Main Forums >> PC Music
        Print Thread
Pages: 1
StoneTape
Master Sequencing Software
      #946290 - 10/10/11 04:37 PM
Hi... i was just wondering what Mastering/Sequencing software everyones using at the moment
what i want is a software to sequence an album... make gapless transitions and such.
whats the industry standard???
any tutorials out there???
thansk
Martin WalkerModerator
Watcher Of The Skies
Loc: Cornwall, UK
Re: Master Sequencing Software new [Re: StoneTape]
      #946451 - 11/10/11 10:55 AM
Hi StoneTape!
I don’t think there is an industry standard DAW any more. Pro Tools is still extremely popular in commercial studios, as is Logic, but Cubase is huge in Europe, Sonar is huge in the US, and Samplitude, Reaper, Ableton and the rest all have loads of enthusiastic followers.
If you want to use the same software as someone else so you can collaborate, or the same as a local studio so you can take your own projects in there more easily then fine - buy that.
On the other hand if you want to buy some software for your own music making the best thing is to download some demos and try it out
Hope this helps!
YewTreeMagic
Dynamic Mike
      #946471 - 11/10/11 11:33 AM
If you mean sequencing as in re-ordering tracks, perhaps Wavelab?
Not much in life worth running for. Or from.
James PerrettModerator
Loc: The wilds of Hampshire
      #946484 - 11/10/11 11:56 AM
I answered the same question in another section...
Please don't post the same question to multiple sections of the forum.
James.
JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
StoneTape
Re: Master Sequencing Software new [Re: James Perrett]
      #946494 - 11/10/11 12:21 PM
how would i go about making gapless track to track transitions on a CD??? or wherever for that matter
will i be able to define the end of Track 1 so that it merges with the start of Track 2?
this might be a dumb question but ive really never heard anyone explain how to properly sequence a CD...
Hugh RobjohnsAdministrator
SOS Technical Editor
Loc: Worcestershire
      #946531 - 11/10/11 03:18 PM
Quote StoneTape:
Despite manufacturer's claims, there is no such thing as an 'industry standard'. However, some products are optimised and far better suited to some applications than others. Amongst the most popular DAW for mastering purposes is undoubtedly SADiE. This system has superb editing facilities and a very easy and stunningly powerful PQ editor to create CD masters.
SADiE used to require specific hardware, which made it very expensive. It is now available as a native product, in four versions optimised for different purposes, and is no quite so expensive!
http://www.sadie.com/applications/mastering.php
That link tells you about the SADiE 6 mastering software, as well as providing a useful overview of the process and the facilities they provide to create 'red book' CD masters.
Hugh
      #946539 - 11/10/11 04:00 PM
I don't have time to write a full tutorial but there are various types of markers embedded into the data stream of a CD. The audio is one long continuous stream so I usually create one audio file for the whole CD and use software that inserts the various markers needed. Obviously there are track markers (up to 99), but less obviously, there are also index markers within tracks (also up to 99). While very few CD players allow you to skip to an index marker, they all recognise index 0 and index 1. Index 0 is actually taken as the end of the previous track while index 1 is taken as the start of the current track. If you are creating a live CD you might want to put an index 0 just as the applause of the previous track dies away and an index 1 when the next song starts. Any between song chatter will then lie between index 0 and index 1 so it won't be heard by anyone who only wants to hear the previous track or anyone who goes direct to the track - only by people who play the CD straight through.
Track and index markers should be placed on CD frame boundaries - there are 75 frames per second and software designed for the job will allow you to count in frames. You normally should place the markers 5-10 frames early to allow the CD player to unmute. If you have a quiet start to a track it sometimes feels better to place the marker even earlier.
Hope this makes sense,
James.
StoneTape
      #946596 - 11/10/11 09:24 PM
hmmmmm... sort off hard to make sense of it all... what software do i use to insert those markers on the cd???
cant be the only who doesnt get this
      #946706 - 12/10/11 12:42 PM
Most of the software already mentioned in this thread will allow you to place markers and burn a CD with those markers on it.
I prefer to create a single master file and then create a .cue sheet file to go with that file which can be read by lots of different CD burning programs. You can find more info about cue files here.
If you want a quick way to create a basic .cue sheet or to separate a single .wav file into tracks which will play seamlessly when burned on a CD then look at a program called CD Wave.
James.
StoneTape
      #946783 - 12/10/11 05:20 PM
thanks!
pitty there isnt a tutorial out there
guess ill have to dive full on into it
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 21 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Forum Admin, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts,
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
