Huge Longjohns
long-serving member
Loc: Where the black rocks stand gu...
Good resource for learning about guitar wiring?
#992208 - 10/06/12 03:30 PM
Hi, anyone recommend a good site for learning how to do your own circuit diagrams for
guitar wiring? I've wired dozens of guitars in the past but never really understood the
theory.
For example, I'm starting another build currently where I want to wire
three humbuckers to a gibson style toggle selector, with a master volume, a master tone
treble cut and a master tone bass cut. But have no idea how to go about putting a circuit
together and, clearly, this isn't one you can just lift off the net! I'll probably go for
a simple, neck or middle or bridge switch but if I knew the theory I could do something
more challenging instead!
Also the humbuckers are four wire plus ground type so
if I knew what I was talking about I could consider push pull pots for extra versatility,
coil taps etc.
Anybody know where you can find a really good "how to draw your
own guitar circuits" tutorial, sort of thing?
-------------------- "Ignorance more frequently begets confidence than does knowledge" Charles Darwin.
active member
Loc: Devon
Re: Good resource for learning about guitar wiring?
[Re: Huge Longjohns]
#992219 - 10/06/12 05:28 PM
Not a web site, but one of the better starting points is Guitar Electronics for Musicians by Donald Brosnac. Yes it's old and
parts are out of date, yes it's poorly written in places, but it will give you the basics
so that you can then go explore online and make the most of the internet. For many years
it was the only reference available. Dan Erlwine's Trade Secrets articles at StewMac as well as his books are very
useful. And at Seymour
Duncan support pages there are a lot of schematics, some FAQ's and about 250 articles
written by Seymour that are published as Seymour's FAQs. A couple more pages about how
pick-ups work are here and here.
And as well as FX pedals, there is some interesting stuff about guitar wiring on the GEOFEX pages. Get your head
around those and you'll be able to use search engines to find more. Hope that
helps. Andy
-------------------- When the going gets weird, the Weird turn Pro.
Huge Longjohns
long-serving member
#992361 - 11/06/12 06:28 PM
OK, cheers Zen, I'll check 'em out. In the meantime, anyone got a schematic for the above
wiring scheme let me know!
active member
Loc: Devon
#992366 - 11/06/12 07:10 PM
What pick-up selections do you need on the switch Huge? The Gibson style toggle has two
inputs and select them individually or together. If you want to have neck in the up
position, middle in the centre position and bridge in the down position... no chance. Our friends StewMac offer this 6-way toggle switch that almost
gives you the options you want. It will fit in Les Paul style cavities, although some will
need modification to use it. A rotary selector switch would do the job, but the
PRS style switch is 5 positions and the Gibson Varitone style switch is 6 way. However,
they wouldn't fit in a Les Paul style cavity although you could leave a dummy toggle
switch there and put the rotary selector in place of a volume pot and then use the other 3
for Master Volume, Treble cut and Bass cut controls. A quick search found this 3 position
rotary switch from RS. You would need to cut down the shaft to length and use a knob
with a grub screw rather than a push on knob. Bass cut circuits are less common
on guitars, but a quick search found some useful schematics and info here that
should get you started. Andy
Huge Longjohns
long-serving member
#992426 - 12/06/12 08:28 AM
Well, what I'm doing is converting a Yamaha pacifica strat into a Rickenbacker 325-alike
(!). This is the famous child-size John Lennon one in case you're unfamiliar with the
name. So that's why I've got the three Artec humbuckers which look like Rickenbacker
toasters and two large knobs and one small, the thought being to add a toggle for pickup
selection to keep it looking in the spirit of the 325. I was going for three knobs for
master vol, master treb cut and master bass cut as I mentioned. But as far as
pickup combinations go, I'm not too fussy. The original 325 pickup toggle offered: just
bridge, all three or neck and middle. But with a 3 way toggle I guess I'd prefer to go for
bridge, bridge and middle, and neck. Is that doable with a regular three position? (I've
no idea what 3 pup Les Pauls offer, by the way???) That stewmac switch looks
fascinating though--useful for coiltapping. The description is a little vague but I assume
it moves side to side as well as up and down or something? PS Andy If you're
interested you can see my other recent guitar conversion projects on Facebook--the
Wilkocaster, the Fraudcaster and the Billycaster: http://www.facebook.com/pages/Plent/100928886698056?ref=tn_tnmnSimon
active member
Loc: Devon
#992465 - 12/06/12 12:15 PM
Yep, the switch moves from side to side as well... You can see how Rickenbacker
wired the 325 models on their support pages where they have a section devoted to schematics. By far the easiest way to do what you want is
to use a Fender style 3 way switch which should drop straight into the Pacifica. Andy
Huge Longjohns
long-serving member
[Re: zenguitar]
#992468 - 12/06/12 12:41 PM
I know, I could leave the loom exactly as it now in the usual strat configuration, but
where's the challenge in that!
