dadking
hands up if you own a bit of behringer kit
#998614 - 18/07/12 10:31 PM
It seems to me that lots of people are keen to knock Behringer products but most seem to
own a piece of there kit. I for one have a couple of pieces like autocom, DI box and a
graphic Eq, I certainly would not say they are my goto choices but when needs arise they
are available and used, apart from the DI box which i find unusable due to high noise
levels. So hands up if you have a piece of their kit lurking around your studio
vinyl_junkie
active member
Loc: Kent, UK
Re: hands up if you own a bit of behringer kit
[Re: dadking]
#998619 - 18/07/12 10:50 PM
I don't have any gripes with Behringer, you get what you pay for imo
Some of
it is junk and some of it is actually pretty good value for money
I use the
EM-600 delay guitar pedal quite a lot, for the price I can't complain.
I did
also have the CC-300 which is meant to be based on the Boss Dimension C (DC2) and it was
utter crap
Edited by vinyl_junkie (18/07/12 10:53 PM)
chris...
active member
Loc: Glasgow
[Re: dadking]
#998620 - 18/07/12 10:50 PM
Pretty sure I've got a volume pedal somewhere.
Hope that helps.
Airfix
[Re: dadking]
#998621 - 18/07/12 10:51 PM
One has to hide ones behringers. It's the shame that's hard to live with.
_ Six _
Loc: Liverpool
[Re: dadking]
#998622 - 18/07/12 10:51 PM
I use a graphic EQ on my PA system. Does the job, sounds good and has never let me down.
oggyb
Loc: Leeds, UK
[Re: dadking]
#998632 - 19/07/12 12:27 AM
I own a Xenyx 502 mixer. It's pants.
-------------------- Composer;
www.ogonline.org
Bob Bickerton
active member
Loc: Nelson, New Zealand
[Re: dadking]
#998634 - 19/07/12 12:43 AM
Used to, but ditched it all due to multiple failures................. Bob
-------------------- www.bickerton.co.nz
Mike Senior
SOS Mix Specialist
Loc: Cambridge, UK
[Re: Bob Bickerton]
#998642 - 19/07/12 05:47 AM
Quote Bob Bickerton:
Used to, but
-------------------- Mixing Secrets for the Small Studio
A complete mixing method based around the techniques of the world's most famous producers.
jaminem
active member
[Re: Mike Senior]
#998643 - 19/07/12 05:51 AM
Quote Mike Senior:
Used to,
+2
The Red Bladder
Loc: . ...
[Re: dadking]
#998646 - 19/07/12 07:16 AM
+3
The trouble is, it's a craps-shoot whether you get something worth having
and will actually work for longer than a few months. Having had a mixer go up in flames,
EQs that are phase problems in a box and headphone amps that weaker than the average
proper line-driver, plus having opened and seen what is actually inside their other boxes,
I just stay totally clear of their rubbish.
You can get far, far better stuff
from companies like Phonic and many others that actually work and only cost marginally
more, so there just is no reason to buy heavily marketed junk that is unlikely to work
properly from Behringer.
I have had five small mixers from Phonic that cost
about £35 each that are one eight hours a day, five days a week. We keep them as
personal mixers for foldback and they have so far have never ever had one single fault -
and we have had them for nearly ten years!!!
active member
Loc: Sheffield, UK
[Re: dadking]
#998649 - 19/07/12 07:30 AM
There's snobbery both ways. Some people don't have many good things to say about Behringer
just because they are believers in the 'reassuringly expensive'. Some simply want to
appear to be 'cool' on internet fora! There's also a reverse snobbery with some people who
seem to feel that any criticism of Behringer must be fought and defended. Of course, it's
all nonsense.
Let's face it, a lot of B gear is cheap because it's built down
to a price. You get what you pay for, in other words. If you're happy to accept a lower
build standard for the sake of just being able to get going, then no problem, but don't be
blinkered into believing that cheap always equates with good. Some days I don't want to
eat McDonalds.
