Dave.jj
Backing track playback device
#987008 - 12/05/12 09:09 AM
As stated in my post about small mixers, I play in a guitar duo and we are upgrading some
of our setup. We make our own backing tracks which consist mostly of programmed
drums and bass... some keyboard here and there. At the moment we use a rack
mounted Tascam minidisc player which has always been fautless, in this world of MP3
players or devices that use SD cards do any of you have experience or views on us changing
what we use. I feel these players might reduce the size and weight of our gear...be more
versatile etc, but I know very little about whats out there. We would also need it to
have an auto pause function after each track. The one drawback of the minidisc
is having to change discs depending on the set we play or changing the order we play on
the night. Thanks again in advance Dave www.the2fbs.co.uk
Bob Bickerton
active member
Loc: Nelson, New Zealand
Re: Backing track playback device
[Re: Dave.jj]
#987010 - 12/05/12 09:59 AM
I've used minidisc for playback for many years (Sony pro model) but I'm just changing over
to iPad. There are a number of playback apps that are compatible with the 'Airturn'
Bluetooth foot pedals, which make for a much more flexible solution. You can playback
uncompressed WAV files, and I'm picking the iPad converters whilst not ideal are OK for
most live work. In addition you can use apps like the unreal book to give you lyrics at
the same time as music playback. Alternative would be flas drive players like
the Tascam rack mount models which would offer auto pause. Bob
-------------------- www.bickerton.co.nz
Mike Stranks
active member
Loc: Oxford, UK
[Re: Dave.jj]
#987020 - 12/05/12 11:46 AM
I've been on a similar journey to Bob... Used to use rack-mount mini-disc with
the track auto-stop/cue-to-next engaged, then 'upgraded' to rack-mount CD - but without
auto-stop cue. Have recently switched to PC laptop and Multiplay. Very happy with the result and it's easy to create and
store set-lists. Mike
Dave.jj
[Re: Mike Stranks]
#987023 - 12/05/12 12:11 PM
The laptop option just does not feel to safe to me, also its something else to have to
have next to you while playing.... I guess you have to have it next to your mixer? We also have a footswitch adaption on our minidisc for me to start the next
track. I have just come accross this unit http://www.dv247.com/studio-equipment/denon-dn-f300-professional-solid-sta
te-audio-player--68472Not sure about the playback options though.... I
will keep looking, there has to be something out there that will work for us But then apart from the amount of tracks we can fit on 1 minidisc, maybe what we already
have is still the best option?
Dave71
Loc: Lat: 54:24:38N Lon: 1:43:30W
[Re: Dave.jj]
#987027 - 12/05/12 12:27 PM
There are some very good devices on the Market now, some with keyboard support etc if you
want that kind of thing I use a simple citronic sd player which also has a USB
slot for various things. Cheap and cheerful but it does the job. http://www.htfr.com/p/333850/citronic_mpsd_1_dual_sd_card_media_player
-------------------- I eat kebabs when i'm sober!
BWSE
Loc: Littlehampton
[Re: Dave.jj]
#987028 - 12/05/12 12:39 PM
It depends on how much you want to spend really. I have seen all sorts of successful
methods including iPad applications etc.
I went from dual tascam 2424 units
(sync via smpte/ wc) running exact copies to Pro Tools a few years ago. This has
functioned fine and dare I say it, more reliable than the tascams which would start to
show flaws after about 800 shows.
I now run dual pro tools rigs. Which gives the
convenience of quick editing and a multitude of ins/outs.
-------------------- Control room to be finished summer '12
Edited by BWSE (12/05/12 12:39 PM)
artzmusic
Loc: usa
[Re: Dave.jj]
#987035 - 12/05/12 01:42 PM
Dave, As for the smaller devices, I've found they can be more difficult to navigate while
on stage. A laptop using Multiplay gives a larger display and can be placed where you can
actually see it - not in a rack. That being said, assuming your playlist is set in order,
you might use a remote to trigger the tracks. I use the Logitech N305 remote number pad -
and Multiplay lets you assign the keys however you'd like.
As for the
reliablility of a laptop, there are far too many acts using them for that to even be a
question any more. Turning off wireless and turning on presentation mode will set you up.
The only problem I've had is forgetting to plug in the power cord and having the battery
running low. That won't happen again!
I'm sure the other options mentioned
work equally as well depending on personal preference.
