Main Forums >> DIY, Electronics, Studio Design & Acoustics
        Print Thread
Pages: 1
PaoloC
Sustain pedal compatibility
      #998244 - 16/07/12 10:22 PM
Hi, I have this problem: I have a Casio CDP 100 piano, and I need to connect a sustain pedal (Roland DP-10) to the piano.
The pedal's jack is (unusually) a stereo jack, since the pedal permits the half-pedalling when connected to a compatible keyboard. On the pedal there is a switch for enabling/disabling the half-pedalling.
Problem is that the pedal works reversed: when pressed, it disables the sustain, e when depressed, the sustain is enabled.
I have tried to make myself an adapter: a female stereo jack and a male mono jack, connected through a piece of cable. The pedal's stereo jack goes into the adapter's female stereo jack, and the adapter's male mono jack goes into the piano mono jack socket.
I have tried every possible cables' connection/inversion (I've used a cable consisting of two cables + shield), with no luck.
Any suggestion?
Many thanks!
Paolo
shufflebeat
Loc: Manchester, UK
Re: Sustain pedal compatibility new [Re: PaoloC]
      #998246 - 16/07/12 10:44 PM
Might this be related?
"I've just googled Dp-10 & can see it has two switches...one which will kick in when the pedal is half pressed & the other when the pedal is fully pressed. I have no wiring diagram, but I'd hazard a guess, that both switches are "normally open" (with no confirmation from Terratec, I'd hazard a guess -due to the high number of related posts on here -that the Axon expects a footswitch that is normally closed)."
From this discussion:
http://www.axon-technologies.net/forum/viewtopic.php?p=8166
Different symptoms in that case but, I think, possibly the same cause.
Ohm's Law states, "Your PA isn't as powerful as you think it is".
James PerrettModerator
Loc: The wilds of Hampshire
      #998326 - 17/07/12 09:30 AM
I think you probably need a different pedal. Some general purpose sustain pedals can be switched to be normally open or normally closed so that they work with the widest possible range of keyboards.
James.
JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Loc: Norwich UK
Re: Sustain pedal compatibility new [Re: James Perrett]
      #998330 - 17/07/12 10:49 AM
Quote James Perrett:
Yep, sustain pedals either have a closed contact which is opened by pressing the pedal (NC or "normally closed") or an open contact which is closed by pressing the pedal (NO or "normally open"). Seems Roland are generally NC while Korg and Casio are generally NO. Neither your pedal or your keyboard has an option to reverse the polarity, so you need a different pedal. I should get a switchable one.
hollowsun
Loc: Cowbridge, South Wales
      #998347 - 17/07/12 11:18 AM
Most keyboards now normally detect the type of sustain pedal switch on power up....
Plug pedal in, switch on - should detect and adjust accordingly. Can't vouch for the CDP100 but certainly my experience here.
Website / Music Lab Machines / Blog
PaoloC
      #998780 - 19/07/12 03:35 PM
Thanks to everyone for the suggestions.
Now I get the problem: It's not possible to change from normally opended to normally closed by just switching the wires.
At the moment I'm experimenting a different approach: switch the pedal to continuous, and then find a way to simulate the behavior of the Casio sustain pedal by getting the signal from the DP-10 tip and ring jack contacts.
I'll let you know my findings...
damoore
Loc: New Hampshire
      #1000227 - 28/07/12 01:29 AM
You would need to swap the internal switch from a momentary on to a momentary off (or vice versa as the case may be). But there are sustain pedals which can be switched to be either open when down (aka mom off) or open when up (mom on). Just changing the wires on the plug, or building an adapter won't help.
Edited by damoore (28/07/12 01:30 AM)
Pages: 1
Rate this thread
Jump to
Extra Information
0 registered and 55 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Home | Search | News | Current Issue | Digital Editions | Articles | Forum | Subscribe | Shop | Readers Ads
Advertise | Information | Links | Privacy Policy | Support
May 2013
SOS Web Shop)
Click image for May 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