Some B gear is great for the money. Some does an 'OK job' for
a knock-down price. Some of it is just pants. I'd include some of their DI boxes very much
in the latter category - not only unreliable, but appallingly noisy and tinny when it *is*
working. Some of it is also derivative, arguably to the point of plagiarism, and I would
not be comfortable giving my money away for such gear - I voluntarily paid more for my
cable tester, for instance.
But I do own and use some of their stuff and I
have no problem with this. I'm no snob either way. If a piece of their gear works to an
acceptable standard, then I'll use it, but if it doesn't meet my requirements then I'll
pass and buy something else that does.
I've had two ADA-8000s fail too early
in their lifespan, and one studio owner I know went through several of their headphone
amps in an alarmingly short timespan before ditching them for another brand. That many of
us are aware of that kind of track record makes us realistic about what we get with
Behringer - it may be cheap, but it's not always cheerful, and when your living depends on
your gear you need to be able to rely on it to an acceptable standard day after day.
Behringer aren't a cause or a religion that need to be defended, or championed.
They simply make gear that should be viewed for what it is, and either does what you want,
or doesn't.
-------------------- An Eagle for an Emperor, A Kestrel for a Knave.
Richie Royale
Loc: Bristol, England.
[Re: dadking]
#998651 - 19/07/12 07:35 AM
I have an early Composer which has a usable noise gate, but the compressor isn't much to
write about. But it still works after about 14 years, although the left LEDs have failed a
bit. I also have a Eurorack mixer which has useless EQ and a constant hum, so
has been unplugged and propped against the wall for a while. The only piece I
use is a DI box, for my Rhodes and clavinet, it does a job, but I have nothing to compare
the quality of it against. I don't mind some budget kit in my studio, I have a
little Samson mixer to accomodate some inputs and it is quiet and compact.
-------------------- http://soundcloud.com/richie-royale
http://www.mixcrate.com/richieroyale
Zukan
Zukan
[Re: dadking]
#998658 - 19/07/12 08:04 AM
Absolutely nothing wrong with Behringer gear and I wish people would stop knocking them.
Hell, they make the best doorstops I've ever come across after Samson Servos and the
C1000.
-------------------- Samplecraze
Stretch That Note
vinyl_junkie
active member
Loc: Kent, UK
[Re: dadking]
#998665 - 19/07/12 08:16 AM
Friend of mine had a cheap nasty Behringer mixer, all I can say is I've had more problems
with my 32ch over priced Mackie board than he has ever had with his cheap door stop
I feel as if the crapnes adds to my "tone" now though hahahah
ParlourSound
[Re: dadking]
#998666 - 19/07/12 08:23 AM
Gary_W
[Re: dadking]
#998670 - 19/07/12 08:31 AM
I sell medical equipment for a living. When a customer wants to buy a system from me they
have a choice between mine and competing products. When I try to discover their needs,
the most important factor to come out fron the customer will ALWAYS be some feature or
other and of course price.... When you are buying something, you are already imagining
how great it is going to be when you have all those new features and your life gets
better. Being a dour old sod, I gently point out that the most important feature of any
piece of equipment is that you press the 'on' button and it works.
The thing
is, features and performance are really subjective. One persons great sound quality is
another persons harsh. Reliability is far less subjective. In the case of 'it doesn't
work at all' or 'it caught on fire' then it isn't very subjective at all!!
Behringer have earned a reputation for being the company whose 'on button' doesn't
always work. I have no personal experience of them and I would not slag them off based on
what I don't personally know but the depth of feeling out there based on binary user
experience (it works vs it doesn't work) is huge. For this reason I think it is
reasonable for an individual to write them off based on other folks experience. Of
course, YMMV but that's the way I feel because of how I feel about reliability.
I do no have brand blinkers. I'm fine with using a cheap one of a pricey one of
whatever the product is. But if I'm buying something it's because I need it. Any whiff
of reliability issues sends me elsewhere as I just do not need the stress in my life.