Best, Rick
Dave.jj
[Re: artzmusic]
#987042 - 12/05/12 02:16 PM
Quote artzmusic:
As
for the reliablility of a laptop, there are far too many acts using them for that to even
be a question any more.
Rick
I'm sure your right, and I guess if we went this way we might wonder why
we never took the plunge long ago....
I still like the idea of everthing being in a rack though.
Thanks for your
thoughts....
Bob Bickerton
active member
[Re: Dave.jj]
#987048 - 12/05/12 02:53 PM
Just for the record you can mount the iPad solution on your mic stand so you have direct
control from your performance position including very good visual feedback. I know it's
essentially a pc, but it feels much more like a dedicated playback solution. It really is the ultimate, flexible, secure Playback solution. Bob
shufflebeat
Loc: Manchester, UK
[Re: Bob Bickerton]
#987075 - 12/05/12 07:16 PM
Quote Bob Bickerton:
It
That's fantastic, Bob.
Now
hold it up to the camera and... smiiiile!
-------------------- Ohm's Law states, "Your PA isn't as powerful as you think it is".
artzmusic
Loc: usa
[Re: Dave.jj]
#987099 - 13/05/12 03:44 AM
Bob doesn't know it but he's about to sell me on the iPad. Just when I said I wasn't
going to do any more to upgrade my rig! @##$%
Rick
Dave.jj
[Re: artzmusic]
#987104 - 13/05/12 07:00 AM
Quote artzmusic:
Bob doesn't know
it but he's about to sell me on the iPad. Just when I said I wasn't going to do any more
Rick
Mike Stranks
active member
Loc: Oxford, UK
[Re: Dave.jj]
#987105 - 13/05/12 07:36 AM
You have to watch that man Bickerton... a few weeks ago I came here looking for a
sub-£100 mic and went away with a £1000 mixer!  It's a good job I know that he knows what he's talking about.
SparkyG
[Re: Dave.jj]
#987107 - 13/05/12 07:48 AM
Bob Where do you take the output from? I have been using an adapter at the
bottom to give me a line out, but it's not that stable and I keep losing the left channel.
Tried a couple of different adapters. Last night I used the headphone out,and it sounded
fine. When I used my old iPod classics I always found the headphone output poor. But the
iPad 2 seems pretty clear.
Comments?
Bob Bickerton
active member
[Re: Dave.jj]
#987112 - 13/05/12 09:13 AM
Shame I'm not on commission for all my suggestions. But buyers beware! When I
suggest something, it is only my opinion, I do try to be as objective as possible and
relate to my own personal experience, but there will always be alternative options. In this case I like the iPad because it seems pretty foolproof, but mainly the
interface and playback app options give excellent feedback, it's what Apple do well. I
wanted to move from minidisc because of its inflexibility. Need to add to a set, you need
to rerecord the disc, or at least add another track in real time. Flash or iPod/iPad
solutions are just more manageable. Also I'm amazed my minidisc has lasted as long as it
has given its a whizzing disk relying on a clean laser to pick up the info. A
pro flash player may have better converters (not a huge issue for gigging live situations
IMO), but in terms of interface usability you can't beat the iPad. Bob
Bob Bickerton
active member
[Re: SparkyG]
#987114 - 13/05/12 09:18 AM
Quote SparkyG:
Where do
I have been using an adapter at the bottom to give me a
line out, but it's not that stable and I keep losing the left channel. Tried a couple of
different adapters. Last night I used the headphone out,and it sounded fine. When I used
my old iPod classics I always found the headphone output poor. But the iPad 2 seems
pretty clear.
Comments?
I use headphone out, but I'm really
careful not to place tension on the lead. I use one of These
K&M stand holders and also a right angle jack plug. I Velcro the cable to the mic
stand, but leave sufficient slack so that the plus doesn't get pulled or tensioned. Seems
to be secure.
mick.n
[Re: Mike Stranks]
#987130 - 13/05/12 11:16 AM
Quote Mike Stranks:
store set-lists.
Mike
Mike, i used the Multiplay software at a rehearsal a few weeks ago. While it did
perform very well, i found it used a lot of CPU when it was running a track on my dual
core laptop. Did you notice this? Good program though & free.
To the OP, i
just switched to using the ipad 2 a few weeks ago for backing tracks & its perfect.
Only done a dozen or so gigs with it but really impressed so far. I am using the rather
delicate looking headphone jack at the moment but, as Bob says, if you are carefull not to
trip over it (ROADIES!) or snag on it you'l be ok. Though i am considering the Alesis I\O
dock as a more sturdy solution.
