Main Forums >> Live Sound & Performance
        Print Thread
Pages: 1
chronemics
Behringer PMP960M setup help
      #957182 - 05/12/11 02:46 AM
I'm a total PA noob, but I recently bought this powered mixer for use with my band, and desperately need some help with it. I am attempting to use two Peavey PV115 400 watt 8 ohm speakers with it, and it's not working as planned.
The mixer has two speakon outputs (A+B), with which I have speakon cables plugged into going to the 1/4" inputs on each speaker. Currently I can only get sound outputted from Output A. I've swapped out the cables and speakers, just to make sure the issue is with the mixer. I've also been reading through the PMP960M manual for some answers, but can't seem to find out why no sound is coming from output B.
The Peavey speakers do work daisy-chained into output A, but I'm not sure if this is the best way to run them? it seems like that's just splitting the signal from one output, and not getting the Behringer's full power...
I really hope this is something simple that I am missing, and appreciate any help that you guys can give.
Thanks in advance.
active member
Loc: Oxford, UK
Re: Behringer PMP960M setup help new [Re: chronemics]
      #957218 - 05/12/11 10:12 AM
Two thoughts:
1) Have you checked that the 'Power Amp' switch is in the right position and that one side of the amp isn't being used as a monitor send?
2) Are you sure that your Speakon Adapter Leads are wired correctly? You should be using the +1 and -1 connectors on the speakon plug.
TDC
chronemics
Re: Behringer PMP960M setup help new [Re: Mike Stranks]
      #957295 - 05/12/11 02:26 PM
Thanks for the response.
"1) Have you checked that the 'Power Amp' switch is in the right position and that one side of the amp isn't being used as a monitor send?"
I believe I have it in the correct position, but I've tried it either way and am still unable to get sound out of Output B.
"2) Are you sure that your Speakon Adapter Leads are wired correctly? You should be using the +1 and -1 connectors on the speakon plug."
This was something I came across in the manual that I did not understand.. I'm new to Speakon cables. How do I find this out? Should I have been looking for this when I originally purchased the Speakon cables?
active member
Loc: Oxford, UK
      #957402 - 05/12/11 11:02 PM
Quote chronemics:
Do you recall where you bought the leads - or beter still can you refer to a make/model. You need cables that are specified as "2-Pole Speakon to Mono Jack".
TDC
chronemics
      #957606 - 06/12/11 11:03 PM
I'm not at the location that the cables are, so bear with me, my bandmate found "NL2FC" on the cable's packaging, which Google tells me means it's a 2-pole cable?...
active member
Loc: Oxford, UK
      #957658 - 07/12/11 10:12 AM
Quote chronemics:
Yes; that's a Neutrik two-pole. So looks like your mixer/amp may be sick. Has it ever worked OK with output from both speaker outputs?
chronemics
      #957714 - 07/12/11 03:03 PM
No, I just bought it used(perfect condition) a week ago, and the second output has never worked...
active member
Loc: Oxford, UK
      #957777 - 07/12/11 10:22 PM
In that case you probably need a conversation with the seller along the lines of 'show me it working'. If he can't then it's money-back time.
Unfortunately a lot of Behringer gear is not noted for its longevity or robustness.
TDC
chronemics
      #958214 - 09/12/11 07:46 PM
Thanks for your help. I returned it to the store I bought it from yesterday. This is my second bad experience with Behringer products, I will be steering clear of them from now on.
seablade
      #958221 - 09/12/11 08:50 PM
Quote chronemics:
You learned the hard way sorry. But that is why most of us do the same.
Seablade
Pages: 1
Rate this thread
Jump to
Extra Information
1 registered and 47 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, Paul White, zenguitar, Martin Walker, Forum Admin, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts,
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Home | Search | News | Current Issue | Digital Editions | Articles | Forum | Subscribe | Shop | Readers Ads
Advertise | Information | Links | Privacy Policy | Support
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
