Mud on the road
member
Checking Akai S950 ram
#977545 - 22/03/12 05:50 PM
Hi forum, half of the ram in my fully expanded Akai S950 is no longer
work. I have been moving the unit around a bit so I am hoping its just come unseated or
the contacts need cleaning. As I did not install the added ram myself I have no idea which
screws etc,to undo, and where the ram is located. I have been searching the internet for a
PDF or info on how to install ram in this unit but could find nothing. As the S950 is a
later version of the S900,any info about doing this should be the same as for both units.
Can anybody help.
Regards
Peter
Richie Royale
Loc: Bristol, England.
Re: Checking Akai S950 ram
[Re: Mud on the road]
#977585 - 22/03/12 09:18 PM
ken long
Loc: The Orient, East London
#977588 - 22/03/12 09:40 PM
On start up, the 900 will display available memory. However, this will be in kilo
words.
So, for example, on start up, my 950 displays 1536KW.
hth
-------------------- I'm All Ears.
Mud on the road
member
[Re: ken long]
#977609 - 22/03/12 11:31 PM
Thanks for the info and pictures. I bought the unit new from a shop and they
installed the extra ram. Therefore I do not know the best way to get in the unit to check
the ram. Any suggestions.
Peter
Richie Royale
#977652 - 23/03/12 08:32 AM
It will be simple to open up. Just unscrew the screws around the case and lift of the grey
top cover. As Ken has pointed out, what Kwords are available? 1536Kwords =
2.25MB 1024Kwords = 1.5MB 512Kwords = 0.72MB
-------------------- http://soundcloud.com/richie-royale
http://www.mixcrate.com/richieroyale
ken long
#977673 - 23/03/12 10:02 AM
Quote Mud on the road:
Thanks for
I bought the unit new from a shop and they installed the
extra ram. Therefore I do not know the best way to get in the unit to check the ram. Any
suggestions.
Well, my
suggestion was to check the RAM at start up. That way you'll know how much is being
accessed. Then you can physically inspect. Here's a thread from another forum with more
info about locating the RAM:
http://www.mpc-forums.com/viewtopic.php?f=11&t=152812
The RAM is circled in Red
http://i196.photobucket.com/albums/aa18/Petepipe/RAM.jpg
AS you can see, there are many points to check
for Bad RAM. I don't think this is a seatign issue as they are all soldered to the board.
Edited by ken long (23/03/12 10:12 AM)
Richie Royale
#977693 - 23/03/12 10:40 AM
That is the S900 though isn't it, which has fixed memory. I've never opened my S950 and it
sits at the bottom of a pile of other racks, so I can't exactly get into mine easily. Mine
has 1024Kwords, so there is a presumably an expansion card in it, but having looked at the
Flikr set above, it seems that one has the same amount of RAM, but no obvious expansion in
it.
Chaconne
Loc: Oxford
#977815 - 23/03/12 04:21 PM
I remember installing the RAM myself - but that was a long time ago. I am pretty sure
that there was a panel that could be removed from the bottom on the machine, and the RAM
was on cards that stood up like the cards you put in a P.C. I cant see the bottom of
mine, (being on the bottom!) but this is what I can remember...
( I found the
manual - type written with hand drawn diagrams ! - was it that long ago?)
Mine
has been known to have hissy fits, and loose its memory, but checking the start up it
always seams to return.
vinyl_junkie
active member
Loc: Kent, UK
#977871 - 23/03/12 07:33 PM
I'm not very familiar with the S-950 but I have found a picture of the RAM expansion if
that helps, to me it looks very very similar to the one fitted into the MPC-60
ken long
[Re: Richie Royale]
#977883 - 23/03/12 09:29 PM
Quote Richie Royale:
That is the
S900 though isn't it, which has fixed memory..
Yes, that's right. I misread OP's post. I thought he was
talking about a 900. VJ, don't think they are the same though look similar.
OP, check the KW on startup. If it's 1536, you have max RAM. if it's less and you've
got the expansion (will be separate board like VJ's picture), then try reseating the card
is all I can suggest. If you're in there take some pics and post them up, it might help.