This
is the app i use and cannot recommend it highly enough.
All i need now is an
app that will control the lighting rig too.
seablade
[Re: Bob Bickerton]
#987134 - 13/05/12 11:38 AM
A pro
Not quite true for the record, some of
those, namely the Tascam players, but a few others, all have direct track access remote
'keypads' that can be placed much closer than the unit itself, and would make it
relatively easy to launch tracks as well while having the unit in the rack. Of course
this adds to the cost. And of course you could always do similar with a computer which
has already been mentioned, even to the point of launching tracks from a keyboard on stage
if you really wanted by tying it to MIDI.
All that being said, the point is
there are a half dozen ways to accomplish this on stage and several 'good' ways, or at
least 'not bad' ways, including sticking with MD as well.
Seablade
shufflebeat
Loc: Manchester, UK
[Re: Bob Bickerton]
#987135 - 13/05/12 11:45 AM
I wanted to
move from minidisc because of its inflexibility. Need to add to a set, you need to
I realise this has been obsolete for some
time but there was a way to put songs on minidisc in a "drag and drop" kind of way over
USB. It was a Sony music management system that was totally useless for a hundred other
reasons but did keep one of my regular gig partners using minidisc while everyone else and
their Granny had moved on to mp3 players.
I suppose it could still be found
if one was masochistically inclined.
Bob Bickerton
active member
[Re: seablade]
#987141 - 13/05/12 12:02 PM
Quote seablade:
A
Seablade
Yep, in fact that's what I've
been using until now, Sony MD, remote access by keypad and footswitch for start/stop has
been rock solid, but having a large touchscreen attached to your microphone stand with
'named' key pad start buttons, easy scroll set lists, lyrics displayed on playback, well
it simply doesn't compare. The only reason I was holding off on the change was because I
wanted footswitch start/stop functionality, which is now available with the bluetooth air
turn pedal.
Interestingly, I'm still using the minidisc for my music theatre
productions in schools, because the sets never change and I don't have to look at the
display to see what's next!
Re computers, happy enough to use them when I'm
engineering, but never fancied them for when I'm performing.
As usual it's
horses for courses......
TheBev
Loc: London
[Re: shufflebeat]
#987143 - 13/05/12 12:07 PM
Quote shufflebeat:
I wanted
to move from minidisc because of its inflexibility. Need to add to a set, you need to
I suppose it could still be found if
This wasn't Sonic Stage was it, I seem to remember this came with
my earlier Sony mp3 players, maybe developed from the minidisc.. maybe not.
-------------------- "The tech gets better, the user error remains the same.." Roberts Plant
artzmusic
Loc: usa
[Re: Dave.jj]
#987179 - 13/05/12 05:00 PM
Since many acts are going totally wireless these days, (ours included) any suggestions on
getting the iPad signal to the mixer sans wires?
The freedom this affords us in
our presentation is vital these days.
Rick
shufflebeat
Loc: Manchester, UK
[Re: TheBev]
#987186 - 13/05/12 05:35 PM
Quote drargon:
Quote shufflebeat:
I wanted
That sounds familiar. I remember it
putting up a hell of a fight when I tried to replace it with something more adaptable.
Bob Bickerton
active member
[Re: artzmusic]
#987201 - 13/05/12 08:03 PM
Quote artzmusic:
Since many acts
are going totally wireless these days, (ours included) any suggestions on getting the iPad
The freedom this affords us in our presentation
Rick
Now theres a thought.
I guess you could use Apple TV and take the
optical audio out, but I've no idea what the quality would be like. If it was OK, then it
would get around the issue of using the headphone out and potentially give you option to
use better converters at the mixer end.
I wonder if anyone else could add to
this?
seablade
[Re: shufflebeat]
#987240 - 13/05/12 10:39 PM
Quote shufflebeat:
I wanted
While what you are referring to was a Sony specific solution, there was on many MD
recorders of decent quality an ability to reorder tracks without needing to re-record the
disc IIRC, and without hooking up via USB. It has been some time, but I am fairly sure I
still have a couple of player/recorders with this functionality on them laying around.
Seablade
seablade
[Re: Bob Bickerton]
#987242 - 13/05/12 10:41 PM
Yep,
in fact that's what I've been using until now, Sony MD, remote access by keypad and
footswitch for start/stop has been rock solid, but having a large touchscreen attached to
your microphone stand with 'named' key pad start buttons, easy scroll set lists, lyrics
displayed on playback, well it simply doesn't compare. The only reason I was holding off
on the change was because I wanted footswitch start/stop functionality, which is now
available with the bluetooth air turn pedal.