Recording and gigging for me are a beloved hobby as opposed to my living, but even as a
keen amatuer I won't risk it. My time is precious and I want to spend my hobby time doing
pleasurable stuff, not fault-finding duff gear.
feline1
active member
Loc: Brighton, UK
[Re: dadking]
#998673 - 19/07/12 08:51 AM
I've got three (!) "Eurorack" analogue mixers from Behringer that I bought in 1999 or 2000
or summat. They sound crap. The EQ is crap. The preamps are crap. I also had a "rackmount
tuner" of theirs that I sold cos it was crap. Unless they've seriously changed
their crapness levels in recent years, and was rather skeptcial of Hugh's review of their
new digital mixer in this month's SoS, which is apparently a "gamechanger". All I can
mutter is "well it would bloody well need to be, because the game they've been playing up
until now is crap". You know?
-------------------- ~~~ A weasel hath not such a deal of spleen as you are tossed with! www.feline1.co.uk ~~~
Mike Stranks
active member
Loc: Oxford, UK
[Re: The Elf]
#998676 - 19/07/12 08:54 AM
Quote The Elf:
There's snobbery
both ways. Some people don't have many good things to say about Behringer just because
they are believers in the 'reassuringly expensive'. Some simply want to appear to be
'cool' on internet fora! There's also a reverse snobbery with some people who seem to feel
that any criticism of Behringer must be fought and defended. Of course, it's all
nonsense.
Let's face it, a lot of B gear is cheap because it's built down to a
price. You get what you pay for, in other words. If you're happy to accept a lower build
eat McDonalds.
Some B gear is great for the money. Some does an 'OK job' for a
But I do own and use some of their stuff and I have
I've had two ADA-8000s fail too early in
their lifespan, and one studio owner I know went through several of their headphone amps
in an alarmingly short timespan before ditching them for another brand. That many of us
are aware of that kind of track record makes us realistic about what we get with Behringer
- it may be cheap, but it's not always cheerful, and when your living depends on your gear
Behringer aren't a cause or a religion that need to be defended, or championed. They
simply make gear that should be viewed for what it is, and either does what you want, or
doesn't.
Spot-on your Elfness.
mpostor
member
Loc: S.W. London
[Re: Mike Stranks]
#998681 - 19/07/12 09:11 AM
Let's see...
4 x Multicom compressors 2 x ADA8000 Pre amps 1 x
FBQ3102 graphic 2 x DSP1124 Feedback Destroyers 1 x Composer compressor
In my time owning and using these, I had no failures.
I had a 602 mixer that
was used as a keyboard submixer twice a week every week for three years. 2.5 years
into this, the PSU cable failed. Not the PSU, the cable, due to the way that I was coiling
it. I've also had a MX2642 mixer for the past 15 years and the PSU on that has
gone. 15 years though. I've got rid of cars with less use than that.
That said, turning up for a festival with a rack full of Multicoms, etc and setting up
next to the guy with the Drawmers, SPXs, DBXs and Klark Tekniks, etc would lead to gear
envy...
Stu.
Big_al
[Re: dadking]
#998693 - 19/07/12 10:03 AM
I've got a Mini Mon 800. Had it now for over 6 years and it's still going with no
problems!
-------------------- www.thinkootb.com
vinyl_junkie
active member
Loc: Kent, UK
[Re: dadking]
#998696 - 19/07/12 10:13 AM
Wasn't the original Behringer compressor meant to be good? The black faced one made in
Germany. Copy of the Drawmer LX-20 I think
OneWorld
[Re: dadking]
#998698 - 19/07/12 10:17 AM
I have had the ADA8000 and that failed too early, until then it was fine, though I
replaced it with an Octopre which immediately sounded much better.
I also had
the mx8000, used it for years, no problem at all, though a little noisy
I use a
BCF2000 - works fine
Today I am going to buy a DDX3216, I am getting it for a
very low price, and at that price I am curious to see if it could replace my DM24, which
is fine, but I fear the LCD will fail eventually, which is a known fault with the DM
series and they are quite expensive to replace, in fact I am buying the DDX for less than
it would cost to replace the LCD in the DM24
Loc: The wilds of Hampshire
[Re: Airfix]
#998701 - 19/07/12 10:40 AM
Quote Airfix:
One has to hide
I know someone who had one of the Ultrafex
enhancers and powder coated the front panel black so no-one would know what he was
using.