I'm replacing displays on both of mine in April. So I can take pictures then
Mud on the road
member
[Re: ken long]
#977895 - 23/03/12 11:47 PM
Thanks everybody for the help. I have looked on the bottom of the unit and they is a
massive plate you can unscrew. I tested the ram on starting up the unit and got the
message Bad ICL1. Showing only 512 Kwords when starting the unit instead of the full
amount. I will open the unit over the weekend and see how I get on. Will post some
pictures.
Regards
Peter
Mud on the road
member
Re: Checking Akai S950 ram. Pictures of ram
#978291 - 26/03/12 08:14 PM
Hi All,
sorted out the S950. The ram had come unseated. Got all the
1536Kwords back. Pictures show the bottom of the S950 with the plate in place and removed.
Ram is at the upper right hand side. Thanks everybody for the help.
Regards
Peter
OK. How do I attach the pictures to the
post.
Richie Royale
#978334 - 27/03/12 07:54 AM
I'm glad you got it sorted out. You can upload pictures to photobucket and then
link here using the img code.
Chaconne
Loc: Oxford
#978535 - 27/03/12 04:24 PM
So ya'all - whatcha still using old akais' for?
Just curious - cant decide if
I'm keeping mine for sentimental reasons, I mean 1.5 meg - woohoo - and thats fully
stuffed!
Richie Royale
#978555 - 27/03/12 06:36 PM
I tend to stick drums or anything that I want to dirty up through my old samplers. It is a
huge effects processor! I tend to just sample and then record the samples back into
Cubase, cut it up and then import into Battery. It isn't the same sound as a bit
crusher/sample rate reduction plug in. I have a dodgy Cheetah sampler which gives the most
crunchy aliasing at low sample rates and does something even more destructive if you use
the built in reverse option.
ken long
[Re: Chaconne]
#978563 - 27/03/12 07:35 PM
Quote Chaconne:
So ya'all -
Just curious - cant decide if I'm keeping
mine for sentimental reasons, I mean 1.5 meg - woohoo - and thats fully stuffed!
Cause they're fun as hell.
DGL.
[Re: Chaconne]
#978571 - 27/03/12 08:04 PM
1.5MB?? my Roland s-330 has 750k (un-expandable) Ram! (and only a maximum of half that can
be used per sample). But then again it does have the D-50's TVF's One of the best filters
every do endow a sampler.
ken long
#978574 - 27/03/12 08:16 PM
750K? luxury. My SP has 384Kbytes ahahahha!!!
vinyl_junkie
active member
Loc: Kent, UK
[Re: Chaconne]
#978577 - 27/03/12 08:28 PM
Quote Chaconne:
So ya'all -
keeping mine for sentimental reasons, I mean 1.5 meg - woohoo - and thats fully stuffed!
I'll take it off your
hands
Nah I'm stuck on using old Akai's for everything, I'm very
comfortable with using these old dinosaurs and quicker with them than their software
equivalents oh and fun.
Still use the 3200XL and MPC-2000XL oh and a
Ensoniq EPS-16+. I'd love a MPC-60, borrowed my mates for a while which made my lust for
wanting one even more... So I want this sampling drum machine right? And don't have a lot
of money.. So I then went out and blew close to £1k on a vintage dj mixer from 1976 and
that's before I service it hahaha I'm a tit Mind most of the cash came from selling my
Urei that I had before this Bozak..
But it sounds really nice lol
Edited by vinyl_junkie (27/03/12 08:47 PM)
ken long
#978586 - 27/03/12 09:23 PM
yeah, but a Bozak is a Bozak and I'd love to own one.
Chaconne
Loc: Oxford
#978588 - 27/03/12 09:26 PM
Yeah it can toughen up a riff if its a bit 'soft synthy', and err...
I guess
one or two elements find there way into some tracks, but I'm not sure its vital. On the
other hand its a nice looking machine, and worth nothing really so it stays. I think if I
did the mod to replace the drive with a card reader, and it had a good selection of kits
ready to go it would feel like it was earning its keep - but floppies - it seams a bit
embarrasing now!
Richie Royale
#978655 - 28/03/12 08:54 AM
vinyl_junkie
active member
Loc: Kent, UK
#978671 - 28/03/12 10:24 AM
Richie Royale
#978680 - 28/03/12 10:55 AM
Very nice. You had the Urei 1620 before didn't you? An original or re-issue? Presumably
you prefer the Bozak?
hollowsun
Loc: Cowbridge, South Wales
[Re: Chaconne]
#978682 - 28/03/12 11:01 AM
Quote Chaconne:
( I found the
Yep.