Huge Longjohns
long-serving member
#992477 - 12/06/12 01:29 PM
ANdy, this switch is described as being for 3 pickup guitars. Is this different from a
normal toggle? ie would this help me? 3way toggle
active member
Loc: Devon
#992558 - 12/06/12 11:51 PM
Quote Huge Longjohns:
ANdy, this
switch is described as being for 3 pickup guitars. Is this different from a normal toggle?
Nope, does nothing like you need
I'm afraid. Toggle switches are essentially A, B, or A+B, and that's it. Even the 6 way
toggle I highlighted earlier is basically 2 normal toggle switches linked together
mechanically in the same housing to get some extra options. Once you need to switch
between 3 or more inputs you need a blade or rotary switch. Blade and rotary switches are
variations of the same thing, the shaft or lever turns a wiper, or wipers, (similar to a
rotary pot) to connect to different sets of connections. A toggle switch breaks pairs of
connections that are normally closed by spring actions. Grab a Les Paul toggle and a Tele
3 way switch and examine how the work mechanically, that will give you a good idea what's
happening.
Andy
active member
Loc: Devon
#992559 - 12/06/12 11:58 PM
I know, I
could leave the loom exactly as it now in the usual strat configuration, but where's the
challenge in that!
But that's not what I said
I said use a switch that fits the body and make a loom that delivers the functionality
you need. And quite clearly, that is a challenge. You may have to compromise the
aesthetics to accommodate a switch that allows you to select one of three sources but to
get your Master Volume, Master Treble Cut, and Master Bass cut you need a new loom.
Andy
leemo
Loc: Sheffield
#992566 - 13/06/12 07:15 AM
i destroyed my strat with this site: guitar nuts was good fun though
active member
Loc: Devon
[Re: leemo]
#992632 - 13/06/12 12:45 PM
Quote leemo:
Yep, that's another good resource and
one I've had bookmarked for a long time now.
Andy
Huge Longjohns
long-serving member
#992641 - 13/06/12 01:07 PM
OK, made my decision. Toggle switch for bridge, bridge and middle, neck. THen vol, bass,
treb using this circuit here: Bass and treb cuts Thanks for all your help, Andy,
much appreciated!
leemo
Loc: Sheffield
#992647 - 13/06/12 01:30 PM
+1 for the bass cut been wanting to do this on my guitar for ages, just not had the
time
active member
Loc: Devon
#992693 - 13/06/12 04:28 PM
OK, made my
decision. Toggle switch for bridge, bridge and middle, neck. THen vol, bass, treb using
much appreciated!
You're
very welcome Huge.
There's a lot of wishy washy anecdotal stuff on that page,
but the technical stuff is good and the circuit is just fine. As you are still new to this
game it might be worth pointing out a few things from the schematic that you might not
have picked up on.
The circuit is for a strat, but he has made some interesting
choices and this might help you understand his explanation. The main issue is that he is
using 500k pots rather than the 250k pots usually used for a strat. The value of the pots
does make a difference, they affect the high frequencies by changing the load on the
pick-up. The higher the value of the pot, the more high frequencies get through. Gibson
originally used 300k pots and later switched to 500k pots for humbuckers because they are
not as bright tonally as single coils.
One of the common tricks for fine tuning
the sound of an instrument is to swap the some or all of the pots to ones of different
values, especially the volume pot. A lot of metal guitarists use a 1Meg pot for the volume
control on humbucker equipped guitars to get extra brightness. What we don't know here is
whether he has chosen 500k pots just because he has a preference for a brighter tone, or
whether he is also compensating for some treble loss due to the other changes to the
circuit.
I would stick with the 500k pots as they are the norm for humbuckers,
but if it sounded a little dull in use I would swap out the volume pot for a 1Meg pot.
Next, the Master Bass control will affect all 3 pick-ups. It is always in the
circuit and is connected between the output of the pick-up selector and the Master Volume
control (and this is why I wonder whether it might have affected the choice of pot
values). However, the treble control will only work on the Neck and Middle pick-ups. If
you want to use it as a Master Treble for all 3 pick-ups you will need to make a
modification to the circuit.
If you want to do that, there are 3 ways you could
do it easily. Which is best depends on the physical layout. Basically, you will only need
one side of the switch so if you look at the schematic you can disconnect from the switch
the wire that leads to the centre tag on the treble control and you can omit the two
diagonal wires linking from one side (or pole) of the switch to the other. The wire from
the centre tag of the tone control is then connected to either the pick-up output of the
selector switch, the centre tag of the Bass control, or the input to the volume control. I
would suggest the centre tag of the bass control would be the neatest way to do it.
