over driving, over
powering something, really not to my taste.. too much emphasis on "Moog" and analogue
"phat" done badly. Filter was probs the only good bit on it and...meh
I agree totally. I actually
think the Moog filters are way overrated. They are nice and smooth, very American
sounding, but they don't have the snap and bite of say, the MS20 or the old Rolands.
You can use the Monotron as an external filter, and it is a great sounding one.
It is pretty noisy though, and you can't control it externally without modding. Hopefully
Korg will bring out some new MS20 inspired analogue goodness soon with full midi
control...
vinyl_junkie
active member
Loc: Kent, UK
[Re: Pitchfork]
#947407 - 16/10/11 01:54 PM
When my friend moved house earlier this year I had pretty much all his gear until he got
settled which meant I had a chance to familiarize my self with some things a lot better
being in my own environment and what have you.
One of the things I did have a
play on was his Doefper A-100 modular system, can't remember the module names but there
was a high end Doepfer dual vco which sounded quite Moogy (I actually think it used the
same CEM VCO chip as the 101! albeit it sounded way different) and a Analogue Solutions
dual VCO module which sounded more Rolandy' when comparing both OSC's to his SH-101...
Also fitted was a SSM filter and a Doepfer MS-20 inspired one. Last but not least I had
two Dark Energy's as we both had one (Now both sold)
The MS-20 filter sounded
amazing if you like that sort of thing, it could self oscillate and resonate till the seas
boil lol
Loved making strange sounds with it... One night I had to take my
headphones off thinking is that sound coming from outside or something hahah
Bob Moose
[Re: Pitchfork]
#947409 - 16/10/11 02:06 PM
Quote johnny h:
Quote vinyl_junkie:
I
hated the Dark Energy... Horrid sounding one osc that always seemed to be over driving,
over powering something, really not to my taste.. too much emphasis on "Moog" and analogue
"phat" done badly.
You may like the Moog sound or
not, but the Dark Energy does not have a Moog filter and sounds very different in my
opinion.
Also, talking about the Moog filters, they all sound quite
different. For example, check the Moog 904A (http://www.moogarchives.com/m904a.htm), the
Minimoog filter and the Moogerfooger MF101.
I think there is no universal
filter. For example, you may not use the same filter for processing instruments (bass,
guitar, piano, etc) and for "bass" sound synthesis. Processing instruments usually
requires an optical filter, but on these filters the cutoff cannot change as fast as on
non-optical ones.
Finally, the same filter can react very differently
depending on which envelope (or envelope follower) you are using for controlling the
cutoff.
Best
-j
vinyl_junkie
active member
Loc: Kent, UK
[Re: Bob Moose]
#947410 - 16/10/11 02:10 PM
Quote Bob Moose:
Finally,
the same filter can react very differently depending on which envelope (or envelope
follower) you are using for controlling the cutoff.
Best -j
Absolutely, one of the things I love
about the SH-101 is how quick and nice the envelope sounds esp when you modulate the
filter with it... I may get a similar sound on another synth but as soon as you apply that
env mod and keyboard tracking on the 101 it gets very hard to nail that sound on another
synth. Also the JX-3P uses the same filter chip as the Juno-60 albeit way different
sounding beasts
Mr Arkadin
member
[Re: Pitchfork]
#948409 - 21/10/11 01:46 PM
Love my SH-09 filter, but maybe this is the way to go...
nathanscribe
[Re: Pitchfork]
#948448 - 21/10/11 05:21 PM
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaargh! Now I DO need to buy a lunchbox. 1073 pre
& EQ, Moog ladder, and an SSL bus compressor. Noooooooooooooooooooooooooooooo.
Loc: Cornwall, UK
[Re: nathanscribe]
#948894 - 24/10/11 11:20 AM
Don’t get caught out trying to mix and match lunchbox modules with those from the
various modular synth manufacturers, however compatible they appear to look
dimensionally. Even if the PSU voltages are the same they all tend to have
different audio/control voltage specs, PSU connectors and so on. However, synth filter
modules do tend to be priced rather cheaper than Lunchbox modules  That Moog module is rare for being a synth filter in Lunchbox format  Martin
Zukan
Zukan
[Re: Pitchfork]
#949678 - 27/10/11 08:01 AM
dubbmann
active member
Loc: 3rd stone from the sun.
[Re: Zukan]
#950148 - 29/10/11 03:40 PM
Quote Zukan:
I could go on all
day as I'm a synth slut, but apparently I have to work. Wife says it would be nice to eat
meat this month.
zuk,
tell that lazy cow to strap on her high heel sneakes and tight skirt and get out
there! what's more important - her virtue or your gear? question answers itself, i mean,
don' it? ;-)
anyway, on a serious note, two more options: electrix filter
factory - i've got one and it's smashing on drums, etc. has MIDI syncable clocks, very
nice design (sort of wedge-shaped) so it can fit in a 19" rack or on a desktop. very
ruggedly built, too.
second choice: get a doepfer 404. their version of
tb303/sh101 in a 1U rack mount with mono input that can be routed to the filter.
basically a couple o/t doepfer modules fitted into a 19" case w/ MIDI. i own thtis as
well, and it is quite tasty, w/ an almost zen simplicity.
cheers,
d
-------------------- "Patsy had the drug tolerance of Keith Richards and the moral rectitude of Brian Jones." - Dr. Walter Bishop, "Fringe"