I wrote that on an Amstrad
PCW8256...
And had to hand draw the diagrams!!!
This was after the
S900 was released - Akai UK were embarrassed by the four-page (ahem) 'manual' that shipped
with the 900 so asked me to do something a bit more comprehensive. They sent it to
customers who asked for more details on sampling and operation.
Then Akai Japan
got wind of it and (I think) shipped it with subsequent production runs and as the S900
and S950 were essentially identical, it was (I think) used for the S950 as well with an
addendum, errrmmm, added to describe the extra features (higher sampling rates and
expanded memory).
This was 26 years or so ago!! There are probably people here
raving about a 12-bit, 8-voice (at best) sampler that's actually older than they are!
Happy days!
-------------------- Website / Music Lab Machines / Blog
chris...
active member
Loc: Glasgow
[Re: Richie Royale]
#978683 - 28/03/12 11:05 AM
does
something even more destructive if you use the built in reverse option.
Blimey. It's trivial to implement the
perfect reverse function - just write the sample values out back to front. This is
clearly not destructive in any way. Not exactly rocket surgery.
Amazing if
the early samplers managed to f*** this up!
Richie Royale
[Re: chris...]
#978691 - 28/03/12 11:19 AM
Quote chris...:
does
Amazing if the
Indeed, this is what one would expect,
however the Cheetah really does something weird. It seems to change the pitch as well as
add more aliasing noise. I guess the guys at Cheetah were more adept at making joysticks
than samplers (and a good synth apparently, the MS6). I also have their MS800! What a
bizarre product.
I'll post up a clip if I can (and if it is still working, not
been powered on in a while! )
vinyl_junkie
active member
Loc: Kent, UK
[Re: Richie Royale]
#978692 - 28/03/12 11:19 AM
Very nice.
You had the Urei 1620 before didn't you? An original or re-issue? Presumably you prefer
the Bozak?
I prev had the
re-issue 1620 which I brought new, not all that compared to the original imo... Really
noisy too, I know the original is a bit hissy but this was taking the p*ss. The sound was
very hard in the mids too, top end not that nice either.
The Bozak is lovely,
all class a discrete circuitry. It's a lot quieter than the Urei and the sound with music
(especially music with real instruments and propper production) has a very nice quality to
it.
It has quite a big musical bottom end, not sure if that's just the eq out of
calibration though.
The mic pre's totally wipe the floor with my studio desk (32ch
Mackie VLZ pro thing) they also have nice BeyerDynamic transformers on the inputs which
also give a bit of gain.
I got 8 sets of NOS ALPS RK-40's to fit to it as it
still has the horrible Allen & Bradley pots fitted like all early Bozak's. I'm having
it fully re-capped with ELNA caps and fitting one of these to it which will bring the SNR
of the phono inputs to a nice 83 dB
http://www.isonoe.com/custom-equipment.html
Not really
the best example but here is a quick clip of it playing a old disco record
http://www.youtube.com/watch?v=0vEJYo12Dh0&list=UU0ysg8Om_zET-YzX9lUZh
ZQ&index=1&feature=plcp
Can't wait to have it serviced
Richie Royale
#978710 - 28/03/12 12:07 PM
The Urei sounds a bit crap for a grand mixer then! I bought the cheap two channel Urei DJ
mixer which I think is alright, but has very little gain on the channel gains. I'm sure the Bozak wil be amazing once the pots and caps are sorted out.
Chaconne
Loc: Oxford
#978768 - 28/03/12 05:59 PM
@ Hollowsun
Thats really interesting. My S950 with 8 mono outs into a mixer
and some alesis outboard is all I had at first, so I knew the Akai inside out - and it was
a good manual - it seamed written for the 'power user'! I squeezed every drop out of it
and it kick started what modest success I have had with music.
Thats the
reason really I cant ditch it - it wold seam so undignified, to get what - £150? A plug
in? I'll probably keep it until I cant lift it!!!
