Main Forums >> Product & Industry News
        Print Thread
Pages: 1 | 2 | 3 | (show all)
Hugh RobjohnsAdministrator
SOS Technical Editor
Loc: Worcestershire
Re: NEW! Pseudo-Balanced Cables new [Re: mjfe2]
      #985714 - 04/05/12 11:18 AM
Quote mjfe2:
But will I still benefit from the pseudo-balanced technology?!
It is still an unbalanced output from the mixer's insert point, and so there is still a very real risk of ground loop problems.
Assuming this unbalanced insert send is going to be routed to a balanced line input, then the pseudo-balanced cable idea will prevent any possibility of a ground loop problem because there won't be a direct low-impedance DC path between the mixer and recorder grounds -- the resistor/capacitor in the screen connection will see to that. The balanced line input sees the send signal on its hot input, and the mixer ground on it's cold input, providing the signal voltage difference required to extract the wanted audio.
Hugh
Rate this thread
Jump to
Extra Information
2 registered and 8 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
