Nathy
Headphone monitoring..
#991348 - 05/06/12 12:06 PM
Hello
Im looking to use a pair of headphones as a replacement of wedges for a
drummer. I have an idea of how it'd work but before I do I want to make sure you all
agree...
XLR output of the aux into a small mixing desk situated next to the
drummer and then using the headphone output on the smaller desk?
cheers
-------------------- Nathan Stewart | Freelance Sound Engineer
Exalted Wombat
Re: Headphone monitoring..
[Re: Nathy]
#991353 - 05/06/12 12:47 PM
Quote Nathy:
Hello
Im
looking to use a pair of headphones as a replacement of wedges for a drummer. I have an
idea of how it'd work but before I do I want to make sure you all agree...
XLR
output of the aux into a small mixing desk situated next to the drummer and then using the
cheers
You could certainly use a small mixer as a
personal, volume-controllable headphone amp. It may even be cheaper than a dedicated
headphone amp!
Check what signal level your main desk's Aux Out provides
though. It's quite likely a balanced Line Out. The XLR inputs on the small mixer will
expect a Mic level signal.
This, plus any ground loop issues, can be solved by
putting a DI box between the two mixers.
Nathy
[Re: Exalted Wombat]
#991400 - 05/06/12 04:33 PM
Cheers pal! Much appreciated!
chris...
active member
Loc: Glasgow
[Re: Nathy]
#991550 - 06/06/12 04:14 PM
Quote Nathy:
Hello
Im looking to use a pair of headphones as a replacement of wedges for a drummer. I have
an idea of how it'd work but before I do I want to make sure you all agree...
XLR output of the aux into a small mixing desk situated next to the drummer and then
As a drummer, I used to do that. Works fine. I also mixed in a click
in on the mixer.
Nowadays I tend to keep things abit simpler by taking the
wedge the PA company provide by default, and feeding my headphones / IEMs with click
only. The click being the most important thing to hear. I don't really want to hear vast
amounts of other band members, as any errors in their timing might risk affecting my time.
Nathy
[Re: Nathy]
#991696 - 06/06/12 07:46 PM
This way of monitoring will most likely only be used for drummers with clicks / backing
tracks. Its because the wedges I use arent loud enough most of the time.
Cheers
Bob Bickerton
active member
Loc: Nelson, New Zealand
[Re: Nathy]
#991706 - 06/06/12 10:24 PM
Quote Nathy:
This way of
monitoring will most likely only be used for drummers with clicks / backing tracks. Its
Cheers
I think you're implying from the above
that you intend to have this available as an alternative to wedges when doing sound for
other bands. I think you'll find drummers, or any musician, would be resistant to this
unless they're used to it, in which case they'd probably use their own system anyway.
-------------------- www.bickerton.co.nz
seablade
[Re: Bob Bickerton]
#991717 - 07/06/12 01:59 AM
Quote Bob Bickerton:
Quote Nathy:
This way of
Cheers
Depends. I have
two campuses I rotate through volunteer drummers that range from semi-pro to professional
quality(Meaning they are in their own working bands) and typically I have drummers request
a wedge once, and we encourage the use of in-ears. After typically one or two
performances with headphones I haven't had anyone go back to a wedge yet, several have
bought their own plugs as a result, but they still depend on me for the kit.
I
have several musicians that own their own monitoring setup, only one that chooses to bring
their own over mine, and in that case it is because it is just what he knows, and he is
someone I use for shows that will run for weeks straight so he prefers using his own kit
for familiarity's sake. Of course last time he did this his behringer board died in
mid-tech and I had to scramble to get him a replacement, which ended up being a Focusrite
Saffire24DSP interface that I set up for him to adjust the monitor volume on only.
Most of the drummers that have their own kit have it for one specific reason.
They can't trust the engineers all the time to provide them with a good monitor mix. So
they bring their own mini-board to plug the monitor feed into, and mix with their own omni
mic (Not sure if I can name the position here as it isn't PC, and not sure how the mods
would take it, but I don't know another term for it) and their own gadgets like
metronomes, iPods, etc. (The one that does bring his own kit when dealing with me is also
one that sends me text messages in the middle of playing somehow, have never figured that
one out) That way they can be sure they can at least hear themselves and the monitor
engineer just has to give them other musicians rather than tweak the drum mix. Once they
learn to work with me however, they don't generally worry about it and are content with my
kit.
Seablade