Richie Royale
#978773 - 28/03/12 06:36 PM
As mentioned above here is a short example of how my SX16 messes with the playback if you
use the reverse option on the front panel. Even with the Soundcloud encoding, you can here
the crunch on the third track compared to the second. Both are the same sample, but the
second has been played back from the front panel and then reversed in Cubase. http://soundcloud.com/richie-royale/sets/sx16-example
hollowsun
[Re: Chaconne]
#978777 - 28/03/12 07:12 PM
Quote Chaconne:
@ Hollowsun
Thats really interesting. My S950 with 8 mono outs into a mixer and some alesis
outboard is all I had at first, so I knew the Akai inside out - and it was a good manual -
it seamed written for the 'power user'! I squeezed every drop out of it and it kick
The S900/950 was a cracking piece of kit in its way (and its day)
- pretty much a Fairlight for a 10th of the price. And, of course, its release coincided
with the Atari which was a marriage made in heaven back in 1986.
I take your
point about selling it (or not, as the case may be). If you like it, get on well with it
and it has a use for you, then yes ... keep on doing what you're doing and good luck to
you - more power to your elbow.
Glad you liked my (ahem) 'manual'. Yes - it WAS
aimed at those who wanted to coax more out of their S900, know more about sampling in
general, etc.. The original 4-pager was just a joke but Akai were very young back then
(roughly two years old by the time the S900 came out) and finding their feet so some
leeway should be afforded them.
It always makes me smile all these years on to
see there's still love for all the old Akai sampling gear I had a hand in.
ken long
[Re: Chaconne]
#978778 - 28/03/12 07:28 PM
Quote Chaconne:
£150?
Recent eBay sales in the US have seen
them go for $500 on average... crazy.
ken long
#978782 - 28/03/12 07:39 PM
Chaconne
Loc: Oxford
#978785 - 28/03/12 08:05 PM
Ha - I was just looking at a few ads in the back of SOS. I'll keep a check on ebay then,
I mean maybe that sentimentality might melt away!!!
( i see someone hoping for
£150 just for the 750K RAM!)
@ Hollowsun 'a fairlight at 1/10th the price - '
thats a good description of how I felt. It seamed a limitless machine to me at the time.
vinyl_junkie
active member
Loc: Kent, UK
#978787 - 28/03/12 08:47 PM
The S2800 was my first sampler and loved it, great manual too. It pretty much taught me
sampling. Probs the most overlooked thing on it was the "help" button but I thought it was
cool.
The 8meg Memory expansion though was almost as much as the sampler hahah
Edited by vinyl_junkie (28/03/12 09:03 PM)
ken long
[Re: Chaconne]
#978793 - 28/03/12 09:59 PM
Quote Chaconne:
Yeah it can
I guess one or two
elements find there way into some tracks, but I'm not sure its vital. On the other hand
its a nice looking machine, and worth nothing really so it stays. I think if I did the
mod to replace the drive with a card reader, and it had a good selection of kits ready to
go it would feel like it was earning its keep - but floppies - it seams a bit embarrasing
now!
Floppy emulating card
reader takes this baby into the 21st century. Hahaha.
Chaconne
Loc: Oxford
#978794 - 28/03/12 10:25 PM
OK - thats pretty cool.
I have looked over that site and considered this - its
not a bad price - but the site is a bit confusing.
Can you put stuff on the SD
card from a computer, or does it save things only from the S950 memory?
Plus,
what do you do, fill it up, save the data / programs, then clear the memory for another
load etc? If you dont mind answering a couple of queries here publicly it might interest
others...?
Thanks
ken long
[Re: Chaconne]
#978851 - 29/03/12 08:52 AM
Quote Chaconne:
Can
you put stuff on the SD card from a computer, or does it save things only from the S950
memory?
No and yes. The card
will act exactly like a floppy. You create a 950 disk image for the card. You save to
the card as you would a normal floppy except that you obviously now have a great deal more
storage on a single card.
Quote:
Plus, what do you do, fill it up, save the data / programs, then
clear the memory for another load etc? If you dont mind answering a couple of queries
here publicly it might interest others...?
No problem... That's not my machine but I've done this to
another sampler of mine. You can sample / load as much as your sample time permits (i
think 26 seconds on full 2.25MB, IIRC). I'm not sure if you can create partitions on the
card but as you mention, you can offload the card contents to your PC for a more permanent
archival storage.
