Main Forums >> Guitar Technology
        Print Thread
Pages: 1
4TrackMadman
active member
Floyd rose issues
      #970208 - 15/02/12 09:49 AM
Hello,
I am the (somewhat proud) owner of one of the new 7 string Jackson Soloists.
Ever since I got the guitar I have an issues with the tremolo bar getting loose even after tightening it up, and floating back and forth after pretty much the first pull.
Here is a pic of the guitar (bit big but should help you get the idea):
Any ideas/suggestions on things top try are welcome.
Thanks!
www.descentintomadness.com
4TrackMadman
active member
Re: Floyd rose issues new [Re: 4TrackMadman]
      #971189 - 20/02/12 03:53 PM
Here is another closeup on this type of Floyd Rose, basically trem arm wouldn't stay tightened to the base, it would loosen up after short use and swing freely.
JM-1
      #971221 - 20/02/12 06:34 PM
To my knowledge this is a known problem with the floyd rose tremolos in which the tremolo arm has a little knurled nut at the base. It's a real pain and works itself loose very easily after which the arm swings about. More irritatingly for me, there's a certain 'play' in it even when using the arm to raise and lower string pitch.
The Ibanez tremolos with their plastic 'c'-shaped / horse-shoe washers are much nicer. They stay where you put them and have very little such 'play'.
4TrackMadman
active member
Re: Floyd rose issues new [Re: JM-1]
      #971270 - 20/02/12 10:20 PM
Jay, I am aware that the Ibanez one is better as my other guitar with FR is an Ibanez
Jonny DiBergi
      #974307 - 05/03/12 11:28 PM
Plumber's tape. Aka Teflon Tape. Put some around the 'inserted' bit of the arm and it should give you a nice snug fit. Replace when necessary!
4TrackMadman
active member
      #974476 - 06/03/12 08:52 PM
I have a string of that, will give it a try!
Pages: 1
Rate this thread
Jump to
Extra Information
5 registered and 39 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating: *****
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