And finally, even though it is a strat circuit it will work equally well with a 3
way tele style switch.
Hope that helps.
Andy
Huge Longjohns
long-serving member
#992707 - 13/06/12 05:55 PM
Brilliant, Andy, thanks! Take me a while to get my head round this but I'll enjoy the
learning curve! I'd love to be able to 'read' a circuit like you've just done and know
what's going on! I've been doing mods to guitars for so many years but without the
slightest idea what the wires did, really!
active member
Loc: Devon
#992742 - 14/06/12 12:51 AM
Cheers Huge, And if it helps, I started with 'painting-by-numbers' just like
you did. The good news is that it really does start to make sense after a while, the bad
news is that, like so many things, the more you learn, the more you realise you need to
learn. Ho Hum !! Switches seem simple, but once you get to multiple pole
switches it's easy to get confused. When you are looking at schematics with switches it's
definitely worth getting out the pencil and paper and working out a separate circuit
diagram for each switch position to help you understand what's going on. That helped me
learn a lot, and it's something I still do now. Did you see the schematic for
the Peavey Omniac I posted in another thread recently? I'd read several descriptions of
what the 5 different switch positions did, they all made sense but I still couldn't get my
head around how it all worked. So I printed it out and took it to the pub along with a
pencil and paper, and then I sat at the bar with a pint or 3 of cider and patiently worked
through it, drawing out the circuit for each switch position. Turned out to be a quiet
night in the pub so I got all 5 positions drawn out, the explanations I'd read suddenly
made a lot more sense, and the barmaid was pretty impressed too  It's a
very flexible and powerful wiring loom and with the aid of my notes I can now reverse
engineer that circuit and apply the ideas elsewhere. And my tame amp tech has
about 40 years experience, he still prefers to work through a circuit and draw out his own
schematics because that helps him to better understand what is going on. So
don't worry, it will all come together with practice  Andy
Huge Longjohns
long-serving member
#992849 - 14/06/12 03:20 PM
Yes, you're right. And part of the problem is that, for me currently (!), actual
schematics seem to bear so little relation to pictorial wiring diagrams. I can follow the
latter, obviously, but schematics seem so unnecessarily complicated to the untrained eye!
You see a pictorial diagram and it's clear that three wires all join onto the same lug on
a pot but on the schematic they might all appear to be joined at various places along
their length etc!
Huge Longjohns
long-serving member
Found this schematic for a three pickup sg or firebird. Is this a regular toggle switch or
a special one? Firebird
Korff
Loose Cannon (Reviews Editor)
Loc: The Wrong Precinct
Looks like a regular 3-way switch — the middle positions is pickups 2+3 together, but
the third pickup has a pot so you can roll that all the way down and effectively use it
for just pickup 2 (the first position is just pickup 1, the third is just pickup 3).
I think...
Cheers!
Chris
active member
Loc: Devon
#992983 - 15/06/12 11:48 AM
No, it is DEFINITELY a different switch. Allparts carry them in right angle and straight
configurations, I've linked to the straight version here because they don't have a photo of the right
angle version that was used in the Firebird VII and SG. For comparison, here's a standard right angle
switch used with 2 pick-ups. The forum post the image is linked to does
confirm it is a different switch with an extra blade. But that is a difficult schematic to
read without having an example of the switch to hand. It's not clear how the connections
are made and broken in the 3 different toggle positions just from looking at the
schematic. Andy
Huge Longjohns
long-serving member
#993043 - 15/06/12 03:25 PM
Now I'm REALLY confused, Andy. Isn't that switch you've linked to the same as the one I
linked to earlier in the thread which you said COULDN"T do the three pick up thing?
active member
Loc: Devon
#993111 - 16/06/12 12:04 AM
Yes, it is Huge  The difference is the context. When you first linked to it, I
replied saying that it wouldn't do A, B, or C switching s you required. Don't forget that
you specified that you needed to select A, or B, or C, individually, not in combination,
that switch gives you A, B+C, and C. But when you later linked to the post with the
schematic you asked a different question, was it a normal switch or a special one. And I
replied that it was a special one and provided the links for clarification. Remember, a
lot of people visit the SOS forums and read posts here, so I always bear that in mind when
I answer. And it was important to make that distinction after Korf had suggested it was a
standard switch. The bottom line is that it was the wrong switch when you first
linked to it, and it remains the wrong switch now. Andy
Huge Longjohns
long-serving member
#993126 - 16/06/12 08:27 AM
Quote:
Toggle switches are
Sorry, I took what you said here to mean that there weren't any toggle
switches that were designed for anything other than two pickups. Told you I was in need of
a lot of education.