So 2 real advantages:
1. no longer need to store
many floppies (which fail).
2. flexible archival tool for projects.
and of course, the ability to share your project with someone else without mailing them
the floppies!
On my 3000, I also use a CF solution but via the SCSI. It allows
me to edit my audio ona PC, then convert it to the sampler's format, load it onto a CF
card and into the unit. I have 32 partitions on a 1GB card which I can pick and choose
samples from or load entiore programs. It really saves so much time and allows me to back
up my projects easily.
chris...
active member
Loc: Glasgow
[Re: Chaconne]
#978869 - 29/03/12 10:02 AM
Quote Chaconne:
Can you put stuff
No.
Quote:
or does it
That.
Pitchfork
new member
Loc: London
[Re: chris...]
#979948 - 03/04/12 04:36 PM
Not to drift off the post, I have also just scored an s950! In good nick with
1024kwords? - 1.5mb? It will go nicely with my S3200. I am hoping to use the
950 as an fx unit to grunge up some VST's and the like, as well as loops
vinyl_junkie
active member
Loc: Kent, UK
#979978 - 03/04/12 07:43 PM
I really don't get the grunge thing with these 12 bit things... Not to sh*t on any ones
bonfire but I think it's one of the most over rated things ever.
When you say grunge
first thing that comes to mind is this
I've had MPC-60's and they sound nothing but nice..
Edited by vinyl_junkie (03/04/12 07:58 PM)
vinyl_junkie
active member
Loc: Kent, UK
#979987 - 03/04/12 09:22 PM
Have a listen for yourself
http://soundcloud.com/fromafarawayplace/sets/sampler-shootout/
There are much better samplers out there to "dirty" up the sound than the poor
ol' 950 which imo is a good clean sounding sampler..
Edited by vinyl_junkie (03/04/12 09:26 PM)
johnny h
[Re: vinyl_junkie]
#979990 - 03/04/12 09:59 PM
Quote vinyl_junkie:
Have a listen
for yourself
There are much better samplers out there to "dirty" up the sound than the poor ol'
The dirt is in the aliasing when you tune the samples
vinyl_junkie
active member
Loc: Kent, UK
[Re: johnny h]
#979991 - 03/04/12 10:01 PM
Quote johnny h:
Quote vinyl_junkie:
Have a
listen for yourself
It still sounds clean, if it's
anything like the MPC-60 it sounds damn good.. The SP-1200 on the other hand now there's
filth, it's like a ring modulator or something.
To be honest the S-3000
sounds worse than the MPC-60... The further you transpose the more muffled the sound gets
and it starts becoming like mush, sounds cr*p. It's not gritty/dirty in a nice way imo
where's the SP is.
The MPC-60 stays clean and I couldn't really hear any
obvious aliasing when transposing, the kicks retain that punch and clarity whilst on the
S-3000 you loose punch, fidelity and the will to live.
It could have
something to do with this (taken from a SOS article)
"A good sampler should
use high-quality interpolation algorithms that are far kinder on samples, even when they
are transposed in either direction some distance from their base pitch. As samplers
developed, though, the progression wasn't always smooth — for example, the Akai S1000
and S1100 used so-called 'eight-point windowed sinc interpolation', which was a good
algorithm allowing a good deal of transposition in either direction, and which introduced
artefacts only with extreme transpositions. But the later S2000 and S3000 family used
linear interpolation, one of the most basic methods available, as a cost-cutting exercise
to make the range of samplers more affordable. In practice, this meant that samples
couldn't be transposed too far away from their base pitch without transposition artefacts
being heard (a kind of metallic 'mush'). In my experience, hardware samplers seem to
handle transposition better than software ones, perhaps because hardware samplers have
dedicated circuitry built into them devoted to interpolation, and maybe also because the
software that drives this hardware will often be written in the lowest level of machine
code to ensure optimal performance under all circumstances, unlike the software
interpolation 'emulators' responsible for transposition in a software sampler. Of course,
low-quality interpolation will have no effect on recordings when they are played at their
sampled pitch, but the usefulness of a sampler is reduced if it can't transpose audio too
far away from its original pitch."