I still have an Ultrafex here together with an ADA8000. The Ultrafex was
bought at the time when Behringer were just a little cheaper than the competition rather
the bargain basement brand they are now and it still works fine after nearly 20 years. I
bought the ADA8000 used a few years ago and it has been fine - I understand that the US
models are less reliable due to differences in the power supply design.
James.
-------------------- JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
ken long
Loc: The Orient, East London
[Re: James Perrett]
#998705 - 19/07/12 10:49 AM
Quote James Perrett:
I bought the
Do you use this for recording non-critical sources or does
anything go, James? Really keen to have another look at one but have been told the
convertors are mushy. Btu for that price, obviously...
-------------------- I'm All Ears.
Zukan
Zukan
[Re: vinyl_junkie]
#998707 - 19/07/12 10:51 AM
Quote vinyl_junkie:
Wasn't the
original Behringer compressor meant to be good? The black faced one made in Germany. Copy
Hard to pin that one down Vinyl as all their products are a copy of summat or other...
Stretch That Note
Richie Royale
[Re: vinyl_junkie]
#998714 - 19/07/12 10:58 AM
Quote vinyl_junkie:
Wasn't the
I seem to recall they had a much higher price tag, not 100% sure though, but I have some
old
around at home which probably have them in. I think I paid £90 for mine which was
discounted as far I recall at the time. Not sure where mine was made though, I suspect
China. Pretty sure mine is the MDX2100.
[Re: ken long]
#998717 - 19/07/12 11:01 AM
Quote ken long:
I bought
I use it for all kinds of things - including
some expensive mics sometimes. It sounds very similar to my ADAT LX20's and I wouldn't be
surprised to find that they use the same Wavefront convertors. There is possibly a slight
veil to the sound compared to other convertors I have but mic choice and mic position will
have a much bigger effect on the sound than the ADA8000.
James.
[Re: vinyl_junkie]
#998718 - 19/07/12 11:03 AM
Quote vinyl_junkie:
Wasn't the
It was a copy of the DL221 if I remember correctly (or maybe the 241). The Behringer was
actually more expensive than the LX20 when it first came out.
James.
Richie Royale
[Re: James Perrett]
#998719 - 19/07/12 11:15 AM
Quote vinyl_junkie:
Wasn't the
James.
Looks more like the 241, which is
still £529 on DV.
active member
Loc: Sheffield, UK
[Re: James Perrett]
#998720 - 19/07/12 11:22 AM
I bought the
ADA8000 used a few years ago and it has been fine - I understand that the US models are
A local studio (UK) had two fail in a couple of
months and have gone through six in the last three years or so. At least two failures were
power supply I'm told. My own ADA-8000s have been solid.
When mic pre's are
running short I will farm out less critical sources to ADA-8000. Their worst crime IMO is
the horrible gain controls that switch to 'INSANELY LOUD' between the next-to-last and
last click of their turn. Despite their click controls, matching levels between a pair of
ADA-8000 inputs is bit hit and miss.
Sound-wise they can sound a bit dull -
not 'bad', but just lacking in the sparkle and detail you might expect from something
sexier. For drum recording I get something extra back from them for tom mic's - a nice
'smack' I don't get from my Fireface's pre's, for example -so it's not all bad!
Karl H.
new member
[Re: The Elf]
#998726 - 19/07/12 11:49 AM
I have a BCR I don't use much, a patchbay I don't use at the moment, a cheap 8-channel
mixer I used to use for monitoring (actually, the sonic difference between driving my DT
770s from the Behringer to driving it from a MOTU 2408 mkII was huge - much bigger than I
expected) and a newly-acquired ADA8000.