For the record, while obviously it doesn't do lyrics, what I was
referring to wasn't the standard keypad remote access, but literally a direct access
playback mechanism, meaning you had a button per track/sound and you had them labeled and
just punched the one you wanted.
Seablade
Bob Bickerton
active member
[Re: seablade]
#987287 - 14/05/12 09:34 AM
Quote seablade:
Yep,
Seablade
Thanks for clarifying that, I wasn't aware
there was such a device.
Mike Stranks
active member
Loc: Oxford, UK
[Re: mick.n]
#987305 - 14/05/12 10:22 AM
Quote mick.n:
Quote Mike Stranks:
Have
store set-lists.
Mike
Mike, i used the Multiplay software at a rehearsal a few weeks ago. While it did perform
very well, i found it used a lot of CPU when it was running a track on my dual core
I have a bargain-basement laptop - "the finest
that Woolworth's could sell" - and I've never experienced any problems issues. Obviously,
when using Multiplay, I have no other apps running...
mick.n
[Re: Mike Stranks]
#987387 - 14/05/12 06:31 PM
Quote Mike Stranks:
I have
a bargain-basement laptop - "the finest that Woolworth's could sell" - and I've never
experienced any problems issues. Obviously, when using Multiplay, I have no other apps
running...
Thank you for the
info Mike. I also had nothing running (AV off, wireless disabled, etc, etc), but it still
pulled around 35-45% cpu when playing a track. Although my I7 sandybridge desktop cpu
barely moved running the same prog....but thats got a lot more grunt than my dual core
Samsung laptop (Intel T2310 @1.47GHz).
May try it with a clean win 7 install
& see what happens.
Thanks again for replying Mike.
Dave.jj
[Re: mick.n]
#987393 - 14/05/12 07:05 PM
Quote mick.n:
To the OP, i just
switched to using the ipad 2 a few weeks ago for backing tracks & its perfect. Only
This
We are looking into this now....if we
have any money left after getting a mixer and new cab's that is
TheChorltonWheelie
[Re: Dave.jj]
#987397 - 14/05/12 07:17 PM
Quote Dave.jj:
The one drawback
of the minidisc is having to change discs depending on the set we play or changing the
order we play on the night.
www.the2fbs.co.uk
Why on earth would anyone want to invest in
a technology that has been dead for literally years is beyond me. I know people that still
use MD, but that's because they see no need to upgrade, it works and so they're happy with
it. However, if you're new to the backing track idea then I cannot see any reason why you
wouldn't want to go for a laptop and software or an SSD recorder/player.
On
that basis, if you use something like Ableton Live you can do all of the cueing that you
need, pre-programmed pauses between songs, chain songs together into mini-sets, MIDI pedal
to move to the next song in a set, etc, etc, etc. I've used it quite extensively, on a
moderate spec laptop, and I've never had a moments trouble.
Dave.jj
Quote TheChorltonWheelie:
Why on
earth would anyone want to invest in a technology that has been dead for literally years
is beyond me. I know people that still use MD, but that's because they see no need to
upgrade, it works and so they're happy with it. However, if you're new to the backing
track idea then I cannot see any reason why you wouldn't want to go for a laptop and
I think you must have misread or misunderstood my original post,
as I said we have been using MD with no issues, we are maybe looking to change due to the
amount of tracks that one disc holds.
As I said MD works fine, its just the
fact of having to change discs depending one how we play a set. We have not just invested
in MD we have had it for sometime.
Cheers Dave
Loc: The wilds of Hampshire
[Re: artzmusic]
#987534 - 15/05/12 10:15 AM
Quote artzmusic:
Since many acts
You could try turning the problem round and have the iPad control a media player
sitting next to the mixing desk.