Edited by vinyl_junkie (03/04/12 10:13 PM)
vinyl_junkie
active member
Loc: Kent, UK
#979997 - 03/04/12 10:22 PM
Did a how to chop a sample video on the mpc-60 where I sample a record at 45rpm then slow
it down in the sampler.. I know the vid is kinda crappy quality but I can't hear any extra
grit when I'm dropping that sample down the octaves http://www.youtube.com/watch?v=5u4m5qZhX7M&feature=autoplay&list=U
U0ysg8Om_zET-YzX9lUZhZQ&lf=plcp&playnext=2What I will say though
is the 60 takes out a bit of bottom end when sampling, this was very clear when I sampled
some SH-101 and replayed it back on some speakers that can play low.. Transposing the
sample down gave you back this low end in a really nice way without making it muddy..
Being a S-3x man this really is something lovely
hollowsun
[Re: vinyl_junkie]
#980003 - 03/04/12 11:42 PM
Quote vinyl_junkie:
It could have
use high-quality interpolation algorithms that are far kinder on samples....
From 'The lost art of sampling'
wot I writ!
vinyl_junkie
active member
Loc: Kent, UK
[Re: hollowsun]
#980004 - 04/04/12 12:02 AM
Quote hollowsun:
Quote vinyl_junkie:
It could
have something to do with this (taken from a SOS article)
"A good sampler
should use high-quality interpolation algorithms that are far kinder on samples....
From <a
href="/sos/sep05/articles/lostscience.htm" target="_blank">'The lost art of sampling'
</a>wot I writ!
Damn
fine read that mate!
Although it still bugs me at night that they cheeped out
on the S-3000 series lol (I'm sad :-)
Were the XL's any different to the non XL
models in the way they transposed samples etc?
Pitchfork
new member
Loc: London
[Re: vinyl_junkie]
#980016 - 04/04/12 07:25 AM
Quote vinyl_junkie:
Were the XL's any different to the non XL models in the way they transposed samples etc?
I read and I think
Hollowsun mentioned (I could be wrong?) that the Akai S3000, S3200 and S3200XL were the
same, but the smaller 3000XL was made in a different country and sounded different?
There are thousands of posts now about the non-XL vs XL, and as an owner of the
original S3000 3u (since sold) and now owner of the S3200XL 3u, (same as you VJ ) I can't
really tell much difference?
Edited by Pitchfork (04/04/12 07:25 AM)
vinyl_junkie
active member
Loc: Kent, UK
#980084 - 04/04/12 11:13 AM
Coolio
Think you'll like the 950. I know it's odd but I loved not having a waveform display on
the MPC-60! The one on the MPC-2000XL is the worst, having to wait for the waveform to
buffer.. proper lame!! Especially considered you don't have this issue on the rack
samplers The closest thing I had to the original S-3000 was a S-2800 which was
pretty much the same thing other than the amount of ram it could take, outputs and
physical size. It's been too long to remember how it sounded the only thing I
can remember is if you sampled with the backlight on you would have a very slight high
pitch whine in your samples.
Chaconne
Loc: Oxford
#980263 - 04/04/12 11:32 PM
You raise some interesting points V.J.
I would say that the S950 is actually
quite 'nice', but indeed it does subtract bass. I would hesitate to use it now for
sampling nice analogue synths.
I find it gives a sort of 'glassy' texture to
samples - making the sound a little distant. The other thing it seams to do is hype the
mid range a bit, and add attack to dynamic samples. A way to hear this is to sample a riff
using chords from a soft synth, something a bit stabby say, and on playback it will have
more body and attack - almost like it has been through a compressor.
But I
agree, there is very little grain or dirt on anything recorded on an S950 - but it does
make the sound slightly hard in some way. If you listen to say Peter Gabriel records from
the 80's you can hear how lots of low grade sampling actually makes for quite a rough mix.
Those early digital 80's albums sound quite harsh. Once you get to the next generation -
by the S1000 - things sound a lot smoother - house records from the period sound quite
analog, rather than grainy.
One good trick with the S950 is to make a tiny
loop, until the buzzing makes a note, and then use that for a dirty electro side chain
bass. Bit of trial and error for the right sample, but any bit of complex audio will
generally do - MONSTER!!!