Any opinions on the sonic quality (or
lack thereof) of the ADA8000 converters (ie when using it with line-level sources, not
using the mic amps)? It is by far the cheapest ADAT box you can get, and it has gotten
some good press in various SOS articles over the years...
Edited by Karl H. (19/07/12 11:49 AM)
vinyl_junkie
active member
Loc: Kent, UK
[Re: James Perrett]
#998730 - 19/07/12 12:09 PM
Quote vinyl_junkie:
Wasn't the
James.
Ah right, thanks for the info
Here are some pics of what they look like (not mine)
http://www.mahosta.de/studio/verkauf/studiocomp.php
On a
different note the BCR MIDI controllers are actually pretty good, I've been contemplating
getting one to control my Alpha Juno with (poor man's PG)
RhinoTime
Loc: West Sussex UK
[Re: dadking]
#998746 - 19/07/12 01:02 PM
In the past I had:
An a500 power amp that sounded quite brittle, and seemed to
have a design flaw where having the volume knobs in the middle of their range introduced
distortion, no distortion at full volume though.
A 32 (maybe 34) channel mixer
that had horrible crosstalk, barely adequate sound and died suddenly one day.
A
rack compressor that would be gone if I could find the allen key for the rack bolts.
A rack mount digital FX thing which is utterly useless as all the sounds are thin
and nasty.
Can't imagine I'd buy anything from them in the future.
-------------------- I've never liked a solo violin, you need at least five for a proper fire.
The_Big_Piano_Player
active member
Loc: Lincolnshire
[Re: dadking]
#998747 - 19/07/12 01:09 PM
I have a Behringer 8 way headphone amp I use for quiet rehearsals. I got it 'cause I
thought sound quality wasn't too much of an issue, as it's only for rehearsal.
It's worked for a year so far.
Having said that, if I compare the behringer
headphone output to the original output, it sounds pretty bad (unpleasant top-end), and
there's an intermittent noise.
I wouldn't want to rely on it for live work,
or mixing decisions.
-------------------- www.thediplomatz.com
Mike Senior
SOS Mix Specialist
Loc: Cambridge, UK
[Re: Zukan]
#998752 - 19/07/12 01:35 PM
Quote Zukan:
the best doorstops
I've ever come across after Samson Servos and the C1000.
But you've got to stamp repeatedly on a
C1000 to get the basket into a suitable wedge shape, so that it fits under the door. By
happy coincidence, I've often found myself wanting to stamp repeatedly on a C1000...
alexis
Loc: San Antonio, TX USA
[Re: dadking]
#998797 - 19/07/12 04:31 PM
Just starting using a BCF 2000, no probs  !
Also using a 4-channel Euro-Rack (?) mixer for foldback to my IEMs, fine
also.
I have a foot pedal "kill switch" for my keyboards (it's complicated),
it's either a little buzzy or it's my cables, etc., haven't troubleshooted that yet.
And I have a cable tester, which seems to work.
-------------------- Alexis -Cubase 6.5.0/SX3.1.1.944, XP SP2, 4GB RAM (1GB not accessible, but used just to balance the computer so it doesn't tip over); Delta 66 in Omni i/O Studio; Motif8; UAD-1
darrylonguitar
[Re: dadking]
#998809 - 19/07/12 05:25 PM
Active DI box and ADA8000 here. No problems with either yet. Both seem quiet to me, or
at least below the noise floor of my monitoring/recording environment. It was either a
new $500 audio interface or the $180 ADA8000 to upgrade my E-Mu 1010 PCI audio interface.
Happy with the ADA8000 after a few months.
I had one of their digital guitar
modeling rack mount processors for about a week a few years ago before selling it. Way
too much noise and horrible guitar tones.