James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
markjosefmusic
[Re: Dave.jj]
#987573 - 15/05/12 01:17 PM
Like the majority of people out there, I used a Sony Mini-Disc for ages, although I do
remember originally using CD..."skippety, skip". When I decided to get back into singing,
I had a good Samsung NC10 netbook that wasn't getting used so decided to give it a go. I
have around 750 backing tracks all in WAV format from full rate CD sources (about 26gb
worth). My advice for what it is worth would be to firstly strip the laptop of all
unnecessary programs that may hunt for an internet connection to update etc... and on that
note turn off any windows update features and internet access. Once the netbook was
running as lean as I could get it, I then installed a basic version of Winamp. I know that
there are a lot of bells and whistles programs out there but be honest about what you
actually want it to do and you should be fine. Windows Media Player used to be OK but it
is now too resource hungry to be viable. Another good media player I considered was Foobar
2000 but I went for Winamp purely because it has been around for ever. I really like the
simplicity of Winamp once you change the preferences to just show what you need. You can
also increase font size of the song list view so that it can be easily seen at around 6
feet away. It also has a good colour pallet on the themes so that you can get a really
clear view without it glaring too much on stage. Set list creation is a breeze with drag
and drop and these can be saved for later reference. I have a USB footswitch that simply
controls play/pause but Winamp lets you set up various "hot keys" on the laptop keyboard
(I think "C" is play/pause). I can see where some people may be a bit nervous of laptop
use on stage but I have never had a problem with it even only running Windows XP and only
1gb RAM. Just keep it simple, follow the rules about only using it as a music player and
you should be fine.
Hope that helps………..Mark
Dave71
[Re: Dave.jj]
#987852 - 16/05/12 05:57 PM
Back to the laptop idea, ive been running my acer extensa for over 3 years with a stripped
down install of XP and 1gb ram. Has done over 300 gigs + occasinal home use for playlist
and other audio related tasks. Its been knocked had the occasion dowse in lager. in the
same time frame i have gone through 3 mixers including two Denon units.
Not
done any windows updates for 2 years as its not a web machine and use virtual DJ with
external multi channel usb soundcards for better audio.
as long as you have a
plan b just in case - my wife kicks off if i even try to take the ipad out so i dont even
go there, not worth the aggro!
Dave.jj
[Re: Dave71]
#987867 - 16/05/12 07:33 PM
Quote Dave71:
my wife kicks off
if i even try to take the ipad out so i dont even go there, not worth the aggro!
houseofpung
[Re: Dave.jj]
#990545 - 31/05/12 03:32 AM
I had a similar need to play single tracks from a playlist on my iPod/iPad, and I was
unable to find an app that would do the job, so I created One Track Mind. It plays one track
and then stops (or, optionally, loops that track indefinitely). It can also be set to
automatically advance to the next track after it finishes playing. It uses the same
playlists as the iPod music player, so you can manage your playlists the same way you are
used to in iTunes or on the device. I've heard from several musicians who are using it to
play backing tracks, so you may find it useful.
MarkPAman
Loc: Somewhere between Portsmouth &...
[Re: Dave.jj]
#990653 - 31/05/12 02:48 PM
Nice little app! I'll get that. Thanks. For those wanting a bit more
sophistication, PlayFadePause is a good little app. Designed as a simple theatre
playback system & pretty easy to use.
GlynB
Loc: Lancashire, UK.
[Re: Dave.jj]
#990659 - 31/05/12 03:22 PM
Quote Dave.jj:
Why
on earth would anyone want to invest in a technology that has been dead for literally
years is beyond me. I know people that still use MD, but that's because they see no need
to upgrade, it works and so they're happy with it. However, if you're new to the backing
Cheers Dave
Curve ball....
For a time I used
a Digitech Jamman footpedal for backing tracks. It takes SD cards. You can fit up to 99
songs on it. It's designed for looping, but works fine for this purpose too.
The main benefit, which was important to me at the time working solo, was that it's
hands free, being a footpedal.
http://www.digitech.com/en-US/products/jamman
You do have
to buy an additional add-on foot-pedal to move up through the 99 programs.
Dave.jj
[Re: GlynB]
#990695 - 31/05/12 08:03 PM
Quote GlynB:
Quote Dave.jj:
Why
Cheers Dave
Curve ball....
For a time I used
You do have
Interesting... I might look into one of
these
misuspita
new member
[Re: Dave.jj]
#998454 - 17/07/12 07:04 PM
I use a Zoom R16
for my tracks. It works fine since 2009(or 10?) without error. It's true, I dont need a
lot of tracks/songs, just maybe 30-40. I can also use it as a relatively good soundcard,
as it can record as a standalone recorder, or a USB device. When having opened
too many tracks for record it gets a little slow to start playback, but once started, no
problem
bellicapelli
[Re: Dave.jj]
#1044113 - 19/04/13 04:08 PM
I wanted to point out a link which can be useful : www.syncinside.net
