differing levels from ADAT and analogue preamp outputs
#996901 - 09/07/12 03:06 PM
Edit
Reply
Quote
Can anyone enlighten me: I get very different output levels from my preamps into
recorders depending on an ADAT or Line level analogue signal.
Scenario: Live
festival stage: x16 mic splits (x2 ARTS8 splitters) from Soundcraft desk into: ISA828
& Audient ASP008 pre's.
Each preamp outputs x8 analogue line level into a
Fostex DV2424LVmk2 digital recorder (24 bit/44.1) and also x8 ADAT (24 bit) into a
Yamaha AW2400 multi-track recorder, recording at 16 bit (i forgot to switch jumper in ISA
to force to 16 bit and venue mud and wet was not place to open it up..)
The
main recorder in this case is the Fostex (files go to client on CF card) so i worked with
a regular -12dB or just over max level. This is set on the pre's as there is no input
control on the fostex.
The ADAT levels coming into the AW were significantly
lower. The AW was recording at 16 bit/44.1 so i would have liked a slightly higher level.
This is my back up recorder this time but i also mixed a live disc from it (stereo to HHB
recorder) and i worked on a mix at home from the AW to add to the package for the client
(just in case they like it) i had to use lots of make up gain to get decent
levels.
Is there any reason that the ADAT is lower in level or have i missed a
link in the chain?
Re: differing levels from ADAT and analogue preamp outputs
[Re: sabletones]
#996905 - 09/07/12 03:45 PM
Edit
Reply
Quote
This is a simple gain-structure question, but there aer many possible level anomalies when
working with different converters and different analogue interfaces.
You
need to find out what the actual operating levels are for the analogue line interfaces at
the preamp outputs and at the recorder input that you are working with, and how they
relate to 0dBFS (digital full scale). We need real numbers since the metering will
probably also provide misleading impressions!
I think the ISA428 is set up so
that +4dBu (standard line level) provides a digital output of -18dBFS. The Audient is the
same: 0dBFS = +22dBu.
However, the obvious pragmatic solution is to set the
preamps and recorders up again, input a test tone to the preamps and adjust the gain to
achieve the desired digital level from their internal converters (say, -10dBFS to
represent nominal peak level), then configure the analogue input sensitivity on the
recorders to achieve the desired level via that path.
hugh
-------------------- Technical Editor, Sound On Sound
Loc: The wilds of Hampshire
[Re: sabletones]
#996986 - 10/07/12 09:09 AM
Edit
Reply
Quote
Quote sabletones:
The main
recorder in this case is the Fostex (files go to client on CF card) so i worked with a
According to the Fostex website you can change the input sensitivity from a nominal
+4dBu to -10dBv. If you have it set to -10dBv then that would probably explain the level
difference.
[Re: sabletones]
#999130 - 21/07/12 04:04 PM
Edit
Reply
Quote
These guides much appreciated.
I went for pragmatic approach with concomittant
homework on level relationships etc and attempting to relate spec's to practice.
Used o1v oscillator (omni outs +4dB balanced) to send -12dB tone to ISA pre line input,
and yes the ISA -18 on meter is a +4dBu at line output.
I checked the fostex
set up. I was already using a +4dB balanced level at line input. The unbalanced -10dBv
did indeed shoot into the red, but i wasn't using that originally....but the observation
got me deeper into the manual, thank you James.
Current solution is to adjust
input levels on the AW2400 by using the input layer fader (needs to be +5 to equate to
levels on preamps/fostex. i can increase the meter level here also with the virtual
rotary level. I will ask Yamaha what the difference is here? I am doing this: 1) in
an effort to understand 2) when i need more than x8 channels i can only record at 16
bit on the yamaha.
What i have not grasped yet is why the ADAT level from pre's
into the AW2400 requires +5dB boosting to match level on fostex and ISa pre (audient being
less visually precise)......all stages seem to be operating balanced +4dBu....etc. Maybe
that's the way it is?...or is that a stupid thing to say?
I've got my tin hat
on if i've been a bit slow on the uptake!