So, yes, it's apparently a crap shot
with their gear, but it certainly has its place in the amateur demo/writing studio on a
budget.
darrylonguitar
[Re: darrylonguitar]
#998810 - 19/07/12 05:41 PM
Just thought of one hiccup I've had with the ADA8000 that may be of consequence to other
ADA8000 owners here. The DA converters on the outputs of recent models go to sleep after
a short number of cycles with no signal. As a result, there can be horrible audio fade
ins that act almost like awful latency. Behringer claims the new DA converters of the
recent hardware revision have better sound quality, but my guess is that their just
cheaper. To fix the problem, I keep an inaudible white noise signal sent to the
ADA8000 output when in use for things like re-amping soft synths and guitar (for use with
Ableton looper, for example). Some nice discussion of the problem here, where I
was very happy to find the solution... http://www.gearslutz.com/board/music-computers/537785-strange-playback-pro
blem-digi-002-ada8000.html#post7983343Also, there are DIY mods which can
be made to bypass the mic preamp for line level sources. The fact that the mic preamps
are not bypassed for line level input is claimed to be the reason the ADA8000 does not
perform optimally for those sources. I have only used mine as a mic pre into my DAW.
Wimek
Loc: Holland
[Re: dadking]
#998821 - 19/07/12 06:52 PM
As mentioned before: you get what you pay for! When I compare the build quality of my
ZED14 mixer with "B" stuff, the ZED wins hands-down! However: I'm surprised how it is
possible that "B" sells some of it's products for such little money and still make a
profit... I do have: - BCF2000 - more than 5
year old and works like a charm!
- Ultra Patch PX3000 - about two year old, no
problems so far.
- Bass V-Amp - about one year old, since a few days the right
output seams to have a lose contact (I still have to check the cable...)
My conclusion: I cannot imagine that a professional studio buys "B" stuff, but there
certainly is a place for some budget equipment in my humble "hobby-studio"
active member
Loc: Lincolnshire
[Re: Wimek]
#998872 - 20/07/12 07:36 AM
Quote Wimek:
My conclusion: I
cannot imagine that a professional studio buys "B" stuff, but there certainly is a place
I agree, but I've bought a
Behringer headphone amp and DI box, and at no point did I feel like I was getting a
premium product at a discount price. Just a cheap and cheerful bit of kit. There is a
market for that, though, clearly.
jaminem
active member
[Re: Wimek]
#998876 - 20/07/12 08:02 AM
Quote Wimek:
BCF2000 - more than
5 year old and works like a charm!
What aside from it being so noisy when the faders move?
Samstag
[Re: The_Big_Piano_Player]
#998968 - 20/07/12 02:34 PM
Where to begin? I have a stack of their little half-rack units - two multi-FXs, an EQ and
two mic preamps which I've found to be the most adaptable and reliable examples of their
kind - a stash of guitar pedals, MIDI controllers, active monitors...
The only
dud item I ever had was one pedal, which just died for no reason, but on a pro-rata basis
I've had more high-end gear pack up than this.
My challenge to anyone is this:
listen to a piece of music blindfold, either recorded or live, then tell me if there's an
item of Behringer gear used in its production. Can't tell? No case.
I've done
any number of enthusiastically-received and well-paid gigs and made five albums using a
backbone of Behringer kit. Furthermore, it's the affordability of this stuff that has
enabled me to work with a wide range of sounds and techniques, which is turn has helped me
to create the kind of music that attracts the kind of gigs mentioned above. To put it
another way, I could have spent all the money I've ever spent on Behringer gear on a
single mic pre-amp and had nothing to show for it except a very expensively pre-amped
microphone.
That said, speaking of cases, there's certainly a build quality
issue with some of their stuff if you want something roadworthy - I wouldn't care to drop
one of the above mini-rack things on a hard surface, for example - but nothing that can't
be remedied by careful handling and transportation.
Wimek
Loc: Holland
[Re: dadking]
#998974 - 20/07/12 02:46 PM
At €195 I accept the BCF2000's faders to be a bit noisy  And regarding SAMSTAG's post: I can't agree more - In the end a good song played an
recorded with cheap equipment is better the no song at all
Guy Johnson
Loc: Pembrokeshire
[Re: dadking]
#999022 - 20/07/12 06:32 PM
a 1 U headphone mixer 2 feedback destroyers a 4-way compressor-gate a dual
active DI box, hardly ever used.
