Main Forums >> User Reviews
        Print Thread
Pages: 1
abby normal
Loc: washington, USA
some consumer software can also be useful for the audio restoration pro
      #995645 - 01/07/12 03:43 PM
some disorganized thoughts from an outsider- i am not a certified member of the pro music establishment, but i do audio restoration work as a highly perseverative hobby as well as to help the occasional music-loving person with a problematic old recording that they'd like to hear in better sound. to this end, aside from the mandatory sound forge 10, i've long used pristine sounds 2005 and iZotype Rx- i use them both in a complementary manner, the Rx gets rid of the loud pops and discrete clicks very well [via spectral editing and their declicker] and pristine sounds does the rest, including being able to "paintbrush" away certain nasties as well as iron-out nonlinearities in the waveform, performed within a spectral window. i've never used CEDAR retouch but i can't imagine how it could do much better with intrusive noise than the RX does, and even retouch can't touch what pristine sounds 2005 can do with their paintbrush [which, btw is somewhat different in function than the "healing brush" used in adobe audition]. i've also found that an economical [$40] program called "Click Repair" works even better [quicker and cleaner] than CEDAR DeClick on a wider variety of material, including brasses. the main advantage of having a CEDAR DeClick module is in real-time cleaning of phonographic recordings without having to load a PC.
i would like to hear from others here on this forum, with similar audio restoration experience or concerns.
Pages: 1
Rate this thread
Jump to
Extra Information
0 registered and 2 anonymous users are browsing this forum.
Moderator:  David Etheridge, James Perrett, zenguitar, Martin Walker, Hugh Robjohns, Zukan, Frank Eleveld, Will Betts
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is enabled
      UBBCode is enabled
Rating:
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