-------------------- PA stuff on FB
fully funktional
Loc: devon, england
[Re: Guy Johnson]
#999034 - 20/07/12 07:59 PM
Untill recently I had a Behringer 12 channel mixer I bought in 2002 which I used nearly
every day as my main monitor controller and recording input - it was solidly built, never
failed, was never noisy and cost £120. Only sold it because I was downsizing my studio
and didn't need it anymore.
Chaconne
Loc: Oxford
[Re: dadking]
#999178 - 22/07/12 01:51 AM
I had one of those German built exciters, I used to love it when I was mixing to
cassette!
Recently I got an autocom from ebay for next to nothing, and was
quite surprised by how nice it sounded - as a bus compressor! Considering all the crying
and bitching on fora I was expecting something that would ruin a mix just being plugged
into it, but I rekon properly set up people would have difficulty picking it out blind.
Pashmina
Loc: north-east england
[Re: dadking]
#999222 - 22/07/12 01:12 PM
I have a few pieces, which I've had for quite a while:
"Composer"
MDX2100 - dual comp/gate - perfectly servicable character-free comp/lim. I bought an
Aphex Expressor 651 a year or 2 after I got this - I got better bass guitar tones out of
the Aphex, but thought I got better ac gt recordings thru the Behringer.
"Mastercom" MDX4000 - 2-band stereo compressor/leveller - supposedly a mastering
tool, I occasionally use it when tracking EG a heavily chorused/phasered string machine or
electric 12-string w/stereo chorus, it sounds ok, a kind of a subtle biggener, plus it
keeps peaks under control OK - useful if youre using reso phase/flange sweep which can get
a bit peaky when it hits certain frequencies
"Edison" EX1 - stereo
widener w/phase meter. Never found much of a use for this thing TBH
The above
three items are all sturdily constructed, and appear well made inside & out.
Some UB-range mixer - 4mono/4stereo channels, built in multi FX. Servicable live
keyboard sub-mixer which is what I bought it for. The built in FX are dreadful, but can
be substituted for by plugging something else into the send/return sockets. I bought an
Alesis Wedge for fifty quid from the local free ads paper and use that, it's much
better.
that little valve mic pre in an oval silver box, the first generation
of these - I bought it after reading an OK review in SoS. I never found this to be much
use TBH. The mic pres on my old Mackie VLZ mixer are just as good/no worse than this.
ADA8000 8ch analogue - adat - analogue convertor box. This is pretty
decent I think. a year after i got it I bought an Apogee Mini-Me, did a lot of a/b
testing between it and the ADA using various sound sources, I concluded that the Mini-Me
was better, but by a tiny margin. I used the Mini-Me to record into the PC, and used the
ADA for effect loops and extra ins when necessary. I just bought a Yamaha 01v96i mixer,
so both DAD-8000 and Mini-me will probably go on the blocks soonish.
All of
this stuff has been very reliable - nothing has gone wrong - the little mixer was gigged
quite extensively over a period of 2-3 years, and once got a whack from the singer's mic
stand, there is a dent on the front panel. everything still works. The valve mic pre I
dropped down a ladder - about 2 1/2 metres, I was amazed when it still works, it still
does. That said the three older items are noticeably better made and sturdier than the
later ones. The ADA is made of cheaper, thinner metal, the rack ears flimsy and
cheap-looking, etc.
I wouldn't replace any of this stuff if it knackered TBH,
but then like I suspect most ppl do I record w/o effects and add compression, EQ etc in
the box anyway.
I wouldn't buy any of their stuff now because I find the
knock-off aspect of their stuff shady. i was not aware of this when i bought the stuff I
have.
I'm vaguely curious about the add-on transfformers you could buy for the
composer and the edison, and also about that multi-effect unit they brought out a few
years ago that got good write-ups - the "v-verb"? Something like that. The sort of thing
I'd pick up as a try-out if I saw it cheap.
(I am an amateur, fwiw. Har har.)
-------------------- "We hate all those who diss them, but shot all those who like them"
